[GRASS-SVN] r64148 - grass/trunk/gui/wxpython/core
svn_grass at osgeo.org
Tue Jan 13 12:10:04 PST 2015
Author: martinl
Date: 2015-01-13 12:10:04 -0800 (Tue, 13 Jan 2015)
New Revision: 64148
grass/trunk/gui/wxpython/core/globalvar.py
wxGUI: modify CheckForWx() to enable selection of wxPython version (eg. 2.8 over 3.0)
Modified: grass/trunk/gui/wxpython/core/globalvar.py
--- grass/trunk/gui/wxpython/core/globalvar.py 2015-01-13 19:56:50 UTC (rev 64147)
+++ grass/trunk/gui/wxpython/core/globalvar.py 2015-01-13 20:10:04 UTC (rev 64148)
@@ -49,8 +49,11 @@
return True
-def CheckForWx():
- """Try to import wx module and check its version"""
+def CheckForWx(forceVersion = None):
+ """Try to import wx module and check its version
+ :param forceVersion: force wxPython version, eg. '2.8'
if 'wx' in sys.modules.keys():
return
@@ -60,7 +63,8 @@
import wxversion
except ImportError as e:
raise ImportError(e)
- # wxversion.select(str(minVersion[0]) + '.' + str(minVersion[1]))
+ if forceVersion:
+ wxversion.select(forceVersion)
wxversion.ensureMinimal(str(minVersion[0]) + '.' + str(minVersion[1]))
import wx
version = wx.version().split(' ')[0]
