[GRASS-SVN] r64234 - grass/trunk/vector/v.generalize
svn_grass at osgeo.org
Sun Jan 18 15:14:52 PST 2015
Author: mmetz
Date: 2015-01-18 15:14:52 -0800 (Sun, 18 Jan 2015)
New Revision: 64234
grass/trunk/vector/v.generalize/main.c
grass/trunk/vector/v.generalize/misc.c
grass/trunk/vector/v.generalize/misc.h
v.generalze: add extremely fast mode (default) and exremely slow mode (debugging)
Modified: grass/trunk/vector/v.generalize/main.c
--- grass/trunk/vector/v.generalize/main.c 2015-01-18 22:10:31 UTC (rev 64233)
+++ grass/trunk/vector/v.generalize/main.c 2015-01-18 23:14:52 UTC (rev 64234)
@@ -334,14 +334,14 @@
G_fatal_error(_("Unable to create vector map <%s>"), map_out->answer);
- if(error_out->answer)
+ if (error_out->answer) {
if (0 > Vect_open_new(&Error, error_out->answer, with_z)) {
Vect_close(&In);
G_fatal_error(_("Unable to create error vector map <%s>"), error_out->answer);
Vect_copy_head_data(&In, &Out);
Vect_hist_copy(&In, &Out);
Vect_hist_command(&Out);
@@ -391,6 +391,8 @@
int not_modified_boundaries = 0, n_oversimplified = 0;
struct line_pnts *APoints; /* original Points */
+ set_topo_debug();
Vect_copy_map_lines(&In, &Out);
Vect_build_partial(&Out, GV_BUILD_CENTROIDS);
Modified: grass/trunk/vector/v.generalize/misc.c
--- grass/trunk/vector/v.generalize/misc.c 2015-01-18 22:10:31 UTC (rev 64233)
+++ grass/trunk/vector/v.generalize/misc.c 2015-01-18 23:14:52 UTC (rev 64234)
@@ -24,6 +24,16 @@
#include <grass/glocale.h>
#include "misc.h"
+static int topo_debug = 0;
+int set_topo_debug(void)
+ if (getenv("GRASS_VECTOR_TOPO_DEBUG"))
+ topo_debug = 1;
+ return topo_debug;
int type_mask(struct Option *type_opt)
int res = 0;
@@ -187,14 +197,22 @@
return 1;
+static int cmp(const void *a, const void *b)
+ int ai = *(int *)a;
+ int bi = *(int *)b;
+ return (ai - bi);
/* check topology corruption by boundary modification
* return 0 on corruption, 1 if modification is ok */
int check_topo(struct Map_info *Out, int line, struct line_pnts *APoints,
struct line_pnts *Points, struct line_cats *Cats)
- int i, j, intersect, newline, left_old, right_old,
- left_new, right_new;
- struct bound_box box, abox;
+ int i, j, k, intersect, newline;
+ struct bound_box box, abox, tbox;
+ struct bound_box lbox, rbox, areabox;
struct line_pnts **AXLines, **BXLines;
int naxlines, nbxlines;
static struct line_pnts *BPoints = NULL;
@@ -202,13 +220,17 @@
static struct line_pnts *BPoints2 = NULL;
static struct ilist *BList = NULL;
int area, isle, centr;
+ int left_o, left_n, right_o, right_n;
int node, node_n_lines;
float angle1, angle2;
+ off_t offset;
+ /* topology debugging */
+ int area_l_o, area_r_o, area_l_n, area_r_n;
+ int centr_l_o, centr_r_o, centr_l_n, centr_r_n;
+ int *isles_l_o, nisles_l_o, *isles_l_n, nisles_l_n;
+ int *isles_r_o, nisles_r_o, *isles_r_n, nisles_r_n;
+ int found;
- /* order of tests:
- * first: fast tests
- * last: tests that can only be done after writing out the new line */
if (!BPoints) {
BPoints = Vect_new_line_struct();
BPoints2 = Vect_new_line_struct();
@@ -229,8 +251,18 @@
return 1;
+ i = APoints->n_points - 1;
+ if (APoints->x[0] == APoints->x[i] && APoints->y[0] == APoints->y[i]) {
+ i = Points->n_points - 1;
+ if (Points->x[0] != Points->x[i] || Points->y[0] != Points->y[i]) {
+ /* input line forms a loop, output not */
+ return 0;
/* test node angles
