[GRASS-SVN] r64151 - in grass/trunk: gui/wxpython/core lib/init
svn_grass at osgeo.org
Tue Jan 13 16:12:14 PST 2015
Author: martinl
Date: 2015-01-13 16:12:14 -0800 (Tue, 13 Jan 2015)
New Revision: 64151
grass/trunk/gui/wxpython/core/globalvar.py
grass/trunk/lib/init/variables.html
introduce GRASS_WXVERSION variable
Modified: grass/trunk/gui/wxpython/core/globalvar.py
--- grass/trunk/gui/wxpython/core/globalvar.py 2015-01-13 23:22:35 UTC (rev 64150)
+++ grass/trunk/gui/wxpython/core/globalvar.py 2015-01-14 00:12:14 UTC (rev 64151)
@@ -49,7 +49,7 @@
return True
-def CheckForWx(forceVersion = None):
+def CheckForWx(forceVersion = os.getenv('GRASS_WXVERSION', None)):
"""Try to import wx module and check its version
:param forceVersion: force wxPython version, eg. '2.8'
Modified: grass/trunk/lib/init/variables.html
--- grass/trunk/lib/init/variables.html 2015-01-13 23:22:35 UTC (rev 64150)
+++ grass/trunk/lib/init/variables.html 2015-01-14 00:12:14 UTC (rev 64151)
@@ -288,7 +288,16 @@
When set, the wxGUI will not check the wxPython version, as this
function is incompatible with a bundled wxPython. It is up to the
packager to make sure that a compatible wxPython version is bundled.</dd>
+ <dt>GRASS_WXVERSION</dt>
+ <dd>[wxGUI]<br>
+ set to tell wxGUI which version of wxPython to use.<br>
+ When set, the wxGUI will select the given wxPython version. It's
+ useful when multiple versions of wxPython are installed and the
+ user wants to run wxGUI with non-default wxPython version.</dd>
<dt>GRASS_XTERM</dt>
<dd>[lib/init/grass-xterm-wrapper, lib/init/grass-xterm-mac]<br>
set to any value (e.g. rxvt, aterm, gnome-terminal, konsole) to
