[GRASS-SVN] r65544 - grass/trunk/tools/g.html2man
Tue Jul 7 21:13:49 PDT 2015
Author: zarch
Date: 2015-07-07 21:13:49 -0700 (Tue, 07 Jul 2015)
New Revision: 65544
   grass/trunk/tools/g.html2man/g.html2man.py
   grass/trunk/tools/g.html2man/groff.py
   grass/trunk/tools/g.html2man/html.py
   grass/trunk/tools/g.html2man/rest.py
clean code using PEP8 rules, substitute mixed tab/space indentation with space
Modified: grass/trunk/tools/g.html2man/g.html2man.py
--- grass/trunk/tools/g.html2man/g.html2man.py	2015-07-06 20:30:45 UTC (rev 65543)
+++ grass/trunk/tools/g.html2man/g.html2man.py	2015-07-08 04:13:49 UTC (rev 65544)
@@ -8,9 +8,11 @@
 entities = {
     'nbsp': " ",
     'bull': "*"
 # Remove ToC
 def fix(content):
     if isinstance(content, tuple):
         tag, attrs, body = content
@@ -26,20 +28,25 @@
     else:
         return content
 def main():
     # parse HTML
     infile = sys.argv[1]
     inf = file(infile)
     p = HTMLParser(entities)
     for n, line in enumerate(inf):
-	try:
-	    p.feed(line)
-	except HTMLParseError as err:
-	    sys.stderr.write('%s:%d:%d: Parse error: %s\n' % (infile, err.lineno, err.offset, err.msg))
-	    sys.exit(1)
-	except Exception as err:
-	    sys.stderr.write('%s:%d:0: Error (%s): %s\n' % (infile, n + 1, repr(err), line))
-	    sys.exit(1)
+        try:
+            p.feed(line)
+        except HTMLParseError as err:
+            sys.stderr.write(
+                '%s:%d:%d: Parse error: %s\n' %
+                (infile, err.lineno, err.offset, err.msg))
+            sys.exit(1)
+        except Exception as err:
+            sys.stderr.write(
+                '%s:%d:0: Error (%s): %s\n' %
+                (infile, n + 1, repr(err), line))
+            sys.exit(1)
     p.close()
     inf.close()
Modified: grass/trunk/tools/g.html2man/groff.py
--- grass/trunk/tools/g.html2man/groff.py	2015-07-06 20:30:45 UTC (rev 65543)
+++ grass/trunk/tools/g.html2man/groff.py	2015-07-08 04:13:49 UTC (rev 65544)
@@ -11,255 +11,261 @@
     version = ""
 styles = {
-    'b':        "\\fB@\\fR",
-    'i':        "\\fI@\\fR",
-    'em':       "\\fI@\\fR",
-    'code':     "\\fC@\\fR",
-    'span':     "\\fC@\\fR",
-    'sup':      "\\u@\\d",
-    'hr':       ""
+    'b': "\\fB@\\fR",
+    'i': "\\fI@\\fR",
+    'em': "\\fI@\\fR",
+    'code': "\\fC@\\fR",
+    'span': "\\fC@\\fR",
+    'sup': "\\u@\\d",
+    'hr': ""
 formats = {
-    'br':       "\n.br\n",
-    'h2':       "\n.SH @",
-    'h3':       "\n.SS @",
-    'h4':       "\n.SS @",
-    'dt':       ("\n.IP \"@\" 4m", 'no_nl'),
-    'dd':       "\n.br\n@",
-    'ul':       ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
-    'menu':     ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
-    'dir':      ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
-    'ol':       ("\n.IP\n@\n.PP\n", 'index'),
-    'p':        "\n.PP\n@",
-    'pre':      ("\n.br\n.nf\n\\fC\n@\n\\fR\n.fi\n", 'preformat')
+    'br': "\n.br\n",
+    'h2': "\n.SH @",
+    'h3': "\n.SS @",
+    'h4': "\n.SS @",
+    'dt': ("\n.IP \"@\" 4m", 'no_nl'),
+    'dd': "\n.br\n@",
+    'ul': ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+    'menu': ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+    'dir': ("\n.RS 4n\n@\n.RE\n", 'in_ul'),
+    'ol': ("\n.IP\n@\n.PP\n", 'index'),
+    'p': "\n.PP\n@",
+    'pre': ("\n.br\n.nf\n\\fC\n@\n\\fR\n.fi\n", 'preformat')
 formats.update(styles)
 def is_string(x):
     return isinstance(x, str)
 def is_tuple(x):
     return isinstance(x, tuple)
 def is_list(x):
     return isinstance(x, list)
 def is_blank(s):
