[GRASS-SVN] r65535 -	grass/branches/releasebranch_7_0/vector/v.vect.stats
    svn_grass at osgeo.org
    Thu Jul  2 13:42:23 PDT 2015
Author: neteler
Date: 2015-07-02 13:42:23 -0700 (Thu, 02 Jul 2015)
New Revision: 65535
   grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c
   grass/branches/releasebranch_7_0/vector/v.vect.stats/v.vect.stats.html
v.vect.stats: fixed error msgs; examples added
Modified: grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c
--- grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c	2015-07-02 07:43:19 UTC (rev 65534)
+++ grass/branches/releasebranch_7_0/vector/v.vect.stats/main.c	2015-07-02 20:42:23 UTC (rev 65535)
@@ -227,14 +227,14 @@
 	    G_fatal_error("Method but no point column selected");
 	if (!print_flag->answer && !stats_column_opt->answer)
-	    G_fatal_error("Name for stats column is missing");
+	    G_fatal_error("Name for stats_column is missing");
     if (point_column_opt->answer) {
 	if (!method_opt->answer)
 	    G_fatal_error("No method for statistics selected");
     /* Open points vector */
@@ -301,7 +301,7 @@
 			  AFi->database, AFi->driver);
 	if (!count_column_opt->answer)
-	    G_fatal_error(_("ccolumn is required to upload point counts"));
+	    G_fatal_error(_("count_column is required to upload point counts"));
 	/* check if count column exists */
 	G_debug(1, "check if count column exists");
@@ -310,7 +310,7 @@
 	    /* check count column type */
 	    if (db_column_Ctype(Adriver, AFi->table, count_column_opt->answer)
 		!= DB_C_TYPE_INT)
-		G_fatal_error(_("ccolumn must be of type integer"));
+		G_fatal_error(_("count_column must be of type integer"));
 	    db_free_column(column);
 	    column = NULL;
@@ -329,7 +329,7 @@
 	if (method_opt->answer) {
 	    if (!stats_column_opt->answer)
-		G_fatal_error(_("scolumn is required to upload point stats"));
+		G_fatal_error(_("stats_column is required to upload point stats"));
 	    /* check if stats column exists */
 	    G_debug(1, "check if stats column exists");
@@ -340,7 +340,7 @@
 		if (db_column_Ctype
 		     stats_column_opt->answer) != DB_C_TYPE_DOUBLE)
-		    G_fatal_error(_("scolumn must be of type double"));
+		    G_fatal_error(_("stats_column must be of type double precision"));
 		column = NULL;
Modified: grass/branches/releasebranch_7_0/vector/v.vect.stats/v.vect.stats.html
--- grass/branches/releasebranch_7_0/vector/v.vect.stats/v.vect.stats.html	2015-07-02 07:43:19 UTC (rev 65534)
+++ grass/branches/releasebranch_7_0/vector/v.vect.stats/v.vect.stats.html	2015-07-02 20:42:23 UTC (rev 65535)
@@ -6,8 +6,7 @@
 calculated for each area. The results are either uploaded to the
 attribute table of the vector map <em>areas</em> or printed to stdout.
-<h3>OPTIONS</h3>
+<p>
 <em>Statistical Methods:</em>
 Using numeric attribute values of all points falling into a given area,
 a new value is detmined with the selected method.
@@ -65,18 +64,88 @@
 existing. If they do already exist, the <em>count_column</em> must be of
 type integer and the <em>stats_column</em> of type double precision.
-<!-- TODO
+<h2>EXAMPLES</h2>
-<h2>EXAMPLE</h2>
+<h3>Preparation for examples</h3>
+The subsequent examples are based on randomly sampled
+elevation data (North Carolina sample database):
 <div class="code"><pre>
+# work on map copy for attribute editing
+g.copy vector=zipcodes_wake,myzipcodes_wake
+# set computational region: extent of ZIP code map, raster pixels
+# aligned to raster map
+g.region vector=myzipcodes_wake align=elev_state_500m -p
+#  generate random elevation points
+r.random elev_state_500m vector=rand5000 n=5000
+v.colors rand5000 color=elevation
+# visualization
+d.mon wx0
+d.vect myzipcodes_wake -c
+d.vect rand5000
 </pre></div>
+These vector maps are used for the examples below.
+<h3>Count points per polygon with printed output</h3>
+<i>See above for the creation of the input maps.</i>
+<p>
+Counting points per polygon, print results to terminal:
+<div class="code"><pre>
+v.vect.stats points=rand5000 area=myzipcodes_wake -p
+</pre></div>
+<h3>Count points per polygon with column update</h3>
+<p>
+Counting of points per polygon, with update of "num_points" column
+(will be automatically created):
+v.vect.stats points=rand5000 area=myzipcodes_wake count_column=num_points
+# verify result
+v.db.select myzipcodes_wake column=ZIPCODE_,ZIPNAME,num_points
+</pre></div>
+<h3>Average values of points in polygon with printed output</h3>
+<p>
+Calculation of average point elevation per ZIP code
+polygon, printed to terminal in comma separated style:
+# check name of point map column:
+v.info -c rand5000
+v.vect.stats points=rand5000 area=myzipcodes_wake \
+  method=average points_column=value separator=comma -p
+</pre></div>
+<h3>Average values of points in polygon with column update</h3>
+<p>
+Calculation of average point elevation per ZIP code polygon,
+with update of "avg_elev" column and counting of points per polygon,
+with update of "num_points" column (new columns will be automatically
+created):
+v.info -c rand5000
+v.vect.stats points=rand5000 area=myzipcodes_wake count_column=num_points \
+  method=average points_column=value stats_column=avg_elev
+# verify result
+v.db.select myzipcodes_wake column=ZIPCODE_,ZIPNAME,avg_elev
+</pre></div>
 <h2>SEE ALSO</h2>
 <em>
