[GRASS-SVN] r65539 - in grass-addons/grass7/vector/v.kriging: . images images/small
Sun Jul 5 07:28:14 PDT 2015
Author: evas
Date: 2015-07-05 07:28:14 -0700 (Sun, 05 Jul 2015)
New Revision: 65539
Added:
   grass-addons/grass7/vector/v.kriging/images/
   grass-addons/grass7/vector/v.kriging/images/small/
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_exponential.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_exponential_2.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_gauss_1.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_gauss_2.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_linear_1.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_spherical_2.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential_1.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential_2.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss_1.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss_2.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_hz_15000.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_hz_20000.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_linear.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_linear_1.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical_1.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical_2.png
   grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_vertical_1200.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_diff_lid792_500_rst.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_diff_lid792_500_surfer.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_result_exponential.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_result_gauss.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_result_lid792_500.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_result_linear.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_result_spherical.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_exponential.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_gaussian.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_hz_100000.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_lid792_500_linear.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_lid792_500_surfer.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_linear.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_spherical.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_vertical_1600.png
   grass-addons/grass7/vector/v.kriging/images/v_kriging_xvalid_rst_krig.png
   grass-addons/grass7/vector/v.kriging/geostat.c
   grass-addons/grass7/vector/v.kriging/getval.c
   grass-addons/grass7/vector/v.kriging/local_proto.h
   grass-addons/grass7/vector/v.kriging/main.c
   grass-addons/grass7/vector/v.kriging/spatial_index.c
   grass-addons/grass7/vector/v.kriging/utils.c
   grass-addons/grass7/vector/v.kriging/utils_kriging.c
   grass-addons/grass7/vector/v.kriging/v.kriging.html
v.kriging: manual page + debugging
Modified: grass-addons/grass7/vector/v.kriging/geostat.c
--- grass-addons/grass7/vector/v.kriging/geostat.c	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/geostat.c	2015-07-05 14:28:14 UTC (rev 65539)
@@ -86,7 +86,7 @@
   double *dr;   // coordinate differences of each couple
   double *h;    // distance of boundary of the horizontal segment
   double tv;    // bearing of the line between the couple of the input points
-  double ddir;  // the azimuth of computing variogram
+  double ddir1, ddir2;  // the azimuth of computing variogram
   double rv;    // radius of the couple of points
   double drv;   // distance between the points
   double rvh;   // difference between point distance and the horizontal segment boundary
@@ -172,7 +172,7 @@
   if (type == 2) {
     vert = &var_pars->vertical.h[0];
   /* *** Experimental variogram computation *** */
   for (b = 0; b < ncols; b++) {      // for each vertical lag...
     if (type == 2) {                 // just in case that the variogram is vertical
@@ -222,10 +222,15 @@
 	      else {                           // hz / aniso / bivar variogram:
 		tv = atan2(*(dr+1), *dr);      // bearing
+		if (tv < 0.) {
+		  tv += 2. * PI;
-	      ddir = tv - dir;                 // difference between bearing and azimuth
-	      if (fabsf(ddir) <= td) {         // angle test: compare the diff with critical value
+	      ddir1 = dir - tv;                // difference between bearing and azimuth
+	      ddir2 = (dir + PI) - tv;
+	      if (fabsf(ddir1) <= td || fabsf(ddir2) <= td) {         // angle test: compare the diff with critical value
 		// test squared distance: vertical variogram => 0., ...
 		rv = type == 1 ? 0. : radius_hz_diff(dr); // ... otherwise horizontal distance
@@ -336,11 +341,14 @@
   // set up:
   var_pars->type = type;   // hz / vert / bivar / aniso
   var_pars->const_val = 0; // input values are not constants
   switch (type) {
   case 0: // horizontal variogram
     if (i3 == TRUE) { // 3D interpolation (middle phase)
       variogram = opt.function_var_hz->answer; // function type available:
-      if (strcmp(variogram, "linear") != 0) { // nonlinear
+      var_pars->function = set_function(variogram, report);
+      if (strcmp(variogram, "linear") != 0 && strcmp(variogram, "parabolic") != 0) { // nonlinear or not parabolic
 	var_pars->nugget = atof(opt.nugget_hz->answer);
 	var_pars->h_range = atof(opt.range_hz->answer);
 	if (opt.sill_hz->answer) {
@@ -348,12 +356,14 @@
       else { // function type not available:
-	linear_variogram(var_pars, report);
+	LMS_variogram(var_pars, report);
     else { // 2D interpolation (final phase)
       variogram = opt.function_var_final->answer; // function type available:
 	var_pars->nugget = atof(opt.nugget_final->answer);
 	var_pars->h_range = atof(opt.range_final->answer);
 	if (opt.sill_final->answer) {
@@ -361,7 +371,7 @@
@@ -380,6 +390,8 @@
       var_pars->sill = atof(opt.sill_vert->answer);
     variogram = opt.function_var_vert->answer;
     if (report->name) {
       fprintf(report->fp, "Parameters of vertical variogram:\n");
       fprintf(report->fp, "Nugget effect: %f\n", var_pars->nugget);
@@ -390,7 +402,7 @@
   case 2: // bivariate variogram (just final phase)
     if (!(opt.function_var_final->answer && opt.function_var_final_vert->answer) || strcmp(opt.function_var_final->answer, "linear") == 0) { // planar function:
       var_pars->function = 5; // planar variogram (3D)
     else { // function type was set up by the user:
@@ -427,7 +439,9 @@
   case 3: // univariate (just final phase)
-    if (strcmp(variogram, "linear") != 0) { // nonlinear variogram:
+    if (strcmp(variogram, "linear") != 0 && strcmp(variogram, "parabolic") != 0) { // nonlinear and not parabolic variogram:
@@ -446,14 +460,13 @@
 	fprintf(report->fp, "Range:         %f\n", var_pars->h_range);
-    else {
+    else { // linear or parabolic variogram
     break;
   if (type != 2) {
-    var_pars->function = set_function(variogram, report);
     plot_var(i3, FALSE, var_pars); // Plot variogram using gnuplot
@@ -540,7 +553,7 @@
 	  G_percent(row, reg->nrows, 1);
-      //#pragma omp parallel for private(col, r0, cellCent, ind, sqDist, n1, GM, GM_Inv, g0, w0, rslt_OK)
+      //#pragma omp parallel for private(col, r0, GM, GM_Inv, g0, w0, rslt_OK)
       for (col=0; col < reg->ncols; col++) {
 	if (var_par->const_val == 1) { // constant input values
@@ -556,11 +569,12 @@
 	  list = find_NNs_within(3, r0, pnts, max_dist, max_dist_vert);
 	else { // 2D kriging:
-	  list = find_NNs_within(2, r0, pnts, 3. * max_dist, max_dist_vert);
+	  list = find_NNs_within(2, r0, pnts, max_dist, max_dist_vert);
 	if (list->n_values > 1) { // positive # of selected points:
 	  correct_indices(i3, list, r0, pnts, var_par);
 	  GM_sub = submatrix(list, GM, report); // make submatrix for selected points
 	  GM_Inv = G_matrix_inverse(GM_sub);    // invert submatrix
 	  G_matrix_free(GM_sub);
@@ -572,6 +586,7 @@
 	  G_matrix_free(g0);
 	  rslt_OK = result(pnts, list, w0); // Estimated cell/voxel value rslt_OK = w x inputs
+	  G_matrix_free(w0);
 	else if (list->n_values == 1) {
 	  rslt_OK = vals[list->value[0] - 1]; // Estimated cell/voxel value rslt_OK = w x inputs
@@ -584,6 +599,8 @@
 	  G_fatal_error(_("This point does not have neighbours in given radius..."));
 	} // end else: error
+	G_free_ilist(list);    // free list memory
   	  // Create output
       constant_voxel_val:
 	if (var_par->const_val == 1) { // constant input values:
@@ -598,8 +615,6 @@
 	  G_fatal_error(_("Error writing result into output layer..."));
-	G_free_ilist(list);    // free list memory
       } // end col
     } // end row
   } // end dep
Modified: grass-addons/grass7/vector/v.kriging/getval.c
