[GRASS-SVN] r63948 - grass-addons/grass7/raster/r.valley.bottom
svn_grass at osgeo.org
Sat Jan 3 14:20:02 PST 2015
Author: hellik
Date: 2015-01-03 14:20:02 -0800 (Sat, 03 Jan 2015)
New Revision: 63948
grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
r.valley.bottom: region setting update
Modified: grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py
--- grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py 2015-01-03 20:50:42 UTC (rev 63947)
+++ grass-addons/grass7/raster/r.valley.bottom/r.valley.bottom.py 2015-01-03 22:20:02 UTC (rev 63948)
@@ -59,12 +59,17 @@
# Region settings
+ grass.run_command('g.region', flags = 'a',
+ raster = r_elevation,
+ align = r_elevation)
current_region = grass.region()
Yres_base = current_region['nsres']
Xres_base = current_region['ewres']
grass.message( "Finest scale calculations" )
grass.message( "Original resolution: %s x %s" % (Xres_base, Yres_base))
- grass.run_command('g.region', flags = 'p', save = "base_region_MrVBF", overwrite = True)
+ grass.run_command('g.region', flags = 'p',
+ save = "base_region_MrVBF",
+ overwrite = True)
# Region settings step 3: resolution 3 x base resolution
@@ -333,7 +338,8 @@
# change resolution
grass.message( "Step 3: change to resolution of 3 x base resolution" )
grass.run_command('g.region', res = Xres_step3,
- flags = 'a')
+ flags = 'a',
+ raster = r_elevation)
current_region_step3 = grass.region()
Y_step3 = current_region_step3['nsres']
@@ -383,9 +389,9 @@
# switch back to base resolution
grass.message( "Step 3: switch back to base resolution." )
- grass.run_command('g.region', rast = r_elevation,
- align = r_elevation,
- flags = 'a')
+ grass.run_command('g.region', raster = r_elevation,
+ align = r_elevation,
+ flags = 'a')
current_region_step3_switched_back = grass.region()
Y_step3_switched_back = current_region_step3_switched_back['nsres']
X_step3_switched_back = current_region_step3_switched_back['ewres']
@@ -467,7 +473,8 @@
# change resolution
grass.message( "Step 4: change to resolution of step 3" )
- flags = 'a')
+ flags = 'a',
@@ -514,12 +521,13 @@
# change resolution
grass.message( "Step 4: change to resolution to 3 x step 3 resolution" )
grass.run_command('g.region', res = Xres_step4,
- flags = 'a')
+ flags = 'a',
current_region_step4 = grass.region()
Y_step4 = current_region_step4['nsres']
X_step4 = current_region_step4['ewres']
- grass.message( "Resolution step 3: %s x %s" % (X_step4, Y_step4))
+ grass.message( "Resolution step 4: %s x %s" % (X_step4, Y_step4))
grass.message( "----" )
# coarsening DEM to resolution step 4 and calculate PCTL step 4
@@ -564,9 +572,9 @@
grass.message( "Step 4: switch back to base resolution." )
- flags = 'a')
+ flags = 'a')
current_region_step4_switched_back = grass.region()
Y_step4_switched_back = current_region_step4_switched_back['nsres']
X_step4_switched_back = current_region_step4_switched_back['ewres']
