[GRASS-SVN] r64018 - in grass/branches/releasebranch_7_0/lib: cairodriver cdhc gpde proj python/docs/src python/pygrass/gis python/pygrass/messages python/pygrass/modules/interface python/pygrass/vector python/temporal raster symbol vector
svn_grass at osgeo.org
Thu Jan 8 14:45:30 PST 2015
Author: neteler
Date: 2015-01-08 14:45:30 -0800 (Thu, 08 Jan 2015)
New Revision: 64018
Removed:
grass/branches/releasebranch_7_0/lib/python/temporal/pythontemporallib.dox
grass/branches/releasebranch_7_0/lib/cairodriver/raster.c
grass/branches/releasebranch_7_0/lib/cdhc/Makefile
grass/branches/releasebranch_7_0/lib/gpde/n_gwflow.c
grass/branches/releasebranch_7_0/lib/proj/README.txt
grass/branches/releasebranch_7_0/lib/python/docs/src/index.rst
grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py
grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py
grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py
grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py
grass/branches/releasebranch_7_0/lib/python/temporal/register.py
grass/branches/releasebranch_7_0/lib/raster/close.c
grass/branches/releasebranch_7_0/lib/symbol/read.c
grass/branches/releasebranch_7_0/lib/vector/vectorlib.dox
minor backports from trunk
Modified: grass/branches/releasebranch_7_0/lib/cairodriver/raster.c
--- grass/branches/releasebranch_7_0/lib/cairodriver/raster.c 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/cairodriver/raster.c 2015-01-08 22:45:30 UTC (rev 64018)
@@ -96,7 +96,7 @@
dst_w = dst_r - dst_l;
dst_h = dst_b - dst_t;
- G_debug(1, "Cairo_begin_raster(): masked=%d, src_lrtb=%d %d %d %d -> w/h=%d/%d, "
+ G_debug(1, "Cairo_begin_raster(): masked=%d, src_lrtb=%d %d %d %d -> w/h=%d %d, "
"dst_lrtb=%d %d %d %d -> w/h=%d %d",
masked, src_l, src_r, src_t, src_b, src_w, src_h,
dst_l, dst_r, dst_t, dst_b, dst_w, dst_h);
@@ -145,7 +145,7 @@
if (y1 <= y0)
return next_row(row, d_y1);
- G_debug(3, "Cairo_raster(): row=%d", row);
+ G_debug(3, "Cairo_raster(): n=%d row=%d", n, row);
for (x = x0; x < x1; x++) {
int xx = dst_l + x;
Modified: grass/branches/releasebranch_7_0/lib/cdhc/Makefile
--- grass/branches/releasebranch_7_0/lib/cdhc/Makefile 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/cdhc/Makefile 2015-01-08 22:45:30 UTC (rev 64018)
@@ -16,7 +16,7 @@
endif
test: $(OBJDIR)/test$(EXE)
- cd $(OBJDIR) && $(call run_grass,./test < ../test_numbers.csv)
+ $(call run_grass,$(OBJDIR)/test$(EXE) < test_numbers.csv)
# Test functions
$(OBJDIR)/test$(EXE): $(OBJDIR)/test.o $(GISDEP) $(CDHCDEP)
Modified: grass/branches/releasebranch_7_0/lib/gpde/n_gwflow.c
--- grass/branches/releasebranch_7_0/lib/gpde/n_gwflow.c 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/gpde/n_gwflow.c 2015-01-08 22:45:30 UTC (rev 64018)
@@ -435,7 +435,7 @@
if(fabs(sum) < 0.0000000001)
G_message(_("The total sum of the water budget: %g\n"), sum);
else
- G_warning(_("The total sum of the water budget is significant larger then 0: %g\n"), sum);
+ G_warning(_("The total sum of the water budget is significantly larger then 0: %g\n"), sum);
return;
@@ -714,7 +714,7 @@
else
return;
Modified: grass/branches/releasebranch_7_0/lib/proj/README.txt
--- grass/branches/releasebranch_7_0/lib/proj/README.txt 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/proj/README.txt 2015-01-08 22:45:30 UTC (rev 64018)
@@ -4,3 +4,5 @@
according to this procedure:
http://svn.osgeo.org/metacrs/geotiff/trunk/libgeotiff/csv/README
+alternative:
+ls `gdal-config --datadir`
Modified: grass/branches/releasebranch_7_0/lib/python/docs/src/index.rst
--- grass/branches/releasebranch_7_0/lib/python/docs/src/index.rst 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/docs/src/index.rst 2015-01-08 22:45:30 UTC (rev 64018)
@@ -12,17 +12,16 @@
A set of packages is provided to the user in order to provide functionality
