[GRASS-SVN] r64099 - grass/branches/releasebranch_7_0/vector/v.external
svn_grass at osgeo.org
Mon Jan 12 07:52:08 PST 2015
Author: martinl
Date: 2015-01-12 07:52:08 -0800 (Mon, 12 Jan 2015)
New Revision: 64099
grass/branches/releasebranch_7_0/vector/v.external/list.c
v.external: fix -t flag output for PG format (print also geometry column)
(merge r64098 from trunk)
Modified: grass/branches/releasebranch_7_0/vector/v.external/list.c
--- grass/branches/releasebranch_7_0/vector/v.external/list.c 2015-01-12 15:46:21 UTC (rev 64098)
+++ grass/branches/releasebranch_7_0/vector/v.external/list.c 2015-01-12 15:52:08 UTC (rev 64099)
@@ -142,7 +142,7 @@
int list_layers_pg(FILE *fd, const char *conninfo, const char *table, int print_types)
int row, ntables, ret, print_schema;
- char *value_schema, *value_table;
+ char *value_schema, *value_table, *value_type, *value_column;
char *schema_name, *table_name;
PGconn *conn;
@@ -159,7 +159,7 @@
PQerrorMessage(conn));
db_init_string(&sql);
- db_set_string(&sql, "SELECT f_table_schema, f_table_name, type "
+ db_set_string(&sql, "SELECT f_table_schema, f_table_name, f_geometry_column, type "
"FROM geometry_columns ORDER BY "
"f_table_schema, f_table_name");
G_debug(2, "SQL: %s", db_get_string(&sql));
@@ -197,15 +197,16 @@
for (row = 0; row < ntables; row++) {
value_schema = PQgetvalue(res, row, 0);
value_table = PQgetvalue(res, row, 1);
+ value_column = PQgetvalue(res, row, 2);
+ value_type = PQgetvalue(res, row, 3);
if (fd) {
if (print_types) {
if (print_schema && G_strcasecmp(value_schema, "public") != 0)
- fprintf(fd, "%s.%s,%s,0\n",
- value_schema, value_table,
- feature_type(PQgetvalue(res, row, 2)));
- else
- fprintf(fd, "%s,%s,0\n", value_table,
+ fprintf(fd, "%s.", value_schema);
+ fprintf(fd, "%s,%s,0,%s\n", value_table,
+ feature_type(value_type), value_column);
else {
