[GRASS-SVN] r63944 - grass-addons/grass7/raster/r.valley.bottom
Sat Jan 3 11:36:01 PST 2015
Author: hellik
Date: 2015-01-03 11:36:01 -0800 (Sat, 03 Jan 2015)
New Revision: 63944
   grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: fix clean up
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2015-01-03 15:11:31 UTC (rev 63943)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py	2015-01-03 19:36:01 UTC (rev 63944)
@@ -647,23 +647,23 @@
     # clean up some temporay files and maps
     grass.message( "Some clean up ..." )
-    grass.run_command('g.remove', region = "base_region_MrVBF",
+    grass.run_command('g.remove', flags = 'f', type = 'region', name = "base_region_MrVBF",
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["F1,F2,F3,F4"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["F1,F2,F3,F4"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["CF2,CF3,CF4"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["CF2,CF3,CF4"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["PCTL1,PCTL2,PCTL3,PCTL3_refined_base_resolution,PCTL4,PCTL4_refined_base_resolution"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["PCTL1,PCTL2,PCTL3,PCTL3_refined_base_resolution,PCTL4,PCTL4_refined_base_resolution"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["PVF1,PVF2,PVF3,PVF4"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["PVF1,PVF2,PVF3,PVF4"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["VF1,VF2,VF3,VF4"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["VF1,VF2,VF3,VF4"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["W2,W3,W4"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["W2,W3,W4"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["r_slope_step1,r_slope_step3,r_slope_step4,r_slope_step4_refined_base_resolution"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["r_slope_step1,r_slope_step3,r_slope_step4,r_slope_step4_refined_base_resolution"],
                                      quiet = True)
-    grass.run_command('g.remove', flags='f', type='raster', name= ["DEM_smoothed_step3,DEM_smoothed_step3_coarsed,DEM_smoothed_step4,DEM_smoothed_step4_coarsed"],
+    grass.run_command('g.remove', flags = 'f', type = 'raster', name = ["DEM_smoothed_step3,DEM_smoothed_step3_coarsed,DEM_smoothed_step4,DEM_smoothed_step4_coarsed"],
                                      quiet = True)
     grass.message( "Clean up done." )