at various levels:
-* **script package**: Python interface to launch GRASS GIS modules in scripts
-* **PyGRASS documentation**: PyGRASS is an object-oriented Python Application
+* **script package** provides Python interface to launch GRASS GIS modules in scripts
+* **PyGRASS** is an object-oriented Python Application
Programming Interface (API) for GRASS GIS which uses the GRASS C API as
backend but additionally offers a convenient interface to the GRASS GIS
modules
-* **GRASS GIS Temporal Framework**: implements the temporal GIS functionality
+* **GRASS GIS Temporal Framework** implements the temporal GIS functionality
of GRASS GIS and provides an API to implement spatio-temporal processing modules
-* **exceptions package**: FIXME
-* **imaging package**: library to create animated images and films
-* **Testing GRASS GIS source code and modules**: (gunittest package
-* **pydispatch package**: Multiple-producer-multiple-consumer signal-dispatching
+* **exceptions package** contains exceptions used by other packages
+* **imaging package** is a library to create animated images and films
+* **pydispatch package** is a library for signal-dispatching
Contents:
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/gis/__init__.py 2015-01-08 22:45:30 UTC (rev 64018)
@@ -19,9 +19,7 @@
'raster_3d': libgis.G_ELEMENT_RASTER3D,
'vector': libgis.G_ELEMENT_VECTOR,
'ascii_vector': libgis.G_ELEMENT_ASCIIVECTOR,
- 'icon': libgis.G_ELEMENT_ICON,
- 'labels': libgis.G_ELEMENT_LABEL,
- 'sites': libgis.G_ELEMENT_SITE,
+ 'label': libgis.G_ELEMENT_LABEL,
'region': libgis.G_ELEMENT_REGION,
'group': libgis.G_ELEMENT_GROUP}
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/messages/__init__.py 2015-01-08 22:45:30 UTC (rev 64018)
@@ -76,7 +76,7 @@
libgis.G_debug(1, "Stop messenger server")
sys.exit()
- message = data[1]
+ message = data[1]
# libgis limitation
if isinstance(message, type(" ")):
if len(message) >= 2000:
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py 2015-01-08 22:45:30 UTC (rev 64018)
@@ -67,7 +67,7 @@
number of parallel processes it will wait for all processes to finish,
sets the stdout and stderr of the Module object and removes it
from the queue when its finished.
To finish the queue before the maximum number of parallel
processes was reached call wait() .
@@ -77,13 +77,13 @@
Usage:
Check with a queue size of 3 and 5 processes
>>> import copy
>>> from grass.pygrass.modules import Module, ParallelModuleQueue
>>> mapcalc_list = []
Setting run_ to False is important, otherwise a parallel processing is not possible
>>> mapcalc = Module("r.mapcalc", overwrite=True, run_=False)
>>> queue = ParallelModuleQueue(nprocs=3)
>>> for i in xrange(5):
@@ -105,7 +105,7 @@
0
Check with a queue size of 8 and 5 processes
>>> queue = ParallelModuleQueue(nprocs=8)
>>> mapcalc_list = []
>>> for i in xrange(5):
@@ -127,7 +127,7 @@
0
Check with a queue size of 8 and 4 processes
>>> mapcalc_list = []
>>> new_mapcalc = copy.deepcopy(mapcalc)
@@ -257,11 +257,11 @@
:returns: the number fo Module processes running/finished in the queue
- return self._proc_count
+ return self._proc_count
def get_max_num_procs(self):
"""Return the maximum number of parallel Module processes
:returns: the maximum number of parallel Module processes
return self._num_procs
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/vector/geometry.py 2015-01-08 22:45:30 UTC (rev 64018)
@@ -780,7 +780,6 @@
>>> line.distance(point) #doctest: +NORMALIZE_WHITESPACE
LineDist(point=Point(2.300000, 0.000000),
dist=0.5, spdist=0.2999999999999998, sldist=2.3)
# instantite outputs
cx = ctypes.c_double(0)
@@ -925,6 +924,7 @@
def segment(self, start, end):
"""Create line segment. using the ``Vect_line_segment`` C function.