- * same like dig_build_area_with_line() */
+ * an area can be built only if there are no two lines with the same
+ * angle at the same node */
/* line start */
angle1 = dig_calc_begin_angle(Points, 0);
if (angle1 == -9)
@@ -257,14 +289,17 @@
return 0;
- if (angle1 == angle2 &&
- Points->x[0] == Points->x[i] && Points->y[0] == Points->y[i]) {
- /* same angle, same start and end coordinates,
- * an area can not be constructed -> error */
- return 0;
+ if (Points->x[0] == Points->x[i] && Points->y[0] == Points->y[i]) {
+ if (angle1 == angle2) {
+ /* same angle, same start and end coordinates,
+ * an area can not be constructed -> error */
+ return 0;
+ else {
+ node = dig_find_node(&(Out->plus), Points->x[i], Points->y[i], Points->z[i]);
- node = dig_find_node(&(Out->plus), Points->x[i], Points->y[i], Points->z[i]);
if (node) {
/* if another line exists with the same angle at this node,
@@ -347,20 +382,47 @@
if (intersect)
return 0;
- /* the point-in-poly tests are needed to avoid some cases up duplicate centroids */
- Vect_get_line_areas(Out, line, &left_old, &right_old);
+ /* test centroid attachment (point-in-poly) */
+ Vect_get_line_areas(Out, line, &left_o, &right_o);
Vect_line_box(APoints, &abox);
/* centroid on the left side */
isle = centr = 0;
- area = left_old;
+ area = left_o;
if (area < 0) {
isle = -area;
area = Vect_get_isle_area(Out, isle);
if (area > 0)
centr = Vect_get_area_centroid(Out, area);
+ centr_l_o = centr;
+ area_l_o = area;
+ lbox = box;
+ if (isle)
+ Vect_get_isle_boundaries(Out, isle, BList);
+ else
+ Vect_get_area_boundaries(Out, area, BList);
+ Vect_reset_line(BPoints2);
+ for (i = 0; i < BList->n_values; i++) {
+ int bline = BList->value[i];
+ int dir = bline > 0 ? GV_FORWARD : GV_BACKWARD;
+ if (abs(bline) != line) {
+ Vect_read_line(Out, BPoints, NULL, abs(bline));
+ Vect_line_box(BPoints, &tbox);
+ Vect_box_extend(&lbox, &tbox);
+ Vect_append_points(BPoints2, BPoints, dir);
+ else
+ Vect_append_points(BPoints2, Points, dir);
+ BPoints2->n_points--; /* skip last point, avoids duplicates */
+ BPoints2->n_points++; /* close polygon */
if (centr > 0) {
int ret;
double cx, cy, cz;
@@ -369,36 +431,14 @@
cx = BPoints->x[0];
cy = BPoints->y[0];
cz = BPoints->z[0];
- if (1 || Vect_point_in_box(cx, cy, cz, &box) ||
+ if (Vect_point_in_box(cx, cy, cz, &box) ||
Vect_point_in_box(cx, cy, cz, &abox)) {
- if (isle)
- Vect_get_isle_boundaries(Out, isle, BList);
- else
- Vect_get_area_boundaries(Out, area, BList);
- Vect_reset_line(BPoints2);
- for (i = 0; i < BList->n_values; i++) {
- int bline = BList->value[i];
- int dir = bline > 0 ? GV_FORWARD : GV_BACKWARD;
- if (abs(bline) != line) {
- Vect_read_line(Out, BPoints, NULL, abs(bline));
- Vect_append_points(BPoints2, BPoints, dir);
- else
- Vect_append_points(BPoints2, Points, dir);
- BPoints2->n_points--; /* skip last point, avoids duplicates */
- BPoints2->n_points++; /* close polygon */
ret = Vect_point_in_poly(cx, cy, BPoints2);
- /* see Vect_point_in_area() */
if (!isle) {
/* area: centroid must be inside */
- if (ret == 0)
+ if (ret != 1)
return 0;
else {
@@ -408,17 +448,43 @@
- left_old = centr;
/* centroid on the right side */
isle = centr = 0;
- area = right_old;
+ area = right_o;
if (area < 0) {
isle = -area;
if (area > 0)
+ centr_r_o = centr;
+ area_r_o = area;
+ rbox = box;
+ if (isle)
+ else
+ Vect_box_extend(&rbox, &tbox);
