[GRASS-SVN] r64374 - in grass-addons/grass7/raster: r.stream.basins r.stream.channel r.stream.distance r.stream.order r.stream.segment r.stream.snap r.stream.stats
svn_grass at osgeo.org
Fri Jan 30 14:31:10 PST 2015
Author: mmetz
Date: 2015-01-30 14:31:10 -0800 (Fri, 30 Jan 2015)
New Revision: 64374
grass-addons/grass7/raster/r.stream.basins/basins_inputs.c
grass-addons/grass7/raster/r.stream.basins/io.c
grass-addons/grass7/raster/r.stream.channel/io.c
grass-addons/grass7/raster/r.stream.channel/stream_topology.c
grass-addons/grass7/raster/r.stream.channel/stream_write.c
grass-addons/grass7/raster/r.stream.distance/distance_calc.c
grass-addons/grass7/raster/r.stream.distance/io.c
grass-addons/grass7/raster/r.stream.order/io.c
grass-addons/grass7/raster/r.stream.segment/io.c
grass-addons/grass7/raster/r.stream.snap/io.c
grass-addons/grass7/raster/r.stream.stats/io.c
r-stream: fix NULL handling step 1
Modified: grass-addons/grass7/raster/r.stream.basins/basins_inputs.c
--- grass-addons/grass7/raster/r.stream.basins/basins_inputs.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.basins/basins_inputs.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -210,7 +210,6 @@
for (r = 0; r < nrows; ++r) {
G_percent(r, nrows, 4);
for (c = 0; c < ncols; ++c) {
Segment_get(streams, &streams_cell, r, c);
if (streams_cell > 0) {
if (outlets_num > 6 * (out_max - 1))
Modified: grass-addons/grass7/raster/r.stream.basins/io.c
--- grass-addons/grass7/raster/r.stream.basins/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.basins/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
* map pointer to map structure (created with create_map);
* check_res: [1]: check res correspondence between region and map [0 no check];
* check_data_type [CELL, FCELL, DCELL] check if reading map is of particular type, [-1] no check;
+ * nullval: value to use as NULL value
int r, c;
@@ -395,6 +396,7 @@
* seg: pointer to map structure (created with create_map);
int input_fd;
Modified: grass-addons/grass7/raster/r.stream.channel/io.c
--- grass-addons/grass7/raster/r.stream.channel/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.channel/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
int r, c;
@@ -395,6 +396,7 @@
int input_fd;
Modified: grass-addons/grass7/raster/r.stream.channel/stream_topology.c
--- grass-addons/grass7/raster/r.stream.channel/stream_topology.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.channel/stream_topology.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -328,8 +328,8 @@
for (i = 1; i < number_of_streams; ++i) {
- SA[i].points = (unsigned long int *)
- G_malloc((SA[i].number_of_cells) * sizeof(unsigned long int));
+ SA[i].points = (long int *)
+ G_malloc((SA[i].number_of_cells) * sizeof(long int));
SA[i].elevation = (float *)
G_malloc((SA[i].number_of_cells) * sizeof(float));
SA[i].distance = (double *)
@@ -411,7 +411,7 @@
int i, j = 0;
int next_r, next_c;
- float elev_min = 9999;
+ FCELL elev_min = 9999;
for (i = 1; i < 9; ++i) {
if (NOT_IN_REGION(i))
Modified: grass-addons/grass7/raster/r.stream.channel/stream_write.c
--- grass-addons/grass7/raster/r.stream.channel/stream_write.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.channel/stream_write.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -135,8 +135,8 @@
int r, c;
int i, j, k;
+ STREAM *SA;
double output_cell;
- STREAM *SA;
SA = stream_attributes;
@@ -185,7 +185,7 @@
int r, c;
int i, j;
- double output_cell;
+ double result;
STREAM *SA;
@@ -194,12 +194,12 @@
for (j = 1; j < SA[i].number_of_cells - 1; ++j) {
/* what if any elevation is -99999 ? */
- output_cell = downstream ?
+ result = downstream ?
SA[i].elevation[j - 1] - SA[i].elevation[j] :
SA[i].elevation[j] - SA[i].elevation[j + 1];
r = (int)SA[i].points[j] / ncols;
c = (int)SA[i].points[j] % ncols;
- Segment_put(output, &output_cell, r, c);
+ Segment_put(output, &result, r, c);
@@ -244,8 +244,8 @@
int r, c;
int i, j;
double init;
+ STREAM *SA;
double output_cell;
- STREAM *SA;
@@ -317,9 +317,9 @@
int r, c;
int i, j;
double init;
double cum_length;
STREAM *SA;
+ double output_cell;
@@ -384,8 +384,8 @@
int r, c;
int i, j;
double elev_diff;
+ STREAM *SA;
double output_cell;
- STREAM *SA;
G_debug(3, "seg_calculate_local_gradient(): downstream=%d", downstream);
@@ -433,8 +433,8 @@
int r, c;
int i, j;
+ STREAM *SA;
double output_cell;
- STREAM *SA;
G_debug(3, "seg_calculate_local_distance(): downstream=%d", downstream);
@@ -490,9 +490,9 @@
int r, c;
int i, j;
STREAM *SA;
double first_derivative, second_derivative;
G_debug(3, "seg_calculate_curvature(): downstream=%d", downstream);
Modified: grass-addons/grass7/raster/r.stream.distance/distance_calc.c
--- grass-addons/grass7/raster/r.stream.distance/distance_calc.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.distance/distance_calc.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -36,7 +36,7 @@
POINT n_cell;
double cur_dist = 0;
double tmp_dist = 0;
- double target_elev; /* eleavation at stream or outlet */
+ double target_elev; /* elevation at stream or outlet */
double easting, northing;
double cell_easting, cell_northing;
struct Cell_head window;
@@ -52,6 +52,8 @@
target_elev = elevation[r][c];
elevation[r][c] = 0.;
+ else
+ Rast_set_d_null_value(&target_elev, 1);
while (tail != head) {
easting = window.west + (c + .5) * window.ew_res;
Modified: grass-addons/grass7/raster/r.stream.distance/io.c
--- grass-addons/grass7/raster/r.stream.distance/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.distance/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
int r, c;
@@ -395,6 +396,7 @@
int input_fd;
Modified: grass-addons/grass7/raster/r.stream.order/io.c
--- grass-addons/grass7/raster/r.stream.order/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.order/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
int r, c;
@@ -395,6 +396,7 @@
int input_fd;
Modified: grass-addons/grass7/raster/r.stream.segment/io.c
--- grass-addons/grass7/raster/r.stream.segment/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.segment/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
int r, c;
@@ -395,6 +396,7 @@
int input_fd;
Modified: grass-addons/grass7/raster/r.stream.snap/io.c
--- grass-addons/grass7/raster/r.stream.snap/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.snap/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
int r, c;
@@ -395,6 +396,7 @@
int input_fd;
Modified: grass-addons/grass7/raster/r.stream.stats/io.c
--- grass-addons/grass7/raster/r.stream.stats/io.c 2015-01-30 18:32:32 UTC (rev 64373)
+++ grass-addons/grass7/raster/r.stream.stats/io.c 2015-01-30 22:31:10 UTC (rev 64374)
@@ -53,6 +53,7 @@
int r, c;
@@ -395,6 +396,7 @@
int input_fd;
