[GRASS-SVN] r64068 - in grass-addons/grass7/raster: r.mess r.random.weight r.recode.attr
Sun Jan 11 15:31:14 PST 2015
Author: pvanbosgeo
Date: 2015-01-11 15:31:14 -0800 (Sun, 11 Jan 2015)
New Revision: 64068
   grass-addons/grass7/raster/r.mess/r.mess.py
   grass-addons/grass7/raster/r.random.weight/r.random.weight.py
   grass-addons/grass7/raster/r.recode.attr/r.recode.attr.html
   grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py
small improvements (hopefully)
Modified: grass-addons/grass7/raster/r.mess/r.mess.py
--- grass-addons/grass7/raster/r.mess/r.mess.py	2015-01-11 22:32:27 UTC (rev 64067)
+++ grass-addons/grass7/raster/r.mess/r.mess.py	2015-01-11 23:31:14 UTC (rev 64068)
@@ -149,6 +149,12 @@
         grass.run_command("g.remove",
         type="rast", name = rast, quiet = True)
+def CheckLayer(envlay):
+    for chl in xrange(len(envlay)):
+        ffile = grass.find_file(envlay[chl], element = 'cell')
+        if ffile['fullname'] == '':
+            grass.fatal("The layer " + envlay[chl] + " does not exist.")
 # main function
 def main():
@@ -182,6 +188,7 @@
     # old environmental layers & variable names
     ipl = options['env_old']
     ipl = ipl.split(',')
+    CheckLayer(ipl)
     ipn = [z.split('@')[0] for z in ipl]
     ipn = [x.lower() for x in ipn]
@@ -193,6 +200,7 @@
     else:
         ipl_dif = True
         ipl2 = ipl2.split(',')
+        CheckLayer(ipl2)
         if len(ipl2) != len(ipl) and len(ipl2) != 0:
             grass.fatal('number of old and new environmental variables is not the same')
Modified: grass-addons/grass7/raster/r.random.weight/r.random.weight.py
--- grass-addons/grass7/raster/r.random.weight/r.random.weight.py	2015-01-11 22:32:27 UTC (rev 64067)
+++ grass-addons/grass7/raster/r.random.weight/r.random.weight.py	2015-01-11 23:31:14 UTC (rev 64068)
@@ -4,7 +4,7 @@
 # MODULE:       r.rand.weight
-# AUTHOR(S):    paulo van Breugel <paulo at ecodiv.org>
+# AUTHOR(S):    paulo van Breugel <paulo at ecodiv.org>
 # PURPOSE:      Create a layer with weighted random sample
 # COPYRIGHT: (C) 2014 Paulo van Breugel
 #            http://ecodiv.org
@@ -87,23 +87,23 @@
 import grass.script as grass
 # Runs modules silently
-os.environ['GRASS_VERBOSE']='-1'
+os.environ['GRASS_VERBOSE']='-1'
 clean_rast = set()
 def cleanup():
     for rast in clean_rast:
-        grass.run_command("g.remove",
+        grass.run_command("g.remove",
 # main function
 def main():
     # check if GISBASE is set
     if "GISBASE" not in os.environ:
     # return an error advice
-       grass.fatal(_("You must be in GRASS GIS to run this program"))
-    # input raster map and parameters
+    grass.fatal(_("You must be in GRASS GIS to run this program"))
+    # input raster map and parameters
     minval = options['start']
     maxval = options['end']
     weight = options['weights']
@@ -111,29 +111,29 @@
     subsample = options['subsample']
     seed = options['seed']
     flag_n = flags['n']
     # setup temporary files and seed
     tmp_map = "r_w_rand_" + str(uuid.uuid4())
     tmp_map = string.replace(tmp_map, '-', '_')
     # Compute minimum and maximum value raster
-    minmax = grass.parse_command('r.univar',
+    minmax = grass.parse_command('r.univar',
         map = weight,
         flags='g')
-    if seed == "auto":
-        grass.mapcalc("$tmp_map = rand(float(${minval}),float(${maxval}))",
+    if seed == "auto":
+        grass.mapcalc("$tmp_map = rand(float(${minval}),float(${maxval}))",
             seed='auto',
-            minval = minval,
+            minval = minval,
             maxval = maxval,
             tmp_map = tmp_map)
-    else:
+    else:
             seed=int(seed),
-            minval = minval,
+            minval = minval,
             maxval = maxval,
             tmp_map = tmp_map)
-    clean_rast.add(tmp_map)
+    clean_rast.add(tmp_map)
     if flag_n:
         grass.mapcalc("${outmap} = if($tmp_map <= ${weight},1,0)",
@@ -145,11 +145,11 @@
             weight = weight,
             outmap = outmap,
             tmp_map = tmp_map)
-    grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmp_map)
-    if not subsample == '':
+    grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmp_map)
+    if not subsample == '':
         grass.run_command('r.null',
-            map = outmap,
+            map = outmap,
             setnull = 0)
         grass.run_command('r.random',
             input = outmap,
@@ -158,17 +158,16 @@
             overwrite=True)
         if flag_n:
-                map = outmap,
+                map = outmap,
                 null = 0)
-    print("------------------")
-    print("Ready!")