+ else
if (centr > 0) {
int ret;
double cx, cy, cz;
@@ -427,36 +493,14 @@
cx = BPoints->x[0];
cy = BPoints->y[0];
cz = BPoints->z[0];
- if (isle)
- else
- else
if (!isle) {
- if (ret == 0)
+ if (ret != 1)
return 0;
else {
@@ -466,34 +510,346 @@
- right_old = centr;
+ /* all fine:
+ * areas/isles can be built
+ * no intersection with another boundary, e.g. isle attachment will be preserved
+ * centroids are still on the correct side of the boundary */
+ if (!topo_debug) {
+ /* update only those parts of topology that actually get changed */
+ /* boundary:
+ * node in case of loop support
+ * node angles
+ * bounding box */
+ /* rewrite boundary on level 1 */
+ offset = Out->plus.Line[line]->offset;
+ Out->level = 1;
+ offset = Vect_rewrite_line(Out, offset, GV_BOUNDARY, Points, Cats);
+ Out->level = 2;
+ /* delete line from topo */
+ dig_del_line(&Out->plus, line, APoints->x[0], APoints->y[0], APoints->z[0]);
+ /* restore line in topo */
+ dig_restore_line(&Out->plus, line, GV_BOUNDARY, Points, &box, offset);
+ /* update area/isle box to the left */
+ if (left_o < 0) {
+ dig_spidx_del_isle(&Out->plus, -left_o);
+ dig_spidx_add_isle(&Out->plus, -left_o, &lbox);
+ else if (left_o > 0) {
+ dig_spidx_del_area(&Out->plus, left_o);
+ dig_spidx_add_area(&Out->plus, left_o, &lbox);
+ /* update area/isle box to the right */
+ if (right_o < 0) {
+ dig_spidx_del_isle(&Out->plus, -right_o);
+ dig_spidx_add_isle(&Out->plus, -right_o, &rbox);
+ else if (right_o > 0) {
+ dig_spidx_del_area(&Out->plus, right_o);
+ dig_spidx_add_area(&Out->plus, right_o, &rbox);
+ /* done */
+ return 1;
+ /* debug topology */
+ /* record isles of the old areas to the left and right */
+ nisles_l_o = 0;
+ isles_l_o = NULL;
+ if (area_l_o) {
+ nisles_l_o = Out->plus.Area[area_l_o]->n_isles;
+ if (nisles_l_o) {
+ isles_l_o = G_malloc(nisles_l_o * sizeof(int));
+ for (i = 0; i < nisles_l_o; i++) {
+ isles_l_o[i] = Out->plus.Area[area_l_o]->isles[i];
+ qsort(isles_l_o, nisles_l_o, sizeof(int), cmp);
+ nisles_r_o = 0;
+ isles_r_o = NULL;
+ if (area_r_o) {
+ nisles_r_o = Out->plus.Area[area_r_o]->n_isles;
+ if (nisles_r_o) {
+ isles_r_o = G_malloc(nisles_r_o * sizeof(int));
+ for (i = 0; i < nisles_r_o; i++) {
+ isles_r_o[i] = Out->plus.Area[area_r_o]->isles[i];
+ qsort(isles_r_o, nisles_r_o, sizeof(int), cmp);
/* OK, rewrite modified boundary */
newline = Vect_rewrite_line(Out, line, GV_BOUNDARY, Points, Cats);
+ if (newline != line)
+ G_fatal_error("Vect_rewrite_line(): new line id %d != old line id %d",
+ newline, line);
+ /* get new area and centroid ids to the left and right */
+ centr_l_n = centr_r_n = 0;
+ Vect_get_line_areas(Out, newline, &left_n, &right_n);
+ area = left_n;
+ if (area < 0)
+ area = Vect_get_isle_area(Out, -area);
+ if (area > 0)
+ centr_l_n = Vect_get_area_centroid(Out, area);
+ area_l_n = area;
+ area = right_n;
+ if (area < 0)
+ if (area > 0)
+ centr_r_n = Vect_get_area_centroid(Out, area);
+ area_r_n = area;
+ /* record isles of the new areas to the left and right */
+ nisles_l_n = 0;
+ isles_l_n = NULL;
+ if (area_l_n) {
+ nisles_l_n = Out->plus.Area[area_l_n]->n_isles;
+ if (nisles_l_n) {
+ isles_l_n = G_malloc(nisles_l_n * sizeof(int));
+ for (i = 0; i < nisles_l_n; i++) {
+ isles_l_n[i] = Out->plus.Area[area_l_n]->isles[i];
+ qsort(isles_l_n, nisles_l_n, sizeof(int), cmp);
+ nisles_r_n = 0;
