[GRASS-SVN] r64180 - grass/branches/releasebranch_7_0/general/g.parser
svn_grass at osgeo.org
Wed Jan 14 07:46:16 PST 2015
Author: neteler
Date: 2015-01-14 07:46:16 -0800 (Wed, 14 Jan 2015)
New Revision: 64180
grass/branches/releasebranch_7_0/general/g.parser/g.parser.html
g.parser manual: added Glynn's notes about conditional rules from http://lists.osgeo.org/pipermail/grass-dev/2014-November/071916.html
Modified: grass/branches/releasebranch_7_0/general/g.parser/g.parser.html
--- grass/branches/releasebranch_7_0/general/g.parser/g.parser.html 2015-01-14 15:45:57 UTC (rev 64179)
+++ grass/branches/releasebranch_7_0/general/g.parser/g.parser.html 2015-01-14 15:46:16 UTC (rev 64180)
@@ -112,7 +112,8 @@
#%end
</pre></div>
-The parser also allows to define "OR" conditions, e.g. requiring raster OR vector:
+The parser also allows to define "OR" conditions, e.g. requiring raster
+OR vector (for details, see below):
<div class="code"><pre>
#%rules
@@ -165,7 +166,50 @@
by <b>--o</b>, <b>--q</b> or <b>--v</b> being passed to the script or
set by other means.
+<h2>Conditional parameters</h2>
+Marking an option as "required" will result in the parser raising a
+fatal error if the option is not given, with one exception: if a flag
+has the <tt>suppress_required</tt> option, and that flag is given, all
+requirements are ignored. This feature is intended for flags which
+abandon "normal operation" for the module; e.g. <em>r.in.gdal</em>'s
+<b>-f</b> flag (list supported formats) uses it.
+<br>
+But in general, an option cannot be marked as required if it is
+optional except for the special case of a <tt>suppress_required</tt> flag.
+The parser has the ability to specify option relationships.
+<p>
+For C, the relevant functions are those in
+<a href="http://grass.osgeo.org/programming7/parser__dependencies_8c.html">lib/gis/parser_dependencies.c</a>.
+<p>
+For scripts, relationships are specified using a "rules" section, e.g.
+<div class="code"><pre>
+ #%rules
+ #%required altitude,elevation
+ #%end
+</pre></div>
+specifies that at least one of those options must be given. Both
+options and flags can be specified (a leading "<b>-</b>" denotes a flag).
+The available rule types are:
+<ul>
+<li> <tt>exclusive</tt>: at most one of the options may be given</li>
+<li> <tt>required</tt>: at least one of the options must be given</li>
+<li> <tt>requires</tt>: if the first option is given, at least one of the
+ subsequent options must also be given</li>
+<li> <tt>requires_all</tt>: if the first option is given, all of the
+<li> <tt>excludes</tt>: if the first option is given, none of the
+ subsequent options may be given</li>
+<li> <tt>collective</tt>: all or nothing; if any option is given, all
+ must be given</li>
+</ul>
<h2>AUTOMATED SCRIPT CREATION</h2>
The flag <b>--script</b> added to a GRASS command, generates shell
