[GRASS-SVN] r64355 - grass-addons/grass7/raster/v.in.proj
svn_grass at osgeo.org
Thu Jan 29 00:53:21 PST 2015
Author: mmetz
Date: 2015-01-29 00:53:21 -0800 (Thu, 29 Jan 2015)
New Revision: 64355
Added:
grass-addons/grass7/raster/v.in.proj/v.in.proj.html
grass-addons/grass7/raster/v.in.proj/v.in.proj.py
Removed:
grass-addons/grass7/raster/v.in.proj/r.in.proj.html
grass-addons/grass7/raster/v.in.proj/r.in.proj.py
grass-addons/grass7/raster/v.in.proj/Makefile
v.in.proj: vector import and reprojection at once
Modified: grass-addons/grass7/raster/v.in.proj/Makefile
--- grass-addons/grass7/raster/v.in.proj/Makefile 2015-01-29 08:51:41 UTC (rev 64354)
+++ grass-addons/grass7/raster/v.in.proj/Makefile 2015-01-29 08:53:21 UTC (rev 64355)
@@ -1,6 +1,6 @@
MODULE_TOPDIR = ../..
-PGM = r.in.proj
+PGM = v.in.proj
include $(MODULE_TOPDIR)/include/Make/Script.make
Deleted: grass-addons/grass7/raster/v.in.proj/r.in.proj.html
--- grass-addons/grass7/raster/v.in.proj/r.in.proj.html 2015-01-29 08:51:41 UTC (rev 64354)
+++ grass-addons/grass7/raster/v.in.proj/r.in.proj.html 2015-01-29 08:53:21 UTC (rev 64355)
@@ -1,48 +0,0 @@
-<h2>DESCRIPTION</h2>
-<em>r.in.proj</em> imports selected bands from a GDAL raster datasouce
-into the current location and mapset. If the projection of the input
-does not match the projection of the location, the input is reprojected
-into the current location. If the projection of the input does match
-the projection of the location, the input is imported directly with <a
-href="r.in.gdal.html">r.in.gdal</a>.
-<h4>Resolution</h4>
-<em>r.in.proj</em> reports the estimated target resolution for each
-input band. The estimated resolution will usually be some floating
-point number, e.g. 271.301. The target resolution should be the rounded
-estimated resolution, e.g. 250 or 300 instead of 271.301. For latlong
-locations, the resolution might be set to arc seconds, e.g. 1, 3, 7.5,
-15, and 30 arc seconds are commonly used resolutions.
-<h4>Resampling methods</h4>
-<b>nearest</b> is the simplest method and the only possible method for
-categorical data.
-<p>
-<b>bilinear</b> does linear interpolation and provides smoother output
-than <b>nearest</b>. <b>bilinear</b> is recommended when reprojecting a
-DEM for hydrological analysis or for surfaces where overshoots must be
-avoided, e.g. precipitation should not become negative.
-<p>
-<b>bicubic</b> produces smoother output than <b>bilinear</b>, at
-the cost of overshoots.
-<p>
-<b>lanczos</b> produces the smoothest output of all methods and
-preserves contrast best. <b>lanczos</b> is recommended for imagery.
-Both <b>bicubic</b> and <b>lanczos</b> preserve linear features. With
-<b>nearest</b> or <b>bilinear</b>, linear features can become zigzag
-features after reprojection.
-<h2>SEE ALSO</h2>
-<em>
-<a href="r.in.gdal.html">r.in.gdal</a>,<br>
-<a href="r.proj.html">r.proj</a>
-</em>
-<h2>AUTHORS</h2>
-Markus Metz<br>
-<p><i>Last changed: $Date: 2015-01-20 20:52:27 +0100 (Tue, 20 Jan 2015) $</i>
Deleted: grass-addons/grass7/raster/v.in.proj/r.in.proj.py
--- grass-addons/grass7/raster/v.in.proj/r.in.proj.py 2015-01-29 08:51:41 UTC (rev 64354)
+++ grass-addons/grass7/raster/v.in.proj/r.in.proj.py 2015-01-29 08:53:21 UTC (rev 64355)
@@ -1,337 +0,0 @@
-#!/usr/bin/env python
-# MODULE: r.in.proj
-# AUTHOR(S): Markus Metz
-# PURPOSE: Import and reproject on the fly
-# COPYRIGHT: (C) 2015 GRASS development team
-# This program is free software under the GNU General
-# Public License (>=v2). Read the file COPYING that
-# comes with GRASS for details.
