[GRASS-SVN] r64369 - in grass/branches/releasebranch_7_0: . lib/init
svn_grass at osgeo.org
Fri Jan 30 08:25:28 PST 2015
Author: martinl
Date: 2015-01-30 08:25:28 -0800 (Fri, 30 Jan 2015)
New Revision: 64369
grass/branches/releasebranch_7_0/
grass/branches/releasebranch_7_0/lib/init/grass.py
attempt to fix #2552
Property changes on: grass/branches/releasebranch_7_0
___________________________________________________________________
Modified: svn:mergeinfo
- /grass/trunk:64258
+ /grass/trunk:64258,64367
Modified: grass/branches/releasebranch_7_0/lib/init/grass.py
--- grass/branches/releasebranch_7_0/lib/init/grass.py 2015-01-30 13:17:40 UTC (rev 64368)
+++ grass/branches/releasebranch_7_0/lib/init/grass.py 2015-01-30 16:25:28 UTC (rev 64369)
@@ -60,7 +60,7 @@
# i18N
import gettext
-gettext.install('grasslibs', os.path.join(gisbase, 'locale'), unicode=True)
+gettext.install('grasslibs', os.path.join(gisbase, 'locale'))
tmpdir = None
lockfile = None
@@ -857,9 +857,8 @@
del os.environ['LC_ALL'] # Remove LC_ALL to not override LC_NUMERIC
# From now on enforce the new language
- gettext.install('grasslibs', os.path.join(gisbase, 'locale'), unicode=True)
+ gettext.install('grasslibs', os.path.join(gisbase, 'locale'))
def check_lock():
global lockfile
if not os.path.exists(location):
