[GRASS-SVN] r64066 - grass/branches/releasebranch_7_0/lib/vector/Vlib
svn_grass at osgeo.org
Sun Jan 11 11:35:59 PST 2015
Author: mmetz
Date: 2015-01-11 11:35:59 -0800 (Sun, 11 Jan 2015)
New Revision: 64066
grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c
Vlib: fix r49178
Modified: grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c
--- grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c 2015-01-11 19:35:44 UTC (rev 64065)
+++ grass/branches/releasebranch_7_0/lib/vector/Vlib/build.c 2015-01-11 19:35:59 UTC (rev 64066)
@@ -475,7 +475,6 @@
int i, sel_area, centr;
static int first = 1;
static struct boxlist *List;
- static struct line_pnts *Points;
struct P_area *Area;
struct P_line *Line;
struct P_topo_c *topo;
@@ -486,15 +485,13 @@
plus = &(Map->plus);
if (first) {
- List = Vect_new_boxlist(0);
- Points = Vect_new_line_struct();
+ List = Vect_new_boxlist(1);
first = 0;
Vect_select_lines_by_box(Map, box, GV_CENTROID, List);
G_debug(3, "\tnumber of centroids to reattach = %d", List->n_values);
for (i = 0; i < List->n_values; i++) {
- int orig_area;
centr = List->id[i];
Line = plus->Line[centr];
@@ -508,26 +505,7 @@
if (topo->area > 0)
continue;
- orig_area = topo->area;
- Vect_read_line(Map, Points, NULL, centr);
- if (Points->n_points < 1) {
- /* try to get centroid from spatial index (OGR layers) */
- int found;
- struct boxlist list;
- dig_init_boxlist(&list, TRUE);
- Vect_select_lines_by_box(Map, box, GV_CENTROID, &list);
- found = 0;
- for (i = 0; i < list.n_values; i++) {
- if (list.id[i] == centr) {
- found = i;
- break;
- Vect_append_point(Points, list.box[found].E, list.box[found].N, 0.0);
- sel_area = Vect_find_area(Map, Points->x[0], Points->y[0]);
+ sel_area = Vect_find_area(Map, List->box[i].E, List->box[i].N);
G_debug(3, "\tcentroid %d is in area %d", centr, sel_area);
if (sel_area > 0) {
Area = plus->Area[sel_area];
