[GRASS-SVN] r64088 - in grass/trunk: lib/gis raster/r.param.scale raster/r.walk
svn_grass at osgeo.org
Mon Jan 12 05:48:48 PST 2015
Author: neteler
Date: 2015-01-12 05:48:48 -0800 (Mon, 12 Jan 2015)
New Revision: 64088
grass/trunk/lib/gis/renamed_options
grass/trunk/raster/r.param.scale/interface.c
grass/trunk/raster/r.walk/main.c
r.param.scale+r.walk: parameter standardization (trac #2409)
Modified: grass/trunk/lib/gis/renamed_options
--- grass/trunk/lib/gis/renamed_options 2015-01-12 13:47:23 UTC (rev 64087)
+++ grass/trunk/lib/gis/renamed_options 2015-01-12 13:48:48 UTC (rev 64088)
@@ -278,9 +278,10 @@
# r.out.vtk
r.out.vtk|elevscale:zscale
# r.param.scale
-r.param.scale|s_tol:slope_tolerance
r.param.scale|c_tol:curvature_tolerance
r.param.scale|exp:exponent
+r.param.scale|param:method
+r.param.scale|s_tol:slope_tolerance
# r.plane
r.plane|name:output
# r.profile
@@ -396,6 +397,7 @@
r.uslek|usle_k:output
# r.walk
r.walk|coordinate:start_coordinates
+r.walk|percent_memory:memory
r.walk|start_rast:start_raster
# r.water.outlet
r.water.outlet|drainage:input
Modified: grass/trunk/raster/r.param.scale/interface.c
--- grass/trunk/raster/r.param.scale/interface.c 2015-01-12 13:47:23 UTC (rev 64087)
+++ grass/trunk/raster/r.param.scale/interface.c 2015-01-12 13:48:48 UTC (rev 64088)
@@ -96,7 +96,7 @@
win_size->options = G_store(buf);
win_size->answer = "3";
- parameter->key = "param";
+ parameter->key = "method";
parameter->description =
_("Morphometric parameter in 'size' window to calculate");
parameter->type = TYPE_STRING;
Modified: grass/trunk/raster/r.walk/main.c
--- grass/trunk/raster/r.walk/main.c 2015-01-12 13:47:23 UTC (rev 64087)
+++ grass/trunk/raster/r.walk/main.c 2015-01-12 13:48:48 UTC (rev 64088)
@@ -254,7 +254,7 @@
opt6->guisection = _("NULL cells");
opt10 = G_define_option();
- opt10->key = "percent_memory";
+ opt10->key = "memory";
opt10->type = TYPE_INTEGER;
opt10->key_desc = "value";
opt10->required = NO;