:param start: distance from the begining of the line where
the segment start
:type start: float
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/open_stds.py 2015-01-08 22:45:30 UTC (rev 64018)
@@ -235,7 +235,7 @@
mapset = get_current_mapset()
dbif, connected = init_dbif(dbif)
- new_map = check_new_map_dataset(name, layer, "raster", overwrite, dbif)
+ new_map = check_new_map_dataset(name, layer, type, overwrite, dbif)
# Check if new map is in the temporal database
if new_map.is_in_db(dbif):
Deleted: grass/branches/releasebranch_7_0/lib/python/temporal/pythontemporallib.dox
--- grass/branches/releasebranch_7_0/lib/python/temporal/pythontemporallib.dox 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/pythontemporallib.dox 2015-01-08 22:45:30 UTC (rev 64018)
@@ -1,255 +0,0 @@
-/*! \page pythontemporallib GRASS GIS Temporal Framework
-by GRASS Development Team (http://grass.osgeo.org)
-The GRASS GIS Temporal Framework
-\section PythonTGISIntro Introduction
-The GRASS GIS Temporal Framework implements the temporal GIS functionality of GRASS GIS
-and provides an API to implement spatio-temporal processing modules. The framework
-introduces space time datasets that represent time series of raster, 3D raster or vector maps.
-This framework provides the following functionalities:
-- Assign time stamp to maps and register maps in the temporal database
-- Modification of time stamps
-- Creation, renaming and deletion of space time datasets
-- Registration and un-registration of maps in space time datasets
-- Query of maps that are registered in space time datasets using SQL where statements
-- Analysis of the spatio-temporal topology of space time datasets
-- Sampling of space time datasets
-- Computation of temporal and spatial relationships between registered maps
-- Higher level functions that are shared between modules
-Most of the functions described above are member functions of the maps and space time dataset classes.
-Maps and space time datasets are represented as objects in the temporal framework.
-\section PythonTGISPackages Library
-Core functionality such as the initialization function, the database interface connection to sqlite3
-and postgresql as well as the creation of the temporal database are defined here:
-- python::temporal::core
-In these modules are the temporal database interfaces for raster maps,
-3D raster maps, vector maps and space time datasets defined.
-In addition the temporal and spatial extent modules implement the topological
-relationship computation that is needed for spatio-temporal topology computation:
-- python::temporal::base
-- python::temporal::spatial_extent
-- python::temporal::temporal_extent
-- python::temporal::metadata
-Several "abstract" classes are defined that implement the shared functionality
-of time stamped maps and space time datasets, such as temporal and spatial
-handling and representation:
-- python::temporal::spatial_topology_dataset_connector
-- python::temporal::temporal_topology_dataset_connector
-- python::temporal::abstract_dataset
-- python::temporal::abstract_map_dataset
-- python::temporal::abstract_space_time_dataset
-The RPC C-library interface for exit safe and fast access to raster, vector and 3D raster informations:
-- python::temporal::c_libraries_interface
-All dataset classes that are used in the GRASS temporal modules are specified
-here:
-- python::temporal::space_time_datasets
-Functions to compute temporal granularity, handling of datetime objects
-and their conversion as well as spatio-temporal topology computation are defined in these modules:
-- python::temporal::datetime_math
-- python::temporal::spatio_temporal_relationships
-- python::temporal::temporal_granularity
-Functionality that is shared between different temporal GRASS modules, such as
-map listing, space time dataset creation, map registration and unregistration,
-aggregation, extraction, map calculation, statistics as well as import and export of
-space time datasets are defined here:
-- python::temporal::aggregation
-- python::temporal::extract
-- python::temporal::factory
-- python::temporal::open_stds
-- python::temporal::list_stds
-- python::temporal::mapcalc
-- python::temporal::register
-- python::temporal::sampling
-- python::temporal::stds_export
-- python::temporal::stds_import
-- python::temporal::univar_statistics
-Spatio-temporal algebra classes for space time raster and vector datasets are defined in:
-- python::temporal::temporal_algebra
-- python::temporal::temporal_vector_algebra
-- python::temporal::temporal_vector_operator
-Two helper functions to support the listing of space time datasets in the automatically generated GUI:
-- python::temporal::gui_support
-Unittests:
-- python::temporal::unittests_register
-\section PythonTGISExamples Examples
-\subsection PythonTGISExamplesSimple Simple example
-This simple example shows how to open a space time raster dataset
-to access its registered maps.
