[GRASS-SVN] r64051 - grass-addons/grass7/vector/v.transects
svn_grass at osgeo.org
Sat Jan 10 19:48:53 PST 2015
Author: annakrat
Date: 2015-01-10 19:48:53 -0800 (Sat, 10 Jan 2015)
New Revision: 64051
grass-addons/grass7/vector/v.transects/v.transects.html
grass-addons/grass7/vector/v.transects/v.transects.py
v.transects: add new options controlling transect spacing and perpendicularity
Modified: grass-addons/grass7/vector/v.transects/v.transects.html
--- grass-addons/grass7/vector/v.transects/v.transects.html 2015-01-10 23:44:09 UTC (rev 64050)
+++ grass-addons/grass7/vector/v.transects/v.transects.html 2015-01-11 03:48:53 UTC (rev 64051)
@@ -1,12 +1,35 @@
<h2>DESCRIPTION</h2>
<em>v.transects</em> creates equally spaced geometries along
-input lines. The geometries can be lines or quadrilateral areas. Lines
-and areas are generated to be perpendicular to the input line.
+input lines. Depending on the selected <b>metric</b>, the distances
+are measured either as straight distances between the transects or along the line.
+Straight distance is better when the lines are complicated (shorelines)
+and using the distance along line would result in big differences in the transect spacing.
+<p>
+The geometries can be lines or quadrilateral areas. Lines
+and areas are generated to be perpendicular to either the input line
+(select <em>line</em> for parameter <b>transect_perpendicular</b>),
+or to the line connecting the transect points
+(select <em>trend</em> for parameter <b>transect_perpendicular</b>).
+The latter option is useful for complicated lines, because it follows the trend of the line.
+<p>
By default the last point of each line is not used
because the last transect distance would be typically different from the previous once.
To create a transect from the last point, use flag <b>-l</b>.
+<p>
+The following pictures show the effect of different options on a line with simple geometry.
+In the first picture, the circles show points generated by <a href=v.segment.html"">v.segment</a>
+in 100 m interval along the line. The green lines were generated with option
+<code>metric=along</code>, therefore they match with the points. The blue lines
+were generated with <code>metric=straight</code>.<br>
+In the second picture, green lines use <code>transect_perpendicular=line</code>
+while the blue ones use <code>transect_perpendicular=trend</code>.
+<center>
+<img src="vtransect_options1.jpg">
+<img src="vtransect_options2.jpg">
+</center>
<h2>NOTES</h2>
Input vector lines that are shorter than <b>transect_spacing</b> are ignored.
@@ -74,12 +97,10 @@
<h2>SEE ALSO</h2>
-<em>
+<a href="v.segment.html">v.segment</a><br>
<a href="v.generalize.html">v.generalize</a>
<br>
<a href="http://www4.ncsu.edu/~ejhardi2/vTransect.html">v.transects tutorial</a>
-</em>
<h2>AUTHOR</h2>
Modified: grass-addons/grass7/vector/v.transects/v.transects.py
--- grass-addons/grass7/vector/v.transects/v.transects.py 2015-01-10 23:44:09 UTC (rev 64050)
+++ grass-addons/grass7/vector/v.transects/v.transects.py 2015-01-11 03:48:53 UTC (rev 64051)
@@ -47,6 +47,24 @@
#% options: point,line,area
#% answer: line
#%end
+#%option
+#% key: metric
+#% type: string
+#% description: Determines how transect spacing is measured
+#% multiple: no
+#% options: straight, along
+#% descriptions: straight;Straight distance between transect points;along;Distance along the line
+#% answer: straight
+#%end
+#%option
+#% key: transect_perpendicular
+#% type: string
+#% description: Determines which line is the transect perpendicular to
+#% multiple: no
+#% options: trend, line
+#% descriptions: trend;Perpendicular to the line connecting transect points;line;Perpendicular to the particular segment of the original line
+#% answer: trend
+#%end
#%flag
#% key: l
#% description: Use the last point of the line to create transect
@@ -121,57 +139,81 @@
return v
-def get_transects_locs(vector, transect_spacing, last_point):
+def get_transects_locs(vector, transect_spacing, dist_function, last_point):
"""!Get transects locations along input vector lines."""