--- grass-addons/grass7/vector/v.kriging/getval.c	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/getval.c	2015-07-05 14:28:14 UTC (rev 65539)
@@ -26,10 +26,10 @@
   else {
     save = 1;
+  G_message(_("Reading values from attribute column <%s>..."), column);
-  G_message(_("Reading values from attribute column <%s>..."), column);
   db_CatValArray_init(&cvarr);	/* array of categories and values initialised */
   Fi = Vect_get_field(map, field);	/* info about call of DB */
   if (Fi == NULL) {
     if (save == 1 && xD->report.write2file == TRUE) { // close report file
@@ -162,7 +162,7 @@
   db_CatValArray_free(&cvarr);	// free memory of the array of categories and values
   return values;
@@ -340,6 +340,10 @@
     G_fatal_error(_("Unable to read coordinates of point layer (all points are out of region)"));
+  if (out_reg > 0) {
+    G_message(_("Unused points: %d (out of region)"), out_reg);
   if (xD->phase == 0) { // initial phase:
     write2file_vector(xD, point);  // describe properties
@@ -401,7 +405,7 @@
   fp = fopen(file_name, "r");
   if (fp == NULL) {
-    G_fatal_error(_("File is missing..."));
+    G_fatal_error(_("Temporary file is missing, please repeat an initial phase..."));
   else { // file exists:
@@ -545,4 +549,8 @@
   fclose(fp);
+  if (xD->phase == 2) {
+    remove(file_name);
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_exponential.png
(Binary files differ)
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_exponential.png
___________________________________________________________________
Added: svn:mime-type
   + application/octet-stream
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_exponential_2.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_exponential_2.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_gauss_1.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_gauss_1.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_gauss_2.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_gauss_2.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_linear_1.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_linear_1.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_spherical_2.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_result_spherical_2.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential_1.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential_1.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential_2.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_exponential_2.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss_1.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss_1.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss_2.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_gauss_2.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_hz_15000.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_hz_15000.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_hz_20000.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_hz_20000.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_linear.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_linear.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_linear_1.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_linear_1.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical_1.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical_1.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical_2.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_spherical_2.png
Added: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_vertical_1200.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/small/v_kriging_variogram_vertical_1200.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_diff_lid792_500_rst.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_diff_lid792_500_rst.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_diff_lid792_500_surfer.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_diff_lid792_500_surfer.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_exponential.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_exponential.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_gauss.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_gauss.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_lid792_500.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_lid792_500.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_linear.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_linear.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_spherical.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_result_spherical.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_exponential.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_exponential.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_gaussian.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_gaussian.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_hz_100000.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_hz_100000.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_lid792_500_linear.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_lid792_500_linear.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_lid792_500_surfer.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_lid792_500_surfer.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_linear.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_linear.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_spherical.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_spherical.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_vertical_1600.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_variogram_vertical_1600.png
Added: grass-addons/grass7/vector/v.kriging/images/v_kriging_xvalid_rst_krig.png
Property changes on: grass-addons/grass7/vector/v.kriging/images/v_kriging_xvalid_rst_krig.png
Modified: grass-addons/grass7/vector/v.kriging/local_proto.h
--- grass-addons/grass7/vector/v.kriging/local_proto.h	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/local_proto.h	2015-07-05 14:28:14 UTC (rev 65539)
@@ -205,6 +205,7 @@
 void triple(double, double, double, double *);
 double lag_size(int, struct int_par *, struct points *, struct parameters *, struct write *);
 int lag_number(double, double *);
+void optimize(double *, int *, double);
 void variogram_restricts(struct int_par *, struct points *, struct parameters *);
 void geometric_anisotropy(struct int_par *, struct points *);
 double find_intersect_x(double *, double *, double *, double *, struct write *);
@@ -216,7 +217,7 @@
 void T_variogram(int, int, struct opts, struct parameters *, struct write *);
 void ordinary_kriging(struct int_par *, struct reg_par *, struct points *, struct var_par *, struct output *);
-void linear_variogram(struct parameters *, struct write *);
+void LMS_variogram(struct parameters *, struct write *);
 double bivar_sill(int, mat_struct *);
 void sill(struct parameters *);
 int sill_compare(struct int_par *, struct flgs *, struct var_par *, struct points *);
Modified: grass-addons/grass7/vector/v.kriging/main.c
--- grass-addons/grass7/vector/v.kriging/main.c	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/main.c	2015-07-05 14:28:14 UTC (rev 65539)
@@ -149,7 +149,7 @@
   opt.var_dir_hz->key = "azimuth";
   opt.var_dir_hz->type = TYPE_DOUBLE;
   opt.var_dir_hz->required = NO;
-  opt.var_dir_hz->answer = "0.0";
+  opt.var_dir_hz->answer = "45.0";
   opt.var_dir_hz->description =
     _("Azimuth of variogram computing (isotrophic)");
   opt.var_dir_hz->guisection = _("Initial");
@@ -181,7 +181,7 @@
   opt.td_hz = G_define_option();
   opt.td_hz->key = "td";
   opt.td_hz->type = TYPE_DOUBLE;
-  opt.td_hz->answer = "90.0";
+  opt.td_hz->answer = "45.0";
   opt.td_hz->description = _("Angle of variogram processing");
   opt.td_hz->required = NO;
   opt.td_hz->guisection = _("Initial");
@@ -189,6 +189,7 @@
   opt.nugget_hz = G_define_option();
   opt.nugget_hz->key = "hz_nugget";
   opt.nugget_hz->type = TYPE_DOUBLE;
+  opt.nugget_hz->answer = "0.0";
   opt.nugget_hz->description = _("Nugget effect of horizontal variogram");
   opt.nugget_hz->required = NO;
   opt.nugget_hz->guisection = _("Middle");
@@ -196,6 +197,7 @@
   opt.nugget_vert = G_define_option();
   opt.nugget_vert->key = "vert_nugget";
   opt.nugget_vert->type = TYPE_DOUBLE;
+  opt.nugget_vert->answer = "0.0";
   opt.nugget_vert->description = _("Nugget effect of vertical variogram");
   opt.nugget_vert->required = NO;
   opt.nugget_vert->guisection = _("Middle");
@@ -203,7 +205,7 @@
   opt.nugget_final = G_define_option();
   opt.nugget_final->key = "final_nugget";
   opt.nugget_final->type = TYPE_DOUBLE;
-  opt.nugget_final->multiple = TRUE;