-\code
-# Lets import the temporal framework and
-# the script framework
-import grass.temporal as tgis
-import grass.script as grass
-# Make sure the temporal database exists
-# and set the temporal GIS environment
-tgis.init()
-# We create the temporal database interface for fast processing
-dbif = tgis.SQLDatabaseInterfaceConnection()
-dbif.connect()
-# The id of a space time raster dataset is build from its name and its mapset
-id = "test at PERMANENT"
-# We create a space time raster dataset object
-strds = tgis.SpaceTimeRasterDataset(id)
-# Check if the space time raster dataset is in the temporal database
-if strds.is_in_db(dbif=dbif) == False:
- dbif.close()
- grass.fatal(_("Space time %s dataset <%s> not found") % (
- strds.get_new_map_instance(None).get_type(), id))
-# Fill the object with the content from the temporal database
-strds.select(dbif=dbif)
-# Print informations about the space time raster dataset to stdout
-strds.print_info()
-# Get all maps that are registered in the strds and print
-# informations about the maps to stdout
-maps = strds.get_registered_maps_as_objects(dbif=dbif)
-# We iterate over the temporal sorted map list
-for map in maps:
- # We fill the map object with the content
- # from the temporal database. We use the existing
- # database connection, otherwise a new connection
- # will be established for each map object
- # which slows the processing down
- map.select(dbif=dbif)
- map.print_info()
-# Close the database connection
-dbif.close()
-\endcode
-\subsection PythonTGISExamplesSTDSCreation Creation of a space time dataset
-This example shows howto create a space time dataset. The code is generic and works
-for different space time datasets (raster, 3D raster and vector):
-\code
-# The id of the new space time dataset
-id="test at PERMANENT"
-# The title of the new space time dataset
-title="This is a test dataset"
-# The description of the space time dataset
-description="The description"
-# The type of the space time dataset (strds, str3ds or stvds)
-type="strds"
-# The temporal type of the space time dataset (absolute or relative)
-temporal_type="absolute"
-tgis.init()
-# We use the dataset factory to create an new space time dataset instance of a specific type
-stds = tgis.dataset_factory(type, id)
-# We need a dtabase connection to insert the content of the space time dataset
-dbif.connect()
-# First we check if the dataset is already in the database
-if stds.is_in_db(dbif=dbif) and overwrite == False:
- dbif.close()
- grass.fatal(_("Space time %s dataset <%s> is already in the database. "
- "Use the overwrite flag.") %
- (stds.get_new_map_instance(None).get_type(), name))
-# We delete the exiting dataset and create a new one in case we are allowed to overwrite it
-if stds.is_in_db(dbif=dbif) and overwrite == True:
- grass.warning(_("Overwrite space time %s dataset <%s> "
- "and unregister all maps.") %
- stds.delete(dbif=dbif)
- stds = stds.get_new_instance(id)
-# We set the initial values. This function also created the command history.