# holds locations where transects should intersect input vector lines
transect_locs = []
+ vectors = []
for line in vector:
transect_locs.append([line[0]])
+ vectors.append([[line[0], line[1]]])
# i starts at the beginning of the line.
# j walks along the line until j and i are separated by a distance of transect_spacing.
# then, a transect is placed at j, i is moved to j, and this is iterated until the end of the line is reached
i = 0
j = i + 1
while j < len(line):
- d = dist(line[i], line[j])
+ d = dist_function(line, i, j)
if d > transect_spacing:
- r = ((transect_spacing - dist(line[i], line[j - 1])) /
- (dist(line[i], line[j]) - dist(line[i], line[j - 1])))
+ r = ((transect_spacing - dist_function(line, i, j - 1)) /
+ (dist_function(line, i, j) - dist_function(line, i, j - 1)))
transect_locs[-1].append((r * array(line[j]) +
(1 - r) * array(line[j - 1])).tolist())
+ vectors[-1].append([line[j - 1], transect_locs[-1][-1]])
i = j - 1
line[i] = transect_locs[-1][-1]
else:
j += 1
if last_point:
transect_locs[-1].append(line[j-1])
- return transect_locs
+ vectors[-1].append([line[j-2], line[j-1]])
+ return transect_locs, vectors
-def get_transect_ends(transect_locs, dleft, dright):
+def get_transect_ends(transect_locs, vectors, trend, dleft, dright):
"""!From transects locations along input vector lines, get transect ends."""
transect_ends = []
- for transect in transect_locs:
- # if a line in input vec was shorter than transect_spacing
- if len(transect) < 2:
- continue # then don't put a transect on it
- transect_ends.append([])
- transect = array(transect)
- v = NR(transect[0], transect[1]) # vector pointing parallel to transect
- transect_ends[-1].append([transect[0] + dleft * v, transect[0] - dright * v])
- for i in range(1, len(transect) - 1, 1):
- v = NR(transect[i - 1], transect[i + 1])
- transect_ends[-1].append([transect[i] + dleft * v, transect[i] - dright * v])
- v = NR(transect[-2], transect[-1])
- transect_ends[-1].append([transect[-1] + dleft * v, transect[-1] - dright * v])
+ if not trend:
+ for k, transect in enumerate(transect_locs):
+ # if a line in input vec was shorter than transect_spacing
+ if len(transect) < 2:
+ continue # then don't put a transect on it
+ transect_ends.append([])
+ transect = array(transect)
+ v = NR(*vectors[k][0]) # vector pointing parallel to transect
+ transect_ends[-1].append([transect[0] + dleft * v, transect[0] - dright * v])
+ for i in range(1, len(transect)):
+ v = NR(*vectors[k][i])
+ transect_ends[-1].append([transect[i] + dleft * v, transect[i] - dright * v])
+ else:
+ for transect in transect_locs:
+ v = NR(transect[0], transect[1]) # vector pointing parallel to transect
+ for i in range(1, len(transect) - 1, 1):
+ v = NR(transect[i - 1], transect[i + 1])
+ v = NR(transect[-2], transect[-1])
+ transect_ends[-1].append([transect[-1] + dleft * v, transect[-1] - dright * v])
return transect_ends
-def dist(ip, fp):
+def dist_euclidean(line, i1, i2):
"""!Calculates distance between two points"""
- return sqrt((ip[0] - fp[0]) ** 2 + (ip[1] - fp[1]) ** 2)
+ return sqrt((line[i1][0] - line[i2][0]) ** 2 + (line[i1][1] - line[i2][1]) ** 2)
+def dist_along_line(line, i1, i2):
+ distance = 0
+ for i in range(i1, i2):
+ distance += dist_euclidean(line, i, i + 1)
+ return distance
def NR(ip, fp):
"""!Take a vector, normalize and rotate it 90 degrees."""
x = fp[0] - ip[0]
@@ -286,13 +328,21 @@
v = loadVector(vector)
- transect_locs = get_transects_locs(v, transect_spacing, last_point)
+ if options['metric'] == 'straight':
+ dist = dist_euclidean
+ else:
+ dist = dist_along_line
+ if options['transect_perpendicular'] == 'trend':
+ trend = True
+ else:
+ trend = False
+ transect_locs, vectors = get_transects_locs(v, transect_spacing, dist, last_point)
temp_map = tempmap()
if shape == 'line' or not shape:
- transect_ends = get_transect_ends(transect_locs, dleft, dright)
+ transect_ends = get_transect_ends(transect_locs, vectors, trend, dleft, dright)
writeTransects(transect_ends, temp_map)
elif shape == 'area':
writeQuads(transect_ends, temp_map)
else:
writePoints(transect_locs, temp_map)
