[GRASS-SVN] r64055 - in grass/trunk/gui/wxpython: docs nviz
svn_grass at osgeo.org
Sat Jan 10 20:46:59 PST 2015
Author: wenzeslaus
Date: 2015-01-10 20:46:59 -0800 (Sat, 10 Jan 2015)
New Revision: 64055
grass/trunk/gui/wxpython/docs/wxGUI.nviz.html
grass/trunk/gui/wxpython/nviz/tools.py
wxGUI/nviz: replace volume by 3D raster in 3D view controls and documentation
* no change for 'volume' used with vectors
* now there is strange inconsistency with surfaces and 3D rasters (considering as minor)
Modified: grass/trunk/gui/wxpython/docs/wxGUI.nviz.html
--- grass/trunk/gui/wxpython/docs/wxGUI.nviz.html 2015-01-11 04:42:09 UTC (rev 64054)
+++ grass/trunk/gui/wxpython/docs/wxGUI.nviz.html 2015-01-11 04:46:59 UTC (rev 64055)
@@ -8,10 +8,10 @@
<p>
<b>wxNviz</b> is a <em><a href="wxGUI.html">wxGUI</a></em> <b>3D view
mode</b> which allows users to realistically render multiple
-<em>surfaces</em> (raster data) in a 3D space, optionally using
-thematic coloring, draping 2D <em>vector</em> data over the surfaces,
-displaying 3D vector data in the space, and visualization
-of <em>volume</em> data (3D raster data).
+<em>surfaces</em> (2D raster maps) in a 3D space, optionally using
+thematic coloring, draping 2D <em>vector</em> data or different 2D raster data
+over the surfaces, displaying 3D vector data in the space, and visualization
+of <em>3D rasters</em>.
<p>
To start the wxGUI 3D view mode, choose '3D view' from the map
@@ -120,7 +120,7 @@
<h3>Data properties</h3>
This tab controls the parameters related to map layers. It consists
of four collapsible panels - <em>Surface</em>, <em>Constant surface</em>,
-<em>Vector</em> and <em>Volume</em>.
+<em>Vector</em> and <em>3D raster</em>.
<h4>Surface</h4>
@@ -240,20 +240,21 @@
<br><img src="wxGUI_nviz_tools_vector.jpg" border="1" alt="toolbox"><br><br>
</center>
-<h4>Volume</h4>
+<h4>3D rasters</h4>
-Volumes (3D raster maps) can be displayed either as isosurfaces or slices.
+3D raster maps (volumes, voxel models) can be displayed either as isosurfaces
+or slices.
Similarly to surface panel you can define draw <b>shading</b> -
-<em>gouraud</em> (draws the volumes with a smooth shading to blend
-individual cell colors together) and <em>flat</em> (draws the volumes with
-flat shading with one color for every two cells. The volume appears
+<em>gouraud</em> (draws the 3D rasters with a smooth shading to blend
+individual cell colors together) and <em>flat</em> (draws the 3D rasters with
+flat shading with one color for every two cells. The 3D raster appears
faceted). As mentioned above currently are supported two visualization
modes:
<ul>
<li><b>isosurface</b> - the levels of values for drawing the
- volume(s) as isosurfaces,</li>
- <li>and <b>slice</b> - drawing the volume
+ 3D raster(s) as isosurfaces,</li>
+ <li>and <b>slice</b> - drawing the 3D raster
as cross-sections.</li>
</ul>
<p>
@@ -268,23 +269,23 @@
<li><b>isosurface value</b> - reference isosurface value (height in map
units).</li>
<li><b>color</b> - raster map or constant color to drape over the
- current volume.</li>
+ current 3D raster.</li>
<li><b>mask</b> - raster map that controls the areas displayed from
- the current volume.</li>
+ the current 3D raster.</li>
<li><b>transparency</b> - raster map or constant value that controls
- the transparency of the current volume. The default is completely
+ the transparency of the current 3D raster. The default is completely
opaque. Range from 0 (opaque) to 100 (transparent).</li>
<li><b>shininess</b> - raster map or constant value that controls
- the shininess (reflectivity) of the current volume. Range from 0 to
+ the shininess (reflectivity) of the current 3D raster. Range from 0 to
100.</li>
</ul>
-In case of volume slice the bottom part of the panel controls the slice
+In case of 3D raster slice the bottom part of the panel controls the slice
attributes (which axis is slice parallel to, position of slice edges,
transparency). Press button <em>Reset</em> to reset slice position
attributes.
<p>
-Volumes can be moved the same way like surfaces do.
+3D rasters can be moved the same way like surfaces do.
<center>
<br><img src="wxGUI_nviz_tools_volume.jpg" border="1" alt="toolbox"><br><br>
@@ -350,7 +351,7 @@
<h2>Settings</h2>
This panel has controls which allows user to set default surface,
-vector and volume data attributes. You can also modify default view
+vector and 3D raster data attributes. You can also modify default view
parameters, or to set the background color of the Map Display Window
(the default color is white).
Modified: grass/trunk/gui/wxpython/nviz/tools.py
--- grass/trunk/gui/wxpython/nviz/tools.py 2015-01-11 04:42:09 UTC (rev 64054)
+++ grass/trunk/gui/wxpython/nviz/tools.py 2015-01-11 04:46:59 UTC (rev 64055)
@@ -560,7 +560,7 @@
self.EnablePage("vector", enabled = False)
# volume page
- volumePanel = self.foldpanelData.AddFoldPanel(_("Volume"), collapsed = True)
+ volumePanel = self.foldpanelData.AddFoldPanel(_("3D raster"), collapsed=True)
self.foldpanelData.AddFoldPanelWindow(volumePanel,
window = self._createVolumePage(parent = volumePanel), flags = fpb.FPB_ALIGN_WIDTH)
self.EnablePage("volume", enabled = False)
