[GRASS-SVN] r64203 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Thu Jan 15 13:03:10 PST 2015
Author: mmetz
Date: 2015-01-15 13:03:10 -0800 (Thu, 15 Jan 2015)
New Revision: 64203
grass/trunk/lib/vector/Vlib/find.c
Vlib: optimize Vect_find_area(), add comments
Modified: grass/trunk/lib/vector/Vlib/find.c
--- grass/trunk/lib/vector/Vlib/find.c 2015-01-15 20:54:42 UTC (rev 64202)
+++ grass/trunk/lib/vector/Vlib/find.c 2015-01-15 21:03:10 UTC (rev 64203)
@@ -287,7 +287,13 @@
Vect_select_areas_by_box(Map, &box, List);
G_debug(3, " %d areas selected by box", List->n_values);
- /* sort areas by size, the smallest is likely to be the nearest */
+ /* sort areas by bbox size
+ * get the smallest area that contains the point
+ * using the bbox size is working because if 2 areas both contain
+ * the point, one of these areas must be inside the other area
+ * which means that the bbox of the outer area must be larger than
+ * the bbox of the inner area, and equal bbox sizes are not possible */
if (alloc_size_list < List->n_values) {
alloc_size_list = List->n_values;
size_list = G_realloc(size_list, alloc_size_list * sizeof(BOX_SIZE));
@@ -314,7 +320,9 @@
for (i = 0; i < List->n_values; i++) {
area = size_list[i].i;
- ret = Vect_point_in_area(x, y, Map, area, &size_list[i].box);
+ /* testing only the outer ring is sufficient because
+ * inner rings have been tested earlier (sorted list) */
+ ret = Vect_point_in_area_outer_ring(x, y, Map, area, &size_list[i].box);
G_debug(3, " area = %d Vect_point_in_area() = %d", area, ret);
@@ -342,6 +350,8 @@
static struct boxlist *List;
static struct line_pnts *Points;
+ /* TODO: sync to Vect_find_area() */
G_debug(3, "Vect_find_island() x = %f y = %f", x, y);
if (first) {
