[GRASS-SVN] r63997 - grass/trunk/gui/wxpython/lmgr
svn_grass at osgeo.org
Thu Jan 8 09:02:46 PST 2015
Author: annakrat
Date: 2015-01-08 09:02:46 -0800 (Thu, 08 Jan 2015)
New Revision: 63997
grass/trunk/gui/wxpython/lmgr/frame.py
wxGUI: attempt to fix launching script on Windows #2532
Modified: grass/trunk/gui/wxpython/lmgr/frame.py
--- grass/trunk/gui/wxpython/lmgr/frame.py 2015-01-08 13:57:08 UTC (rev 63996)
+++ grass/trunk/gui/wxpython/lmgr/frame.py 2015-01-08 17:02:46 UTC (rev 63997)
@@ -43,7 +43,7 @@
from grass.script import core as grass
-from core.gcmd import RunCommand, GError, GMessage, GException
+from core.gcmd import RunCommand, GError, GMessage, EncodeString
from core.settings import UserSettings, GetDisplayVectSettings
from core.utils import SetAddOnPath, GetLayerNameFromCmd, command2ltype, _
from gui_core.preferences import MapsetAccess, PreferencesDialog
@@ -851,6 +851,14 @@
if not filename:
return False
+ try:
+ filename_encoded = EncodeString(filename)
+ except UnicodeEncodeError:
+ GError(parent=self,
+ message = _("Due to the limitations of your operating system, "
+ "the script path cannot contain non-ascii characters. "
+ "Please rename the script or move it to a different location."))
+ return
if not os.path.exists(filename):
GError(parent = self,
@@ -882,7 +890,7 @@
addonPath = os.getenv('GRASS_ADDON_PATH', [])
if addonPath:
addonPath = addonPath.split(os.pathsep)
- dirName = os.path.dirname(filename)
+ dirName = os.path.dirname(filename_encoded)
if dirName not in addonPath:
addonPath.append(dirName)
dlg = wx.MessageDialog(self,