-#%module
-#% description: Import raster data using GDAL library and reproject on the fly.
-#% keyword: raster
-#% keyword: import
-#% keyword: projection
-#%end
-#%option G_OPT_F_INPUT
-#% key: input_file
-#% required: no
-#% multiple: no
-#% description: Name of GDAL dataset (file) to be imported
-#% guisection: Input
-#%end
-#%option G_OPT_M_DIR
-#% key: input_directory
-#% required: no
-#% multiple: no
-#% description: Name of GDAL dataset (directory) to be imported
-#%end
-#%option
-#% key: band
-#% type: integer
-#% required: no
-#% multiple: yes
-#% description: Input band(s) to select (default is all bands)
-#%end
-#%option
-#% key: memory
-#% type: integer
-#% required: no
-#% multiple: no
-#% options: 0-2047
-#% label: Maximum memory to be used (in MB)
-#% description: Cache size for raster rows
-#% answer: 300
-#%end
-#%option G_OPT_R_OUTPUT
-#% required: yes
-#% multiple: no
-#% key_desc: name
-#% description: Name for output raster map
-#% guisection: Output
-#%end
-#%option
-#% key: resample
-#% type: string
-#% required: yes
-#% multiple: no
-#% options: nearest,bilinear,bicubic,lanczos,bilinear_f,bicubic_f,lanczos_f
-#% description: Resampling method to use for reprojection
-#% descriptions: nearest;nearest neighbor;bilinear;bilinear interpolation;bicubic;bicubic interpolation;lanczos;lanczos filter;bilinear_f;bilinear interpolation with fallback;bicubic_f;bicubic interpolation with fallback;lanczos_f;lanczos filter with fallback
-#%end
-#%option
-#% key: extents
-#% type: string
-#% required: yes
-#% multiple: no
-#% options: region,input
-#% description: Ouput raster map extents
-#% descriptions: region;extents of current region;input;extents of input map
-#%end
-#%option
-#% key: resolution
-#% type: double
-#% required: no
-#% multiple: no
-#% description: Resolution of output raster map (default: current region)
-#%end
-#%flag
-#% key: i
-#% description: Import and reproject (default: estimate resolution only)
-#%end
-#%flag
-#% key: n
-#% description: Do not perform region cropping optimization
-#%end
-import sys
-import os
-import shutil
-import atexit
-import math
-import grass.script as grass
-def cleanup():
- # remove temp location
- if tmploc:
- path = os.path.join(gisdbase, tmploc)
- grass.try_rmdir(path)
- if srcgisrc:
- grass.try_remove(srcgisrc)
-def main():
- global tmploc, srcgisrc, gisdbase
- output = options['output']
- method = options['resample']
- memory = options['memory']
- do_import = flags['i']
- bands = None
- if options['band']:
- bands = options['band']
- tgtres = None
- if options['resolution']:
- tgtres = options['resolution']
- # initialize global vars
- tmploc = None
- srcgisrc = None
- gisdbase = None
- # make sure current location is not xy
- if grass.parse_command('g.proj', flags = 'g')['name'] == 'xy_location_unprojected':
- grass.fatal(_("The current location is a XY location (unprojected)"))
- sys.exit(1)
- GDALdatasource = None
- if options['input_file']:
- GDALdatasource = options['input_file']
- if not GDALdatasource:
- GDALdatasource = options['input_directory']
- grass.fatal(_("Either option 'input_file' or option 'input_directory' must be given"))
- # TODO: check if input is a dataset recognized by GDAL */
- # compare output of g.proj -j and g.proj -j georef=GDALdatasource
- insrs = grass.read_command('g.proj', flags = 'j', georef = GDALdatasource, quiet = True)
- tgtsrs = grass.read_command('g.proj', flags = 'j', quiet = True)
- if insrs == tgtsrs:
- # try r.in.gdal directly
- grass.message(_("Trying direct import of <%s>...") % GDALdatasource)
- ps = grass.start_command('r.in.gdal', input = GDALdatasource,
- band = bands, output = output,
- memory = memory, flags = 'k')
- returncode = ps.wait()
- # if it succeeds, return
- if returncode == 0:
- grass.message(_("Input <%s> successfully imported without reprojection") % GDALdatasource)
- sys.exit(0)
- grassenv = grass.gisenv()
- tgtloc = grassenv['LOCATION_NAME']
- tgtmapset = grassenv['MAPSET']
- gisdbase = grassenv['GISDBASE']
- tgtgisrc = os.environ['GISRC']
- srcgisrc = grass.tempfile()
- tmploc = 'temp_import_location_' + str(os.getpid())
- # r.in.gdal with location=temp location
- grass.message(_("Importing <%s> ...") % GDALdatasource)
