[GRASS-SVN] r63981 - grass/trunk/display/d.vect.thematic
svn_grass at osgeo.org
Wed Jan 7 01:50:03 PST 2015
Author: martinl
Date: 2015-01-07 01:50:03 -0800 (Wed, 07 Jan 2015)
New Revision: 63981
grass/trunk/display/d.vect.thematic/main.c
d.vect.thematic: more guisections
Modified: grass/trunk/display/d.vect.thematic/main.c
--- grass/trunk/display/d.vect.thematic/main.c 2015-01-07 09:45:12 UTC (rev 63980)
+++ grass/trunk/display/d.vect.thematic/main.c 2015-01-07 09:50:03 UTC (rev 63981)
@@ -96,7 +96,8 @@
breaks_opt->required = NO;
breaks_opt->multiple = YES;
breaks_opt->description = _("Class breaks, without minimum and maximum");
+ breaks_opt->guisection = _("Classes");
algo_opt = G_define_option();
algo_opt->key = "algorithm";
algo_opt->type = TYPE_STRING;
@@ -113,6 +114,7 @@
_("equiprobable (normal distribution)"));
algo_opt->descriptions = desc;
/*currently disabled because of bugs "dis;discontinuities"); */
+ algo_opt->guisection = _("Classes");
nbclass_opt = G_define_option();
nbclass_opt->key = "nbclasses";
@@ -120,6 +122,7 @@
nbclass_opt->required = NO;
nbclass_opt->multiple = NO;
nbclass_opt->description = _("Number of classes to define");
+ nbclass_opt->guisection = _("Classes");
colors_opt = G_define_option();
colors_opt->key = "colors";
@@ -154,21 +157,25 @@
legend_file_opt->description =
_("File in which to save d.graph instructions for legend display");
legend_file_opt->required = NO;
+ legend_file_opt->guisection = _("Legend");
legend_flag = G_define_flag();
legend_flag->key = 'l';
legend_flag->description =
_("Create legend information and send to stdout");
+ legend_flag->guisection = _("Legend");
algoinfo_flag = G_define_flag();
algoinfo_flag->key = 'e';
algoinfo_flag->description =
_("When printing legend info, include extended statistical info from classification algorithm");
+ algoinfo_flag->guisection = _("Legend");
nodraw_flag = G_define_flag();
nodraw_flag->key = 'n';
nodraw_flag->description = _("Do not draw map, only output the legend");
+ nodraw_flag->guisection = _("Legend");
/* Check command line */
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
