[GRASS-SVN] r65532 - grass/trunk/lib/python/pygrass/vector/testsuite
svn_grass at osgeo.org
Wed Jul 1 23:32:09 PDT 2015
Author: zarch
Date: 2015-07-01 23:32:09 -0700 (Wed, 01 Jul 2015)
New Revision: 65532
Added:
grass/trunk/lib/python/pygrass/vector/testsuite/test_filters.py
pygrass: Add tests for Filters class
Added: grass/trunk/lib/python/pygrass/vector/testsuite/test_filters.py
--- grass/trunk/lib/python/pygrass/vector/testsuite/test_filters.py (rev 0)
+++ grass/trunk/lib/python/pygrass/vector/testsuite/test_filters.py 2015-07-02 06:32:09 UTC (rev 65532)
@@ -0,0 +1,82 @@
+# -*- coding: utf-8 -*-
+Created on Thu Jul 2 07:25:34 2015
+ at author: pietro
+from grass.gunittest.case import TestCase
+from grass.gunittest.main import test
+from grass.pygrass.vector.table import Filters
+class FiltersTestCase(TestCase):
+ def setUp(self):
+ """Create a not empty filters instance"""
+ self.filters = Filters('table')
+ self.attrs = ('_select', '_where', '_groupby', '_orderby', '_limit')
+ def test_init(self):
+ """Test Filters __init__"""
+ self.assertEqual(self.filters.tname, 'table')
+ for attr in self.attrs:
+ self.assertEqual(getattr(self.filters, attr), None)
+ def test_select(self):
+ """Test Filters select method"""
+ self.assertEqual(self.filters.select()._select,
+ 'SELECT * FROM table')
+ self.assertEqual(self.filters.select('column')._select,
+ 'SELECT column FROM table')
+ self.assertEqual(self.filters.select('column0', 'column1')._select,
+ 'SELECT column0, column1 FROM table')
+ def test_where(self):
+ """Test Filters where method"""
+ self.assertEqual(self.filters.where('column >= 10')._where,
+ 'WHERE column >= 10')
+ def test_order_by(self):
+ """Test Filters order_by method"""
+ self.assertEqual(self.filters.order_by('column')._orderby,
+ 'ORDER BY column')
+ self.assertEqual(self.filters.order_by('column0', 'column1')._orderby,
+ 'ORDER BY column0, column1')
+ def test_limit(self):
+ """Test Filters limit method"""
+ self.assertEqual(self.filters.limit(10)._limit, 'LIMIT 10')
+ with self.assertRaises(ValueError):
+ self.filters.limit('a')
+ def test_group_by(self):
+ """Test Filters group_by method"""
+ self.assertEqual(self.filters.group_by('column')._groupby,
+ 'GROUP BY column')
+ self.assertEqual(self.filters.group_by('column0', 'column1')._groupby,
+ 'GROUP BY column0, column1')
+ def test_get_sql(self):
+ """Test Filters get_sql method"""
+ sql_code = 'select_sql'
+ sep = '=> '
+ fsep = ' ' + sep
+ self.filters._select = sql_code
+ for attr in self.attrs[1:]:
+ attr_sql = sep + attr[1:]
+ setattr(self.filters, attr, attr_sql)
+ sql_code += fsep + attr[1:]
+ self.assertEqual(self.filters.get_sql(), sql_code + ';')
+ def test_reset(self):
+ """Test Filters reset method"""
+ # fill the attributes with strigns
+ setattr(self.filters, attr, attr)
+ self.filters.reset()
+if __name__ == '__main__':
+ test()
Property changes on: grass/trunk/lib/python/pygrass/vector/testsuite/test_filters.py
___________________________________________________________________
Added: svn:mime-type
+ text/x-python
Added: svn:eol-style
+ native
