[GRASS-SVN] r64039 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Fri Jan 9 12:42:11 PST 2015
Author: mmetz
Date: 2015-01-09 12:42:11 -0800 (Fri, 09 Jan 2015)
New Revision: 64039
grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c
Vlib: sync Vect_remove_small_areas() to trunk
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c 2015-01-09 20:25:35 UTC (rev 64038)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/remove_areas.c 2015-01-09 20:42:11 UTC (rev 64039)
@@ -10,15 +10,13 @@
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
- \author Radim Blazek
+ \author Radim Blazek, Markus Metz
#include <stdlib.h>
#include <grass/vector.h>
#include <grass/glocale.h>
-#define DEGUG_RMAREA
int Vect_remove_small_areas_nat(struct Map_info *, double,
struct Map_info *, double *);
@@ -43,14 +41,11 @@
Vect_remove_small_areas(struct Map_info *Map, double thresh,
struct Map_info *Err, double *removed_area)
- return Vect_remove_small_areas_ext(Map, thresh, Err, removed_area);
-#if 0
if (Map->format == GV_FORMAT_NATIVE)
return Vect_remove_small_areas_nat(Map, thresh, Err, removed_area);
else
-#endif
int
@@ -213,9 +208,7 @@
struct ilist *List;
struct ilist *AList;
struct ilist *BList;
-#ifdef DEGUG_RMAREA
struct ilist *NList;
-#endif
struct ilist *IList;
struct line_pnts *Points;
struct line_cats *Cats;
@@ -227,9 +220,7 @@
List = Vect_new_list();
AList = Vect_new_list();
BList = Vect_new_list();
NList = Vect_new_list();
-#endif
IList = Vect_new_list();
Points = Vect_new_line_struct();
Cats = Vect_new_cats_struct();
@@ -418,10 +409,10 @@
Vect_list_append(IList, Vect_get_area_isle(Map, dissolve_neighbour, i));
/* get neighbour boundaries */
Vect_get_area_boundaries(Map, dissolve_neighbour, NList);
-#endif
/* delete area from topo */
dig_del_area(&(Map->plus), area);
/* delete neighbour area from topo */
@@ -436,17 +427,19 @@
Node = Map->plus.Node[topo->N1];
dig_del_line(&(Map->plus), line, Node->x, Node->y, Node->z);
- /* rebuild neighbour area from leftover boundaries */
+ /* build new area from leftover boundaries of deleted area */
for (i = 0; i < BList->n_values; i++) {
struct P_topo_b *topo;
+ int new_isle;
line = BList->value[i];
topo = Map->plus.Line[abs(line)]->topo;
if (topo->left == 0 || topo->right == 0) {
- int new_isle;
new_isle = Vect_build_line_area(Map, abs(line), (line > 0 ? GV_RIGHT : GV_LEFT));
if (new_isle > 0) {
+ if (outer_area > 0)
+ G_fatal_error("dissolve_neighbour > 0, new area has already been created");
outer_area = new_isle;
/* reattach centroid */
Map->plus.Area[outer_area]->centroid = centroid;
@@ -456,16 +449,20 @@
ctopo->area = outer_area;
+ else if (new_isle < 0) {
+ /* leftover boundary creates a new isle */
+ Vect_list_append(IList, -new_isle);
else {
- /* should not happen */
- G_warning(_("Failed to build new area"));
+ /* neither area nor isle, should not happen */
+ G_fatal_error(_("dissolve_neighbour > 0, failed to build new area"));
/* check */
- G_warning(_("Dissolve with neighbour area: corrupt topology"));
+ G_fatal_error(_("Dissolve with neighbour area: corrupt topology"));
+ /* build new area from neighbour's boundaries */
for (i = 0; i < NList->n_values; i++) {
@@ -474,13 +471,14 @@
continue;
int new_isle;
- G_warning(_("Neighbor boundaries should be complete"));
if (new_isle > 0) {
@@ -490,15 +488,18 @@
+ /* Neigbour's boundary creates a new isle */
else {
+ G_fatal_error(_("Failed to build new area"));
-#endif
/* dissolve with outer isle */
else if (dissolve_neighbour < 0) {
@@ -510,7 +511,7 @@
#ifdef DEGUG_RMAREA
/* get isle boundaries */
Vect_get_isle_boundaries(Map, -dissolve_neighbour, NList);
-#endif
/* delete isle from topo */
@@ -525,7 +526,7 @@
- /* rebuild isles from leftover boundaries */
+ /* build new isle(s) from leftover boundaries */
@@ -540,15 +541,16 @@
else {
- G_warning(_("Failed to build new isle"));
+ /* area or nothing should not happen */
+ G_fatal_error(_("Failed to build new isle"));
/* check */
- G_warning(_("Dissolve with outer isle: corrupt topology"));
+ G_fatal_error(_("Dissolve with outer isle: corrupt topology"));
+ /* build new isle(s) from old isle's boundaries */
@@ -557,25 +559,23 @@
continue;
int new_isle;
if (new_isle < 0) {
else {
/* check */
-#endif
if (dissolve_neighbour > 0 && outer_area <= 0) {
@@ -585,6 +585,8 @@
/* attach all isles to outer or new area */
if (outer_area >= 0) {
for (i = 0; i < IList->n_values; i++) {
+ if (!Map->plus.Isle[IList->value[i]])
+ continue;
Map->plus.Isle[IList->value[i]]->area = outer_area;
if (outer_area > 0)
dig_area_add_isle(&(Map->plus), outer_area, IList->value[i]);
@@ -604,9 +606,7 @@
Vect_destroy_list(List);
Vect_destroy_list(AList);
Vect_destroy_list(BList);
Vect_destroy_list(NList);
-#endif
Vect_destroy_list(IList);
Vect_destroy_line_struct(Points);
Vect_destroy_cats_struct(Cats);
