[GRASS-SVN] r64225 - grass/trunk/raster/r.horizon
svn_grass at osgeo.org
Fri Jan 16 05:45:35 PST 2015
Author: neteler
Date: 2015-01-16 05:45:34 -0800 (Fri, 16 Jan 2015)
New Revision: 64225
grass/trunk/raster/r.horizon/main.c
r.horizon: bug with distant mountains not being seen: more debug
Modified: grass/trunk/raster/r.horizon/main.c
--- grass/trunk/raster/r.horizon/main.c 2015-01-16 13:42:47 UTC (rev 64224)
+++ grass/trunk/raster/r.horizon/main.c 2015-01-16 13:45:34 UTC (rev 64225)
@@ -8,7 +8,7 @@
2) For a given minimum angle it calculates one or more raster map giving the mazimum
distance to a point on the horizon.
-This program was written in 2006 by Tfomas Huld and Tomas Cebecauer,
+This program was written in 2006 by Thomas Huld and Tomas Cebecauer,
Joint Research Centre of the European Commission, based on bits of the r.sun module by Jaro Hofierka
@@ -466,7 +466,13 @@
if (sscanf(parm.maxdistance->answer, "%lf", &fixedMaxLength) != 1)
G_fatal_error(_("Could not read maximum distance. Aborting."));
+ G_debug(1,"Using maxdistance %f", fixedMaxLength); /* predefined as BIG */
+/* TODO: fixing BIG, there is a bug with distant mountains not being seen: attempt to contrain to current region
+ fixedMaxLength = (fixedMaxLength < AMAX1(deltx, delty)) ? fixedMaxLength : AMAX1(deltx, delty);
sscanf(parm.dist->answer, "%lf", &dist);
if (dist < 0.5 || dist > 1.5 ) G_fatal_error(_("The distance value must be 0.5-1.5. Aborting."));
@@ -505,7 +511,7 @@
n /* n_cols */ = new_cellhd.cols;
m /* n_rows */ = new_cellhd.rows;
- /* G_debug(3,"%lf %lf %lf %lf \n",ymax, ymin, xmin,xmax); */
+ G_debug(1,"%lf %lf %lf %lf \n",ymax, ymin, xmin,xmax);
n100 = ceil(n / 100.);
m100 = ceil(m / 100.);
@@ -541,7 +547,7 @@
INPUT();
- G_debug(3, "calculate() starts...");
+ G_debug(1, "calculate() starts...");
calculate(xcoord, ycoord, (int)(ebufferZone / stepx),
(int)(wbufferZone / stepx), (int)(sbufferZone / stepy),
(int)(nbufferZone / stepy));
@@ -606,7 +612,7 @@
z100[i][j] = zmax;
- /* G_debug(3,"%d %d %lf\n", i, j, z100[i][j]); */
+ G_debug(1,"%d %d %lf\n", i, j, z100[i][j]);
@@ -948,14 +954,14 @@
jp100 = floor(jp / 100.);
/*test the new position with low resolution */
if ((ip100 != iold100) || (jp100 != jold100)) {
- /* G_debug(3,"%d %d %d %d\n",ip,jp, iold100,jold100); */
+ G_debug(1,"ip:%d jp:%d iold100:%d jold100:%d\n",ip,jp, iold100,jold100);
/* replace with approximate version
curvature_diff = EARTHRADIUS*(1.-cos(length/EARTHRADIUS));
curvature_diff = 0.5 * length * length * invEarth;
z2 = z_orig + curvature_diff + length * tanh0;
zp100 = z100[jp100][ip100];
- /*G_debug(3,"%d %d %lf %lf \n",ip,jp,z2,zp100); */
+ G_debug(1,"ip:%d jp:%d z2:%lf zp100:%lf \n",ip,jp,z2,zp100);
if (zp100 <= z2)
/*skip to the next lowres cell */
@@ -988,11 +994,11 @@
mindel = min(delx, dely);
- /* G_debug(3,"%d %d %d %lf %lf\n",ip, jp, mindel,xg0, yg0);*/
+ G_debug(1,"%d %d %d %lf %lf\n",ip, jp, mindel,xg0, yg0);
yy0 = yy0 + (mindel * stepsinangle);
xx0 = xx0 + (mindel * stepcosangle);
- /* G_debug(3," %lf %lf\n",xx0,yy0);*/
+ G_debug(1," %lf %lf\n",xx0,yy0);
return (3);
@@ -1108,8 +1114,8 @@
coslatsq = coslat * coslat;
- G_debug(3, "yindex: %d, xindex %d", yindex, xindex);
z_orig = zp = z[yindex][xindex];
+ G_debug(1, "yindex: %d, xindex %d, z_orig %.2f", yindex, xindex, z_orig);
calculate_shadow();
fclose(fp);
@@ -1241,12 +1247,11 @@
z_orig = zp = z[j][i];
maxlength = (zmax - z_orig) / TANMINANGLE;
maxlength =
- (maxlength <
- fixedMaxLength) ? maxlength : fixedMaxLength;
+ (maxlength < fixedMaxLength) ? maxlength : fixedMaxLength;
if (z_orig != UNDEFZ) {
- /* G_debug(3,"**************new line %d %d\n", i, j); */
+ G_debug(1,"**************new line %d %d\n", i, j);
shadow_angle = horizon_height();
if (degreeOutput) {
@@ -1256,7 +1261,7 @@
if((j==1400)&&(i==1400))
- G_debug(3, "coordinates=%f,%f, raster no. %d, horizon=%f\n",
+ G_debug(1, "coordinates=%f,%f, raster no. %d, horizon=%f\n",
xp, yp, k, shadow_angle);
@@ -1267,7 +1272,7 @@
- G_debug(3, "OUTGR() starts...");
+ G_debug(1, "OUTGR() starts...");
OUTGR(cellhd.rows, cellhd.cols);
/* empty array */