+  opt.nugget_final->answer = "0.0";
   opt.nugget_final->description = _("Nugget effect of anisotropic variogram (or horizontal component of bivariate variogram)");
   opt.nugget_final->required = NO;
   opt.nugget_final->guisection = _("Final");
@@ -211,6 +213,7 @@
   opt.nugget_final_vert = G_define_option();
   opt.nugget_final_vert->key = "final_vert_nugget";
   opt.nugget_final_vert->type = TYPE_DOUBLE;
+  opt.nugget_final_vert->answer = "0.0";
   opt.nugget_final_vert->description = _("For bivariate variogram only: nuget effect of vertical component");
   opt.nugget_final_vert->required = NO;
   opt.nugget_final_vert->guisection = _("Final");
@@ -476,7 +479,7 @@
       G_fatal_error(_("Please set up name of output layer..."));
     // read properties of final variogram from temp file
     if (xD.i3 == TRUE) { // 3D kriging:
       read_tmp_vals("variogram_final_tmp.txt", &var_pars.fin, &xD);
@@ -491,7 +494,7 @@
       if (xD.report.fp == NULL) // ... the file does not exist:
 	G_fatal_error(_("Cannot open the file..."));
     // check variogram settings
     if (var_pars.fin.type == 2 && strcmp(opt.function_var_final->answer, "linear") != 0) { // bivariate nonlinear variogram:
       // just one function type is set up (none or both should be)
@@ -503,7 +506,7 @@
 	G_fatal_error(_("If you wish to specify components of bivariate variogram please set up function type for both of them..."));
       // if both of the function types are set up:
       if (opt.function_var_final->answer && opt.function_var_final_vert->answer) {
 	if (!opt.nugget_final->answer) { // horizontal nugget effect should not be missing
@@ -541,8 +544,8 @@
     else { // univariate variogram
-      if (xD.i3 == TRUE && strcmp(opt.function_var_final->answer, "linear") != 0) { // anisotropic 3D:
-	if (opt.function_var_final_vert->answer || opt.nugget_final_vert->answer || opt.range_final_vert->answer) { // vertical settings available:
+      if (xD.i3 == TRUE && (strcmp(opt.function_var_final->answer, "linear") != 0 && strcmp(opt.function_var_final->answer, "parabolic") != 0)) { // anisotropic 3D:
+	if (opt.function_var_final_vert->answer || atof(opt.nugget_final_vert->answer) != 0. || opt.range_final_vert->answer) { // vertical settings available:
 	  G_fatal_error(_("Not necessary to set up vertical components properties. Anisotropic variogram will be used..."));
 	} // end if vert settings available
       } // end if 3D
@@ -552,13 +555,13 @@
 	G_message(_("Linear variogram will be computed..."));
-      if (strcmp(opt.function_var_final->answer, "linear") != 0) { // nonlinear:
+      if (strcmp(opt.function_var_final->answer, "linear") != 0 && strcmp(opt.function_var_final->answer, "parabolic") != 0) { // nonlinear and not parabolic:
 	if (!opt.nugget_final->answer) { // missing horizontal nugget effect
 	  if (xD.report.write2file == TRUE) { // report file available:
 	    fprintf(xD.report.fp, "Error (see standard output). Process killed...");
 	    fclose(xD.report.fp);
-	  G_fatal_error(_("Please set up nugget effect of horizontal component of bivariate variogram..."));
+	  G_fatal_error(_("Please set up nugget effect..."));
 	} // end if nugget missing
 	if (!opt.range_final->answer) { // missing horizontal range:
@@ -566,9 +569,13 @@
-	  G_fatal_error(_("Please set up range of horizontal component of bivariate variogram..."));
+	  G_fatal_error(_("Please set up range..."));
 	} // end if range missing
+	if (opt.sill_final->answer) { // missing horizontal range:
+	  var_pars.fin.sill = atof(opt.sill_final->answer);
+	} // end if sill has been changed by the user
+      } // end nonlinear and not parabolic variogram
     } // end if univariate variogram (2D or 3D)
     out.name = opt.output->answer; // Output layer name
@@ -578,6 +585,8 @@
     T_variogram(var_pars.fin.type, xD.i3, opt, &var_pars.fin, &xD.report); // compute theoretical variogram
+    G_debug(0,"sill: %f", var_pars.fin.sill);
     break;
Modified: grass-addons/grass7/vector/v.kriging/spatial_index.c
--- grass-addons/grass7/vector/v.kriging/spatial_index.c	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/spatial_index.c	2015-07-05 14:28:14 UTC (rev 65539)
@@ -37,48 +37,61 @@
 struct ilist *find_NNs_within(int dim, double *search_pt, struct points *pnts, double max_dist, double max_dist_vert)
   // local variables
-  double *r;                         // pointer to vector of the coordinates
-  r = &search_pt[0];
+  double *r = search_pt;             // pointer to vector of the coordinates
   int NN_sum = 0;                    // # of NN
   double dist_step = max_dist; // distance iteration in case of empty closest surrounding of search point
-  double dist_step_vert = 0.1 * max_dist_vert; // vertical distance iteration
+  double dist_step_vert = max_dist_vert; // vertical distance iteration
   struct RTree_Rect *search;         // search rectangle
   struct ilist *list;
   list = G_new_ilist();
+  switch (dim) {
+  case 3:
+    search = RTreeAllocRect(pnts->R_tree); // allocate new rectangle
+    break;
+  case 2:
+    search = RTreeAllocRect(pnts->Rtree_hz); // allocate new rectangle
+    break;
+  case 1:
+    search = RTreeAllocRect(pnts->Rtree_vert); // allocate new rectangle
+    break;
   while (NN_sum < 2) { // TODO: this might be tricky - what # (density) is optimal?
     switch (dim) {
     case 3: // 3D:
-      search = RTreeAllocRect(pnts->R_tree); // allocate new rectangle
       RTreeSetRect3D(search, pnts->R_tree,
 		   *r - max_dist, *r + max_dist,
 		   *(r+1) - max_dist, *(r+1) + max_dist,
-		     *(r+2) - max_dist_vert, *(r+2) + max_dist_vert); // set up searching rectangle
+		   *(r+2) - max_dist_vert, *(r+2) + max_dist_vert); // set up searching rectangle
       RTreeSearch2(pnts->R_tree, search, list);   // search the nearest rectangle
       break;
     case 2: // 2D:
-      search = RTreeAllocRect(pnts->Rtree_hz); // allocate new rectangle
       RTreeSetRect2D(search, pnts->Rtree_hz,
 		   *(r+1) - max_dist, *(r+1) + max_dist);           // set up searching rectangle
       RTreeSearch2(pnts->Rtree_hz, search, list);   // search the nearest rectangle
       break;
     case 1: // 1D:
-      search = RTreeAllocRect(pnts->Rtree_vert); // allocate new rectangle
       RTreeSetRect1D(search, pnts->Rtree_vert,
       RTreeSearch2(pnts->Rtree_vert, search, list);   // search the nearest rectangle
       break;
-    RTreeFreeRect(search);
     NN_sum = list->n_values;
-    max_dist += dist_step;
-    max_dist_vert += dist_step_vert;
+    if (NN_sum < 2) {
+      G_warning(_("Point \"x=%f y=%f z=%f\" has less than 2 neighbours in its closest surrounding. The perimeter of the surrounding will be increased to include more neighbouring points"), *r, *(r+1), *(r+2));
+      max_dist += dist_step;
+      max_dist_vert += dist_step_vert;
   } // end while: nonzero # of NNs
+  RTreeFreeRect(search);
   return list;
Modified: grass-addons/grass7/vector/v.kriging/utils.c
--- grass-addons/grass7/vector/v.kriging/utils.c	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/utils.c	2015-07-05 14:28:14 UTC (rev 65539)
@@ -134,8 +134,6 @@
   double dist2;                    // square of the distances between search point and NN
   double *search;                  // search point
-  search = (double *) G_malloc(3 * sizeof(double));
   int perc5;                       // 5% from total number of NN
   int add_ident;                   // number of identical points to add to perc5
@@ -272,6 +270,16 @@
   return n;
+void optimize(double *lag, int *nLag, double max)
+  if (*nLag > 20) {
+    *nLag = 20;
+    *lag = max / *nLag;
+  return;
 // maximal horizontal and vertical distance to restrict variogram computing
 void variogram_restricts(struct int_par *xD, struct points *pnts, struct parameters *var_pars)
@@ -329,17 +337,20 @@
     // horizontal direction:
     var_pars->lag = lag_size(12, xD, pnts, var_pars, report);  // lag distance
     var_pars->nLag = lag_number(var_pars->lag, &var_pars->max_dist); // number of lags
+    optimize(&var_pars->lag, &var_pars->nLag, var_pars->max_dist);
     var_pars->max_dist = var_pars->nLag * var_pars->lag;             // maximum distance
     // vertical direction
     var_pars->lag_vert = lag_size(3, xD, pnts, var_pars, report);             // lag distance
     var_pars->nLag_vert = lag_number(var_pars->lag_vert, &var_pars->max_dist_vert); // # of lags
+    optimize(&var_pars->lag_vert, &var_pars->nLag_vert, var_pars->max_dist_vert);
     var_pars->max_dist_vert = var_pars->nLag_vert * var_pars->lag_vert;             // max distance
   else { // univariate variograms (hz / vert / aniso)
     var_pars->lag = lag_size(dimension, xD, pnts, var_pars, report); // lag size
