[GRASS-SVN] r64254 - grass-addons/grass7/imagery/i.spec.sam
svn_grass at osgeo.org
Tue Jan 20 06:43:50 PST 2015
Author: ychemin
Date: 2015-01-20 06:43:49 -0800 (Tue, 20 Jan 2015)
New Revision: 64254
Removed:
grass-addons/grass7/imagery/i.spec.sam/err.h
grass-addons/grass7/imagery/i.spec.sam/machine.h
grass-addons/grass7/imagery/i.spec.sam/matrix.h
grass-addons/grass7/imagery/i.spec.sam/matrix2.h
grass-addons/grass7/imagery/i.spec.sam/meminfo.h
grass-addons/grass7/imagery/i.spec.sam/Makefile
grass-addons/grass7/imagery/i.spec.sam/main.c
grass-addons/grass7/imagery/i.spec.sam/open.c
grass-addons/grass7/imagery/i.spec.sam/spec_angle.c
fixed by linking to meschach library directly (Ubuntu: libmeschach)
Modified: grass-addons/grass7/imagery/i.spec.sam/Makefile
--- grass-addons/grass7/imagery/i.spec.sam/Makefile 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/Makefile 2015-01-20 14:43:49 UTC (rev 64254)
@@ -2,11 +2,10 @@
PGM = i.spec.sam
-EXTRALIB = meschach.a
-LIBES = $(IMAGERYLIB) $(GMATHLIB) $(RASTERLIB) $(GISLIB)
+LIBES = $(IMAGERYLIB) $(GMATHLIB) $(RASTERLIB) $(GISLIB) -lmeschach
DEPENDENCIES= $(IMAGERYDEP) $(GMATHDEP) $(RASTERDEP) $(GISDEP)
-EXTRA_INC = $(VECT_INC) $(PROJINC)
+EXTRA_INC = -I/usr/include/meschach
include $(MODULE_TOPDIR)/include/Make/Module.make
Deleted: grass-addons/grass7/imagery/i.spec.sam/err.h
--- grass-addons/grass7/imagery/i.spec.sam/err.h 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/err.h 2015-01-20 14:43:49 UTC (rev 64254)
@@ -1,183 +0,0 @@
-** Copyright (C) 1993 David E. Stewart & Zbigniew Leyk, all rights reserved.
-** Meschach Library
-** This Meschach Library is provided "as is" without any express
-** or implied warranty of any kind with respect to this software.
-** In particular the authors shall not be liable for any direct,
-** indirect, special, incidental or consequential damages arising
-** in any way from use of the software.
-** Everyone is granted permission to copy, modify and redistribute this
-** Meschach Library, provided:
-** 1. All copies contain this copyright notice.
-** 2. All modified copies shall carry a notice stating who
-** made the last modification and the date of such modification.
-** 3. No charge is made for this software or works derived from it.
-** This clause shall not be construed as constraining other software
-** distributed on the same medium as this software, nor is a
-** distribution fee considered a charge.
-/* err.h 28/09/1993 */
-/* RCS id: $Id: err.h,v 1.2 1995/01/30 14:48:05 des Exp $ */
-#ifndef ERRHEADER
-#define ERRHEADER
-#include <setjmp.h>
-#include "machine.h"
-/* Error recovery */
-extern jmp_buf restart;
-/* max. # of error lists */
-#define ERR_LIST_MAX_LEN 10
-/* main error functions */
-#ifndef ANSI_C
-extern int ev_err(); /* main error handler */
-extern int set_err_flag(); /* for different ways of handling
- errors, returns old value */
-extern int count_errs(); /* to avoid "too many errors" */
-extern int err_list_attach(); /* for attaching a list of errors */
-extern int err_is_list_attached(); /* checking if a list is attached */
-extern int err_list_free(); /* freeing a list of errors */
-#else /* ANSI_C */
-extern int ev_err(char *,int,int,char *,int); /* main error handler */
-extern int set_err_flag(int flag); /* for different ways of handling
-extern int count_errs(int true_false); /* to avoid "too many errors" */
-extern int err_list_attach(int list_num, int list_len,
- char **err_ptr,int warn); /* for attaching a list of errors */
-extern int err_is_list_attached(int list_num); /* checking if a list
- is attached */
-extern int err_list_free(int list_num); /* freeing a list of errors */
-#endif
-/* error(E_TYPE,"myfunc") raises error type E_TYPE for function my_func() */
-#define error(err_num,fn_name) ev_err(__FILE__,err_num,__LINE__,fn_name,0)
-/* warning(WARN_TYPE,"myfunc") raises warning type WARN_TYPE for
- function my_func() */
-#define warning(err_num,fn_name) ev_err(__FILE__,err_num,__LINE__,fn_name,1)
-/* error flags */
-#define EF_EXIT 0 /* exit on error */
-#define EF_ABORT 1 /* abort (dump core) on error */
-#define EF_JUMP 2 /* jump on error */
-#define EF_SILENT 3 /* jump, but don't print message */
-#define ERREXIT() set_err_flag(EF_EXIT)
-#define ERRABORT() set_err_flag(EF_ABORT)
-/* don't print message */
-#define SILENTERR() if ( ! setjmp(restart) ) set_err_flag(EF_SILENT)
-/* return here on error */
-#define ON_ERROR() if ( ! setjmp(restart) ) set_err_flag(EF_JUMP)
-/* error types */
-#define E_UNKNOWN 0
-#define E_SIZES 1
-#define E_BOUNDS 2
-#define E_MEM 3
-#define E_SING 4
-#define E_POSDEF 5
-#define E_FORMAT 6
-#define E_INPUT 7
-#define E_NULL 8
-#define E_SQUARE 9
-#define E_RANGE 10
-#define E_INSITU2 11
-#define E_INSITU 12
-#define E_ITER 13
-#define E_CONV 14
-#define E_START 15
-#define E_SIGNAL 16
-#define E_INTERN 17
-#define E_EOF 18
-#define E_SHARED_VECS 19
-#define E_NEG 20
-#define E_OVERWRITE 21
-#define E_BREAKDOWN 22
-/* warning types */
-#define WARN_UNKNOWN 0
-#define WARN_WRONG_TYPE 1
-#define WARN_NO_MARK 2
-#define WARN_RES_LESS_0 3
-#define WARN_SHARED_VEC 4
-/* error catching macros */
-/* execute err_part if error errnum is raised while executing ok_part */
-#define catch(errnum,ok_part,err_part) \
- { jmp_buf _save; int _err_num, _old_flag; \
- _old_flag = set_err_flag(EF_SILENT); \
- MEM_COPY(restart,_save,sizeof(jmp_buf)); \
- if ( (_err_num=setjmp(restart)) == 0 ) \
- { ok_part; \
- set_err_flag(_old_flag); \
- MEM_COPY(_save,restart,sizeof(jmp_buf)); } \