+ isles_r_n = NULL;
+ if (area_r_n) {
+ nisles_r_n = Out->plus.Area[area_r_n]->n_isles;
+ if (nisles_r_n) {
+ isles_r_n = G_malloc(nisles_r_n * sizeof(int));
+ for (i = 0; i < nisles_r_n; i++) {
+ isles_r_n[i] = Out->plus.Area[area_r_n]->isles[i];
+ qsort(isles_r_n, nisles_r_n, sizeof(int), cmp);
+ /* compare isle numbers and ids on the left and right */
+ /* left */
+ if (nisles_l_o != nisles_l_n)
+ G_fatal_error("Number of isles to the left differ: old %d, new %d",
+ nisles_l_o, nisles_l_n);
+ found = 0;
+ k = 0;
+ if (isles_l_o[i] != isles_l_n[k]) {
+ if (!found) {
+ found = 1;
+ k--;
+ else {
+ for (j = 0; j < nisles_l_o; j++) {
+ G_message("old %d new %d", isles_l_o[j], isles_l_n[j]);
+ G_fatal_error("New isle to the left %d is wrong",
+ isles_l_n[i]);
+ k++;
+ /* right */
+ if (nisles_r_o != nisles_r_n)
+ nisles_r_o, nisles_r_n);
+ found = 0;
+ k = 0;
+ if (isles_r_o[i] != isles_r_n[k]) {
+ if (!found) {
+ found = 1;
+ k--;
+ else {
+ for (j = 0; j < nisles_r_o; j++) {
+ G_message("old %d new %d", isles_r_o[j], isles_r_n[j]);
+ G_fatal_error("New isle to the right %d is wrong",
+ isles_l_n[i]);
+ k++;
/* Check position of centroids */
- Vect_get_line_areas(Out, newline, &left_new, &right_new);
- if (left_new < 0)
- left_new = Vect_get_isle_area(Out, abs(left_new));
- if (left_new > 0)
- left_new = Vect_get_area_centroid(Out, left_new);
- if (right_new < 0)
- right_new = Vect_get_isle_area(Out, abs(right_new));
- if (right_new > 0)
- right_new = Vect_get_area_centroid(Out, right_new);
+ if (centr_l_n != centr_l_o || centr_r_n != centr_r_o) {
+ G_debug(1, "The modified boundary changes attachment of centroid -> not modified");
- if (left_new != left_old || right_new != right_old) {
- G_debug(3,
- "The modified boundary changes attachment of centroid -> not modified");
+ if (centr_l_n != centr_l_o) {
+ G_debug(1, "*************************************");
+ G_debug(1, "Left area/isle old: %d, new: %d", left_o, left_n);
+ G_debug(1, "Left centroid old: %d, new: %d", centr_l_o, centr_l_n);
- G_debug(1, "Left centroid old: %d, new: %d", left_old, left_new);
- G_debug(1, "Right centroid old: %d, new: %d", right_old, right_new);
- G_debug(1, "New areas left: %d, right: %d", left_new, right_new);
+ if (centr_l_o) {
+ int ret1, ret2, ret3;
- Vect_rewrite_line(Out, newline, GV_BOUNDARY, APoints, Cats);
+ Vect_read_line(Out, BPoints, NULL, centr_l_o);
+ Vect_get_area_box(Out, area_l_n, &abox);
+ ret1 = (BPoints->x[0] >= abox.W && BPoints->x[0] <= abox.E &&
+ BPoints->y[0] >= abox.S && BPoints->y[0] <= abox.N);
+ ret2 = Vect_point_in_area_outer_ring(BPoints->x[0], BPoints->y[0], Out,
+ area_l_n, &abox);
+ Vect_get_area_points(Out, area_l_n, BPoints2);
+ ret3 = Vect_point_in_poly(BPoints->x[0], BPoints->y[0], BPoints2);
+ if (ret2 != ret3) {
+ G_warning("Left old centroid in new area box: %d", ret1);
+ G_warning("Left old centroid in new area as poly: %d", ret2);
+ G_warning("Left old centroid in new area outer ring: %d", ret3);
+ if (centr_r_n != centr_r_o) {
+ G_debug(1, "Right area/isle old: %d, new: %d", right_o, right_n);
+ G_debug(1, "Right centroid old: %d, new: %d", centr_r_o, centr_r_n);
+ if (centr_r_o) {
+ Vect_read_line(Out, BPoints, NULL, centr_r_o);
+ Vect_get_area_box(Out, area_r_n, &abox);
+ area_r_n, &abox);
+ Vect_get_area_points(Out, area_r_n, BPoints2);
