[GRASS-SVN] r64219 - grass-addons/grass7/raster/r.niche.similarity
svn_grass at osgeo.org
Fri Jan 16 05:10:27 PST 2015
Author: pvanbosgeo
Date: 2015-01-16 05:10:27 -0800 (Fri, 16 Jan 2015)
New Revision: 64219
grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py
Modified: grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py
--- grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py 2015-01-16 13:05:53 UTC (rev 64218)
+++ grass-addons/grass7/raster/r.niche.similarity/r.niche.similarity.py 2015-01-16 13:10:27 UTC (rev 64219)
@@ -181,7 +181,7 @@
NO = float(grass.parse_command("r.univar", quiet=True, flags="g", map=tmpf0)['sum'])
NOV = 1 - (0.5 * NO)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf0)
- text_file.write("D, " + nvar1 + "," + nvar2 + "," + str(NOV) + "\n")
+ text_file.write("D," + nvar1 + "," + nvar2 + "," + str(NOV) + "\n")
grass.message("Niche overlap (D) of " + nvar1 + " and " + nvar2 + ": " + str(round(NOV, 3)))
## Calculate I (Warren et al. 2008). Note that the sqrt in the
@@ -203,19 +203,19 @@
NE = float(grass.parse_command("r.univar", quiet=True, flags="g", map=tmpf1)['sum'])
NEQ = 1 - (0.5 * NE)
grass.run_command("g.remove", quiet=True, flags="f", type="raster", name=tmpf1)
- text_file.write("I, " + nvar1 + "," + nvar2 + "," + str(NEQ) + "\n")
+ text_file.write("I," + nvar1 + "," + nvar2 + "," + str(NEQ) + "\n")
grass.message("Niche overlap (I) of " + nvar1 + " and " + nvar2 + ": " + str(round(NEQ, 3)))
## Calculate correlation
if flag_c:
- corl = str(list(grass.parse_command("r.covar", flags="r", map=(nlay1,nlay2)))[0])
+ corl = str(list(grass.parse_command("r.covar", quiet=True, flags="r", map=(nlay1,nlay2)))[0])
corl = float(corl.split(' ')[0])
- text_file.write("corr, " + nvar1 + "," + nvar2 + "," + str(corl) + "\n")
+ text_file.write("corr," + nvar1 + "," + nvar2 + "," + str(corl) + "\n")
grass.message("Correlation of " + nvar1 + " and " + nvar2 + ": " + str(round(corl, 3)))
+ grass.message("--------------------------------------")
j = j + 1
i = i + 1