-stds.set_initial_values(temporal_type=temporaltype, semantic_type="mean",
- title=title, description=description)
-# Now we can insert the new space time dataset in the database
-stds.insert(dbif=dbif)
-dbif.close()
-\endcode
-\subsection PythonTGISExamplesShifting Temporal shifting
-\code
-type="strds"
-tgis.init()
-dbif.connect()
-if stds.is_in_db(dbif) == False:
- dbif.close()
- grass.fatal(_("Space time dataset <%s> not found in temporal database") % (id))
-stds.select(dbif=dbif)
-stds.snap(dbif=dbif)
-stds.update_command_string(dbif=dbif)
-dbif.close()
-\endcode
-\section PythonTGISAuthors Authors
-Soeren Gebbert
-TODO: add more documentation
Modified: grass/branches/releasebranch_7_0/lib/python/temporal/register.py
--- grass/branches/releasebranch_7_0/lib/python/temporal/register.py 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/python/temporal/register.py 2015-01-08 22:45:30 UTC (rev 64018)
@@ -117,7 +117,7 @@
row["id"] = mapid
maplist[count] = row
- # Read the raster map list from file
+ # Read the map list from file
if file:
fd = open(file, "r")
@@ -308,7 +308,7 @@
if name and map_object_list:
count = 0
num_maps = len(map_object_list)
- msgr.message(_("Registering maps in the space time raster dataset..."))
+ msgr.message(_("Registering maps in the space time dataset..."))
for map in map_object_list:
if count % 50 == 0:
msgr.percent(count, num_maps, 1)
@@ -317,7 +317,7 @@
# Update the space time tables
- msgr.message(_("Updating space time raster dataset..."))
+ msgr.message(_("Updating space time dataset..."))
sp.update_from_registered_maps(dbif)
if update_cmd_list is True:
sp.update_command_string(dbif=dbif)
Modified: grass/branches/releasebranch_7_0/lib/raster/close.c
--- grass/branches/releasebranch_7_0/lib/raster/close.c 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/raster/close.c 2015-01-08 22:45:30 UTC (rev 64018)
@@ -375,13 +375,14 @@
fcb->null_temp_name, path, strerror(errno));
stat = -1;
+ /* if rename() was successful what is left to remove() ? */
else {
remove(fcb->null_temp_name);
else {
- remove(path);
+ remove(path); /* again ? */
} /* null_cur_row > 0 */
if (fcb->open_mode == OPEN_NEW_COMPRESSED) { /* auto compression */
@@ -440,6 +441,7 @@
fcb->temp_name, path, strerror(errno));
stat = -1;
else {
remove(fcb->temp_name);
Modified: grass/branches/releasebranch_7_0/lib/symbol/read.c
--- grass/branches/releasebranch_7_0/lib/symbol/read.c 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/symbol/read.c 2015-01-08 22:45:30 UTC (rev 64018)
@@ -221,7 +221,7 @@
fclose(fp);
G_free(s); /* TODO: free all */
- G_warning("%s", msg);
+ G_warning(msg, "%s");
return NULL;
Modified: grass/branches/releasebranch_7_0/lib/vector/vectorlib.dox
--- grass/branches/releasebranch_7_0/lib/vector/vectorlib.dox 2015-01-08 22:28:02 UTC (rev 64017)
+++ grass/branches/releasebranch_7_0/lib/vector/vectorlib.dox 2015-01-08 22:45:30 UTC (rev 64018)
@@ -293,8 +293,10 @@
\section vlibAttributes Attributes
-The old GRASS 4.x 'dig_cats' files are not used any more and vectors'
-attributes are stored in external database. Connection with the
+For a user-centric view about attribute management, see the explanations
+in the <a href="http://grasswiki.osgeo.org/wiki/Vector_Database_Management">GRASS GIS Wiki</a>.
+The attribute data are stored in external database. Connection with the
database is done through drivers based on \ref dbmilib. Records in a
table are linked to vector entities by layer and category number. The
layer identifies table and the category identifies record. I.e., for
@@ -313,6 +315,8 @@
The general DBMI settings are defined in the '$MAPSET/VAR' text file
(maintained with <tt>db.connect</tt> command at user level).
+Note: vector boundaries are (typically) handled without category since adjacent
+parcels might have two different categories which prevents from a unique assignment.
\section vlibGeometry Vector library feature geometry