+ G_warning("Right old centroid in new area box: %d", ret1);
+ G_warning("Right old centroid in new area as poly: %d", ret2);
+ G_warning("Right old centroid in new area outer ring: %d", ret3);
+ /* rewrite old line */
+ newline = Vect_rewrite_line(Out, newline, GV_BOUNDARY, APoints, Cats);
+ Vect_get_line_areas(Out, newline, &area_l_n, &area_r_n);
+ area = area_l_n;
+ if (area < 0)
+ if (area > 0)
+ area_l_n = area;
+ area = area_r_n;
+ if (area < 0)
+ if (area > 0)
+ area_r_n = area;
+ Vect_get_area_box(Out, area_l_n, &areabox);
+ if (centr_l_n > 0) {
+ Vect_read_line(Out, BPoints, NULL, centr_l_n);
+ if (Vect_point_in_area(BPoints->x[0], BPoints->y[0], Out,
+ area_l_n, &areabox)) {
+ G_warning("New left centroid is in new left area");
+ G_warning("New left centroid on outer ring: %d",
+ Vect_point_in_area_outer_ring(BPoints->x[0], BPoints->y[0], Out,
+ area_l_n, &areabox));
+ G_warning("Best area for new left centroid: %d",
+ Vect_find_area(Out, BPoints->x[0], BPoints->y[0]));
+ else
+ G_warning("New left centroid is not in new left area");
+ if (centr_l_o > 0) {
+ G_warning("Old left centroid is in new left area");
+ G_warning("Old left centroid on outer ring: %d",
+ G_warning("Best area for old left centroid: %d",
+ else
+ G_warning("Old left centroid is not in new left area");
+ G_fatal_error("Left centroid old %d, restored %d", centr_l_o, centr_l_n);
+ Vect_get_area_box(Out, area_r_n, &areabox);
+ if (centr_r_n > 0) {
+ Vect_read_line(Out, BPoints, NULL, centr_r_n);
+ area_r_n, &areabox)) {
+ G_warning("New right centroid is in new right area");
+ G_warning("New right centroid on outer ring: %d",
+ area_r_n, &areabox));
+ G_warning("Best area for new right centroid: %d",
+ else
+ G_warning("New right centroid is not in new right area");
+ if (centr_r_o > 0) {
+ G_warning("Old right centroid is in new right area");
+ G_warning("Old right centroid on outer ring: %d",
+ G_warning("Best area for old right centroid: %d",
+ else
+ G_warning("Old right centroid is not in new right area");
+ G_fatal_error("Right centroid old %d, restored %d", centr_r_o, centr_r_n);
return 0;
+ if (isles_l_o)
+ G_free(isles_l_o);
+ if (isles_r_o)
+ G_free(isles_r_o);
+ if (isles_l_n)
+ G_free(isles_l_n);
+ if (isles_r_n)
+ G_free(isles_r_n);
return 1;
Modified: grass/trunk/vector/v.generalize/misc.h
--- grass/trunk/vector/v.generalize/misc.h 2015-01-18 22:10:31 UTC (rev 64233)
+++ grass/trunk/vector/v.generalize/misc.h 2015-01-18 23:14:52 UTC (rev 64234)
@@ -6,22 +6,23 @@
/* returns bitmask for all the types specified in type_opt
* e.g GV_LINE | GV_BOUNDARY
-extern int type_mask(struct Option *type_opt);
+int type_mask(struct Option *type_opt);
/* returns the squared distance and the index of the point furthest
* from the line segment Points[a], Points[b] such that the
* index of this points is in [a,b]
-extern int get_furthest(struct line_pnts *Points, int a, int b, int with_z,
+int get_furthest(struct line_pnts *Points, int a, int b, int with_z,
double *dist);
/* copy attributes of In which appear in Out */
/* returns 1 on success, 0 on failure */
-extern int copy_tables_by_cats(struct Map_info *In, struct Map_info *Out);
+int copy_tables_by_cats(struct Map_info *In, struct Map_info *Out);
int check_topo(struct Map_info *, int, struct line_pnts *,
struct line_pnts *, struct line_cats *);
+int set_topo_debug(void);
#endif
