[GRASS-SVN] r64140 - grass/branches/releasebranch_7_0/general/g.rename
Tue Jan 13 09:44:40 PST 2015
Author: hcho
Date: 2015-01-13 09:44:40 -0800 (Tue, 13 Jan 2015)
New Revision: 64140
   grass/branches/releasebranch_7_0/general/g.rename/main.c
g.rename: Backport the #2546 fix (updating reclassed_to)
Modified: grass/branches/releasebranch_7_0/general/g.rename/main.c
--- grass/branches/releasebranch_7_0/general/g.rename/main.c	2015-01-13 17:40:35 UTC (rev 64139)
+++ grass/branches/releasebranch_7_0/general/g.rename/main.c	2015-01-13 17:44:40 UTC (rev 64140)
@@ -3,13 +3,13 @@
  * MODULE:       g.rename
  * AUTHOR(S):    CERL (original contributor)
- *               Radim Blazek <radim.blazek gmail.com>,
- *               Cedric Shock <cedricgrass shockfamily.net>,
- *               Glynn Clements <glynn gclements.plus.com>,
- *               Markus Neteler <neteler itc.it>,
+ *               Radim Blazek <radim.blazek gmail.com>,
+ *               Cedric Shock <cedricgrass shockfamily.net>,
+ *               Glynn Clements <glynn gclements.plus.com>,
+ *               Markus Neteler <neteler itc.it>,
  *               Martin Landa <landa.martin gmail.com>,
  *               Huidae Cho <grass4u gmail.com>
- * PURPOSE:
+ * PURPOSE:      Rename map names
  * COPYRIGHT:    (C) 1994-2007, 2011-2014 by the GRASS Development Team
  *               This program is free software under the GNU General Public
@@ -25,15 +25,16 @@
 #include <grass/glocale.h>
 #include <grass/manage.h>
+void update_reclass_maps(const char *, const char *);
+void update_base_map(const char *, const char *, const char *);
 int main(int argc, char *argv[])
-    int i, n;
+    int n;
     struct GModule *module;
     struct Option **parm;
-    char *old, *new;
-    int nrmaps, nlist;
-    const char *mapset, *location_path;
-    char **rmaps;
+    int nlist;
+    const char *mapset;
     int result = EXIT_SUCCESS;
     G_gisinit(argv[0]);
@@ -57,10 +58,12 @@
     if (G_parser(argc, argv))
 	exit(EXIT_FAILURE);
-    location_path = G_location_path();
     mapset = G_mapset();
     for (n = 0; n < nlist; n++) {
+	int i;
+	char *old, *new;
 	if (parm[n]->answers == NULL)
 	    continue;
 	i = 0;
@@ -73,7 +76,7 @@
 		G_warning(_("%s <%s> not found"), M_get_list(n)->maindesc, old);
 		continue;
-	    if (M_find(n, new, "") && !(module->overwrite)) {
+	    if (M_find(n, new, mapset) && !(module->overwrite)) {
 		G_warning(_("<%s> already exists in mapset <%s>"), new,
 			  M_find(n, new, ""));
 		continue;
@@ -93,54 +96,116 @@
 		result = EXIT_FAILURE;
-	    if (!renamed && strcmp(parm[n]->key, "raster") == 0 &&
-		Rast_is_reclassed_to(old, mapset, &nrmaps, &rmaps) > 0) {
-		int ptr, l;
-		char buf1[256], buf2[256], buf3[256], *str;
-		FILE *fp;
+	    if (!renamed && strcmp(parm[n]->key, "raster") == 0) {
+		update_reclass_maps(new, mapset);
+		update_base_map(old, new, mapset);
+    exit(result);
-		G_message(_("Renaming reclass maps"));