     return is_string(s) and s.strip() == ""
 def clean(content):
     return [item for item in content if not is_blank(item)]
 class Formatter:
-    def __init__(self, filename, stream = sys.stdout):
-	self.stream = stream
-	self.style = dict(preformat = False,
-			  in_ul = False,
-			  no_nl = False,
-			  in_table = False,
-			  in_tr = False,
-			  index = [])
-	self.stack = []
-	self.strip_re = re.compile("^[ \t]+")
-	self.filename = filename
-	self.at_bol = True
+    def __init__(self, filename, stream=sys.stdout):
+        self.stream = stream
+        self.style = dict(preformat=False,
+                          in_ul=False,
+                          no_nl=False,
+                          in_table=False,
+                          in_tr=False,
+                          index=[])
+        self.stack = []
+        self.strip_re = re.compile("^[ \t]+")
+        self.filename = filename
+        self.at_bol = True
     def warning(self, msg):
-	sys.stderr.write(msg + '\n')
+        sys.stderr.write(msg + '\n')
     def set(self, var, val):
-	self.style[var] = val
+        self.style[var] = val
     def get(self, var):
-	return self.style[var]
+        return self.style[var]
     def push(self, **kwargs):
-	self.stack.append(self.style.copy())
-	self.style.update(**kwargs)
+        self.stack.append(self.style.copy())
+        self.style.update(**kwargs)
     def pop(self):
-	self.style = self.stack.pop()
+        self.style = self.stack.pop()
     def show(self, s):
-	self.stream.write(s)
-	if s != '':
-	    self.at_bol = s.endswith('\n')
+        self.stream.write(s)
+        if s != '':
+            self.at_bol = s.endswith('\n')
     def pp_with(self, content, var, val):
-	self.push()
-	self.set(var, val)
-	self.pp(content)
-	self.pop()
+        self.push()
+        self.set(var, val)
+        self.pp(content)
+        self.pop()
-    def fmt(self, format, content, var = None):
-	# String.partition is only in 2.5+
-	# (pre,sep,post) = format.partition("@")
-	if self.get('no_nl') and '\n' in format:
-	    self.warning("can't handle line breaks in <dt>...</dt>")
-	    format = "@"
-	f = format.split('@', 1)
-	pre = f[0]
-	if len(f) > 1:
-	    sep = '@'
-	    post = f[1]
-	else:
-	    sep = ''
-	    post = ''
+    def fmt(self, format, content, var=None):
+        # String.partition is only in 2.5+
+        # (pre,sep,post) = format.partition("@")
+        if self.get('no_nl') and '\n' in format:
+            self.warning("can't handle line breaks in <dt>...</dt>")
+            format = "@"
+        f = format.split('@', 1)
+        pre = f[0]
+        if len(f) > 1:
+            sep = '@'
+            post = f[1]
+        else:
+            sep = ''
+            post = ''
-	if pre != "":
-	    self.show(pre)
-	if sep != "":
-	    if var:
-		if var == 'index':
-		    val = self.get('index') + [0]
-		else:
-		    val = True
-		self.pp_with(content, var, val)
-	    else:
-		self.pp(content)
-	if post != "":
-	    self.show(post)
+        if pre != "":
+            self.show(pre)
+        if sep != "":
+            if var:
+                if var == 'index':
+                    val = self.get('index') + [0]
+                else:
+                    val = True
+                self.pp_with(content, var, val)
+            else:
+                self.pp(content)
+        if post != "":
+            self.show(post)
     def pp_li(self, content):
-	if self.get('in_ul'):
-	    self.fmt("\n.IP \(bu 4n\n@", content)
-	else:
-	    idx = self.get('index')
-	    idx[-1] += 1
-	    sec = ".".join(map(str,idx))
-	    self.show("\n.IP \\fB%s\\fR\n" % sec)