     var_pars->nLag = lag_number(var_pars->lag, &var_pars->max_dist);   // # of lags
@@ -601,7 +612,7 @@
   switch (bivar) {
   case FALSE: // univariate variogram
     function = var_pars->function;
-    if (function > 0) { // nonlinear variogram
+    if (function > 1) { // nonlinear and not parabolic variogram
       nugget = var_pars->nugget;
       sill = var_pars->sill - nugget;
       h_range = var_pars->h_range;
@@ -697,7 +708,7 @@
       switch (function) {
       case 0: // linear
-	dd = *T * hh + *(T+1);
+	dd = *T * hh; // todo: add nugget effect
 	break;
       case 1: // parabolic
 	dd = *T * SQUARE(hh) + *(T+1);
@@ -820,44 +831,47 @@
-    if (i3 == TRUE) { // 3D
+    if (i3 == TRUE) { // 3D variogram
       if (var_pars->type == 0) { // horizontal variogram
-	fprintf(gp, "set title \"Experimental and theoretical variogram (3D hz) of <%s>\"\n", var_pars->name);
-	//fprintf(gp, "set label \"linear: gamma(h) = %f*h + %f\" at screen 0.30,0.90\n", var_par->T->vals[0], var_par->T->vals[1]);
+	if (i3 == TRUE) {
+	  fprintf(gp, "set title \"Experimental and theoretical variogram (3D hz) of <%s>\"\n", var_pars->name);
+	else {
+	  fprintf(gp, "set title \"Experimental and theoretical variogram (2D hz) of <%s>\"\n", var_pars->name);
       else if (var_pars->type == 1) { // vertical variogram
 	fprintf(gp, "set title \"Experimental and theoretical variogram (3D vert) of <%s>\"\n", var_pars->name);
-      else if (var_pars->type == 3) // anisotropic variogram
+      else if (var_pars->type == 3) {// anisotropic variogram
 	fprintf(gp, "set title \"Experimental and theoretical variogram (3D) of <%s>\"\n", var_pars->name);
     else { // 2D
       fprintf(gp, "set title \"Experimental and theoretical variogram (2D) of <%s>\"\n", var_pars->name);
-    if (var_pars->type == 2) {
-      switch (var_pars->function) {
-      case 0: // linear
-	fprintf(gp, "set label \"linear: gamma(h) = %f*h + %f\" at screen 0.30,0.90\n", var_pars->T->vals[0], var_pars->T->vals[1]);
-	break;
-      case 1: // parabolic
-	fprintf(gp, "set label \"parabolic: gamma(h) = %f*h^2 + %f\" at screen 0.25,0.90\n", var_pars->T->vals[0], var_pars->T->vals[1]);
-	break;
-      case 2: // exponential
-	fprintf(gp, "set rmargin 5\n");
-	fprintf(gp, "set label \"exponential: gamma(h) = %f + %f * (1 - exp(-3*h / %f))\" at screen 0.10,0.90\n", var_pars->nugget, var_pars->sill - var_pars->nugget, var_pars->h_range);
-	break;
-      case 3: // spherical
-	fprintf(gp, "set label \"spherical: gamma(h) = %f+%f*(1.5*h/%f-0.5*(h/%f)^3)\" at screen 0.05,0.90\n", var_pars->nugget, var_pars->sill - var_pars->nugget, var_pars->h_range, var_pars->h_range);
-	break;
-      case 4: // gaussian
-	fprintf(gp, "set label \"gaussian: gamma(h) = %f + %f * (1 - exp(-3*(h / %f)^2))\" at screen 0.10,0.90\n", var_pars->nugget, var_pars->sill - var_pars->nugget, var_pars->h_range);
-	break;
+    switch (var_pars->function) {
+    case 0: // linear
+      fprintf(gp, "set label \"linear: gamma(h) = %f*h\" at screen 0.30,0.90\n", var_pars->T->vals[0]);
+      break;
+    case 1: // parabolic
+      fprintf(gp, "set label \"parabolic: gamma(h) = %f*h^2\" at screen 0.25,0.90\n", var_pars->T->vals[0]);
+      break;
+    case 2: // exponential
+      fprintf(gp, "set rmargin 5\n");
+      fprintf(gp, "set label \"exponential: gamma(h) = %f + %f * (1 - exp(-3*h / %f))\" at screen 0.10,0.90\n", var_pars->nugget, var_pars->sill - var_pars->nugget, var_pars->h_range);
+      break;
+    case 3: // spherical
+      fprintf(gp, "set label \"spherical: gamma(h) = %f+%f*(1.5*h/%f-0.5*(h/%f)^3)\" at screen 0.05,0.90\n", var_pars->nugget, var_pars->sill - var_pars->nugget, var_pars->h_range, var_pars->h_range);
+      break;
+    case 4: // gaussian
+      fprintf(gp, "set label \"gaussian: gamma(h) = %f + %f * (1 - exp(-3*(h / %f)^2))\" at screen 0.10,0.90\n", var_pars->nugget, var_pars->sill - var_pars->nugget, var_pars->h_range);
+      break;
     fprintf(gp, "set xlabel \"h [m]\"\n");
     fprintf(gp, "set ylabel \"gamma(h) [units^2]\"\n");
     fprintf(gp, "set key bottom right\n");
Modified: grass-addons/grass7/vector/v.kriging/utils_kriging.c
--- grass-addons/grass7/vector/v.kriging/utils_kriging.c	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/utils_kriging.c	2015-07-05 14:28:14 UTC (rev 65539)
@@ -5,14 +5,14 @@
     return x*x;
-void linear_variogram(struct parameters *var_par, struct write *report)
+void LMS_variogram(struct parameters *var_par, struct write *report)
   int nZ, nL;                // # of gamma matrix rows and columns
   int nr, nc;                // # of plan matrix rows and columns
   int i, j;                  // indices
   double *h, *vert, *gamma;
-  mat_struct *gR;
+  mat_struct *gR;
   nL = var_par->gamma->rows;        // # of cols (horizontal bins)
   nZ = var_par->gamma->cols;        // # of rows (vertical bins)
   gamma = &var_par->gamma->vals[0]; // pointer to experimental variogram
@@ -28,8 +28,8 @@
     } // end j
   } // end i
-  // Number of columns of design matrix A
-  nc = var_par->function == 5 ? 3 : 2;
+  // # of columns of design matrix A
+  nc = var_par->function == 5 ? 3 : 1;
   var_par->A = G_matrix_init(nr, nc, nr); // initialise design matrix
   gR = G_matrix_init(nr, 1, nr); // initialise vector of observations
@@ -47,18 +47,21 @@
     for (j = 0; j < nL; j++) {
       if (!isnan(*gamma)) { // write to matrix - each valid element of gamma
 	switch (var_par->function) { // function of theoretical variogram
+	case 0: // linear variogram
+	  G_matrix_set_element(var_par->A, nr, 0, *h);
+	  //G_matrix_set_element(var_par->A, nr, 1, 1.);
+	  break;
+	case 1: // parabolic variogram
+	  G_matrix_set_element(var_par->A, nr, 0, SQUARE(*h));
+	  G_matrix_set_element(var_par->A, nr, 1, 1.);
+	  break;
 	case 5: // bivariate planar
 	  G_matrix_set_element(var_par->A, nr, 1, *vert);
 	  G_matrix_set_element(var_par->A, nr, 2, 1.);
-	  G_matrix_set_element(gR, nr, 0, *gamma);
 	  break;
-	default:
-	  G_matrix_set_element(var_par->A, nr, 0, *h);
-	  G_matrix_set_element(var_par->A, nr, 1, 1.);
-	  break;
 	} // end switch variogram fuction
+	G_matrix_set_element(gR, nr, 0, *gamma);
 	nr++; // length of vector of valid elements (not null)
       } // end test if !isnan(*gamma)
       h++;
@@ -83,17 +86,17 @@
   } // error
   // constant raster
-  if (var_par->T->vals[0] == 0. && var_par->T->vals[1] == 0.) { //to do: otestuj pre 2d
+  if (var_par->T->vals[0] == 0. && var_par->T->vals[1] == 0.) {
     var_par->const_val = 1;
     G_message(_("Input values to be interpolated are constant."));
-  } // todo: cnstant raster for exponential etc.
+  } // todo: constant raster for exponential etc.
   // coefficients of theoretical variogram (linear)
   if (report->name) {
     fprintf(report->fp, "Parameters of bivariate variogram:\n");
     fprintf(report->fp, "Function: linear\n\n");
     fprintf(report->fp, "gamma(h, vert) = %f * h + %f * vert + %f\n", var_par->T->vals[0], var_par->T->vals[1], var_par->T->vals[2]);
+  } // end if: report
 double bivar_sill(int direction, mat_struct *gamma)
@@ -552,6 +555,7 @@
   for (i=0; i<n; i++) { // for each input point:
     *vt = *vo;          // subval = selected original
     *wt = *wo;          // sub weight = selected original
+    //G_debug(0,"%f %f", *vt, *wt);
     // go to the next:
     if (n_ind == 0) { // use all points:
@@ -630,10 +634,10 @@
     if (n_vals > 0 ) { // if positive:
       correct_indices(i3, list, r, pnts, var_par);
-      GM_sub = submatrix(list, GM, &xD->report); // create submatrix using indices
+      GM_sub = submatrix(list, GM, &xD->report); // create submatrix using indices
       GM_Inv = G_matrix_inverse(GM_sub);         // inverse matrix
       g0 = set_up_g0(xD, pnts, list, r, var_par); // Diffs inputs - unknowns (incl. cond. 1))
       w0 = G_matrix_product(GM_Inv, g0); // Vector of weights, condition SUM(w) = 1 in last row
@@ -644,7 +648,7 @@
       G_matrix_free(w0);
       //Create output
-      *norm = *vals - rslt_OK;          // differences between input and interpolated values
+      *norm = rslt_OK - *vals;          // differences between input and interpolated values
       *av = fabsf(*norm);               // absolute values of the differences (quantile computation)
       if (xD->i3 == TRUE) { // 3D interpolation:
Modified: grass-addons/grass7/vector/v.kriging/v.kriging.html
--- grass-addons/grass7/vector/v.kriging/v.kriging.html	2015-07-03 01:30:05 UTC (rev 65538)
+++ grass-addons/grass7/vector/v.kriging/v.kriging.html	2015-07-05 14:28:14 UTC (rev 65539)
@@ -3,7 +3,14 @@
 <em>v.kriging</em> interpolates unknown values using method <i>ordinary
 kriging</i>. Output can be 2D or 3D.
