[GRASS-SVN] r64037 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Fri Jan 9 12:16:28 PST 2015
Author: mmetz
Date: 2015-01-09 12:16:27 -0800 (Fri, 09 Jan 2015)
New Revision: 64037
grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c
Vlib: sync building topology to trunk
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c 2015-01-09 20:13:37 UTC (rev 64036)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c 2015-01-09 20:16:27 UTC (rev 64037)
@@ -174,7 +174,7 @@
int Vect_isle_find_area(struct Map_info *Map, int isle)
- int i, line, sel_area, area, poly;
+ int i, j, line, sel_area, area, poly;
const struct Plus_head *plus;
struct P_line *Line;
struct P_node *Node;
@@ -226,7 +226,7 @@
* get the smallest area that contains the isle
* using the bbox size is working because if 2 areas both contain
* the isle, one of these areas must be inside the other area
- * which means that the bbox of the outer area must be lager than
+ * which means that the bbox of the outer area must be larger than
* the bbox of the inner area, and equal bbox sizes are not possible */
if (alloc_size_list < List->n_values) {
@@ -234,12 +234,24 @@
size_list = G_realloc(size_list, alloc_size_list * sizeof(BOX_SIZE));
+ j = 0;
for (i = 0; i < List->n_values; i++) {
- size_list[i].i = List->id[i];
abox = &List->box[i];
- size_list[i].box = List->box[i];
- size_list[i].size = (abox->N - abox->S) * (abox->E - abox->W);
+ if (box.E > abox->E || box.W < abox->W || box.N > abox->N ||
+ box.S < abox->S) {
+ G_debug(3, " isle not completely inside area box");
+ continue;
+ List->id[j] = List->id[i];
+ List->box[j] = List->box[i];
+ size_list[j].i = List->id[j];
+ size_list[j].box = List->box[j];
+ size_list[j].size = (abox->N - abox->S) * (abox->E - abox->W);
+ j++;
+ List->n_values = j;
if (List->n_values > 1) {
if (List->n_values == 2) {
@@ -832,8 +844,11 @@
/* don't write support files for OGR direct and PostGIS Topology */
Map->support_updated = TRUE;
- if (!Map->plus.Spidx_built)
- Vect_open_sidx(Map, 2);
+ if (!Map->plus.Spidx_built) {
+ if (Vect_open_sidx(Map, 2) < 0)
+ G_fatal_error(_("Unable to open spatial index file for vector map <%s>"),
+ Vect_get_full_name(Map));
plus = &(Map->plus);
if (build > GV_BUILD_NONE && !Map->temporary) {