- else if ( _err_num == errnum ) \
- { set_err_flag(_old_flag); \
- MEM_COPY(_save,restart,sizeof(jmp_buf)); \
- err_part; } \
- else { set_err_flag(_old_flag); \
- error(_err_num,"catch"); \
-/* execute err_part if any error raised while executing ok_part */
-#define catchall(ok_part,err_part) \
- { ok_part; \
- else \
- err_part; } \
-/* print message if error raised while executing ok_part,
- then re-raise error to trace calls */
-#define tracecatch(ok_part,function) \
- _old_flag = set_err_flag(EF_JUMP); \
- { ok_part; \
- else \
- error(_err_num,function); } \
-#endif /* ERRHEADER */
Deleted: grass-addons/grass7/imagery/i.spec.sam/machine.h
--- grass-addons/grass7/imagery/i.spec.sam/machine.h 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/machine.h 2015-01-20 14:43:49 UTC (rev 64254)
@@ -1,193 +0,0 @@
-/* machine.h. Generated automatically by configure. */
-/* Any machine specific stuff goes here */
-/* Add details necessary for your own installation here! */
-/* This is for use with "configure" -- if you are not using configure
- then use machine.van for the "vanilla" version of machine.h */
-/* Note special macros: ANSI_C (ANSI C syntax)
- SEGMENTED (segmented memory machine e.g. MS-DOS)
- MALLOCDECL (declared if malloc() etc have
- been declared) */
-/* #undef const */
-/* #undef MALLOCDECL */
-#define NOT_SEGMENTED 1
-/* #undef HAVE_COMPLEX_H */
-#define HAVE_MALLOC_H 1
-#define STDC_HEADERS 1
-#define HAVE_BCOPY 1
-#define HAVE_BZERO 1
-#define CHAR0ISDBL0 1
-/* #undef WORDS_BIGENDIAN */
-#define U_INT_DEF 1
-#define VARARGS 1
-/* for basic or larger versions */
-#define COMPLEX 1
-#define SPARSE 1
-/* for loop unrolling */
-/* #undef VUNROLL */
-/* #undef MUNROLL */
-/* for segmented memory */
-#ifndef NOT_SEGMENTED
-#define SEGMENTED
-#endif
-/* if the system has malloc.h */
-#ifdef HAVE_MALLOC_H
-#define MALLOCDECL 1
-#include <malloc.h>
-#endif
-/* any compiler should have this header */
-/* if not, change it */
-#include <stdio.h>
-/* Check for ANSI C memmove and memset */
-#ifdef STDC_HEADERS
-/* standard copy & zero functions */
-#define MEM_COPY(from,to,size) memmove((to),(from),(size))
-#define MEM_ZERO(where,size) memset((where),'\0',(size))
-#ifndef ANSI_C
-#define ANSI_C 1
-#endif
-#endif
-/* standard headers */
-#ifdef ANSI_C
-#include <stdlib.h>
-#include <stddef.h>
-#include <string.h>
-#include <float.h>
-#endif
-/* if have bcopy & bzero and no alternatives yet known, use them */
-#ifdef HAVE_BCOPY
-#ifndef MEM_COPY
-/* nonstandard copy function */
-#define MEM_COPY(from,to,size) bcopy((char *)(from),(char *)(to),(int)(size))
-#endif
-#endif
-#ifdef HAVE_BZERO
-#ifndef MEM_ZERO
-/* nonstandard zero function */
-#define MEM_ZERO(where,size) bzero((char *)(where),(int)(size))
-#endif
-#endif
-/* if the system has complex.h */
-#ifdef HAVE_COMPLEX_H
-#include <complex.h>
-#endif
-/* If prototypes are available & ANSI_C not yet defined, then define it,
- but don't include any header files as the proper ANSI C headers
- aren't here */
-#define HAVE_PROTOTYPES 1
-#ifdef HAVE_PROTOTYPES
-#ifndef ANSI_C
-#define ANSI_C 1
-#endif
-#endif
-/* floating point precision */
-/* you can choose single, double or long double (if available) precision */
-#define FLOAT 1
-#define DOUBLE 2
-#define LONG_DOUBLE 3
-/* #undef REAL_FLT */
-/* #undef REAL_DBL */
-/* if nothing is defined, choose double precision */
-#ifndef REAL_DBL
-#ifndef REAL_FLT
-#define REAL_DBL 1
-#endif
-#endif
-/* single precision */
-#ifdef REAL_FLT
-#define RReal float
-#define LongReal float
-#define REAL FLOAT
-#define LONGREAL FLOAT
-#endif
-/* double precision */
-#ifdef REAL_DBL
-#define RReal double
-#define LongReal double
-#define REAL DOUBLE
-#define LONGREAL DOUBLE
-#endif
-/* machine epsilon or unit roundoff error */
-/* This is correct on most IEEE Real precision systems */
-#ifdef DBL_EPSILON
-#if REAL == DOUBLE
-#define MACHEPS DBL_EPSILON
-#elif REAL == FLOAT
-#define MACHEPS FLT_EPSILON
-#elif REAL == LONGDOUBLE
-#define MACHEPS LDBL_EPSILON
-#endif
-#endif
-#define F_MACHEPS 1.19209e-07
-#define D_MACHEPS 2.22045e-16
-#ifndef MACHEPS
-#if REAL == DOUBLE
-#define MACHEPS D_MACHEPS
-#define MACHEPS F_MACHEPS
-#endif
-#endif
-/* #undef M_MACHEPS */
-#ifdef DBL_EPSILON
-#endif
-#ifdef M_MACHEPS
-#ifndef MACHEPS
-#define MACHEPS M_MACHEPS
-#endif
-#endif
-#define M_MAX_INT 2147483647
-#ifdef M_MAX_INT
-#ifndef MAX_RAND
-#define MAX_RAND ((double)(M_MAX_INT))
-#endif
-#endif
-/* for non-ANSI systems */
-#ifndef HUGE_VAL
-#define HUGE_VAL HUGE
-#endif
-#ifdef ANSI_C
-extern int isatty(int);
-#endif
Modified: grass-addons/grass7/imagery/i.spec.sam/main.c
--- grass-addons/grass7/imagery/i.spec.sam/main.c 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/main.c 2015-01-20 14:43:49 UTC (rev 64254)
@@ -15,17 +15,15 @@
-#include "global.h"
#include <stdio.h>
#include <strings.h>
#include <math.h>
-#include "matrix.h"
-#include "matrix2.h"
-#include "local_proto.h"
-#include "grass/raster.h"
-#include "grass/vector.h"
-#include "grass/glocale.h"
#include "grass/gis.h"
+#include "grass/raster.h"
+#include "local_proto.h"
+#include "global.h"
+#include <meschach/matrix.h>
+#include <meschach/matrix2.h>
MAT *A;
VEC *b, *Avector;
Deleted: grass-addons/grass7/imagery/i.spec.sam/matrix.h
--- grass-addons/grass7/imagery/i.spec.sam/matrix.h 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/matrix.h 2015-01-20 14:43:49 UTC (rev 64254)
@@ -1,665 +0,0 @@
-** Copyright (C) 1993 David E. Steward & Zbigniew Leyk, all rights reserved.