-<h2>EXAMPLES</h2> Input layer should contain 3D coordinates (xyz) and
+<h2>EXAMPLES</h2>
+Two case studies have been prepared to outline that there is no universal rule how to use the module <i>v.kriging</i>.
+Bahaviour of the phenomena is quite variable and this influences how to interpolate the dataset properly. Every point
+dataset is special and requires trying different anisotropic ratios, variogram functions and careful analysis of
+the results to get relevant interpolated (2D / 3D) raster model.
+<h3>3D kriging</h3>
+Input layer should contain 3D coordinates (xyz) and
 values to be interpolated (in attribute table). The commands can look
 like this:
@@ -11,16 +18,1094 @@
 v.kriging phase=initial in=input_layer icol=name report=report_file.txt file=png
 </pre></div>
 <div class="code"><pre>
-v.kriging in=input_layer phase=middle hz_fun=exponential vert_fun=exponential \
-  ic=name file=png hz_nugget=0 vert_nugget=0 hz_range=double vert_range=double -b
+v.kriging in=input_layer phase=middle hz_fun=exponential vert_fun=exponential ic=name file=png hz_range=double vert_range=double -b
 </pre></div>
-v.kriging in=input_layer phase=final final_fun=bivariate icol=name file=png \
-  out=name crossval=crossval_file.txt
+v.kriging in=input_layer phase=final final_fun=bivariate icol=name file=png out=name crossval=crossval_file.txt
 </pre></div>
+<p>In the middle phase, there is possible also to modify nugget effect (default: 0.0) and sill (default: calculated from
+variogram values, more details in (<i>Stopkova, 2014</i>).
+<h4>Case study: Slovakia 3D precipitation</h4>
+<p>
+The case study is based on the input points of annual precipitation <a href="http://grass.osgeo.org/download/sample-data/" target="_blank">dataset</a>.
+Although positions of the points are given in three-dimensional space, the points are concentrated at the terrain and thus
+interpolation above and below the terrain would become imprecise in deeper / higher areas of the dataset. That is the reason
+to test just cross-section from interpolated 3D raster comparing it with cross-section from the RST result obtained using
+<a href="http://grass.osgeo.org/grass64/manuals/v.vol.rst.html" target="_blank">v.vol.rst</a> according to (<i>Neteler and Mitasova, 2004</i>).
+<p>As the algorithm still needs to be optimized for large datasets, the original region was used with lower resolution
+(hz: 5000 m, vert: 500 m). To test also original resolution, the points in smaller region (<b>Tab. 1</b>) were extracted.
+<p>
+<table border="1">
+	<tr>
+		<td colspan="2" align="center">N = 5 468 000 m</td>
+	</tr>
+	<tr>
+		<td>W = 4 361 000 m</td>
+		<td>E = 4 465 500 m</td>
+	</tr>
+	<tr>
+		<td colspan="2" align="center">S = 5 374 500 m</td>
+	</tr>
+	<tr>
+		<td>top: 2 250 m</td>
+		<td>bottom: 200 m</td>
+	</tr>
+	<caption>
+		<b>Tab. 1:</b> Smaller region extent (resolution hz: 500 m, vert: 50 m)
+	</caption>
+</table>
+<p>
+In the initial phase, <b>experimental variograms</b> (horizontal and vertical) were computed:
+<div class="code"><pre>
+v.kriging phase=initial in=precip3d at PERMANENT ic=precip report=precip3d.txt file=png --o
+</pre></div>
+In the middle phase, there were empirically estimated types of the function and coefficients of <b>theoretical variograms</b>:
+v.kriging in=precip3d at PERMANENT phase=middle hz_fun=exponential vert_fun=gaussian ic=precip file=png hz_range=100000. vert_range=1600 --o -u
+</pre></div>
+<p>
+<table>
+	<tr>
+		<td>
+			<b>Fig. 1:</b> Experimental and theoretical variograms in horiontl and vertical direction<br>
+			left: whole region; middle: small region; right: small region with modified horizontal range
+		</td>
+	</tr>
+	<tr>
+		<td>
+			<img src="images/v_kriging_variogram_hz_100000.png" alt="var_hz_initial" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_hz_20000.png" alt="var_hz_small_initial" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_hz_15000.png" alt="var_hz_small_add" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+</table>
+<table>
+	<tr>
+		<td>
+			<img src="images/v_kriging_variogram_vertical_1600.png" alt="var_vert" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_vertical_1200.png" alt="var_vert_add" style="float: left; width: 24%; margin-left: 12%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+</table>
+The final phase results into theoretical variogram and interpolated values of the 3D raster:
+v.kriging in=precip3d at PERMANENT phase=middle hz_fun=exponential vert_fun=gaussian ic=precip \
+file=png hz_range=100000. vert_range=1600 --o -u
+</pre></div>
+<b>Cross validation</b> results of all the interpolated 3D rasters were compared. RST interpolation was performed using
+modified settings according to (<i>Neteler and Mitasova, 2004</i>, page 173) - different tension and smoothing parameters were set up to obtain more accurate cross
+validation results:
+v.vol.rst -c input="precip3d at PERMANENT" wcolumn="precip" tension=100. smooth=0. \
+cvdev="cxvalidation_rst_final" segmax=50 npmin=200 npmax=700 wscale=1.0 zscale=50
+</pre></div>
+<table>
+	<tr>
+		<td>
+			<img src="images/v_kriging_variogram_linear.png" alt="linear" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_variogram_exponential.png" alt="exponential" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_variogram_spherical.png" alt="spherical" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_variogram_gaussian.png" alt="gaussian" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+	</tr>
+	<caption>
+		<b>Fig. 2:</b> Variogram modelling of the whole region with horizontal range of 100 000 m and vertical range of 1 600 m
+	</caption>
+</table>
+<table border="1" style="text-align: right;">
+	<tr>
+		<td></td>
+		<td align="center"><a href="http://grass.osgeo.org/grass64/manuals/v.vol.rst.html" target="_blank">v.vol.rst</a></td>
+		<td align="center">Linear</td>
+		<td align="center">Exponential</td>
+		<td align="center">Spherical</td>
+		<td align="center">Gaussian</td>
+	</tr>
+	<tr>
+		<td align="left">Minimum [mm]</td>
+		<td>-816.805</td>
+		<td>-684.258</td>
+		<td>-686.063</td>
+		<td>-683.580</td>
+		<td>-741.081</td>
+	</tr>
+	<tr>
+		<td align="left">Maximum [mm]</td>
+		<td>175.831</td>
+		<td>429.597</td>
+		<td>424.419</td>
+		<td>424.228</td>
+		<td>444.747</td>
+	</tr>
+	<tr>
+		<td align="left">Mean [mm]</td>
+		<td>0.171</td>
+		<td>0.131</td>
+		<td>0.699</td>
+		<td>0.653</td>
+		<td>0.721</td>
+	</tr>
+	<tr>
+		<td align="left">Variance [mm<sup>2</sup>]</td>
+		<td>9876.69</td>
+		<td>5740.89</td>
+		<td>5926.62</td>
+		<td>5950.70</td>
+		<td>5979.79</td>
+	</tr>
+	<tr>
+		<td align="left">Std. deviation [mm]</td>
+		<td>99.381</td>
+		<td>75.769</td>
+		<td>76.985</td>
+		<td>77.141</td>
+		<td>77.329</td>
+	</tr>
+	<caption>
+		<b>Tab. 2:</b> Cross validation of the whole region with horizontal range of 100 000 m and vertical range of 1 600 m
+	</caption>
+</table>
+<p>
+<table>
+	<tr>
+		<td>
+			<img src="images/small/v_kriging_variogram_linear.png" alt="small_linear" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_exponential.png" alt="small_exp" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_spherical.png" alt="small_spher" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_gauss.png" alt="small_gauss" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<caption>