-    print("The name of raster created is " + outmap)
-    if minval > minmax['min'] or maxval < minmax['max']:
-        print("Warning!")
-        print("You defined the minimum and maximum weights as: " + minval + " & " + maxval)
-        print("Value range of weight raster is: " + minmax['min'] + " - " + minmax['max'])
+    grass.message("------------------")
+    grass.message("Ready!")
+    grass.message("The name of raster created is " + outmap)
+    #if minval > minmax['min'] or maxval < minmax['max']:
+    grass.warning("You defined the minimum and maximum weights as: "
+        + minval + " & " + maxval + ". Value range of weight raster is: "
+        + minmax['min'] + " - " + minmax['max'])
 if __name__ == "__main__":
     options, flags = grass.parser()
Modified: grass-addons/grass7/raster/r.recode.attr/r.recode.attr.html
--- grass-addons/grass7/raster/r.recode.attr/r.recode.attr.html	2015-01-11 22:32:27 UTC (rev 64067)
+++ grass-addons/grass7/raster/r.recode.attr/r.recode.attr.html	2015-01-11 23:31:14 UTC (rev 64068)
@@ -20,10 +20,8 @@
 <h2>NOTES</h2>
 The script uses r.recode to allow the user to reclass integer values
-to floating point values. However, like <a href=
-"http://grass.osgeo.org/grass70/manuals/r.reclass.html">r.reclass</a>
-you can only convert number one to one (and not like <a href=
-"http://grass.osgeo.org/grass70/manuals/r.recode.html">r.recode</a>
+to floating point values. However, like <a href="http://grass.osgeo.org/grass70/manuals/r.reclass.html">r.reclass</a>
+you can only convert number one to one (and not like <a href="http://grass.osgeo.org/grass70/manuals/r.recode.html">r.recode</a>
 ranges of values to one value or a new range of values)
 <h2>TODO</h2>
@@ -36,18 +34,12 @@
 <h2>EXAMPLES</h2>
-<p>See <a href=
-"http://pvanb.wordpress.com/2014/12/13/recode-your-raster-file-in-gras
-s-gis-using-a-csv-file/">this blog post</a> for an example.
+<p>See <a href="http://pvanb.wordpress.com/2014/12/13/recode-your-raster-file-in-grass-gis-using-a-csv-file/">this blog post</a> for an example.
 <h2>SEE ALSO</h2>
-<em><a href=
-</a></em>,
-<em><a href=
-</a></em>
+<em><a href="http://grass.osgeo.org/grass70/manuals/r.reclass.html">r.reclass</a></em>,
+<em><a href="http://grass.osgeo.org/grass70/manuals/r.recode.html">r.recode</a></em>
 <h2>AUTHOR</h2>
Modified: grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py
--- grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py	2015-01-11 22:32:27 UTC (rev 64067)
+++ grass-addons/grass7/raster/r.recode.attr/r.recode.attr.py	2015-01-11 23:31:14 UTC (rev 64068)
@@ -6,7 +6,7 @@
 # MODULE:       r.recode_attribute
 # AUTHOR(S):    Paulo van Breugel <p.vanbreugel AT gmail.com>
 # PURPOSE:      Recode raster to one or more new layers using an
-#               attribute table (csv file) as input
+#               attribute table (csv file) as input
 #            http://ecodiv.org
@@ -52,6 +52,10 @@
 import os
 import sys
 import numpy as np
+from tempfile import gettempdir, gettempprefix
+from os.path import join
+from string import ascii_lowercase, digits
+from random import choice
 def cleanup():
@@ -61,6 +65,16 @@
       flags='f',
       quiet = True)
+def CreateFileName():
+    (suffix1, suffix2) = ("", "")
+    for _ in xrange( 8 ):
+        suffix1 += choice( ascii_lowercase )
+        suffix2 += choice( digits )
+    flname = join(gettempdir(), '-'.join([gettempprefix(), suffix1, suffix2 ]))
+    while os.path.isfile(flname):
+        flname = flname + "1"
+    return flname
 # main function
 def main():
@@ -87,7 +101,8 @@
     for x in numVar:
         y = x + 1
         myRecode = np.column_stack((myData[:,0], myData[:,0], myData[:,y]))
-        np.savetxt('.numpy_grass_recode', myRecode, delimiter=":")
+        tmpname = CreateFileName()
+        np.savetxt(tmpname, myRecode, delimiter=":")
         if len(numVar) == lengthNames:
             nmOutput = outNames[x]