- Type definitions for general purpose maths package
-#ifndef MATRIXH
-/* RCS id: $Id: matrix.h,v 1.18 1994/04/16 00:33:37 des Exp $ */
-#define MATRIXH
-#include "err.h"
-#include "meminfo.h"
-/* unsigned integer type */
-#ifndef U_INT_DEF
-typedef unsigned int u_int;
-#define U_INT_DEF
-#endif
-/* vector definition */
-typedef struct {
- u_int dim, max_dim;
- RReal *ve;
- } VEC;
-/* matrix definition */
-typedef struct {
- u_int m, n;
- u_int max_m, max_n, max_size;
- RReal **me,*base; /* base is base of alloc'd mem */
- } MAT;
-/* band matrix definition */
-typedef struct {
- MAT *mat; /* matrix */
- int lb,ub; /* lower and upper bandwidth */
- } BAND;
-/* permutation definition */
-typedef struct {
- u_int size, max_size, *pe;
- } PERM;
-/* integer vector definition */
-typedef struct {
- int *ive;
- } IVEC;
-#ifndef MALLOCDECL
-#ifndef ANSI_C
-extern char *malloc(), *calloc(), *realloc();
-#else
-extern void *malloc(size_t),
- *calloc(size_t,size_t),
- *realloc(void *,size_t);
-#endif
-#endif
-#ifndef ANSI_C
-extern void m_version();
-#else
-void m_version( void );
-#endif
-#ifndef ANSI_C
-/* allocate one object of given type */
-#define NEW(type) ((type *)calloc(1,sizeof(type)))
-/* allocate num objects of given type */
-#define NEW_A(num,type) ((type *)calloc((unsigned)(num),sizeof(type)))
- /* re-allocate arry to have num objects of the given type */
-#define RENEW(var,num,type) \
- ((var)=(type *)((var) ? \
- realloc((char *)(var),(unsigned)(num)*sizeof(type)) : \
- calloc((unsigned)(num),sizeof(type))))
-#define MEMCOPY(from,to,n_items,type) \
- MEM_COPY((char *)(from),(char *)(to),(unsigned)(n_items)*sizeof(type))
-#else
-#define NEW(type) ((type *)calloc((size_t)1,(size_t)sizeof(type)))
-#define NEW_A(num,type) ((type *)calloc((size_t)(num),(size_t)sizeof(type)))
- realloc((char *)(var),(size_t)((num)*sizeof(type))) : \
- calloc((size_t)(num),(size_t)sizeof(type))))
-#endif
-/* type independent min and max operations */
-#ifndef max
-#define max(a,b) ((a) > (b) ? (a) : (b))
-#endif
-#ifndef min
-#define min(a,b) ((a) > (b) ? (b) : (a))
-#endif
-#undef TRUE
-#define TRUE 1
-#undef FALSE
-#define FALSE 0
-/* for input routines */
-#define MAXLINE 81
-/* Dynamic memory allocation */
-/* Should use M_FREE/V_FREE/PX_FREE in programs instead of m/v/px_free()
- as this is considerably safer -- also provides a simple type check ! */
-#ifndef ANSI_C
-extern VEC *v_get(), *v_resize();
-extern MAT *m_get(), *m_resize();
-extern PERM *px_get(), *px_resize();
-extern IVEC *iv_get(), *iv_resize();
-extern int m_free(),v_free();
-extern int px_free();
-extern int iv_free();
-extern BAND *bd_get(), *bd_resize();
-extern int bd_free();
-#else
-/* get/resize vector to given dimension */
-extern VEC *v_get(int), *v_resize(VEC *,int);
-/* get/resize matrix to be m x n */
-extern MAT *m_get(int,int), *m_resize(MAT *,int,int);
-/* get/resize permutation to have the given size */
-extern PERM *px_get(int), *px_resize(PERM *,int);
-/* get/resize an integer vector to given dimension */
-extern IVEC *iv_get(int), *iv_resize(IVEC *,int);
-/* get/resize a band matrix to given dimension */
-extern BAND *bd_get(int,int,int), *bd_resize(BAND *,int,int,int);
-/* free (de-allocate) (band) matrices, vectors, permutations and
- integer vectors */
-extern int iv_free(IVEC *);
-extern int m_free(MAT *),v_free(VEC *),px_free(PERM *);
-extern int bd_free(BAND *);
-#endif
-/* MACROS */
-/* macros that also check types and sets pointers to NULL */
-#define M_FREE(mat) ( m_free(mat), (mat)=(MAT *)NULL )
-#define V_FREE(vec) ( v_free(vec), (vec)=(VEC *)NULL )
-#define PX_FREE(px) ( px_free(px), (px)=(PERM *)NULL )
-#define IV_FREE(iv) ( iv_free(iv), (iv)=(IVEC *)NULL )
-#define MAXDIM 2001
-/* Entry level access to data structures */
-#ifdef DEBUG
-/* returns x[i] */
-#define v_entry(x,i) (((i) < 0 || (i) >= (x)->dim) ? \
- error(E_BOUNDS,"v_entry"), 0.0 : (x)->ve[i] )
-/* x[i] <- val */
-#define v_set_val(x,i,val) ((x)->ve[i] = ((i) < 0 || (i) >= (x)->dim) ? \
- error(E_BOUNDS,"v_set_val"), 0.0 : (val))
-/* x[i] <- x[i] + val */
-#define v_add_val(x,i,val) ((x)->ve[i] += ((i) < 0 || (i) >= (x)->dim) ? \
- error(E_BOUNDS,"v_add_val"), 0.0 : (val))
-/* x[i] <- x[i] - val */
-#define v_sub_val(x,i,val) ((x)->ve[i] -= ((i) < 0 || (i) >= (x)->dim) ? \
- error(E_BOUNDS,"v_sub_val"), 0.0 : (val))
-/* returns A[i][j] */
-#define m_entry(A,i,j) (((i) < 0 || (i) >= (A)->m || \
- (j) < 0 || (j) >= (A)->n) ? \
- error(E_BOUNDS,"m_entry"), 0.0 : (A)->me[i][j] )