-	    self.set('index', idx)
-	    self.pp(content)
+        if self.get('in_ul'):
+            self.fmt("\n.IP \(bu 4n\n@", content)
+        else:
+            idx = self.get('index')
+            idx[-1] += 1
+            sec = ".".join(map(str, idx))
+            self.show("\n.IP \\fB%s\\fR\n" % sec)
+            self.set('index', idx)
+            self.pp(content)
     def pp_title(self):
-	self.show("\n.TH " +
-		  os.path.basename(self.filename).replace(".html","") +
-		  " 1 \"\" \"GRASS " +
-		  version +
-		  "\" \"Grass User's Manual\"")
+        self.show("\n.TH " +
+                  os.path.basename(self.filename).replace(".html", "") +
+                  " 1 \"\" \"GRASS " +
+                  version +
+                  "\" \"Grass User's Manual\"")
     def pp_tr(self, content):
-	content = clean(content)
-	self.push(in_tr = True)
-	col = 0
-	for item in content:
-	    if not is_tuple(item):
-		self.warning("invalid item in table row: %s" % str(item))
-		continue
-	    (tag, attrs, body) = item
-	    if tag not in ['td', 'th']:
-		self.warning("invalid tag in table row: %s" % tag)
-		continue
-	    if col > 0:
-		self.show("\t \t")
-	    self.show("T{\n")
-	    self.pp(body)
-	    self.show("\nT}")
-	    col += 1
-	self.show("\n")
-	self.pop()
+        content = clean(content)
+        self.push(in_tr=True)
+        col = 0
+        for item in content:
+            if not is_tuple(item):
+                self.warning("invalid item in table row: %s" % str(item))
+                continue
+            (tag, attrs, body) = item
+            if tag not in ['td', 'th']:
+                self.warning("invalid tag in table row: %s" % tag)
+                continue
+            if col > 0:
+                self.show("\t \t")
+            self.show("T{\n")
+            self.pp(body)
+            self.show("\nT}")
+            col += 1
+        self.show("\n")
+        self.pop()
     def pp_tbody(self, content):
-	    if is_tuple(item):
-		if tag in ['thead', 'tbody', 'tfoot']:
-		    self.pp_tbody(body)
-		elif tag == 'tr':
-		    self.pp_tr(body)
-		    self.show(".sp 1\n")
+            if is_tuple(item):
+                if tag in ['thead', 'tbody', 'tfoot']:
+                    self.pp_tbody(body)
+                elif tag == 'tr':
+                    self.pp_tr(body)
+                    self.show(".sp 1\n")
     def count_cols(self, content):
-	cols = 0
-	    n = 0
-	    if is_blank(item):
-		pass
-	    elif is_tuple(item):
-		    n = self.count_cols(body)
-		elif tag == 'tr':
-		    n = len(clean(body))
-		cols = max(cols, n)
-	    else:
-		self.warning("invalid item in table: %s" % str(item))
-	return cols
+        cols = 0
+            n = 0
+            if is_blank(item):
+                pass
+            elif is_tuple(item):
+                    n = self.count_cols(body)
+                elif tag == 'tr':
+                    n = len(clean(body))
+                cols = max(cols, n)
+            else:
+                self.warning("invalid item in table: %s" % str(item))
+        return cols
     def pp_table(self, content):
-	cols = self.count_cols(content)
-	if cols == 0:
-	    return
-	self.show("\n.TS\nexpand;\n")
-	self.show(" lw1 ".join(["lw60" for i in range(cols)]) + ".\n")
-	self.pp_tbody(content)
-	self.show("\n.TE\n")
+        cols = self.count_cols(content)
+        if cols == 0:
+            return
+        self.show("\n.TS\nexpand;\n")
+        self.show(" lw1 ".join(["lw60" for i in range(cols)]) + ".\n")
+        self.pp_tbody(content)
+        self.show("\n.TE\n")