- memory = memory, flags = 'k',
- location = tmploc)
- # if it fails, return
- if returncode != 0:
- grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
- sys.exit(1)
- f = open(srcgisrc, 'w')
- f.write('DEBUG: 0\n')
- f.write('MAPSET: PERMANENT\n')
- f.write('GISDBASE: %s\n' % gisdbase)
- f.write('LOCATION_NAME: %s\n' % tmploc);
- f.write('GUI: text\n')
- f.close()
- # switch to temp location
- os.environ['GISRC'] = str(srcgisrc)
- outfiles = grass.list_grouped('rast')['PERMANENT']
- # make sure input is not xy
- grass.fatal(_("Coordinate reference system not available for input <%s>") % GDALdatasource)
- sys.exit(1)
- # is output a group?
- group = False
- path = os.path.join(gisdbase, tmploc, 'group', output)
- if os.path.exists(path):
- group = True
- path = os.path.join(gisdbase, tmploc, 'group', output, 'POINTS')
- grass.fatal(_("Input contains GCPs, rectification is required"))
- sys.exit(1)
- # switch to target location
- os.environ['GISRC'] = str(tgtgisrc)
- if tgtres is not None and float(tgtres) <= 0:
- tgtres = None
- region = grass.region()
- if tgtres is not None:
- outres = tgtres
- else:
- outres = (region['ewres'] + region['nsres']) / 2.0
- rflags = None
- if flags['n']:
- rflags = 'n'
- for outfile in outfiles:
- n = region['n']
- s = region['s']
- e = region['e']
- w = region['w']
- grass.use_temp_region()
- if options['extents'] == 'input':
- # r.proj -g
- try:
- tgtextents = grass.read_command('r.proj', location = tmploc,
- mapset = 'PERMANENT',
- input = outfile, flags = 'g',
- memory = memory, quiet = True)
- except:
- grass.fatal(_("Unable to get reprojected map extents"))
- sys.exit(1)
- srcregion = grass.parse_key_val(tgtextents, val_type = float, vsep = ' ')
- n = srcregion['n']
- s = srcregion['s']
- e = srcregion['e']
- w = srcregion['w']
- grass.run_command('g.region', n = n, s = s, e = e, w = w)
- # v.in.region in tgt
- vreg = 'vreg_' + str(os.getpid())
- grass.run_command('v.in.region', output = vreg, quiet = True)
- grass.del_temp_region()
- # reproject to src
- ps = grass.start_command('v.proj', input = vreg, output = vreg,
- location = tgtloc, mapset = tgtmapset, quiet = True)
- grass.fatal(_("Unable to reproject to source location"))
- sys.exit(1)
- # set region from region vector
- grass.run_command('g.region', raster = outfile)
- grass.run_command('g.region', vector = vreg)
- # align to fist band
- grass.run_command('g.region', align = outfile)
- # get number of cells
- cells = grass.region()['cells']
- # resolution = sqrt((n - s) * (e - w) / cells)
- estres = math.sqrt((n - s) * (e - w) / cells)
- grass.run_command('g.remove', type = 'vector', name = vreg,
- flags = 'f', quiet = True)
- grass.message(_("Estimated target resolution for input band <%s>: %g") % (outfile, estres))
- grass.message(_("Specified target resolution: %g") % outres)
- if do_import:
- # r.proj
- grass.message(_("Reprojecting <%s>...") % outfile)
- ps = grass.start_command('r.proj', location = tmploc,
- mapset = 'PERMANENT', input = outfile,
- method = method, resolution = tgtres,
- memory = memory, flags = rflags, quiet = True)
- grass.fatal(_("Unable to to reproject raster <%s>") % outfile)
- sys.exit(1)
- if grass.raster_info(outfile)['min'] is None:
- grass.fatal(_("The reprojected raster <%s> is empty") % outfile)
- sys.exit(1)
- if do_import:
- if group:
- grass.run_command('i.group', group = output, input = ','.join(outfiles))
-if __name__ == "__main__":
- options, flags = grass.parser()
- atexit.register(cleanup)
- main()
Copied: grass-addons/grass7/raster/v.in.proj/v.in.proj.html (from rev 64354, grass-addons/grass7/raster/v.in.proj/r.in.proj.html)
--- grass-addons/grass7/raster/v.in.proj/v.in.proj.html (rev 0)
+++ grass-addons/grass7/raster/v.in.proj/v.in.proj.html 2015-01-29 08:53:21 UTC (rev 64355)
@@ -0,0 +1,33 @@
+<h2>DESCRIPTION</h2>
+<em>v.in.proj</em> imports selected layers from a OGR raster datasouce
+into the current location and mapset. If the projection of the input
+does not match the projection of the location, the input is reprojected
+into the current location. If the projection of the input does match
+the projection of the location, the input is imported directly with <a
+href="v.in.ogr.html">v.in.ogr</a>.