-/* A[i][j] <- val */
-#define m_set_val(A,i,j,val) ((A)->me[i][j] = ((i) < 0 || (i) >= (A)->m || \
- error(E_BOUNDS,"m_set_val"), 0.0 : (val) )
-/* A[i][j] <- A[i][j] + val */
-#define m_add_val(A,i,j,val) ((A)->me[i][j] += ((i) < 0 || (i) >= (A)->m || \
- error(E_BOUNDS,"m_add_val"), 0.0 : (val) )
-/* A[i][j] <- A[i][j] - val */
-#define m_sub_val(A,i,j,val) ((A)->me[i][j] -= ((i) < 0 || (i) >= (A)->m || \
- error(E_BOUNDS,"m_sub_val"), 0.0 : (val) )
-#else
-/* returns x[i] */
-#define v_entry(x,i) ((x)->ve[i])
-/* x[i] <- val */
-#define v_set_val(x,i,val) ((x)->ve[i] = (val))
-#define v_add_val(x,i,val) ((x)->ve[i] += (val))
- /* x[i] <- x[i] - val */
-#define v_sub_val(x,i,val) ((x)->ve[i] -= (val))
-#define m_entry(A,i,j) ((A)->me[i][j])
-#define m_set_val(A,i,j,val) ((A)->me[i][j] = (val) )
-#define m_add_val(A,i,j,val) ((A)->me[i][j] += (val) )
-#define m_sub_val(A,i,j,val) ((A)->me[i][j] -= (val) )
-#endif
-/* I/O routines */
-#ifndef ANSI_C
-extern void v_foutput(),m_foutput(),px_foutput();
-extern void iv_foutput();
-extern VEC *v_finput();
-extern MAT *m_finput();
-extern PERM *px_finput();
-extern IVEC *iv_finput();
-extern int fy_or_n(), fin_int(), yn_dflt(), skipjunk();
-extern double fin_double();
-#else
-/* print x on file fp */
-void v_foutput(FILE *fp,VEC *x),
- /* print A on file fp */
- m_foutput(FILE *fp,MAT *A),
- /* print px on file fp */
- px_foutput(FILE *fp,PERM *px);
-/* print ix on file fp */
-void iv_foutput(FILE *fp,IVEC *ix);
-/* Note: if out is NULL, then returned object is newly allocated;
- Also: if out is not NULL, then that size is assumed */
-/* read in vector from fp */
-VEC *v_finput(FILE *fp,VEC *out);
-/* read in matrix from fp */
-MAT *m_finput(FILE *fp,MAT *out);
-/* read in permutation from fp */
-PERM *px_finput(FILE *fp,PERM *out);
-/* read in int vector from fp */
-IVEC *iv_finput(FILE *fp,IVEC *out);
-/* fy_or_n -- yes-or-no to question in string s
- -- question written to stderr, input from fp
- -- if fp is NOT a tty then return y_n_dflt */
-int fy_or_n(FILE *fp,char *s);
-/* yn_dflt -- sets the value of y_n_dflt to val */
-int yn_dflt(int val);
-/* fin_int -- return integer read from file/stream fp
- -- prompt s on stderr if fp is a tty
- -- check that x lies between low and high: re-prompt if
- fp is a tty, error exit otherwise
- -- ignore check if low > high */
-int fin_int(FILE *fp,char *s,int low,int high);
-/* fin_double -- return double read from file/stream fp
-double fin_double(FILE *fp,char *s,double low,double high);
-/* it skips white spaces and strings of the form #....\n
- Here .... is a comment string */
-int skipjunk(FILE *fp);
-#endif
-/* MACROS */
-/* macros to use stdout and stdin instead of explicit fp */
-#define v_output(vec) v_foutput(stdout,vec)
-#define v_input(vec) v_finput(stdin,vec)
-#define m_output(mat) m_foutput(stdout,mat)
-#define m_input(mat) m_finput(stdin,mat)
-#define px_output(px) px_foutput(stdout,px)
-#define px_input(px) px_finput(stdin,px)
-#define iv_output(iv) iv_foutput(stdout,iv)
-#define iv_input(iv) iv_finput(stdin,iv)
-/* general purpose input routine; skips comments # ... \n */
-#define finput(fp,prompt,fmt,var) \
- ( ( isatty(fileno(fp)) ? fprintf(stderr,prompt) : skipjunk(fp) ), \
- fscanf(fp,fmt,var) )
-#define input(prompt,fmt,var) finput(stdin,prompt,fmt,var)
-#define fprompter(fp,prompt) \
- ( isatty(fileno(fp)) ? fprintf(stderr,prompt) : skipjunk(fp) )
-#define prompter(prompt) fprompter(stdin,prompt)
-#define y_or_n(s) fy_or_n(stdin,s)
-#define in_int(s,lo,hi) fin_int(stdin,s,lo,hi)
-#define in_double(s,lo,hi) fin_double(stdin,s,lo,hi)
-/* Copying routines */
-#ifndef ANSI_C
-extern MAT *_m_copy(), *m_move(), *vm_move();
-extern VEC *_v_copy(), *v_move(), *mv_move();
-extern PERM *px_copy();
-extern IVEC *iv_copy(), *iv_move();
-extern BAND *bd_copy();
-#else
-/* copy in to out starting at out[i0][j0] */
-extern MAT *_m_copy(MAT *in,MAT *out,u_int i0,u_int j0),
- * m_move(MAT *in, int, int, int, int, MAT *out, int, int),
- *vm_move(VEC *in, int, MAT *out, int, int, int, int);
-/* copy in to out starting at out[i0] */
-extern VEC *_v_copy(VEC *in,VEC *out,u_int i0),
- * v_move(VEC *in, int, int, VEC *out, int),
- *mv_move(MAT *in, int, int, int, int, VEC *out, int);
-extern PERM *px_copy(PERM *in,PERM *out);
-extern IVEC *iv_copy(IVEC *in,IVEC *out),
- *iv_move(IVEC *in, int, int, IVEC *out, int);
-extern BAND *bd_copy(BAND *in,BAND *out);
-#endif
-/* MACROS */
-#define m_copy(in,out) _m_copy(in,out,0,0)