     def pp_tag(self, tag, content):
-	if self.get('in_tr') and tag not in styles:
-	    self.pp(content)
-	elif tag in formats:
-	    spec = formats[tag]
-	    if is_string(spec):
-		self.fmt(spec, content)
-	    else:
-		(fmt, var) = spec
-		self.fmt(fmt, content, var)
-	elif tag == 'table':
-	    if self.get('in_table'):
-		self.warning("cannot handle nested tables")
-		return
-	    self.push(in_table = True)
-	    self.pp_table(content)
-	    self.pop()
-	elif tag == 'li':
-	    self.pp_li(content)
-	elif tag == 'title':
-	    self.pp_title()
-	else:
-	    self.pp(content)
+        if self.get('in_tr') and tag not in styles:
+            self.pp(content)
+        elif tag in formats:
+            spec = formats[tag]
+            if is_string(spec):
+                self.fmt(spec, content)
+            else:
+                (fmt, var) = spec
+                self.fmt(fmt, content, var)
+        elif tag == 'table':
+            if self.get('in_table'):
+                self.warning("cannot handle nested tables")
+                return
+            self.push(in_table=True)
+            self.pp_table(content)
+            self.pop()
+        elif tag == 'li':
+            self.pp_li(content)
+        elif tag == 'title':
+            self.pp_title()
+        else:
+            self.pp(content)
     def pp_string(self, content):
-	if content == "":
-	    return
-	s = content
-	if self.get('no_nl'):
-	    s = s.replace("\n"," ")
-	s = s.replace("\\", "\\(rs")
-	s = s.replace("'", "\\(cq")
-	s = s.replace("\"", "\\(dq")
-	s = s.replace("`", "\\(ga")
-	s = s.replace("-", "\\-")
-	if self.at_bol and s[0] in [".","'"]:
-	    s = "\\&" + s
-	self.show(s)
+        if content == "":
+            return
+        s = content
+        if self.get('no_nl'):
+            s = s.replace("\n", " ")
+        s = s.replace("\\", "\\(rs")
+        s = s.replace("'", "\\(cq")
+        s = s.replace("\"", "\\(dq")
+        s = s.replace("`", "\\(ga")
+        s = s.replace("-", "\\-")
+        if self.at_bol and s[0] in [".", "'"]:
+            s = "\\&" + s
+        self.show(s)
     def pp_text(self, content):
-	if content == "":
-	    return
-	lines = content.splitlines(True)
-	if len(lines) != 1:
-	    for line in lines:
-		self.pp_text(line)
-	    return
-	else:
-	    content = lines[0]
-	if self.at_bol and not self.get('preformat'):
-	    content = self.strip_re.sub('', content)
-	self.pp_string(content)
+        if content == "":
+            return
+        lines = content.splitlines(True)
+        if len(lines) != 1:
+            for line in lines:
+                self.pp_text(line)
+            return
+        else:
+            content = lines[0]
+        if self.at_bol and not self.get('preformat'):
+            content = self.strip_re.sub('', content)
+        self.pp_string(content)
     def pp_list(self, content):
-	    self.pp(item)
+            self.pp(item)
     def pp(self, content):
-	if is_list(content):
-	    self.pp_list(content)
-	elif is_tuple(content):
-	    (tag, attrs, body) = content
-	    self.pp_tag(tag, body)
-	elif is_string(content):
-	    self.pp_text(content)
+        if is_list(content):
+            self.pp_list(content)
+        elif is_tuple(content):
+            (tag, attrs, body) = content
+            self.pp_tag(tag, body)
+        elif is_string(content):
+            self.pp_text(content)
Modified: grass/trunk/tools/g.html2man/html.py
--- grass/trunk/tools/g.html2man/html.py	2015-07-06 20:30:45 UTC (rev 65543)
+++ grass/trunk/tools/g.html2man/html.py	2015-07-08 04:13:49 UTC (rev 65544)
