[GRASS-SVN] r63934 - grass/trunk/display/d.grid
svn_grass at osgeo.org
Fri Jan 2 10:32:23 PST 2015
Author: neteler
Date: 2015-01-02 10:32:23 -0800 (Fri, 02 Jan 2015)
New Revision: 63934
grass/trunk/display/d.grid/main.c
grass/trunk/display/d.grid/plot.c
d.grid: attempt to demystify user msgs (but see trac #2520)
Modified: grass/trunk/display/d.grid/main.c
--- grass/trunk/display/d.grid/main.c 2015-01-02 12:03:04 UTC (rev 63933)
+++ grass/trunk/display/d.grid/main.c 2015-01-02 18:32:23 UTC (rev 63934)
@@ -167,9 +167,9 @@
if (wgs84->answer)
geogrid->answer = 1; /* -w implies -g */
if (geogrid->answer && G_projection() == PROJECTION_LL)
- G_fatal_error(_("Geo-Grid option is not available for LL projection"));
+ G_fatal_error(_("Geo-grid option not available for LL projection, use without -g/-w"));
if (geogrid->answer && G_projection() == PROJECTION_XY)
- G_fatal_error(_("Geo-Grid option is not available for XY projection"));
+ G_fatal_error(_("Geo-grid option not available for XY projection, use without -g/-w"));
if (notext->answer)
do_text = FALSE;
@@ -179,7 +179,7 @@
if (lwidth->answer) {
line_width = atoi(lwidth->answer);
if(line_width < 0 || line_width > 1e3)
- G_fatal_error("Invalid line width.");
+ G_fatal_error("Invalid line width");
else
line_width = 0;
Modified: grass/trunk/display/d.grid/plot.c
--- grass/trunk/display/d.grid/plot.c 2015-01-02 12:03:04 UTC (rev 63933)
+++ grass/trunk/display/d.grid/plot.c 2015-01-02 18:32:23 UTC (rev 63934)
@@ -307,7 +307,7 @@
/* draw marks not grid lines */
if (mark_type != MARK_GRID) {
- G_warning("Geogrid marks not yet implemented");
+ G_warning(_("Geo-grid option only available for LL projection, use without -g/-w"));
#ifdef TODO
e1 = combine above;
n1 = combine above;