-#define v_copy(in,out) _v_copy(in,out,0)
-/* Initialisation routines -- to be zero, ones, random or identity */
-#ifndef ANSI_C
-extern VEC *v_zero(), *v_rand(), *v_ones();
-extern MAT *m_zero(), *m_ident(), *m_rand(), *m_ones();
-extern PERM *px_ident();
-extern IVEC *iv_zero();
-#else
-extern VEC *v_zero(VEC *), *v_rand(VEC *), *v_ones(VEC *);
-extern MAT *m_zero(MAT *), *m_ident(MAT *), *m_rand(MAT *),
- *m_ones(MAT *);
-extern PERM *px_ident(PERM *);
-extern IVEC *iv_zero(IVEC *);
-#endif
-/* Basic vector operations */
-#ifndef ANSI_C
-extern VEC *sv_mlt(), *mv_mlt(), *vm_mlt(), *v_add(), *v_sub(),
- *px_vec(), *pxinv_vec(), *v_mltadd(), *v_map(), *_v_map(),
- *v_lincomb(), *v_linlist();
-extern double v_min(), v_max(), v_sum();
-extern VEC *v_star(), *v_slash(), *v_sort();
-extern double _in_prod(), __ip__();
-extern void __mltadd__(), __add__(), __sub__(),
- __smlt__(), __zero__();
-#else
-extern VEC *sv_mlt(double,VEC *,VEC *), /* out <- s.x */
- *mv_mlt(MAT *,VEC *,VEC *), /* out <- A.x */
- *vm_mlt(MAT *,VEC *,VEC *), /* out^T <- x^T.A */
- *v_add(VEC *,VEC *,VEC *), /* out <- x + y */
- *v_sub(VEC *,VEC *,VEC *), /* out <- x - y */
- *px_vec(PERM *,VEC *,VEC *), /* out <- P.x */
- *pxinv_vec(PERM *,VEC *,VEC *), /* out <- P^{-1}.x */
- *v_mltadd(VEC *,VEC *,double,VEC *), /* out <- x + s.y */
-#ifdef PROTOTYPES_IN_STRUCT
- *v_map(double (*f)(double),VEC *,VEC *),
- /* out[i] <- f(x[i]) */
- *_v_map(double (*f)(void *,double),void *,VEC *,VEC *),
-#else
- *v_map(double (*f)(),VEC *,VEC *), /* out[i] <- f(x[i]) */
- *_v_map(double (*f)(),void *,VEC *,VEC *),
-#endif
- *v_lincomb(int,VEC **,RReal *,VEC *),
- /* out <- sum_i s[i].x[i] */
- *v_linlist(VEC *out,VEC *v1,double a1,...);
- /* out <- s1.x1 + s2.x2 + ... */
-/* returns min_j x[j] (== x[i]) */
-extern double v_min(VEC *, int *),
- /* returns max_j x[j] (== x[i]) */
- v_max(VEC *, int *),
- /* returns sum_i x[i] */
- v_sum(VEC *);
-/* Hadamard product: out[i] <- x[i].y[i] */
-extern VEC *v_star(VEC *, VEC *, VEC *),
- /* out[i] <- x[i] / y[i] */
- *v_slash(VEC *, VEC *, VEC *),
- /* sorts x, and sets order so that sorted x[i] = x[order[i]] */
- *v_sort(VEC *, PERM *);
-/* returns inner product starting at component i0 */
-extern double _in_prod(VEC *x,VEC *y,u_int i0),
- /* returns sum_{i=0}^{len-1} x[i].y[i] */
- __ip__(RReal *,RReal *,int);
-/* see v_mltadd(), v_add(), v_sub() and v_zero() */
-extern void __mltadd__(RReal *,RReal *,double,int),
- __add__(RReal *,RReal *,RReal *,int),
- __sub__(RReal *,RReal *,RReal *,int),
- __smlt__(RReal *,double,RReal *,int),
- __zero__(RReal *,int);
-#endif
-/* MACRO */
-/* usual way of computing the inner product */
-#define in_prod(a,b) _in_prod(a,b,0)
-/* Norms */
-/* scaled vector norms -- scale == NULL implies unscaled */
-#ifndef ANSI_C
-extern double _v_norm1(), _v_norm2(), _v_norm_inf(),
- m_norm1(), m_norm_inf(), m_norm_frob();
-#else
- /* returns sum_i |x[i]/scale[i]| */
-extern double _v_norm1(VEC *x,VEC *scale),
- /* returns (scaled) Euclidean norm */
- _v_norm2(VEC *x,VEC *scale),
- /* returns max_i |x[i]/scale[i]| */
- _v_norm_inf(VEC *x,VEC *scale);
-/* unscaled matrix norms */
-extern double m_norm1(MAT *A), m_norm_inf(MAT *A), m_norm_frob(MAT *A);
-#endif
-/* MACROS */
-/* unscaled vector norms */
-#define v_norm1(x) _v_norm1(x,VNULL)
-#define v_norm2(x) _v_norm2(x,VNULL)
-#define v_norm_inf(x) _v_norm_inf(x,VNULL)
-/* Basic matrix operations */
-#ifndef ANSI_C
-extern MAT *sm_mlt(), *m_mlt(), *mmtr_mlt(), *mtrm_mlt(), *m_add(), *m_sub(),
- *sub_mat(), *m_transp(), *ms_mltadd();
-extern BAND *bd_transp();
-extern MAT *px_rows(), *px_cols(), *swap_rows(), *swap_cols(),
- *_set_row(), *_set_col();
-extern VEC *get_row(), *get_col(), *sub_vec(),
- *mv_mltadd(), *vm_mltadd();
-#else
-extern MAT *sm_mlt(double s,MAT *A,MAT *out), /* out <- s.A */
- *m_mlt(MAT *A,MAT *B,MAT *out), /* out <- A.B */
- *mmtr_mlt(MAT *A,MAT *B,MAT *out), /* out <- A.B^T */
- *mtrm_mlt(MAT *A,MAT *B,MAT *out), /* out <- A^T.B */
- *m_add(MAT *A,MAT *B,MAT *out), /* out <- A + B */
- *m_sub(MAT *A,MAT *B,MAT *out), /* out <- A - B */
- *sub_mat(MAT *A,u_int,u_int,u_int,u_int,MAT *out),
- *m_transp(MAT *A,MAT *out), /* out <- A^T */
- /* out <- A + s.B */
- *ms_mltadd(MAT *A,MAT *B,double s,MAT *out);
-extern BAND *bd_transp(BAND *in, BAND *out); /* out <- A^T */
-extern MAT *px_rows(PERM *px,MAT *A,MAT *out), /* out <- P.A */
- *px_cols(PERM *px,MAT *A,MAT *out), /* out <- A.P^T */
