[GRASS-SVN] r64365 - in grass/trunk/temporal/t.rast.what: . testsuite
svn_grass at osgeo.org
Fri Jan 30 04:53:17 PST 2015
Author: huhabla
Date: 2015-01-30 04:53:17 -0800 (Fri, 30 Jan 2015)
New Revision: 64365
grass/trunk/temporal/t.rast.what/t.rast.what.py
grass/trunk/temporal/t.rast.what/testsuite/test_what.py
temporal modules: Fixed col layout header, messages are now verbose, integrated stdout output and text coordinates support, integrated suggestions from Stefan Blumentrath. All new features are covered by tests.
Modified: grass/trunk/temporal/t.rast.what/t.rast.what.py
--- grass/trunk/temporal/t.rast.what/t.rast.what.py 2015-01-30 12:49:34 UTC (rev 64364)
+++ grass/trunk/temporal/t.rast.what/t.rast.what.py 2015-01-30 12:53:17 UTC (rev 64365)
@@ -26,13 +26,21 @@
#%option G_OPT_V_INPUT
#% key: points
+#% required: no
#%end
+#%option G_OPT_M_COORDS
+#% required: no
+#%end
#%option G_OPT_STRDS_INPUT
#% key: strds
#%end
#%option G_OPT_F_OUTPUT
+#% required: no
+#% description: Name for the output file or "-" in case stdout should be used
+#% answer: -
#%end
#%option G_OPT_T_WHERE
@@ -67,7 +75,7 @@
#%option
#% key: nprocs
#% type: integer
-#% description: Number of r.neighbor processes to run in parallel
+#% description: Number of r.what processes to run in parallel
#% required: no
#% multiple: no
#% answer: 1
@@ -94,6 +102,7 @@
##% description: Output integer category values, not cell values
##%end
+import sys
import copy
import grass.script as gscript
import grass.temporal as tgis
@@ -106,6 +115,7 @@
# Get the options
points = options["points"]
+ coordinates = options["coordinates"]
strds = options["strds"]
output = options["output"]
where = options["where"]
@@ -121,7 +131,13 @@
#output_cat = flags["i"]
overwrite = gscript.overwrite()
+ if coordinates and points:
+ gscript.fatal(_("Options coordinates and points are mutually exclusive"))
+ if not coordinates and not points:
+ gscript.fatal(_("Please specify the coordinates or the points option, to provide the sampling coordinates"))
# Make sure the temporal database exists
tgis.init()
# We need a database interface
@@ -158,11 +174,23 @@
# flags += "i"
# Configure the r.what module
- r_what = pymod.Module("r.what", map="dummy",
- output="dummy", run_=False,
- separator=separator, points=points,
- overwrite=overwrite, flags=flags,
- quiet=True)
+ if points:
+ r_what = pymod.Module("r.what", map="dummy",
+ output="dummy", run_=False,
+ separator=separator, points=points,
+ overwrite=overwrite, flags=flags,
+ quiet=True)
+ elif coordinates:
+ # Create a list of values
+ coord_list = coordinates.split(",")
+ coordinates=coord_list,
+ quiet=True)
+ else:
+ grass.error(_("Please specify points or coordinates"))
if len(maps) < nprocs:
nprocs = len(maps)
@@ -203,9 +231,9 @@
process_queue.wait()
- gscript.message("Number of raster map layers remaining for sampling %i"%(remaining_maps))
+ gscript.verbose("Number of raster map layers remaining for sampling %i"%(remaining_maps))
if remaining_maps > 0:
- # Use a single process if less then 400 maps
+ # Use a single process if less then 100 maps
if remaining_maps <= 100:
mod = copy.deepcopy(r_what)
mod(map=map_names, output=file_name)
@@ -241,14 +269,15 @@
output is of type: x,y,start,end,value
# open the output file for writing
- out_file = open(output, "w")
+ out_file = open(output, 'w') if output != "-" else sys.stdout
if write_header is True:
out_file.write("x%(sep)sy%(sep)sstart%(sep)send%(sep)svalue\n"\
%({"sep":separator}))
for count in range(len(output_files)):
file_name = output_files[count]
- gscript.message(_("Transforming r.what output file %s"%(file_name)))
+ gscript.verbose(_("Transforming r.what output file %s"%(file_name)))
map_list = output_time_list[count]
in_file = open(file_name, "r")
for line in in_file:
@@ -268,7 +297,9 @@
out_file.write(coor_string + time_string)
in_file.close()
- out_file.close()
+ if out_file is not sys.stdout:
+ out_file.close()
@@ -281,12 +312,12 @@
Each row represents a single raster map, hence a single time stamp
first = True
lines = in_file.readlines()
@@ -299,10 +330,10 @@
if first is True:
- out_file.write("star%(sep)send"%({"sep":separator}))
- for line in lines:
- x = matrix[0][0]
- y = matrix[0][1]
+ out_file.write("start%(sep)send"%({"sep":separator}))
+ for row in matrix:
+ x = row[0]
+ y = row[1]
out_file.write("%(sep)s%(x)10.10f;%(y)10.10f"\
%({"sep":separator,
"x":float(x),
@@ -325,7 +356,8 @@
out_file.write("\n")
in_file.close()
- out_file.close()
+ out_file.close()
@@ -339,7 +371,7 @@
3730731.49590371|5642483.51236521|6|8|7|7
