[GRASS-SVN] r64212 - grass-addons/grass7/raster/r.niche.similarity
svn_grass at osgeo.org
Fri Jan 16 02:56:25 PST 2015
Author: pvanbosgeo
Date: 2015-01-16 02:56:25 -0800 (Fri, 16 Jan 2015)
New Revision: 64212
grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py
added correlation, small bugfix
Modified: grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py
--- grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py 2015-01-16 08:35:04 UTC (rev 64211)
+++ grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py 2015-01-16 10:56:25 UTC (rev 64212)
@@ -4,7 +4,7 @@
# MODULE: r.niche.similarity
-# AUTHOR(S): Paulo van Breugel <paulo AT ecodiv.org>
+# AUTHOR(S): Paulo van Breugel <p.vanbreugel AT gmail.com>
# PURPOSE: Compute degree of niche overlap using the statistics D
# and I (as proposed by Warren et al., 2008) based on
# Schoeners D (Schoener, 1968) and Hellinger Distances
@@ -46,21 +46,31 @@
#%flag
#% key: i
-#% description: Calculate I niche similarity
+#% description: I niche similarity
#% guisection: Statistics
#%end
#%flag
#% key: d
-#% description: Calculate D niche similarity
+#% description: D niche similarity
#%end
+#%flag
+#% key: c
+#% description: Correlation
+#% guisection: Statistics
+#%end
+#%rules
+#%required: i,d,c
+#%end
# Test purposes
-#options = {"maps":"bio1,bio5,bio6", "output":""}
-#flags = {"i":True, "d":True}
+#options = {"maps":"bio_1,bio_5,bio_6", "output":""}
+#flags = {"i":True, "d":True, "c":True}
## STANDARD ##
@@ -77,7 +87,7 @@
# Check if running in GRASS
if not os.environ.has_key("GISBASE"):
- grass.message( "You must be in GRASS GIS to run this program." )
+ grass.message("You must be in GRASS GIS to run this program.")
sys.exit(1)
# Cleanup
@@ -86,8 +96,25 @@
def cleanup():
for rast in clean_rast:
grass.run_command("g.remove",
- type="rast", name = rast, quiet = True)
+ type="rast", name=rast, quiet=True)
+def fileexist(fname, suffix):
+ k = 0
+ fname2 = fname[:]
+ fname2 = fname2.split('.')
+ while os.path.isfile(fname):
+ k = k + 1
+ opft = fname.split('.')
+ if len(opft) == 1:
+ fname = opft[0] + "_" + str(k)
+ else:
+ fname = fname2[0] + suffix + str(k) + "." + fname2[1]
+ if k > 0:
+ grass.info("there is already a file " + fname2[0] + ".")
+ grass.info("Using " + fname + " instead")
+ return fname
## main function
@@ -102,8 +129,11 @@
OPF = options['output']
if OPF == '':
OPF = tempfile.mkstemp()[1]
+ else:
+ OPF = fileexist(OPF, "v_")
flag_i = flags['i']
flag_d = flags['d']
+ flag_c = flags['c']
## Checks
@@ -113,26 +143,6 @@
if NLAY < 2:
grass.fatal("You need to provide 2 or more raster maps")
- # Check that at least one statistic is selected
- if flag_i == '' and flag_d == '':
- grass.fatal("You need to select at least one statistic")
- # Test if text file exists. If so, append _v1 to file name
- k = 0
- OPFold = OPF[:]
- OPFold = OPFold.split('.')
- while os.path.isfile(OPF):
- k = k + 1
- opft = OPF.split('.')
- if len(opft) == 1:
- OPF = opft[0] + "_" + str(k)
- else:
- OPF = OPFold[0] + "_v" + str(k) + "." + OPFold[1]
- if k > 0:
- grass.info("there is already a file " + OPFold[0] + ".")
- grass.info("Using " + OPF + " instead")
## Calculate D and I and write to standard output (& optionally to file)
@@ -142,7 +152,7 @@
text_file.write("raster1,raster2,statistic,value" + "\n")
# Write D and I values to standard output and optionally to text file
- i=0
+ i = 0
while i < NLAY:
nlay1 = INMAPS[i]
nvar1 = VARI[i]
@@ -162,41 +172,50 @@
tmpf0 = string.replace(tmpf0, '-', '_')
clean_rast.add(tmpf0)
grass.mapcalc("$tmpf0 = abs(double($nlay1)/$vsum1 - double($nlay2)/$vsum2)",
- tmpf0 = tmpf0,
- nlay1 = nlay1,
- vsum1 = vsum1,
- nlay2 = nlay2,
- vsum2 = vsum2,
+ tmpf0=tmpf0,
+ nlay1=nlay1,
+ vsum1=vsum1,
+ nlay2=nlay2,
+ vsum2=vsum2,
quiet=True)
NO = float(grass.parse_command("r.univar", quiet=True, flags="g", map=tmpf0)['sum'])
- NOV = 1 - ( 0.5 * NO )
+ NOV = 1 - (0.5 * NO)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf0)
text_file.write("D, " + nvar1 + "," + nvar2 + "," + str(NOV) + "\n")
- grass.message("niche overlap (D) of " + nvar1 + " and " + nvar2 + ": " + str(round(NOV,3)))
+ grass.message("Niche overlap (D) of " + nvar1 + " and " + nvar2 + ": " + str(round(NOV, 3)))
- ## Calculate I (Warren et al. 2008), but note that the original formulation
- ## was corrected in erratum by Warren et al, using I = 1 - H^2 * 0.5
- ## The sqrt in the H formulation and this new ^2 cancel each other out,
- ## leading to the formulation used below.
+ ## Calculate I (Warren et al. 2008). Note that the sqrt in the
+ # H formulation and the ^2 in the I formation cancel each other out,
+ # hence the formulation below.
if flag_i:
tmpf1 = "rniche_" + str(uuid.uuid4())
tmpf1 = string.replace(tmpf1, '-', '_')
clean_rast.add(tmpf1)
grass.mapcalc("$tmpf1 = (sqrt(double($nlay1)/$vsum1) - sqrt(double($nlay2)/$vsum2))^2",
- tmpf1 = tmpf1,
- nlay1 = nlay1,
- vsum1 = vsum1,
- nlay2 = nlay2,
- vsum2 = vsum2,
+ tmpf1=tmpf1,
+ nlay1=nlay1,
+ vsum1=vsum1,
+ nlay2=nlay2,
+ vsum2=vsum2,
quiet=True)
NE = float(grass.parse_command("r.univar", quiet=True, flags="g", map=tmpf1)['sum'])
NEQ = 1 - (0.5 * NE)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf1)
text_file.write("I, " + nvar1 + "," + nvar2 + "," + str(NEQ) + "\n")
- grass.message("niche overlap (I) of " + nvar1 + " and " + nvar2 + ": " + str(round(NEQ, 3)))
+ grass.message("Niche overlap (I) of " + nvar1 + " and " + nvar2 + ": " + str(round(NEQ, 3)))
+ ## Calculate correlation
+ if flag_c:
+ corl = str(list(grass.parse_command("r.covar", flags="r", map=(nlay1,nlay2)))[0])
+ corl = float(corl.split(' ')[0])
+ text_file.write("corr, " + nvar1 + "," + nvar2 + "," + str(corl) + "\n")
+ grass.message("Correlation of " + nvar1 + " and " + nvar2 + ": " + str(round(corl, 3)))
j = j + 1
i = i + 1