- *swap_rows(MAT *,int,int,int,int),
- *swap_cols(MAT *,int,int,int,int),
- /* A[i][j] <- out[j], j >= j0 */
- *_set_col(MAT *A,u_int i,VEC *out,u_int j0),
- /* A[i][j] <- out[i], i >= i0 */
- *_set_row(MAT *A,u_int j,VEC *out,u_int i0);
-extern VEC *get_row(MAT *,u_int,VEC *),
- *get_col(MAT *,u_int,VEC *),
- *sub_vec(VEC *,int,int,VEC *),
- /* out <- x + s.A.y */
- *mv_mltadd(VEC *x,VEC *y,MAT *A,double s,VEC *out),
- /* out^T <- x^T + s.y^T.A */
- *vm_mltadd(VEC *x,VEC *y,MAT *A,double s,VEC *out);
-#endif
-/* MACROS */
-/* row i of A <- vec */
-#define set_row(mat,row,vec) _set_row(mat,row,vec,0)
-/* col j of A <- vec */
-#define set_col(mat,col,vec) _set_col(mat,col,vec,0)
-/* Basic permutation operations */
-#ifndef ANSI_C
-extern PERM *px_mlt(), *px_inv(), *px_transp();
-extern int px_sign();
-#else
-extern PERM *px_mlt(PERM *px1,PERM *px2,PERM *out), /* out <- px1.px2 */
- *px_inv(PERM *px,PERM *out), /* out <- px^{-1} */
- /* swap px[i] and px[j] */
- *px_transp(PERM *px,u_int i,u_int j);
- /* returns sign(px) = +1 if px product of even # transpositions
- -1 if ps product of odd # transpositions */
-extern int px_sign(PERM *);
-#endif
-/* Basic integer vector operations */
-#ifndef ANSI_C
-extern IVEC *iv_add(), *iv_sub(), *iv_sort();
-#else
-extern IVEC *iv_add(IVEC *ix,IVEC *iy,IVEC *out), /* out <- ix + iy */
- *iv_sub(IVEC *ix,IVEC *iy,IVEC *out), /* out <- ix - iy */
- /* sorts ix & sets order so that sorted ix[i] = old ix[order[i]] */
- *iv_sort(IVEC *ix, PERM *order);
-#endif
-/* miscellaneous functions */
-#ifndef ANSI_C
-extern double square(), cube(), mrand();
-extern void smrand(), mrandlist();
-extern void m_dump(), px_dump(), v_dump(), iv_dump();
-extern MAT *band2mat();
-extern BAND *mat2band();
-#else
-double square(double x), /* returns x^2 */
- cube(double x), /* returns x^3 */
- mrand(void); /* returns random # in [0,1) */
-void smrand(int seed), /* seeds mrand() */
- mrandlist(RReal *x, int len); /* generates len random numbers */
-void m_dump(FILE *fp,MAT *a), px_dump(FILE *,PERM *px),
- v_dump(FILE *fp,VEC *x), iv_dump(FILE *fp, IVEC *ix);
-MAT *band2mat(BAND *bA, MAT *A);
-BAND *mat2band(MAT *A, int lb,int ub, BAND *bA);
-#endif
-/* miscellaneous constants */
-#define VNULL ((VEC *)NULL)
-#define MNULL ((MAT *)NULL)
-#define PNULL ((PERM *)NULL)
-#define IVNULL ((IVEC *)NULL)
-#define BDNULL ((BAND *)NULL)
-/* varying number of arguments */
-#ifdef ANSI_C
-#include <stdarg.h>
-/* prototypes */
-int v_get_vars(int dim,...);
-int iv_get_vars(int dim,...);
-int m_get_vars(int m,int n,...);
-int px_get_vars(int dim,...);
-int v_resize_vars(int new_dim,...);
-int iv_resize_vars(int new_dim,...);
-int m_resize_vars(int m,int n,...);
-int px_resize_vars(int new_dim,...);
-int v_free_vars(VEC **,...);
-int iv_free_vars(IVEC **,...);
-int px_free_vars(PERM **,...);
-int m_free_vars(MAT **,...);
-#elif VARARGS
-/* old varargs is used */
-#include <varargs.h>
-/* prototypes */
-int v_get_vars();
-int iv_get_vars();
-int m_get_vars();
-int px_get_vars();
-int v_resize_vars();
-int iv_resize_vars();
-int m_resize_vars();
-int px_resize_vars();
-int v_free_vars();
-int iv_free_vars();
-int px_free_vars();
-int m_free_vars();
-#endif
-#endif
Deleted: grass-addons/grass7/imagery/i.spec.sam/matrix2.h
--- grass-addons/grass7/imagery/i.spec.sam/matrix2.h 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/matrix2.h 2015-01-20 14:43:49 UTC (rev 64254)
@@ -1,229 +0,0 @@
- Header file for ``matrix2.a'' library file
-#ifndef MATRIX2H
-#define MATRIX2H
-/* Unless otherwise specified, factorisation routines overwrite the
- matrix that is being factorised */
-#ifndef ANSI_C
-extern MAT *BKPfactor(), *CHfactor(), *LUfactor(), *QRfactor(),
- *QRCPfactor(), *LDLfactor(), *Hfactor(), *MCHfactor(),
- *m_inverse();
-extern double LUcondest(), QRcondest();
-extern MAT *makeQ(), *makeR(), *makeHQ(), *makeH();
-extern MAT *LDLupdate(), *QRupdate();
-extern VEC *BKPsolve(), *CHsolve(), *LUsolve(), *_Qsolve(), *QRsolve(),
- *LDLsolve(), *Usolve(), *Lsolve(), *Dsolve(), *LTsolve(),
- *UTsolve(), *LUTsolve(), *QRCPsolve();
-extern BAND *bdLUfactor(), *bdLDLfactor();
-extern VEC *bdLUsolve(), *bdLDLsolve();
-extern VEC *hhvec();
-extern VEC *hhtrvec();
-extern MAT *hhtrrows();
-extern MAT *hhtrcols();
-extern void givens();
-extern VEC *rot_vec(); /* in situ */
-extern MAT *rot_rows(); /* in situ */
-extern MAT *rot_cols(); /* in situ */
-/* eigenvalue routines */
-extern VEC *trieig(), *symmeig();
-extern MAT *schur();