+void update_reclass_maps(const char *name, const char *mapset)
+    int nrmaps;
+    char **rmaps;
-		for (; *rmaps; rmaps++) {
-		    G_message(" %s", *rmaps);
-		    sprintf(buf3, "%s", *rmaps);
-		    if ((str = strchr(buf3, '@'))) {
-			*str = 0;
-			sprintf(buf2, "%s", str + 1);
-		    else {
-			sprintf(buf2, "%s", mapset);
-		    sprintf(buf1, "%s/%s/cellhd/%s", location_path, buf2,
-			    buf3);
+    if (Rast_is_reclassed_to(name, mapset, &nrmaps, &rmaps) <= 0)
+	return;
-		    fp = fopen(buf1, "r");
-		    if (fp == NULL)
-			continue;
+    G_message(_("Updating reclass maps"));
-		    fgets(buf2, 255, fp);
+    for (; *rmaps; rmaps++) {
+	char buf1[256], buf2[256], buf3[256], *str;
+	FILE *fp;
+	int ptr, l;
-		    ptr = G_ftell(fp);
-		    G_fseek(fp, 0L, SEEK_END);
-		    l = G_ftell(fp) - ptr;
+	G_message(" %s", *rmaps);
+	sprintf(buf3, "%s", *rmaps);
+	if ((str = strchr(buf3, '@'))) {
+	    *str = 0;
+	    sprintf(buf2, "%s", str + 1);
+	else {
+	    sprintf(buf2, "%s", mapset);
+	G_file_name(buf1, "cellhd", buf3, buf2);
-		    str = (char *)G_malloc(l);
-		    G_fseek(fp, ptr, SEEK_SET);
-		    fread(str, l, 1, fp);
-		    fclose(fp);
+	fp = fopen(buf1, "r");
+	if (fp == NULL)
+	    continue;
-		    fp = fopen(buf1, "w");
-		    fprintf(fp, "reclass\n");
-		    fprintf(fp, "name: %s\n", new);
-		    fprintf(fp, "mapset: %s\n", mapset);
-		    fwrite(str, l, 1, fp);
-		    G_free(str);
-		    fclose(fp);
+	fgets(buf2, 255, fp);
+	ptr = G_ftell(fp);
+	G_fseek(fp, 0L, SEEK_END);
+	l = G_ftell(fp) - ptr;
+	str = (char *)G_malloc(l);
+	G_fseek(fp, ptr, SEEK_SET);
+	fread(str, l, 1, fp);
+	fclose(fp);
+	fp = fopen(buf1, "w");
+	fprintf(fp, "reclass\n");
+	fprintf(fp, "name: %s\n", name);
+	fprintf(fp, "mapset: %s\n", mapset);
+	fwrite(str, l, 1, fp);
+	G_free(str);
+	fclose(fp);
+void update_base_map(const char *old, const char *new, const char *mapset)
+    int i, nrmaps, found;
+    char bname[GNAME_MAX], bmapset[GMAPSET_MAX], rpath[GPATH_MAX];
+    char *xold, *xnew, **rmaps;
+    FILE *fp;
+    if (Rast_is_reclass(new, mapset, bname, bmapset) <= 0)
+	return;
+    if (Rast_is_reclassed_to(bname, bmapset, &nrmaps, &rmaps) <= 0)
+	nrmaps = 0;
+    found = 0;
+    xold = G_fully_qualified_name(old, mapset);
+    for (i = 0; i < nrmaps; i++) {
+	if (strcmp(xold, rmaps[i]) == 0) {
+	    found = 1;
+	    break;
-    exit(result);
+    if (!found) {
+	G_fatal_error(_("Unable to find reclass information for <%s> in "
+			"base map <%s@%s>"), xold, bname, bmapset);
+    G_message(_("Updating base map <%s@%s>"), bname, bmapset);
+    G_file_name_misc(rpath, "cell_misc", "reclassed_to", bname, bmapset);
+    fp = fopen(rpath, "w");
+    if (fp == NULL) {
+	G_fatal_error(_("Unable to update dependency file in <%s@%s>"),
+		  bname, bmapset);
+    xnew = G_fully_qualified_name(new, mapset);
+	if (strcmp(xold, *rmaps) == 0) {
+	    fprintf(fp, "%s\n", xnew);
+	else {
+	    fprintf(fp, "%s\n", *rmaps);
+    G_free(xold);
+    G_free(xnew);
+    fclose(fp);
