[GRASS-SVN] r64353 - grass/trunk/vector/v.in.ogr
svn_grass at osgeo.org
Thu Jan 29 00:50:45 PST 2015
Author: mmetz
Date: 2015-01-29 00:50:45 -0800 (Thu, 29 Jan 2015)
New Revision: 64353
grass/trunk/vector/v.in.ogr/main.c
v.in.ogr: do not use old projection for area calculations in new projection
Modified: grass/trunk/vector/v.in.ogr/main.c
--- grass/trunk/vector/v.in.ogr/main.c 2015-01-29 08:47:24 UTC (rev 64352)
+++ grass/trunk/vector/v.in.ogr/main.c 2015-01-29 08:50:45 UTC (rev 64353)
@@ -310,12 +310,6 @@
if (G_parser(argc, argv))
exit(EXIT_FAILURE);
- G_begin_polygon_area_calculations(); /* Used in geom() */
- /* TODO: threshold might be recalculated with optional geodesic support to meters */
- if (G_projection() == PROJECTION_LL)
- G_important_message(_("Note: In latitude-longitude coordinate system specify threshold in degree unit"));
OGRRegisterAll();
/* list supported formats */
@@ -532,9 +526,154 @@
/* Get first imported layer to use for extents and projection check */
Ogr_layer = OGR_DS_GetLayer(Ogr_ds, layers[0]);
+ /* projection check must come before extents check */
+ /* Fetch input map projection in GRASS form. */
+ proj_info = NULL;
+ proj_units = NULL;
+ Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
+ /* Do we need to create a new location? */
+ G_get_window(&cellhd);
+ if (param.outloc->answer != NULL) {
+ /* Convert projection information non-interactively as we can't
+ * assume the user has a terminal open */
+ if (GPJ_osr_to_grass(&cellhd, &proj_info,
+ &proj_units, Ogr_projection, 0) < 0) {
+ G_fatal_error(_("Unable to convert input map projection to GRASS "
+ "format; cannot create new location."));
+ else {
+ if (0 != G_make_location(param.outloc->answer, &cellhd,
+ proj_info, proj_units)) {
+ G_fatal_error(_("Unable to create new location <%s>"),
+ param.outloc->answer);
+ G_message(_("Location <%s> created"), param.outloc->answer);
+ G_unset_window(); /* new location, projection, and window */
+ /* If the i flag is set, clean up? and exit here */
+ if(flag.no_import->answer)
+ OGR_DS_Destroy(Ogr_ds);
+ exit(EXIT_SUCCESS);
+ else {
+ int err = 0;
+ /* Projection only required for checking so convert non-interactively */
+ G_warning(_("Unable to convert input map projection information to "
+ "GRASS format for checking"));
+ /* Does the projection of the current location match the dataset? */
+ /* G_get_window seems to be unreliable if the location has been changed */
+ G_get_default_window(&loc_wind);
+ /* fetch LOCATION PROJ info */
+ if (loc_wind.proj != PROJECTION_XY) {
+ loc_proj_info = G_get_projinfo();
+ loc_proj_units = G_get_projunits();
+ if (flag.over->answer) {
+ cellhd.proj = loc_wind.proj;
+ cellhd.zone = loc_wind.zone;
+ G_message(_("Over-riding projection check"));
+ else if (loc_wind.proj != cellhd.proj
+ || (err =
+ G_compare_projections(loc_proj_info, loc_proj_units,
+ proj_info, proj_units)) != TRUE) {
+ int i_value;
+ strcpy(error_msg,
+ _("Projection of dataset does not"
+ " appear to match current location.\n\n"));
+ /* TODO: output this info sorted by key: */
+ if (loc_wind.proj != cellhd.proj || err != -2) {
+ if (loc_proj_info != NULL) {
+ strcat(error_msg, _("GRASS LOCATION PROJ_INFO is:\n"));
+ for (i_value = 0; i_value < loc_proj_info->nitems;
+ i_value++)
+ sprintf(error_msg + strlen(error_msg), "%s: %s\n",
+ loc_proj_info->key[i_value],
+ loc_proj_info->value[i_value]);
+ strcat(error_msg, "\n");
+ if (proj_info != NULL) {
+ strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
+ for (i_value = 0; i_value < proj_info->nitems; i_value++)
+ proj_info->key[i_value],
+ proj_info->value[i_value]);
+ else {
+ if (cellhd.proj == PROJECTION_XY)
+ "Dataset proj = %d (unreferenced/unknown)\n",
+ cellhd.proj);
+ else if (cellhd.proj == PROJECTION_LL)
+ "Dataset proj = %d (lat/long)\n",
+ cellhd.proj);
+ else if (cellhd.proj == PROJECTION_UTM)
+ "Dataset proj = %d (UTM), zone = %d\n",
+ cellhd.proj, cellhd.zone);
+ else
+ "Dataset proj = %d (unknown), zone = %d\n",
+ else {
+ if (loc_proj_units != NULL) {
+ strcat(error_msg, "GRASS LOCATION PROJ_UNITS is:\n");
+ for (i_value = 0; i_value < loc_proj_units->nitems;
+ i_value++)
+ loc_proj_units->key[i_value],
+ loc_proj_units->value[i_value]);
+ if (proj_units != NULL) {
+ strcat(error_msg, "Import dataset PROJ_UNITS is:\n");
+ for (i_value = 0; i_value < proj_units->nitems; i_value++)
+ proj_units->key[i_value],
+ proj_units->value[i_value]);
+ _("\nYou can use the -o flag to %s to override this projection check.\n"),
