[GRASS-SVN] r63995 - grass/trunk/raster/r.horizon
svn_grass at osgeo.org
Thu Jan 8 05:56:07 PST 2015
Author: neteler
Date: 2015-01-08 05:56:07 -0800 (Thu, 08 Jan 2015)
New Revision: 63995
grass/trunk/raster/r.horizon/main.c
grass/trunk/raster/r.horizon/r.horizon.html
r.horizon: implement -c flag for compass oriented output
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2015-01-08 10:58:05 UTC (rev 63994)
+++ grass/trunk/raster/r.horizon/main.c 2015-01-08 13:56:07 UTC (rev 63995)
@@ -107,7 +107,7 @@
int ip, jp, ip100, jp100;
int n, m, m100, n100;
-int degreeOutput = FALSE;
+int degreeOutput, compassOutput = FALSE;
float **z, **z100, **horizon_raster;
double stepx, stepy, stepxhalf, stepyhalf, stepxy, xp, yp, op, dp, xg0, xx0,
yg0, yy0, deltx, delty;
@@ -171,7 +171,7 @@
struct
- struct Flag *degreeOutput;
+ struct Flag *degreeOutput, *compassOutput;
flag;
@@ -308,7 +308,12 @@
flag.degreeOutput->description =
_("Write output in degrees (default is radians)");
+ flag.compassOutput = G_define_flag();
+ flag.compassOutput->key = 'c';
+ flag.compassOutput->description =
+ _("Write output in compass orientation (default is CCW, East=0)");
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
@@ -343,6 +348,7 @@
delty = fabs(cellhd.north - cellhd.south);
degreeOutput = flag.degreeOutput->answer;
+ compassOutput = flag.compassOutput->answer;
if (G_projection() == PROJECTION_LL)
G_important_message(_("Note: In latitude-longitude coordinate system specify buffers in degree unit"));
@@ -865,7 +871,16 @@
else if (printangle >= 360.)
printangle -= 360;
- fprintf(fp, "%lf,%lf\n", printangle, shadow_angle);
+ if(compassOutput ){
+ double tmpangle;
+ tmpangle = 360. - printangle + 90.;
+ if (tmpangle >= 360.)
+ tmpangle = tmpangle - 360.;
+ fprintf(fp, "%lf,%lf\n", tmpangle, shadow_angle);
+ } else {
+ fprintf(fp, "%lf,%lf\n", printangle, shadow_angle);
angle += dfr_rad;
Modified: grass/trunk/raster/r.horizon/r.horizon.html
--- grass/trunk/raster/r.horizon/r.horizon.html 2015-01-08 10:58:05 UTC (rev 63994)
+++ grass/trunk/raster/r.horizon/r.horizon.html 2015-01-08 13:56:07 UTC (rev 63995)
@@ -24,16 +24,12 @@
resulting cardinal directions represent true orientation towards the
East, North, West and South. The only exception of this feature is
LOCATION with x,y coordinate system, where this correction is
-not applied.
+not applied.
+<p>
+Using the <b>-c</b> flag, the azimuthal angles will be printed in compass
+orientation (North=0, clockwise).
-<h3>Flags:</h3>
-<dl>
- <dt><b>-d</b>
- <dd>Output horizon height in degrees (the default is radians)</dd>
-</dl>
<h3>Input parameters:</h3>
<p>The <i>elevation</i> parameter is an input elevation raster map. If
the buffer options are used (see below), this raster should extend
@@ -46,7 +42,8 @@
360/5=72 directions (72 raster maps if used in the raster map mode).
<p>The <i>start</i> parameter gives the angle start (in degrees)
-for the calculation of the horizon. The default value is 0.
+for the calculation of the horizon. The default value is 0 (East with
+North being 90 etc.).
<p>The <i>end</i> parameter gives the angle end (in degrees)
for the calculation of the horizon. The end point is omitted!