+		<b>Fig. 3:</b> Variogram modelling of small region with horizontal range of 20 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+	<tr>
+		<td></td>
+		<td align="center" style="color: greenyellow;">Exponential</td>
+	</tr>
+	<tr>
+		<td>-908.303</td>
+		<td>-709.02</td>
+		<td>-755.531</td>
+		<td>-678.237</td>
+		<td>-786.613</td>
+	</tr>
+	<tr>
+		<td>257.69</td>
+		<td>420.689</td>
+		<td>340.874</td>
+		<td>384.109</td>
+		<td>315.248</td>
+	</tr>
+	<tr>
+		<td>0.554</td>
+		<td>0.908</td>
+		<td style="color: greenyellow;">-0.310</td>
+		<td>1.102</td>
+		<td>-0.739</td>
+	</tr>
+	<tr>
+		<td>28891.6</td>
+		<td>15638.7</td>
+		<td>21259.5</td>
+		<td>19754.8</td>
+		<td>21243.2</td>
+	</tr>
+	<tr>
+		<td>169.975</td>
+		<td>125.055</td>
+		<td>145.806</td>
+		<td>140.552</td>
+		<td>145.751</td>
+	</tr>
+	<caption>
+		<b>Tab. 3:</b> Cross validation of small region <br>with horizontal range of 20 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+<p>
+<table>
+	<tr>
+		<td>
+			<img src="images/small/v_kriging_variogram_linear_1.png" alt="small_linear_1" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_exponential_1.png" alt="small_exp_1" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_spherical_1.png" alt="small_spher_1" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_gauss_1.png" alt="small_gauss_1" style="float: left; width: 24%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<caption>
+		<b>Fig. 4:</b> Variogram modelling of small region with horizontal range of 15 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+	<tr>
+		<td></td>
+		<td align="center" style="color: greenyellow;">Linear</td>
+		<td align="center" style="color: greenyellow;">Gaussian</td>
+	</tr>
+	<tr>
+		<td>-908.303</td>
+		<td>-711.755</td>
+		<td>-756.805</td>
+		<td>-687.44</td>
+		<td>-529.702</td>
+	</tr>
+	<tr>
+		<td>257.69</td>
+		<td>397.666</td>
+		<td>326.057</td>
+		<td>357.990</td>
+		<td>425.637</td>
+	</tr>
+	<tr>
+		<td>0.554</td>
+		<td style="color: greenyellow;">0.208</td>
+		<td>-1.775</td>
+		<td>1.823</td>
+		<td style="color: greenyellow;">0.008</td>
+	</tr>
+	<tr>
+		<td>28891.6</td>
+		<td>15873</td>
+		<td>21438.5</td>
+		<td>20930.9</td>
+		<td>20473.1</td>
+	</tr>
+	<tr>
+		<td>169.975</td>
+		<td>125.988</td>
+		<td>146.419</td>
+		<td>144.675</td>
+		<td>143.084</td>
+	</tr>
+	<caption>
+		<b>Tab. 4:</b> Cross validation of small region <br>with horizontal range of 15 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+<p>
+<p>
+<table>
+	<tr>
+		<td>
+			<img src="images/small/v_kriging_variogram_exponential_2.png" alt="small_exp_2" style="float: left; width: 32%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_spherical_2.png" alt="small_spher_2" style="float: left; width: 32%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_variogram_gauss_2.png" alt="small_gauss_2" style="float: left; width: 32%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<caption>
+		<b>Fig. 5:</b> Variogram modelling of small region with horizontal range of 15 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+	<tr>
+		<td></td>
+	</tr>
+	<tr>
+		<td>-908.303</td>
+		<td>-812.347</td>
+		<td>-792.391</td>
+		<td>-783.897</td>
+	</tr>
+	<tr>
+		<td>257.69</td>
+		<td>279.905</td>
+		<td>284.76</td>
+		<td>293.146</td>
+	</tr>
+	<tr>
+		<td>0.554</td>
+		<td>2.530</td>
+		<td>2.229</td>
+		<td>2.054</td>
+	</tr>
+	<tr>
+		<td>28891.6</td>
+		<td>23983</td>
+		<td>22586.9</td>
+		<td>22209.2</td>
+	</tr>
+	<tr>
+		<td>169.975</td>
+		<td>154.865</td>
+		<td>150.289</td>
+		<td>149.028</td>
+	</tr>
+	<caption>
+		<b>Tab. 5:</b> Cross validation of small region <br>with horizontal range of 15000 m and vertical range of 1200 m<br>
+		with different settings of theoretical variogram
+	</caption>
+</table>
+<p>
+<b>The results</b> were compared just using cross sections because of the distribution of the points. The column <i>RST</i>
+ in following tables summarize statistical characteristics of the cross section by <i><a href="http://grass.osgeo.org/grass64/manuals/v.vol.rst.html" target="_blank">v.vol.rst</a></i>. Other columns represent
+ statistical characteristics of the cross section <i>values</i> and of the <i>differences</i> (between RST and kriging cross sections)
+ produced by each type of variogram.
+ <p>
+	<tr>
+		<td rowspan="2"></td>
+		<td rowspan="2" align="center"><a href="http://grass.osgeo.org/grass64/manuals/v.vol.rst.html" target="_blank">v.vol.rst</a></td>
+		<td colspan="2" align="center">Linear</td>
+		<td colspan="2" align="center">Exponential</td>
+		<td colspan="2" align="center">Spherical</td>
+		<td colspan="2" align="center">Gaussian</td>
+	</tr>
+	<tr>
+		<td align="center">Value</td>
+		<td align="center">Diff.</td>
+	</tr>
+	<tr>
+		<td># of cells</td>
+		<td>196105</td>
+		<td colspan="2" align="center">196105</td>
+	</tr>
+	<tr>
+		<td>491.985</td>
+		<td>551.835</td>
+		<td>-643.783</td>
+		<td>543.503</td>
+		<td>-603.59</td>
+		<td>536.309</td>
+		<td>-629.652</td>
+		<td>550.935</td>
+		<td>-622.887</td>
+	</tr>
+	<tr>
+		<td>1563.660</td>
+		<td>1580.700</td>
+		<td>317.011</td>
+		<td>1572.000</td>
+		<td>316.938</td>
+		<td>1578.820</td>
+		<td>320.219</td>
+		<td>1548.51</td>
+		<td>356.881</td>
+	</tr>
+	<tr>
+		<td>722.036</td>
+		<td>744.689</td>
+		<td>-22.657</td>
+		<td>740.308</td>
+		<td>-18.271</td>
+		<td>740.968</td>
+		<td>-18.932</td>
+		<td>747.655</td>
+		<td>-25.6238</td>
+	</tr>
+	<tr>
+		<td align="left">Variance mm<sup>2</sup></td>
+		<td>14472.9</td>
+		<td>29200.5</td>
+		<td>7978.76</td>
+		<td>28614.7</td>
+		<td>6978.35</td>
+		<td>29263.9</td>
+		<td>7338.56</td>
+		<td>31396.1</td>
+		<td>9139.46</td>
+	</tr>
+	<tr>
+		<td>120.303</td>
+		<td>170.882</td>
+		<td>89.324</td>
+		<td>169.159</td>
+		<td>83.5365</td>
+		<td>171.067</td>
+		<td>85.665</td>
+		<td>177.189</td>
+		<td>95.601</td>
+	</tr>
+	<caption>
+		<b>Tab. 6:</b> Statistical characteristics of the results for the whole region<br>with horizontal range of 100 000 m and vertical range of 1 600 m
+	</caption>
+</table>
+<p>
+<table>
+	<tr>
+		<td>left: linear variogram; right: exponential variogram</td>
+	</tr>
+	<tr>
+		<td>
+			<img src="images/v_kriging_result_linear.png" alt="res_lin" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_result_exponential.png" alt="res_exp" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<caption>
+		<b>Fig. 6:</b> Interpolated rasters in the whole region
+	</caption>
+</table>
+<table>
+	<tr>
+		<td>left: spherical variogram; right: Gaussian variogram</td>
+	</tr>
+	<tr>
+		<td>
+			<img src="images/v_kriging_result_spherical.png" alt="res_spher" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_result_gauss.png" alt="res_gauss" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+</table>
+ <p>
+	<tr>
+		<td colspan="2" align="center" style="color: greenyellow;">Exponential</td>
+	</tr>
+	<tr>
+	</tr>
+	<tr>
+		<td>37639</td>
+		<td colspan="2" align="center">37639</td>
+	</tr>
+	<tr>
+		<td>600.922</td>
+		<td>580.245</td>
+		<td>-669.397</td>
+		<td>595.692</td>
+		<td>-513.497</td>
+		<td>591.531</td>
+		<td>-639.105</td>
+		<td>608.913</td>
+		<td>-378.109</td>
+	</tr>
+	<tr>
+		<td>1675.090</td>
+		<td>1916.93</td>