+ G_program_name());
+ strcat(error_msg,
+ _("Consider generating a new location with 'location' parameter"
+ " from input data set.\n"));
+ G_fatal_error(error_msg);
+ else {
+ G_verbose_message(_("Projection of input dataset and current location "
+ "appear to match"));
+ G_begin_polygon_area_calculations(); /* Used in geom() */
+ /* TODO: threshold might be recalculated with optional geodesic support to meters */
+ if (G_projection() == PROJECTION_LL)
+ G_important_message(_("Note: In latitude-longitude coordinate system specify threshold in degree unit"));
/* fetch boundaries */
- G_get_window(&cellhd);
if ((OGR_L_GetExtent(Ogr_layer, &oExt, 1)) == OGRERR_NONE) {
cellhd.north = ymax = oExt.MaxY;
cellhd.south = ymin = oExt.MinY;
@@ -688,141 +827,6 @@
sqrt((cellhd.east - cellhd.west) * (cellhd.north - cellhd.south));
- /* Fetch input map projection in GRASS form. */
- proj_info = NULL;
- proj_units = NULL;
- Ogr_projection = OGR_L_GetSpatialRef(Ogr_layer); /* should not be freed later */
- /* Do we need to create a new location? */
- if (param.outloc->answer != NULL) {
- /* Convert projection information non-interactively as we can't
- * assume the user has a terminal open */
- if (GPJ_osr_to_grass(&cellhd, &proj_info,
- &proj_units, Ogr_projection, 0) < 0) {
- G_fatal_error(_("Unable to convert input map projection to GRASS "
- "format; cannot create new location."));
- else {
- if (0 != G_make_location(param.outloc->answer, &cellhd,
- proj_info, proj_units)) {
- G_fatal_error(_("Unable to create new location <%s>"),
- param.outloc->answer);
- G_message(_("Location <%s> created"), param.outloc->answer);
- /* If the i flag is set, clean up? and exit here */
- if(flag.no_import->answer)
- OGR_DS_Destroy(Ogr_ds);
- exit(EXIT_SUCCESS);
- else {
- int err = 0;
- /* Projection only required for checking so convert non-interactively */
- G_warning(_("Unable to convert input map projection information to "
- "GRASS format for checking"));
- /* Does the projection of the current location match the dataset? */
- /* G_get_window seems to be unreliable if the location has been changed */
- G_get_default_window(&loc_wind);
- /* fetch LOCATION PROJ info */
- if (loc_wind.proj != PROJECTION_XY) {
- loc_proj_info = G_get_projinfo();
- loc_proj_units = G_get_projunits();
- if (flag.over->answer) {
- cellhd.proj = loc_wind.proj;
- cellhd.zone = loc_wind.zone;
- G_message(_("Over-riding projection check"));
- else if (loc_wind.proj != cellhd.proj
- || (err =
- G_compare_projections(loc_proj_info, loc_proj_units,
- proj_info, proj_units)) != TRUE) {
- int i_value;
- strcpy(error_msg,
- _("Projection of dataset does not"
- " appear to match current location.\n\n"));
- /* TODO: output this info sorted by key: */
- if (loc_wind.proj != cellhd.proj || err != -2) {
- if (loc_proj_info != NULL) {
- strcat(error_msg, _("GRASS LOCATION PROJ_INFO is:\n"));
- for (i_value = 0; i_value < loc_proj_info->nitems;
- i_value++)
- sprintf(error_msg + strlen(error_msg), "%s: %s\n",
- loc_proj_info->key[i_value],
- loc_proj_info->value[i_value]);
- strcat(error_msg, "\n");
- if (proj_info != NULL) {
- strcat(error_msg, _("Import dataset PROJ_INFO is:\n"));
- for (i_value = 0; i_value < proj_info->nitems; i_value++)
- proj_info->key[i_value],
- proj_info->value[i_value]);
- else {
- if (cellhd.proj == PROJECTION_XY)
- "Dataset proj = %d (unreferenced/unknown)\n",
- cellhd.proj);
- else if (cellhd.proj == PROJECTION_LL)
- "Dataset proj = %d (lat/long)\n",
- cellhd.proj);
- else if (cellhd.proj == PROJECTION_UTM)
- "Dataset proj = %d (UTM), zone = %d\n",
- cellhd.proj, cellhd.zone);
- else
- "Dataset proj = %d (unknown), zone = %d\n",
- else {
- if (loc_proj_units != NULL) {
- strcat(error_msg, "GRASS LOCATION PROJ_UNITS is:\n");
- for (i_value = 0; i_value < loc_proj_units->nitems;
- i_value++)
- loc_proj_units->key[i_value],
- loc_proj_units->value[i_value]);
- if (proj_units != NULL) {
- strcat(error_msg, "Import dataset PROJ_UNITS is:\n");
- for (i_value = 0; i_value < proj_units->nitems; i_value++)
- proj_units->key[i_value],
- proj_units->value[i_value]);
- _("\nYou can use the -o flag to %s to override this projection check.\n"),
- G_program_name());
- strcat(error_msg,
- _("Consider generating a new location with 'location' parameter"
- " from input data set.\n"));
- G_fatal_error(error_msg);
- else {
- G_verbose_message(_("Projection of input dataset and current location "
- "appear to match"));
db_init_string(&sql);
db_init_string(&strval);
