[GRASS-SVN] r63937 - in grass/trunk/gui/wxpython: mapwin rdigit rlisetup
svn_grass at osgeo.org
Fri Jan 2 19:33:24 PST 2015
Author: annakrat
Date: 2015-01-02 19:33:24 -0800 (Fri, 02 Jan 2015)
New Revision: 63937
grass/trunk/gui/wxpython/mapwin/analysis.py
grass/trunk/gui/wxpython/mapwin/buffered.py
grass/trunk/gui/wxpython/mapwin/graphics.py
grass/trunk/gui/wxpython/rdigit/controller.py
grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
wxGUI: specify pdc in Graphics API, change pdc where rdigit objects are drawn to avoid problems with pen styles (other than solid) when drawing using wx.GCDC
Modified: grass/trunk/gui/wxpython/mapwin/analysis.py
--- grass/trunk/gui/wxpython/mapwin/analysis.py 2015-01-03 01:43:55 UTC (rev 63936)
+++ grass/trunk/gui/wxpython/mapwin/analysis.py 2015-01-03 03:33:24 UTC (rev 63937)
@@ -76,7 +76,7 @@
item.SetCoords(coords)
# draw
self._mapWindow.ClearLines()
- self._registeredGraphics.Draw(pdc=self._mapWindow.pdcTmp)
+ self._registeredGraphics.Draw()
self._mapWindow.Refresh()
wx.Yield()
Modified: grass/trunk/gui/wxpython/mapwin/buffered.py
--- grass/trunk/gui/wxpython/mapwin/buffered.py 2015-01-03 01:43:55 UTC (rev 63936)
+++ grass/trunk/gui/wxpython/mapwin/buffered.py 2015-01-03 03:33:24 UTC (rev 63937)
@@ -209,8 +209,8 @@
self.pdc = wx.PseudoDC()
# used for digitization tool
self.pdcVector = None
- # decorations (region box, etc.)
- self.pdcDec = wx.PseudoDC()
+ # transparent objects (region box, raster digitizer)
+ self.pdcTransparent = wx.PseudoDC()
# pseudoDC for temporal objects (select box, measurement tool, etc.)
self.pdcTmp = wx.PseudoDC()
@@ -555,22 +555,17 @@
self.pdc.DrawBitmap(self.bufferLast, 0, 0, False)
self.pdc.DrawToDC(dc)
- # draw decorations (e.g. region box)
+ # draw semitransparent objects (e.g. region box, raster digitizer objects)
try:
gcdc = wx.GCDC(dc)
- self.pdcDec.DrawToDC(gcdc)
+ self.pdcTransparent.DrawToDC(gcdc)
except NotImplementedError as e:
print >> sys.stderr, e
- self.pdcDec.DrawToDC(dc)
+ self.pdcTransparent.DrawToDC(dc)
# draw temporary object on the foreground
- try:
- gcdc = wx.GCDC(dc)
- self.pdcTmp.DrawToDC(gcdc)
- except NotImplementedError as e:
- print >> sys.stderr, e
- self.pdcTmp.DrawToDC(dc)
+ self.pdcTmp.DrawToDC(dc)
if switchDraw:
self.redrawAll = False
@@ -854,7 +849,7 @@
# clear pseudoDcs
for pdc in (self.pdc,
- self.pdcDec,
+ self.pdcTransparent,
self.pdcTmp):
pdc.Clear()
pdc.RemoveAll()
@@ -905,7 +900,7 @@
for item in self.graphicsSetList:
try:
- item.Draw(self.pdcTmp)
+ item.Draw()
except:
GError(parent = self,
message = _('Unable to draw registered graphics. '
@@ -950,7 +945,7 @@
regionCoords.append((reg['w'], reg['s']))
regionCoords.append((reg['w'], reg['n']))
# draw region extent
- self.DrawLines(pdc=self.pdcDec, polycoords=regionCoords)
+ self.DrawLines(pdc=self.pdcTransparent, polycoords=regionCoords)
def EraseMap(self):
"""Erase map canvas
@@ -960,7 +955,7 @@
if hasattr(self, "digit"):
self.Draw(self.pdcVector, pdctype = 'clear')
- self.Draw(self.pdcDec, pdctype = 'clear')
+ self.Draw(self.pdcTransparent, pdctype='clear')
self.Draw(self.pdcTmp, pdctype = 'clear')
self.Map.AbortAllThreads()
@@ -2053,11 +2048,12 @@
"""Get render.Map() instance"""
return self.Map
- def RegisterGraphicsToDraw(self, graphicsType, setStatusFunc=None, drawFunc=None,
+ def RegisterGraphicsToDraw(self, graphicsType, pdc=None, setStatusFunc=None, drawFunc=None,
mapCoords=True):
"""This method registers graphics to draw.
:param type: (string) - graphics type: "point", "line" or "rectangle"
+ :param pdc: PseudoDC object, default is pdcTmp
:param setStatusFunc: function called before drawing each item
Status function should be in this form:
setStatusFunc(item, itemOrderNum)
@@ -2074,8 +2070,11 @@
:return: reference to GraphicsSet, which was added.
