[GRASS-SVN] r64083 - in grass/trunk/vector: v.lidar.correction v.lidar.edgedetection
Mon Jan 12 05:36:28 PST 2015
Author: neteler
Date: 2015-01-12 05:36:28 -0800 (Mon, 12 Jan 2015)
New Revision: 64083
   grass/trunk/vector/v.lidar.correction/main.c
   grass/trunk/vector/v.lidar.correction/v.lidar.correction.html
   grass/trunk/vector/v.lidar.edgedetection/main.c
   grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html
v.lidar.correction,v.lidar.edgedetection: sync spline parameter names to v.surf.bspline (trac #2409); minor cleanup
Modified: grass/trunk/vector/v.lidar.correction/main.c
--- grass/trunk/vector/v.lidar.correction/main.c	2015-01-12 12:36:33 UTC (rev 64082)
+++ grass/trunk/vector/v.lidar.correction/main.c	2015-01-12 13:36:28 UTC (rev 64083)
@@ -1,24 +1,24 @@
- * MODULE:       v.lidar.correction				    *
- * AUTHOR(S):    Roberto Antolin & Gonzalo Moreno                   *
- *               general update Markus Metz      		    *
- * PURPOSE:      Correction of the v.growing output		    *
- * COPYRIGHT:    (C) 2005 by Politecnico di Milano - 		    *
- *			     Polo Regionale di Como		    *
- *               This program is free software under the 	    *
- *               GNU General Public License (>=v2). 		    *
- *               Read the file COPYING that comes with GRASS	    *
- *               for details.					    *
+ * MODULE:       v.lidar.correction
+ * AUTHOR(S):    Roberto Antolin & Gonzalo Moreno
+ *               general update Markus Metz
+ * PURPOSE:      Correction of the v.growing output
+ * COPYRIGHT:    (C) 2005 by Politecnico di Milano -
+ *			     Polo Regionale di Como
+ *               This program is free software under the
+ *               GNU General Public License (>=v2).
+ *               Read the file COPYING that comes with GRASS
+ *               for details.
- /*INCLUDES*/
+/* INCLUDES */
 #include <stdlib.h>
 #include <string.h>
 #include <math.h>
@@ -28,14 +28,14 @@
 int main(int argc, char *argv[])
     /* Declarations */
-    int dim_vect, nparameters, BW, npoints, nrows, ncols;
+    int dim_vect, nparameters, BW, npoints;
     int nsply, nsplx, nsplx_adj, nsply_adj;
     int nsubregion_col, nsubregion_row;
     int subregion = 0, nsubregions = 0;
     const char *dvr, *db, *mapset;
     char table_name[GNAME_MAX];
     char xname[GNAME_MAX], xmapset[GMAPSET_MAX];
-    double lambda, ew_resol, ns_resol, mean, stepN, stepE, HighThresh,
+    double lambda, mean, stepN, stepE, HighThresh,
 	LowThresh;
     double N_extension, E_extension, edgeE, edgeN;
@@ -68,7 +68,7 @@
     G_add_keyword(_("vector"));
     G_add_keyword(_("LIDAR"));
     module->description =
-	_("Correction of the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering.");
+	_("Corrects the v.lidar.growing output. It is the last of the three algorithms for LIDAR filtering.");
     spline_step_flag = G_define_flag();
     spline_step_flag->key = 'e';
@@ -93,20 +93,22 @@
 	_("Only 'terrain' points output vector map");
     stepE_opt = G_define_option();
-    stepE_opt->key = "sce";
+    stepE_opt->key = "ew_step";
     stepE_opt->type = TYPE_DOUBLE;
     stepE_opt->required = NO;
     stepE_opt->answer = "25";
     stepE_opt->description =
-	_("Interpolation spline step value in east direction");
+	_("Length of each spline step in the east-west direction");
+    stepE_opt->guisection = _("Settings");
     stepN_opt = G_define_option();
-    stepN_opt->key = "scn";
+    stepN_opt->key = "ns_step";
     stepN_opt->type = TYPE_DOUBLE;
     stepN_opt->required = NO;
     stepN_opt->answer = "25";
     stepN_opt->description =
-	_("Interpolation spline step value in north direction");
+	_("Length of each spline step in the north-south direction");
+    stepN_opt->guisection = _("Settings");
     lambda_f_opt = G_define_option();
     lambda_f_opt->key = "lambda_c";
@@ -248,12 +250,6 @@
     Vect_region_box(&elaboration_reg, &overlap_box);
     Vect_region_box(&elaboration_reg, &general_box);
-    nrows = Rast_window_rows();
-    ncols = Rast_window_cols();
-    ew_resol = original_reg.ew_res;
-    ns_resol = original_reg.ns_res;
       | Subdividing and working with tiles:
       | Each original region will be divided into several subregions.