+<h4>Topology cleaning</h4>
+When importing polygons, non-topological polygons are converted to
+topological areas. If the original polygons contain errors (unexpected
+overlapping areas or small gaps between polygons), the import might
+need to be repeated using the <em>snap</em> option for <a
+href="v.in.ogr.html">v.in.ogr</a>. In this case, automated import and
+reprojection does not work, and the data need to be manually imported
+first with appropriate settings and optionally cleaned afterwards with
+<a href="v.clean.html">v.clean</a>. The cleaned import can then be
+manually reprojected to the target location.
+<h2>SEE ALSO</h2>
+<em>
+<a href="v.in.ogr.html">v.in.ogr</a>,<br>
+<a href="v.proj.html">v.proj</a>
+</em>
+<h2>AUTHORS</h2>
+Markus Metz<br>
+<p><i>Last changed: $Date: 2015-01-20 20:52:27 +0100 (Tue, 20 Jan 2015) $</i>
Copied: grass-addons/grass7/raster/v.in.proj/v.in.proj.py (from rev 64354, grass-addons/grass7/raster/v.in.proj/r.in.proj.py)
--- grass-addons/grass7/raster/v.in.proj/v.in.proj.py (rev 0)
+++ grass-addons/grass7/raster/v.in.proj/v.in.proj.py 2015-01-29 08:53:21 UTC (rev 64355)
@@ -0,0 +1,262 @@
+#!/usr/bin/env python
+# MODULE: v.in.proj
+# AUTHOR(S): Markus Metz
+# PURPOSE: Import and reproject on the fly
+# COPYRIGHT: (C) 2015 GRASS development team
+# This program is free software under the GNU General
+# Public License (>=v2). Read the file COPYING that
+# comes with GRASS for details.
+#%module
+#% description: Import vector data using OGR library and reproject on the fly.
+#% keyword: vector
+#% keyword: import
+#% keyword: projection
+#%end
+#%option G_OPT_F_INPUT
+#% key: input_file
+#% required: no
+#% multiple: no
+#% description: Name of OGR datasource (file) to be imported
+#% guisection: Input
+#%end
+#%option G_OPT_M_DIR
+#% key: input_directory
+#% required: no
+#% multiple: no
+#% description: Name of OGR datasource (directory) to be imported
+#%end
+#%option
+#% key: layer
+#% type: string
+#% required: no
+#% multiple: yes
+#% description: OGR layer name. If not given, all available layers are imported
+#%end
+#%option G_OPT_V_OUTPUT
+#% required: yes
+#% multiple: no
+#% key_desc: name
+#% description: Name for output vector map
+#% guisection: Output
+#%end
+#%option
+#% key: extents
+#% type: string
+#% required: yes
+#% multiple: no
+#% options: region,input
+#% description: Ouput vector map extents
+#% descriptions: region;extents of current region;input;extents of input map
+#%end
+import sys
+import os
+import shutil
+import atexit
+import math
+import grass.script as grass
+def cleanup():
+ # remove temp location
+ if tmploc:
+ path = os.path.join(gisdbase, tmploc)
+ grass.try_rmdir(path)
+ if srcgisrc:
+ grass.try_remove(srcgisrc)
+def main():
+ global tmploc, srcgisrc, gisdbase
+ output = options['output']
+ layers = None
+ if options['layer']:
+ layers = options['layer']
+ # initialize global vars
+ tmploc = None
+ srcgisrc = None
+ gisdbase = None
+ # make sure current location is not xy
+ if grass.parse_command('g.proj', flags = 'g')['name'] == 'xy_location_unprojected':
