[GRASS-SVN] r64262 - grass-addons/grass7/raster/r.in.srtm.region
svn_grass at osgeo.org
Tue Jan 20 11:52:27 PST 2015
Author: mmetz
Date: 2015-01-20 11:52:27 -0800 (Tue, 20 Jan 2015)
New Revision: 64262
grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html
grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
r.in.srtm.region: +import global SRTM v3 1 arcsec
Modified: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html 2015-01-20 19:46:28 UTC (rev 64261)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.html 2015-01-20 19:52:27 UTC (rev 64262)
@@ -5,27 +5,31 @@
patches the tiles together and optionally interpolates holes for
SRTM V2.1.
<p>
-<em>r.in.srtm.region</em> downloads SRTM V3 tiles from:<br>
-<a href="http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/">http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/</a>
+<em>r.in.srtm.region</em> downloads SRTM V3 tiles at 3 arc seconds
+resolution from:<br> <a
+href="http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/">http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/</a>
<br>
+SRTM V3 tiles at 1 arc second
+href="http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL1.003/2000.02.11/">http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/</a>
+<br>
and SRTM V2.1 tiles from:
<a href="http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/">http://dds.cr.usgs.gov/srtm/</a>
<br>
or optionally uses a local folder with previously downloaded files if
the <b>local</b> option is given.
-<h2>NOTES</h2>
-<em>r.in.srtm.region</em> imports only SRTM tiles with 3 arcsec resolution.
<h2>SEE ALSO</h2>
<em>
<a href="r.in.srtm.html">r.in.srtm</a>
</em>
-<p>The <a href="http://www2.jpl.nasa.gov/srtm/">Shuttle Radar Topography Mission</a>
+<p>
+The <a href="http://www2.jpl.nasa.gov/srtm/">Shuttle Radar Topography Mission</a>
homepage at NASA's JPL.
-<br>
+<p>
+The <a href="https://lpdaac.usgs.gov/sites/default/files/public/measures/docs/NASA_SRTM_V3.pdf/">SRTM v3 documentation</a>.
+<p>
The <a href="http://pub7.bravenet.com/forum/537683448/">SRTM Web Forum</a>
<h2>REFERENCES</h2>
Modified: grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py
--- grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py 2015-01-20 19:46:28 UTC (rev 64261)
+++ grass-addons/grass7/raster/r.in.srtm.region/r.in.srtm.region.py 2015-01-20 19:52:27 UTC (rev 64262)
@@ -61,6 +61,10 @@
#% label: Import SRTM v2 tiles
#% description: Default: Import SRTM v3 tiles
#%end
+#%flag
+#% key: 1
+#% description: Import 1-arcsec tiles (default: 3-arcsec)
+#%end
proj = ''.join([
@@ -81,17 +85,23 @@
import grass.script as grass
-def import_local_tile(tile, local, pid, srtmv3):
+def import_local_tile(tile, local, pid, srtmv3, one):
output = tile + '.r.in.srtm.tmp.' + str(pid)
if srtmv3:
- local_tile = str(tile) + '.SRTMGL3.hgt.zip'
+ if one:
+ local_tile = str(tile) + '.SRTMGL1.hgt.zip'
+ else:
+ local_tile = str(tile) + '.SRTMGL3.hgt.zip'
else:
local_tile = str(tile) + '.hgt.zip'
path = os.path.join(local, local_tile)
if os.path.exists(path):
- grass.run_command('r.in.srtm', input = path, output = output, quiet = True)
+ if one:
+ grass.run_command('r.in.srtm', input = path, output = output, flags = '1', quiet = True)
+ else:
+ grass.run_command('r.in.srtm', input = path, output = output, quiet = True)
return 1
# SRTM subdirs: Africa, Australia, Eurasia, Islands, North_America, South_America
@@ -100,15 +110,21 @@
path = os.path.join(local, srtmdir, local_tile)
+ if one:
+ else:
return 1
return 0
-def download_tile(tile, url, pid, srtmv3):
+def download_tile(tile, url, pid, srtmv3, one):
if srtmv3:
+ if one:
+ else:
else:
@@ -175,14 +191,23 @@
memory = options['memory']
fillnulls = flags['n']
srtmv3 = (flags['2'] == 0)
+ one = flags['1']
+ res = '00:00:03'
if srtmv3:
fillnulls = 0
+ if one:
+ res = '00:00:01'
+ else:
+ one = None
if len(local) == 0:
if len(url) == 0:
if srtmv3:
- url = 'http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/'
+ if one:
+ url = 'http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL1.003/2000.02.11/'
+ else:
+ url = 'http://e4ftl01.cr.usgs.gov/SRTM/SRTMGL3.003/2000.02.11/'
else:
url = 'http://dds.cr.usgs.gov/srtm/version2_1/SRTM3/'
@@ -283,11 +308,11 @@
grass.debug("Tile: %s" % tile, debug = 1)
if local != tmpdir:
- gotit = import_local_tile(tile, local, pid, srtmv3)
+ gotit = import_local_tile(tile, local, pid, srtmv3, one)
else:
- gotit = download_tile(tile, url, pid, srtmv3)
+ gotit = download_tile(tile, url, pid, srtmv3, one)
if gotit == 1:
- gotit = import_local_tile(tile, tmpdir, pid, srtmv3)
+ gotit = import_local_tile(tile, tmpdir, pid, srtmv3, one)
if gotit == 1:
grass.verbose(_("Tile %s successfully imported") % tile)
valid_tiles += 1
@@ -314,7 +339,7 @@
else:
tmpw = '%03d:59:58.5E' % (edeg - 1)
- grass.run_command('g.region', n = tmpn, s = tmps, e = tmpe, w = tmpw, res = '00:00:03')
+ grass.run_command('g.region', n = tmpn, s = tmps, e = tmpe, w = tmpw, res = res)
grass.run_command('r.mapcalc', expression = "%s = 0" % (tile + '.r.in.srtm.tmp.' + str(pid)), quiet = True)
grass.run_command('g.region', region = tmpregionname)