3581249.04638104|5634411.97526282|5|8|7|7
matrix = []
header = ""
@@ -347,7 +379,7 @@
first = True
- gscript.message("Transforming r.what output file %s"%(file_name))
+ gscript.verbose("Transforming r.what output file %s"%(file_name))
@@ -377,7 +409,7 @@
out_file.write(header + "\n")
- gscript.message(_("Writing the output file <%s>"%(output)))
+ gscript.verbose(_("Writing the output file <%s>"%(output)))
for row in matrix:
first = True
for col in row:
@@ -390,8 +422,8 @@
first = False
- out_file.close()
+ out_file.close()
@@ -421,7 +453,9 @@
output_time_list.append(map_list)
- gscript.message(_("Process number %(proc)i samples %(num)i raster maps"%({"proc":process, "num":len(map_names)})))
+ gscript.verbose(_("Process maps %(samp_start)i to %(samp_end)i (of %(total)i)"\
+ %({"samp_start":count-len(map_names)+1,
+ "samp_end":count, "total":len(maps)})))
mod(map=map_names, output=final_file_name)
#print(mod.get_bash())
Modified: grass/trunk/temporal/t.rast.what/testsuite/test_what.py
--- grass/trunk/temporal/t.rast.what/testsuite/test_what.py 2015-01-30 12:49:34 UTC (rev 64364)
+++ grass/trunk/temporal/t.rast.what/testsuite/test_what.py 2015-01-30 12:53:17 UTC (rev 64365)
@@ -48,31 +48,99 @@
self.assertModule("t.rast.what", strds="A", output="out_row.txt",
points="points", flags="n",
layout="row",
- nprocs=1, overwrite=True)
+ nprocs=1, overwrite=True, verbose=True)
self.assertFileMd5("out_row.txt", "55209718566d70e1427bd1fecf844d53")
+ def test_row_output_coords(self):
+ self.assertModule("t.rast.what", strds="A", output="out_row_coords.txt",
+ coordinates=(30,30, 45, 45), flags="n",
+ layout="row",
+ self.assertFileMd5("out_row_coords.txt", "cd917ac4848786f1b944512eed1da5bc")
def test_col_output(self):
self.assertModule("t.rast.what", strds="A", output="out_col.txt",
layout="col",
- self.assertFileMd5("out_col.txt", "825f73e284c0f6e09cf873bd3a1bf15f")
+ self.assertFileMd5("out_col.txt", "8720cc237b46ddb18f11440469d0e13f")
+ def test_col_output_coords(self):
+ self.assertModule("t.rast.what", strds="A", output="out_col_coords.txt",
+ layout="col",
+ self.assertFileMd5("out_col_coords.txt", "ac44ebc5aa040d4ce2a5787e95f208ec")
def test_timerow_output(self):
self.assertModule("t.rast.what", strds="A", output="out_timerow.txt",
layout="timerow",
self.assertFileMd5("out_timerow.txt", "129fe0b63019e505232efa20ad42c03a")
+ def test_timerow_output_coords(self):
+ self.assertModule("t.rast.what", strds="A", output="out_timerow_coords.txt",
+ layout="timerow",
+ self.assertFileMd5("out_timerow_coords.txt", "ca4ee0e7e4aaca170d6034e0d57d292d")
+ def test_row_stdout_where_parallel(self):
+ t_rast_what = SimpleModule("t.rast.what", strds="A", output="-",
+ points="points", flags="n",
+ where="start_time > '2001-03-01'",
+ nprocs=4, overwrite=True, verbose=True)
+ self.assertModule(t_rast_what)
+ text="""x|y|start|end|value
+115.0043586274|36.3593955783|2001-04-01 00:00:00|2001-07-01 00:00:00|200
+79.6816763826|45.2391522853|2001-04-01 00:00:00|2001-07-01 00:00:00|200
+97.4892579600|79.2347263950|2001-04-01 00:00:00|2001-07-01 00:00:00|200
+115.0043586274|36.3593955783|2001-07-01 00:00:00|2001-10-01 00:00:00|300
+79.6816763826|45.2391522853|2001-07-01 00:00:00|2001-10-01 00:00:00|300
+97.4892579600|79.2347263950|2001-07-01 00:00:00|2001-10-01 00:00:00|300
+115.0043586274|36.3593955783|2001-10-01 00:00:00|2002-01-01 00:00:00|400
+79.6816763826|45.2391522853|2001-10-01 00:00:00|2002-01-01 00:00:00|400
+97.4892579600|79.2347263950|2001-10-01 00:00:00|2002-01-01 00:00:00|400
+ self.assertLooksLike(text, t_rast_what.outputs.stdout)
+ def test_row_stdout_where_parallel2(self):
+ """Here without output definition, the default is used then"""
def test_row_output_where_parallel(self):
self.assertModule("t.rast.what", strds="A", output="out_where.txt",
- nprocs=4, overwrite=True)
self.assertFileMd5("out_where.txt", "af731bec01fedc262f4ac162fe420707")
@@ -80,14 +148,18 @@
self.assertModuleFail("t.rast.what", strds="A", output="out_error.txt",
where="start_time > '2002-03-01'",
class TestRasterWhatFails(TestCase):
def test_error_handling(self):
- # No vector map, no strds
+ # No vector map, no strds, no coordinates
self.assertModuleFail("t.rast.what", output="out.txt")
+ # No vector map, no coordinates
+ self.assertModuleFail("t.rast.what", strds="A", output="out.txt")
+ # Points and coordinates are mutually exclusive
+ self.assertModuleFail("t.rast.what", points="points", coordinates=(30, 30, 45, 45), output="out.txt", strds="A")
if __name__ == '__main__':
from grass.gunittest.main import test