Modified: grass/trunk/vector/v.lidar.correction/v.lidar.correction.html
--- grass/trunk/vector/v.lidar.correction/v.lidar.correction.html	2015-01-12 12:36:33 UTC (rev 64082)
+++ grass/trunk/vector/v.lidar.correction/v.lidar.correction.html	2015-01-12 13:36:28 UTC (rev 64083)
@@ -34,9 +34,9 @@
 OBJECT DOUBLE PULSE; and an vector map with only the points classified as
 TERRAIN SINGLE PULSE or TERRAIN DOUBLE PULSE.
-The final result of the whole procedure (v.lidar.edgedetection,
-v.lidar.growing, v.lidar.correction) will be a point classification in
-four categories:
+The final result of the whole procedure (<em>v.lidar.edgedetection</em>,
+<em>v.lidar.growing</em>, <em>v.lidar.correction</em>) will be a point
+classification in four categories:
 <br>
 <br>
 TERRAIN SINGLE PULSE (cat = 1, layer = 2)
@@ -60,12 +60,18 @@
 v.lidar.correction input=correction output=correction_bis out_terrain=only_terrain_bis
 </pre></div>
 <h2>SEE ALSO</h2>
-<em><a href="v.lidar.edgedetection.html">v.lidar.edgedetection</a></em>,
-<em><a href="v.lidar.growing.html">v.lidar.growing</a></em>,
-<em><a href="v.surf.bspline.html">v.surf.bspline</a></em>
+<em>
+<a href="v.lidar.edgedetection.html">v.lidar.edgedetection</a>,
+<a href="v.lidar.growing.html">v.lidar.growing</a>,
+<a href="v.surf.bspline.html">v.surf.bspline</a>
+</em>
 <h2>AUTHORS</h2>
 Original version of program in GRASS 5.4:
 <br>
 Maria Antonia Brovelli, Massimiliano Cannata, Ulisse Longoni and Mirko Reguzzoni
@@ -92,7 +98,7 @@
 <br>
 <br>
 Brovelli M. A. and Longoni U.M., 2003. Software per il filtraggio di dati
-LIDAR, Rivista dell?Agenzia del Territorio, n. 3-2003, pp. 11-22 (ISSN 1593-2192).
+LIDAR, Rivista dell'Agenzia del Territorio, n. 3-2003, pp. 11-22 (ISSN 1593-2192).
 <br>
 <br>
 Brovelli M. A., Cannata M. and Longoni U.M., 2002. DTM LIDAR in area urbana,
Modified: grass/trunk/vector/v.lidar.edgedetection/main.c
--- grass/trunk/vector/v.lidar.edgedetection/main.c	2015-01-12 12:36:33 UTC (rev 64082)
+++ grass/trunk/vector/v.lidar.edgedetection/main.c	2015-01-12 13:36:28 UTC (rev 64083)
@@ -1,8 +1,8 @@
- * MODULE:       v.lidar.edgedetection
+ * MODULE:       v.lidar.edgedetection
  * AUTHOR(S):    Original version in GRASS 5.4 (s.edgedetection):
  * 		 Maria Antonia Brovelli, Massimiliano Cannata,
  *		 Ulisse Longoni and Mirko Reguzzoni
@@ -12,17 +12,17 @@
  * PURPOSE:      Detection of object's edges on a LIDAR data set
- * COPYRIGHT:    (C) 2006 by Politecnico di Milano -
- *               for details.
+ * COPYRIGHT:    (C) 2006 by Politecnico di Milano -
+ *               for details.
- /*INCLUDES*/
+/* INCLUDES */
 #include <stdlib.h>
 #include <string.h>
 #include <math.h>
@@ -86,21 +86,21 @@
     out_opt = G_define_standard_option(G_OPT_V_OUTPUT);
-    stepE_opt->key = "see";
     stepE_opt->answer = "4";
-    stepN_opt->key = "sen";
     stepN_opt->answer = "4";
     lambdaB_opt = G_define_option();
Modified: grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html
--- grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html	2015-01-12 12:36:33 UTC (rev 64082)
+++ grass/trunk/vector/v.lidar.edgedetection/v.lidar.edgedetection.html	2015-01-12 13:36:28 UTC (rev 64083)
@@ -65,11 +65,12 @@
 <h3>Basic edge detection</h3>
 <div class="code"><pre>
-v.lidar.edgedetection input=vector_last output=edge see=8 sen=8 lambda_g=0.5
+v.lidar.edgedetection input=vector_last output=edge ew_step=8 ns_step=8 lambda_g=0.5
 </pre></div>
 <h2>SEE ALSO</h2>
 <em>
 <a href="v.lidar.correction.html">v.lidar.correction</a>,
@@ -105,7 +106,7 @@
 <br>
 <br>
 <br>
 <br>