-extern void schur_evals();
-extern MAT *schur_vecs();
-/* singular value decomposition */
-extern VEC *bisvd(), *svd();
-/* matrix powers and exponent */
-MAT *_m_pow();
-MAT *m_pow();
-MAT *m_exp(), *_m_exp();
-MAT *m_poly();
-/* FFT */
-void fft();
-void ifft();
-#else
- /* forms Bunch-Kaufman-Parlett factorisation for
- symmetric indefinite matrices */
-extern MAT *BKPfactor(MAT *A,PERM *pivot,PERM *blocks),
- /* Cholesky factorisation of A
- (symmetric, positive definite) */
- *CHfactor(MAT *A),
- /* LU factorisation of A (with partial pivoting) */
- *LUfactor(MAT *A,PERM *pivot),
- /* QR factorisation of A; need dim(diag) >= # rows of A */
- *QRfactor(MAT *A,VEC *diag),
- /* QR factorisation of A with column pivoting */
- *QRCPfactor(MAT *A,VEC *diag,PERM *pivot),
- /* L.D.L^T factorisation of A */
- *LDLfactor(MAT *A),
- /* Hessenberg factorisation of A -- for schur() */
- *Hfactor(MAT *A,VEC *diag1,VEC *diag2),
- /* modified Cholesky factorisation of A;
- actually factors A+D, D diagonal with no
- diagonal entry in the factor < sqrt(tol) */
- *MCHfactor(MAT *A,double tol),
- *m_inverse(MAT *A,MAT *out);
- /* returns condition estimate for A after LUfactor() */
-extern double LUcondest(MAT *A,PERM *pivot),
- /* returns condition estimate for Q after QRfactor() */
- QRcondest(MAT *A);
-/* Note: The make..() and ..update() routines assume that the factorisation
- has already been carried out */
- /* Qout is the "Q" (orthongonal) matrix from QR factorisation */
-extern MAT *makeQ(MAT *A,VEC *diag,MAT *Qout),
- /* Rout is the "R" (upper triangular) matrix
- from QR factorisation */
- *makeR(MAT *A,MAT *Rout),
- /* Qout is orthogonal matrix in Hessenberg factorisation */
- *makeHQ(MAT *A,VEC *diag1,VEC *diag2,MAT *Qout),
- /* Hout is the Hessenberg matrix in Hessenberg factorisation */
- *makeH(MAT *A,MAT *Hout);
- /* updates L.D.L^T factorisation for A <- A + alpha.u.u^T */
-extern MAT *LDLupdate(MAT *A,VEC *u,double alpha),
- /* updates QR factorisation for QR <- Q.(R+u.v^T)
- Note: we need explicit Q & R matrices,
- from makeQ() and makeR() */
- *QRupdate(MAT *Q,MAT *R,VEC *u,VEC *v);
-/* Solve routines assume that the corresponding factorisation routine
- has already been applied to the matrix along with auxiliary
- objects (such as pivot permutations)
- These solve the system A.x = b,
- except for LUTsolve and QRTsolve which solve the transposed system
- A^T.x. = b.
- If x is NULL on entry, then it is created.
-extern VEC *BKPsolve(MAT *A,PERM *pivot,PERM *blocks,VEC *b,VEC *x),
- *CHsolve(MAT *A,VEC *b,VEC *x),
- *LDLsolve(MAT *A,VEC *b,VEC *x),
- *LUsolve(MAT *A,PERM *pivot,VEC *b,VEC *x),
- *_Qsolve(MAT *A,VEC *,VEC *,VEC *, VEC *),
- *QRsolve(MAT *A,VEC *,VEC *b,VEC *x),
- *QRTsolve(MAT *A,VEC *,VEC *b,VEC *x),
- /* Triangular equations solve routines;
- U for upper triangular, L for lower traingular, D for diagonal
- if diag_val == 0.0 use that values in the matrix */
- *Usolve(MAT *A,VEC *b,VEC *x,double diag_val),
- *Lsolve(MAT *A,VEC *b,VEC *x,double diag_val),
- *Dsolve(MAT *A,VEC *b,VEC *x),
- *LTsolve(MAT *A,VEC *b,VEC *x,double diag_val),
- *UTsolve(MAT *A,VEC *b,VEC *x,double diag_val),
- *LUTsolve(MAT *A,PERM *,VEC *,VEC *),
- *QRCPsolve(MAT *QR,VEC *diag,PERM *pivot,VEC *b,VEC *x);
-extern BAND *bdLUfactor(BAND *A,PERM *pivot),
- *bdLDLfactor(BAND *A);
-extern VEC *bdLUsolve(BAND *A,PERM *pivot,VEC *b,VEC *x),
- *bdLDLsolve(BAND *A,VEC *b,VEC *x);
-extern VEC *hhvec(VEC *,u_int,RReal *,VEC *,RReal *);
-extern VEC *hhtrvec(VEC *,double,u_int,VEC *,VEC *);
-extern MAT *hhtrrows(MAT *,u_int,u_int,VEC *,double);
-extern MAT *hhtrcols(MAT *,u_int,u_int,VEC *,double);
-extern void givens(double,double,RReal *,RReal *);
-extern VEC *rot_vec(VEC *,u_int,u_int,double,double,VEC *); /* in situ */
-extern MAT *rot_rows(MAT *,u_int,u_int,double,double,MAT *); /* in situ */
-extern MAT *rot_cols(MAT *,u_int,u_int,double,double,MAT *); /* in situ */
- /* compute eigenvalues of tridiagonal matrix
- with diagonal entries a[i], super & sub diagonal entries
- b[i]; eigenvectors stored in Q (if not NULL) */
-extern VEC *trieig(VEC *a,VEC *b,MAT *Q),
- /* sets out to be vector of eigenvectors; eigenvectors
- stored in Q (if not NULL). A is unchanged */
- *symmeig(MAT *A,MAT *Q,VEC *out);
- /* computes real Schur form = Q^T.A.Q */
-extern MAT *schur(MAT *A,MAT *Q);
- /* computes real and imaginary parts of the eigenvalues
- of A after schur() */
-extern void schur_evals(MAT *A,VEC *re_part,VEC *im_part);