+ if not pdc:
+ pdc = self.pdcTmp
item = GraphicsSet(parentMapWin=self,
graphicsType=graphicsType,
+ pdc=pdc,
setStatusFunc=setStatusFunc,
drawFunc=drawFunc,
mapCoords=mapCoords)
Modified: grass/trunk/gui/wxpython/mapwin/graphics.py
--- grass/trunk/gui/wxpython/mapwin/graphics.py 2015-01-03 01:43:55 UTC (rev 63936)
+++ grass/trunk/gui/wxpython/mapwin/graphics.py 2015-01-03 03:33:24 UTC (rev 63937)
@@ -25,7 +25,7 @@
class GraphicsSet:
- def __init__(self, parentMapWin, graphicsType,
+ def __init__(self, parentMapWin, graphicsType, pdc,
setStatusFunc=None, drawFunc=None, mapCoords=True):
"""Class, which contains instances of GraphicsSetItem and
draws them For description of parameters look at method
@@ -49,6 +49,7 @@
self.parentMapWin = parentMapWin
self.setStatusFunc = setStatusFunc
self.mapCoords = mapCoords
+ self.pdc = pdc
if drawFunc:
self.drawFunc = drawFunc
@@ -74,14 +75,11 @@
elif self.graphicsType == "polygon":
self.drawFunc = self.parentMapWin.DrawPolygon
- def Draw(self, pdc):
- """Draws all containing items.
- :param pdc: device context, where items are drawn
+ def Draw(self):
+ """Draws all containing items."""
itemOrderNum = 0
for item in self.itemsList:
- self._clearId(pdc, item.GetId())
+ self._clearId(item.GetId())
if self.setStatusFunc is not None:
self.setStatusFunc(item, itemOrderNum)
@@ -111,7 +109,7 @@
self.properties["text"]['color'] = self.parentMapWin.pen.GetColour()
self.properties["text"]['text'] = label
- self.drawFunc(pdc=pdc, drawid=item.GetId(),
+ self.drawFunc(pdc=self.pdc, drawid=item.GetId(),
coords=coords,
text=self.properties["text"],
size=self.properties["size"])
@@ -127,7 +125,7 @@
else:
coords = item.GetCoords()
- self.drawFunc(pdc=pdc, pen=pen,
+ self.drawFunc(pdc=self.pdc, pen=pen,
coords=coords, drawid=item.GetId())
elif self.graphicsType == "rectangle":
@@ -144,7 +142,7 @@
else:
- self.drawFunc(pdc=pdc, pen=pen, brush=brush, drawid=item.GetId(),
+ self.drawFunc(pdc=self.pdc, pen=pen, brush=brush, drawid=item.GetId(),
point1=coords[0],
point2=coords[1])
@@ -162,7 +160,7 @@
else:
itemOrderNum += 1
@@ -357,10 +355,10 @@
except ValueError:
return None
- def _clearId(self, pdc, drawid):
+ def _clearId(self, drawid):
"""Clears old object before drawing new object."""
try:
- pdc.ClearId(drawid)
+ self.pdc.ClearId(drawid)
except:
pass
Modified: grass/trunk/gui/wxpython/rdigit/controller.py
--- grass/trunk/gui/wxpython/rdigit/controller.py 2015-01-03 01:43:55 UTC (rev 63936)
+++ grass/trunk/gui/wxpython/rdigit/controller.py 2015-01-03 03:33:24 UTC (rev 63937)
@@ -157,9 +157,9 @@
self._finish()
# draw
- self._lines.Draw(pdc=self._mapWindow.pdcTmp)
- self._areas.Draw(pdc=self._mapWindow.pdcTmp)
- self._points.Draw(pdc=self._mapWindow.pdcTmp)
+ self._lines.Draw()
+ self._areas.Draw()
+ self._points.Draw()
def _finish(self):
@@ -190,9 +190,9 @@
self.newFeatureCreated.emit()
@@ -255,16 +255,19 @@
color = self._drawColor[:3] + (self._drawTransparency,)
self._areas = self._mapWindow.RegisterGraphicsToDraw(graphicsType='polygon',
+ pdc=self._mapWindow.pdcTransparent,
mapCoords=True)
self._areas.AddPen('pen1', wx.Pen(colour=color, width=2, style=wx.SOLID))
self._areas.AddBrush('done', wx.Brush(colour=color, style=wx.SOLID))
self._lines = self._mapWindow.RegisterGraphicsToDraw(graphicsType='line',
mapCoords=True)
self._lines.AddPen('pen1', wx.Pen(colour=color, width=2, style=wx.SOLID))
self._lines.AddBrush('done', wx.Brush(colour=color, style=wx.SOLID))
self._points = self._mapWindow.RegisterGraphicsToDraw(graphicsType='point',
mapCoords=True)
self._points.AddPen('pen1', wx.Pen(colour=color, width=2, style=wx.SOLID))
self._points.AddBrush('done', wx.Brush(colour=color, style=wx.SOLID))
Modified: grass/trunk/gui/wxpython/rlisetup/sampling_frame.py
--- grass/trunk/gui/wxpython/rlisetup/sampling_frame.py 2015-01-03 01:43:55 UTC (rev 63936)
+++ grass/trunk/gui/wxpython/rlisetup/sampling_frame.py 2015-01-03 03:33:24 UTC (rev 63937)
@@ -182,7 +182,7 @@
item.SetPropertyVal('hide', False)
self.mapWindow.ClearLines()
- self._registeredGraphics.Draw(self.mapWindow.pdcTmp)
def _mouseDbClick(self, x, y):
item = self._registeredGraphics.GetItem(0)
@@ -191,7 +191,7 @@
- self._registeredGraphics.Draw(self.mapWindow.pdc)
self.createRegion()
def createRegion(self):
@@ -294,7 +294,7 @@
self.mapWindow.pdcTmp.SetPen(pen)
self.mapWindow.pdcTmp.DrawCircle(circle.point[0], circle.point[1],
circle.radius)
self.createCricle(circle)
def createCricle(self, c):
@@ -352,7 +352,7 @@
'e': max(p1[0], p2[0])}
if self.samplingtype in [SamplingType.MUNITSR, SamplingType.MMVWINR]:
dlg = wx.MessageDialog(self, "Is this area ok?",
"select sampling unit",