+		<td>203.666</td>
+		<td>1837.18</td>
+		<td>172.858</td>
+		<td>1936.17</td>
+		<td>217.189</td>
+		<td>1545.81</td>
+		<td>244.875</td>
+	</tr>
+	<tr>
+		<td>883.909</td>
+		<td>893.167</td>
+		<td>-9.258</td>
+		<td>869.083</td>
+		<td>14.826</td>
+		<td>863.901</td>
+		<td>20.0083</td>
+		<td>871.364</td>
+		<td>12.5451</td>
+	</tr>
+	<tr>
+		<td>11102</td>
+		<td>39059.1</td>
+		<td>11442.7</td>
+		<td>22743.8</td>
+		<td>3941.73</td>
+		<td>26359.9</td>
+		<td>5983.39</td>
+		<td>20350.4</td>
+		<td>3796.5</td>
+	</tr>
+	<tr>
+		<td>105.366</td>
+		<td>197.634</td>
+		<td>106.97</td>
+		<td>150.811</td>
+		<td>62.7832</td>
+		<td>162.357</td>
+		<td>77.352</td>
+		<td>142.655</td>
+		<td>61.616</td>
+	</tr>
+	<caption>
+		<b>Tab. 7:</b> Statistical characteristics of the results for the small region<br>with horizontal range of 20 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+<p>
+	<tr>
+		<td colspan="2" align="center" style="color: greenyellow;">Linear</td>
+		<td colspan="2" align="center" style="color: greenyellow;">Gaussian</td>
+	</tr>
+	<tr>
+	</tr>
+	<tr>
+		<td>37639</td>
+	</tr>
+	<tr>
+		<td>600.922</td>
+		<td>576.625</td>
+		<td>-709.196</td>
+		<td>595.284</td>
+		<td>-580.65</td>
+		<td>594.467</td>
+		<td>-665.563</td>
+		<td>556.744</td>
+		<td>-937.124</td>
+	</tr>
+	<tr>
+		<td>1675.090</td>
+		<td>1920.29</td>
+		<td>217.844</td>
+		<td>1847.160</td>
+		<td>199.350</td>
+		<td>1925.91</td>
+		<td>209.544</td>
+		<td>2218.170</td>
+		<td>249.345</td>
+	</tr>
+	<tr>
+		<td>883.909</td>
+		<td>886.734</td>
+		<td>-2.82485</td>
+		<td>865.272</td>
+		<td>18.6376</td>
+		<td>860.772</td>
+		<td>23.137</td>
+		<td>860.294</td>
+		<td>23.615</td>
+	</tr>
+	<tr>
+		<td>11102</td>
+		<td>37500.3</td>
+		<td>10985.4</td>
+		<td>23111.1</td>
+		<td>4697.95</td>
+		<td>25530.4</td>
+		<td>6226.34</td>
+		<td>32575</td>
+		<td>10525.7</td>
+	</tr>
+	<tr>
+		<td>105.366</td>
+		<td>193.65</td>
+		<td>104.811</td>
+		<td>152.023</td>
+		<td>68.5416</td>
+		<td>159.782</td>
+		<td>78.907</td>
+		<td>180.485</td>
+		<td>102.595</td>
+	</tr>
+	<caption>
+		<b>Tab. 8:</b> Statistical characteristics of the results for the small region<br>with horizontal range of 15 000 m and vertical range of 1 200 m
+	</caption>
+</table>
+<p>
+	<tr>
+	</tr>
+	<tr>
+	</tr>
+	<tr>
+		<td>37639</td>
+	</tr>
+	<tr>
+		<td>600.922</td>
+		<td>618.417</td>
+		<td>-453.562</td>
+		<td>600.733</td>
+		<td>-665.563</td>
+		<td>608.602</td>
+		<td>-415.753</td>
+	</tr>
+	<tr>
+		<td>1675.090</td>
+		<td>1687.83</td>
+		<td>177.512</td>
+		<td>1586.71</td>
+		<td>209.544</td>
+		<td>1571.55</td>
+		<td>238.521</td>
+	</tr>
+	<tr>
+		<td>883.909</td>
+		<td>867.071</td>
+		<td>16.8376</td>
+		<td>867.047</td>
+		<td>23.137</td>
+		<td>867.075</td>
+		<td>16.834</td>
+	</tr>
+	<tr>
+		<td>11102</td>
+		<td>18570.3</td>
+		<td>3191.89</td>
+		<td>19377.5</td>
+		<td>6226.34</td>
+		<td>19744.4</td>
+		<td>4155.31</td>
+	</tr>
+	<tr>
+		<td>105.366</td>
+		<td>136.273</td>
+		<td>41.737</td>
+		<td>139.203</td>
+		<td>78.907</td>
+		<td>140.515</td>
+		<td>64.462</td>
+	</tr>
+	<caption>
+		<b>Tab. 9:</b> Statistical characteristics of the results for the small region<br>with horizontal range of 15 000 m and vertical range of 1 200 m<br>with different settings of the theoretical variogram
+	</caption>
+</table>
+<p>
+<table>
+	<tr>
+		<td> Gaussian variogram from <b>Tab. 4</b> vs. Exponential variogram from <b>Tab. 5</b></td>
+	</tr>
+	<tr>
+		<td>
+			<img src="images/small/v_kriging_result_gauss_1.png" alt="res_gauss_1" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_result_exponential_2.png" alt="res_exponential_2" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<caption>
+		<b>Fig. 7:</b> Interpolated rasters with the best (on the left) and the worse (on the right) cross validation results.
+	</caption>
+</table>
+<table>
+	<tr>
+		<td> Linear variogram from <b>Tab. 4</b> vs. Spherical variogram from <b>Tab. 5</b></td>
+	</tr>
+	<tr>
+		<td>
+			<img src="images/small/v_kriging_result_linear_1.png" alt="res_linear_1" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_result_spherical_2.png" alt="res_spherical_2" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+</table>
+<table>
+	<tr>
+		<td> Exponential variogram from <b>Tab. 3</b> vs. Gaussian variogram from <b>Tab. 5</b></td>
+	</tr>
+	<tr>
+		<td>
+			<img src="images/small/v_kriging_result_exponential.png" alt="res_exponential" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/small/v_kriging_result_gauss_2.png" alt="res_gauss_2" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+</table>
+<p>
+More case studies on 3D data are described in (<i>Stopkova, 2014</i>).
+<h3>2D kriging</h3>
+Input layer should contain 2D coordinates (xy) and values to be interpolated (in attribute table). The commands can in general look like this:
+v.kriging phase=initial in=input_layer icol=name report=report_file.txt file=png -2
+</pre></div>
+v.kriging in=input_layer phase=final final_function=linear icol=name file=png \
+  out=name crossval=crossval_file.txt -2
+</pre></div>
+<h4>Case study: elev_lid792_randpts</h4>
+<p>
+The case study is based on 500 random points that were extracted from input points of Digital Elevation Model (DEM)
+<i>elev_lid792_randpts</i> from the North Carolina
+<a href="http://grass.osgeo.org/download/sample-data/" target="_blank">dataset</a>.
+<p>In initial phase, temporary <b>experimental variogram</b> was computed:
+v.kriging phase=initial in=elev_lid792_selected ic=value azimuth=45. td=45. \
+report=lid792_500_linear.txt -2 --o
+</pre></div>
+Then, in final phase (middle phase is skipped in 2D kriging) the <b>theoretical variogram</b> was computed and
+interpolation of unknown values was performed:
+v.kriging in=elev_lid792_selected phase=final final_function=linear ic=value \
+file=png out=lid792_500_linear crossval=lid792_500_xval_linear.txt -2 --o
+</pre></div>
+Variogram modelling was compared with the result of variogram analysis in <i>Surfer </i> (<i>Golden Software, Inc.</i>).
+<p>
+<table>
+	<tr>
+		<td>
+			<img src="images/v_kriging_variogram_lid792_500_linear.png" alt="variogram_500_linear" style="float: left; width: 50%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_variogram_lid792_500_surfer.png" alt="variogram_500_surfer" style="float: left; width: 35%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<caption>
+		<b>Fig. 8:</b> Experimental and theoretical variogram (left: by <i>v.kriging</i>; right: by <i>Surfer</i> (<i>Golden Software, Inc.</i>))
+	</caption>
+</table>
+The difference in coefficient of the linear function might be caused by using slightly different lag size or by different approach to the computation (spatial index in <i>v.kriging</i>, optimization algorithms in <i>Surfer</i> (<i>Golden Software, Inc.</i>) etc.).
+<p><b>The results</b> were compared with the values interpolated using the module <i><a href="http://grass.osgeo.org/grass64/manuals/v.surf.rst.html" target="blank">v.surf.rst</a></i> and kriging tool of <i>Surfer</i> (<i>Golden Software, Inc.</i>). <b>Fig. 9a</b> - <b>9c</b> show interpolated DEM and the comparisons with the results of another interpolation tools. Statistical characteristics of the results are summarized in <b>Tab. 10</b>.