+ grass.fatal(_("The current location is a XY location (unprojected)"))
+ sys.exit(1)
+ OGRdatasource = None
+ if options['input_file']:
+ OGRdatasource = options['input_file']
+ if not OGRdatasource:
+ OGRdatasource = options['input_directory']
+ grass.fatal(_("Either option 'input_file' or option 'input_directory' must be given"))
+ # TODO: check if input is a dataset recognized by OGR */
+ # try v.in.ogr directly
+ vflags = None
+ if options['extents'] == 'region':
+ vflags = 'r'
+ grass.message(_("Trying direct import of <%s>...") % OGRdatasource)
+ ps = grass.start_command('v.in.ogr', input = OGRdatasource,
+ layer = layers, output = output, flags = vflags)
+ returncode = ps.wait()
+ # if it succeeds, return
+ if returncode == 0:
+ grass.message(_("Input <%s> successfully imported without reprojection") % OGRdatasource)
+ sys.exit(0)
+ grassenv = grass.gisenv()
+ tgtloc = grassenv['LOCATION_NAME']
+ tgtmapset = grassenv['MAPSET']
+ gisdbase = grassenv['GISDBASE']
+ tgtgisrc = os.environ['GISRC']
+ srcgisrc = grass.tempfile()
+ tmploc = 'temp_import_location_' + str(os.getpid())
+ f = open(srcgisrc, 'w')
+ f.write('DEBUG: 0\n')
+ f.write('MAPSET: PERMANENT\n')
+ f.write('GISDBASE: %s\n' % gisdbase)
+ f.write('LOCATION_NAME: %s\n' % tmploc);
+ f.write('GUI: text\n')
+ f.close()
+ grass.message(_("Importing <%s> ...") % OGRdatasource)
+ if options['extents'] == 'input':
+ # v.in.ogr with location=temp location
+ location = tmploc, verbose = True)
+ # if it fails, return
+ if returncode != 0:
+ grass.fatal(_("Unable to import OGR datasource <%s>") % OGRdatasource)
+ sys.exit(1)
+ # switch to temp location
+ os.environ['GISRC'] = str(srcgisrc)
+ # make sure input is not xy
+ grass.fatal(_("Coordinate reference system not available for input <%s>") % OGRdatasource)
+ sys.exit(1)
+ # switch to target location
+ os.environ['GISRC'] = str(tgtgisrc)
+ # v.proj
+ grass.message(_("Reprojecting <%s>...") % output)
+ ps = grass.start_command('v.proj', location = tmploc,
+ mapset = 'PERMANENT', input = output,
+ quiet = True)
+ grass.fatal(_("Unable to to reproject vector <%s>") % output)
+ sys.exit(1)
+ sys.exit(0)
+ # options['extents'] == 'region'
+ # create location
+ location = tmploc, flags = 'i', quiet = True)
+ grass.fatal(_("Unable to create location from OGR datasource <%s>") % OGRdatasource)
+ sys.exit(1)
+ sys.exit(1)
+ # v.in.region in tgt
+ vreg = 'vreg_' + str(os.getpid())
+ grass.run_command('v.in.region', output = vreg, quiet = True)
+ # reproject to src
+ ps = grass.start_command('v.proj', input = vreg, output = vreg,
+ location = tgtloc, mapset = tgtmapset, quiet = True)
+ grass.fatal(_("Unable to reproject to source location"))
+ sys.exit(1)
+ # set region from region vector
+ grass.run_command('g.region', res = '1')
+ grass.run_command('g.region', vector = vreg)
+ flags = 'r', verbose = True)
+ sys.exit(1)
+ grass.run_command('g.remove', type = 'vector', name = vreg,
+ flags = 'f', quiet = True)
+ # v.proj
+ quiet = True)
+ sys.exit(1)
+ sys.exit(0)
+if __name__ == "__main__":
+ options, flags = grass.parser()
+ atexit.register(cleanup)
+ main()