- /* computes real and imaginary parts of the eigenvectors
-extern MAT *schur_vecs(MAT *T,MAT *Q,MAT *X_re,MAT *X_im);
- /* computes singular values of bi-diagonal matrix with
- diagonal entries a[i] and superdiagonal entries b[i];
- singular vectors stored in U and V (if not NULL) */
-VEC *bisvd(VEC *a,VEC *b,MAT *U,MAT *V),
- /* sets out to be vector of singular values;
- singular vectors stored in U and V */
- *svd(MAT *A,MAT *U,MAT *V,VEC *out);
-MAT *_m_pow(MAT *,int,MAT *,MAT *);
-MAT *m_pow(MAT *,int, MAT *);
-MAT *m_exp(MAT *,double,MAT *);
-MAT *_m_exp(MAT *,double,MAT *,int *,int *);
-MAT *m_poly(MAT *,VEC *,MAT *);
-/* FFT */
-void fft(VEC *,VEC *);
-void ifft(VEC *,VEC *);
-#endif
-#endif
Deleted: grass-addons/grass7/imagery/i.spec.sam/meminfo.h
--- grass-addons/grass7/imagery/i.spec.sam/meminfo.h 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/meminfo.h 2015-01-20 14:43:49 UTC (rev 64254)
@@ -1,155 +0,0 @@
-/* meminfo.h 26/08/93 */
-/* changed 11/12/93 */
-#ifndef MEM_INFOH
-#define MEM_INFOH
-/* for hash table in mem_stat.c */
-/* Note: the hash size should be a prime, or at very least odd */
-#define MEM_HASHSIZE 509
-#define MEM_HASHSIZE_FILE "meminfo.h"
-/* default: memory information is off */
-/* set it to 1 if you want it all the time */
-#define MEM_SWITCH_ON_DEF 0
-/* available standard types */
-#define TYPE_NULL (-1)
-#define TYPE_MAT 0
-#define TYPE_BAND 1
-#define TYPE_PERM 2
-#define TYPE_VEC 3
-#define TYPE_IVEC 4
-#ifdef SPARSE
-#define TYPE_ITER 5
-#define TYPE_SPROW 6
-#define TYPE_SPMAT 7
-#endif
-#ifdef COMPLEX
-#ifdef SPARSE
-#define TYPE_ZVEC 8
-#define TYPE_ZMAT 9
-#else
-#define TYPE_ZVEC 5
-#define TYPE_ZMAT 6
-#endif
-#endif
-/* structure for memory information */
-typedef struct {
- long bytes; /* # of allocated bytes for each type (summary) */
- int numvar; /* # of allocated variables for each type */
-} MEM_ARRAY;
-#ifdef ANSI_C
-int mem_info_is_on(void);
-int mem_info_on(int sw);
-long mem_info_bytes(int type,int list);
-int mem_info_numvar(int type,int list);
-void mem_info_file(FILE * fp,int list);
-void mem_bytes_list(int type,int old_size,int new_size,
- int list);
-void mem_numvar_list(int type, int num, int list);
-int mem_stat_reg_list(void **var,int type,int list);
-int mem_stat_mark(int mark);
-int mem_stat_free_list(int mark,int list);
-int mem_stat_show_mark(void);
-void mem_stat_dump(FILE *fp,int list);
-int mem_attach_list(int list,int ntypes,char *type_names[],
- int (*free_funcs[])(), MEM_ARRAY info_sum[]);
-int mem_free_vars(int list);
-int mem_is_list_attached(int list);
-void mem_dump_list(FILE *fp,int list);
-int mem_stat_reg_vars(int list,int type,...);
-#else
-int mem_info_is_on();
-int mem_info_on();
-long mem_info_bytes();
-int mem_info_numvar();
-void mem_info_file();
-void mem_bytes_list();
-void mem_numvar_list();
-int mem_stat_reg_list();
-int mem_stat_mark();
-int mem_stat_free_list();
-int mem_stat_show_mark();
-void mem_stat_dump();
-int mem_attach_list();
-int mem_free_vars();
-int mem_is_list_attached();
-void mem_dump_list();
-int mem_stat_reg_vars();
-#endif
-/* macros */
-#define mem_info() mem_info_file(stdout,0)
-#define mem_stat_reg(var,type) mem_stat_reg_list((void **)var,type,0)
-#define MEM_STAT_REG(var,type) mem_stat_reg_list((void **)&(var),type,0)
-#define mem_stat_free(mark) mem_stat_free_list(mark,0)
-#define mem_bytes(type,old_size,new_size) \
- mem_bytes_list(type,old_size,new_size,0)
-#define mem_numvar(type,num) mem_numvar_list(type,num,0)
-/* internal type */
-typedef struct {
- char **type_names; /* array of names of types (strings) */
- int (**free_funcs)(); /* array of functions for releasing types */
- unsigned ntypes; /* max number of types */
- MEM_ARRAY *info_sum; /* local array for keeping track of memory */
-} MEM_CONNECT;
-/* max number of lists of types */
-#define MEM_CONNECT_MAX_LISTS 5
-#endif
Modified: grass-addons/grass7/imagery/i.spec.sam/open.c
--- grass-addons/grass7/imagery/i.spec.sam/open.c 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/open.c 2015-01-20 14:43:49 UTC (rev 64254)
@@ -18,7 +18,7 @@
#include <math.h>
#include <grass/gis.h>
#include <grass/raster.h>
int open_files()
Modified: grass-addons/grass7/imagery/i.spec.sam/spec_angle.c
--- grass-addons/grass7/imagery/i.spec.sam/spec_angle.c 2015-01-20 13:29:52 UTC (rev 64253)
+++ grass-addons/grass7/imagery/i.spec.sam/spec_angle.c 2015-01-20 14:43:49 UTC (rev 64254)
@@ -20,7 +20,7 @@
#include <stdio.h>
#include <math.h>
#include "global.h"