+<p>
+<table>
+	<tr>
+		<td>
+			<img src="images/v_kriging_result_lid792_500.png" alt="elev_kriging" style="float: left; width: 30%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_diff_lid792_500_rst.png" alt="elev_diff_rst" style="float: left; width: 30%; margin-right: 1%; margin-bottom: 0.5em;">
+			<img src="images/v_kriging_diff_lid792_500_surfer.png" alt="elev_diff_surfer" style="float: left; width: 30%; margin-right: 1%; margin-bottom: 0.5em;">
+		</td>
+	</tr>
+	<tr>
+		<td>
+			<b>Fig. 9:</b> <b>a</b> - the DEM interpolated using <i>v.kriging</i>, <b>b</b> - the difference between <i>v.kriging</i> and <i><a href="http://grass.osgeo.org/grass64/manuals/v.surf.rst.html" target="blank">v.surf.rst</a></i>, <b>c</b> - the difference between <i>v.kriging</i> and <i>Surfer</i> (<i>Golden Software, Inc.</i>))
+		</td>
+	</tr>
+</table>
+<br>
+<table border="1" style="text-align: right; margin-left: 70px;">
+	<tr>
+		<td rowspan="2" style="text-align: center;"><b>Results</b></td>
+		<td rowspan="2" style="text-align: center;">v.kriging</td>
+		<td colspan="2" style="text-align: center;"><a href="http://grass.osgeo.org/grass64/manuals/v.surf.rst.html" target="blank">v.surf.rst</a></td>
+		<td colspan="2" style="text-align: center;">Surfer (<i>Golden Software, Inc.</i>)</td>
+	</tr>
+	<tr>
+		<td>Values</td>
+		<td>Differences</td>
+		<td>Values</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">Minimum [m]</td>
+		<td>105.114</td>
+		<td>105.061</td>
+		<td>-1.065</td>
+		<td>105.090</td>
+		<td>-1.181</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">Maximum [m]</td>
+		<td>131.510</td>
+		<td>131.570</td>
+		<td>2.072</td>
+		<td>131.510</td>
+		<td>0.522</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">Mean [m]</td>
+		<td>120.763</td>
+		<td>120.781</td>
+		<td>0.018</td>
+		<td>120.584</td>
+		<td>-0.178</td>
+	</tr>
+<tr>
+		<td style="text-align: left;">Variance [m<sup>2</sup>]</td>
+		<td>43.7367</td>
+		<td>43.2701</td>
+		<td>0.045581</td>
+		<td>44.2389</td>
+		<td>0.027244</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">Standard deviation [m]</td>
+		<td>6.613</td>
+		<td>6.578</td>
+		<td>0.165</td>
+		<td>6.651</td>
+		<td>0.213</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">95% quantile [m]</td>
+		<td>130.115</td>
+		<td>130.109</td>
+		<td>0.225</td>
+		<td>130.088</td>
+		<td>0.213</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">75% quantile [m]</td>
+		<td>126.580</td>
+		<td>126.587</td>
+		<td>0.046</td>
+		<td>126.434</td>
+		<td>-0.047</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">50% quantile [m]</td>
+		<td>121.315</td>
+		<td>121.325</td>
+		<td>0.000</td>
+		<td>121.080</td>
+		<td>-0.190</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">25% quantile [m]</td>
+		<td>115.749</td>
+		<td>115.786</td>
+		<td>-0.047</td>
+		<td>115.489</td>
+		<td>-0.328</td>
+	</tr>
+	<tr>
+		<td style="text-align: left;">5% quantile [m]</td>
+		<td>109.004</td>
+		<td>109.115</td>
+		<td>-0.139</td>
+		<td>108.800</td>
+		<td>-0.487</td>
+	</tr>
+	<caption>
+		<b>Tab. 10:</b> Comparison of statistical characteristics of interpolated rasters
+	</caption>
+</table>
+<br>
+Also <b>cross validation</b> results of all the methods mentioned above and their statistical characteristics have been compared.  Cross validation using <i><a href="http://grass.osgeo.org/grass64/manuals/v.surf.rst.html" target="blank">v.surf.rst</a></i> was performed with these settings:
+v.surf.rst -c input="elev_lid792_selected at test_kriging" layer="1" zcolumn="value" \
+cvdev="lid792_500_rst_xval" tension=40 segmax=30 npmin=120 dmin=5.000000 dmax=25.000000 zscale=1.0
+</pre></div>
+Cross validation points are shown in <b>Fig. 10</b> (bigger circles represent kriging results, smaller circles represent the results of RST). Statistical characteristics of the cross validation are summarized in <b>Tab. 11</b>.
+<br>
+<table style="float: left; align: left;">
+	<tr>
+		<td rowspan="11">
+			<img src="images/v_kriging_xval_rst_krig.png" alt="xval" style="margin-right: 10%; margin-left: 10%;">
+		</td>
+	</tr>
+	<tr>
+		<td>
+			<b>Fig. 10:</b> Cross validation by <i>v.kriging</i> and <i><a href="http://grass.osgeo.org/grass64/manuals/v.surf.rst.html" target="blank">v.surf.rst</a></i>
+		</td>
+	</tr>
+</table>
+<table border="1" style="text-align: right; float: left; align: left; vertical-align: center;">
+	<tr>
+		<td style="text-align: center;"><b>Cross validation</b></td>
+		<td>v.kriging</td>
+		<td><a href="http://grass.osgeo.org/grass64/manuals/v.surf.rst.html" target="blank">v.surf.rst</a></td>
+		<td>Surfer (<i>Golden Software, Inc.</i>)</td>
+	</tr>
+	<tr>
+		<td>-2.990</td>
+		<td>-1.593</td>
+		<td>-2.344</td>
+	</tr>
+	<tr>
+		<td>2.399</td>
+		<td>3.362</td>
+		<td>3.011</td>
+	</tr>
+	<tr>
+		<td>-0.004</td>
+		<td>0.004</td>
+		<td>0.003</td>
+	</tr>
+	<tr>
+		<td>0.132490</td>
+		<td>0.143742</td>
+		<td>0.133809</td>
+	</tr>
+	<tr>
+		<td>0.364</td>
+		<td>0.379</td>
+		<td>0.366</td>
+	</tr>
+	<tr>
+		<td>0.434</td>
+		<td>0.557</td>
+		<td>0.584</td>
+	</tr>
+	<tr>
+		<td>0.018</td>
+		<td>-0.013</td>
+		<td>-0.020</td>
+	</tr>
+	<tr>
+		<td>-0.113</td>
+		<td>-0.144</td>
+		<td>-0.126</td>
+	</tr>
+	<tr>
+		<td>-0.587</td>
+		<td>-0.499</td>
+		<td>-0.445</td>
+	</tr>
+	<caption>
+		<b>Tab. 11:</b> Statistical characteristics<br>of the cross validation results
+	</caption>
+</table>
+ <p>
+ <br style="clear:both">
+ <p>
+ <b>Recommendations</b>
+ <table>
+ 	<tr>
+ 		<td>
+ 			In case of too much <b>warnings</b> about input points that have
+ 			"<b>less than 2 neighbours in its closest surrounding</b>. The perimeter of the surrounding will be increased...", please
+ 			consider shorter variogram range.
+ 		</td>
+ 	</tr>
+ 	<tr>
+ 		<td>
+ 			Save just figures with theoretical variogram (using <i>file=extension</i> in the middle and final phase).
+ 			Experimental variograms are included in the theoretical variogram plot and separate "experimental" plots
+ 			can be just temporal.
+ 		</td>
+ 	</tr>
+ </table>
+ <p>
+ <b>References</b>
+ <table>
+ 	<tr>
+ 		<td>
+ 			Neteler, M. and Mitasova, H. (2004). <i>Open Source GIS: A GRASS GIS Approach</i>.
+ 			2nd Ed. 401 pp, Springer, New York. Online Supplement: http://www.grassbook.org
+ 		</td>
+ 	</tr>
+ 	<tr>
+ 		<td>
+ 			Stopkova, E. (2014). <i>Development and application of 3D analytical functions in spatial analyses</i>
+ 			(Unpublished doctoral dissertation). The Department of Theoretical Geodesy, Faculty of Civil Engineering
+ 			of Slovak University of Technology in Bratislava, Slovakia.
+ 		</td>
+ 	</tr>
+ </table>
 <h2>TODO</h2>
 <ul>
+<li>still need <b>optimization</b> for large datasets</li>
 <li><b>anisotropy</b> in horizontal direction missing
 <li>current version is suitable just for <b>metric coordinate systems</b>
 <li>enable <b>mask usage</b>
@@ -30,7 +1115,6 @@
 <h2>BUGS</h2>
 <ul>
-<li>2D variogram gives quite inaccurate results for <b>sparse (or spatially heterogeneous) data</b>
 <li><b>bivariate variogram</b> - too inaccurate results
 </ul>