@@ -1,3 +1,5 @@
+from __future__ import (absolute_import, division, generators, nested_scopes,
+                        print_function, unicode_literals, with_statement)
 import sys
 import HTMLParser as base
 import htmlentitydefs
@@ -9,38 +11,40 @@
 omit_start = ["body", "tbody", "head", "html"]
 single = ["area", "base", "basefont", "br", "col", "frame",
-	  "hr", "img", "input", "isindex", "link", "meta", "param"]
+          "hr", "img", "input", "isindex", "link", "meta", "param"]
 single = frozenset(single)
 heading = ["h1", "h2", "h3", "h4", "h5", "h6"]
 fontstyle = ["tt", "i", "b", "u", "s", "strike", "big", "small"]
-phrase = [ "em", "strong", "dfn", "code", "samp", "kbd", "var", "cite", "abbr",
-	   "acronym"]
-special = [ "a", "img", "applet", "object", "font", "basefont", "br", "script",
-	    "map", "q", "sub", "sup", "span", "bdo", "iframe"]
-formctrl = [ "input", "select", "textarea", "label", "button"]
-lists = [ "ul", "ol", " dir", "menu"]
-head_misc = [ "script", "style", "meta", "link", "object"]
-pre_exclusion = [ "img", "object", "applet", "big", "small", "sub", "sup",
-		  "font", "basefont"]
-block = [ "p", "pre", "dl", "div", "center", "noscript", "noframes",
-	  "blockquote", "form", "isindex", "hr", "table", "fieldset",
-	  "address"] + heading + lists
+phrase = ["em", "strong", "dfn", "code", "samp", "kbd", "var", "cite", "abbr",
+          "acronym"]
+special = ["a", "img", "applet", "object", "font", "basefont", "br", "script",
+           "map", "q", "sub", "sup", "span", "bdo", "iframe"]
+formctrl = ["input", "select", "textarea", "label", "button"]
+lists = ["ul", "ol", " dir", "menu"]
+head_misc = ["script", "style", "meta", "link", "object"]
+pre_exclusion = ["img", "object", "applet", "big", "small", "sub", "sup",
+                 "font", "basefont"]
+block = ["p", "pre", "dl", "div", "center", "noscript", "noframes",
+         "blockquote", "form", "isindex", "hr", "table", "fieldset",
+         "address"] + heading + lists
 inline = fontstyle + phrase + special + formctrl
 flow = block + inline
 html_content = ["head", "body"]
 head_content = ["title", "isindex", "base"]
 def setify(d):
     return dict([(key, frozenset(val)) for key, val in d.iteritems()])
 def omit(allowed, tags):
     result = {}
     for k, v in allowed.iteritems():
-	for t in tags:
-	    if t in v:
-		v = v.union(allowed[t])
-	result[k] = v
+        for t in tags:
+            if t in v:
+                v = v.union(allowed[t])
+        result[k] = v
     return result
 allowed = {
@@ -122,7 +126,7 @@
     "u": inline,
     "ul": ["li"],
     "var": inline
 allowed = setify(allowed)
 allowed = omit(allowed, omit_start)
@@ -135,18 +139,20 @@
     "label": ["label"],
     "menu": block,
     "pre": pre_exclusion
 excluded = setify(excluded)
 class HTMLParser(base.HTMLParser):
-    def __init__(self, entities = None):
-	base.HTMLParser.__init__(self)
-	self.tag_stack = []
-	self.excluded = frozenset()
-	self.excluded_stack = []
-	self.data = []
-	self.data_stack = []
+    def __init__(self, entities=None):
+        base.HTMLParser.__init__(self)
+        self.tag_stack = []
+        self.excluded = frozenset()
+        self.excluded_stack = []
+        self.data = []
+        self.data_stack = []
         self.decls = []
         if entities:
             self.entities = entities
@@ -154,61 +160,60 @@
             self.entities = {}
     def top(self):
-	if self.tag_stack == []:
-	    return None
-	else:
-	    return self.tag_stack[-1][0]
+        if self.tag_stack == []:
+            return None
+        else:
+            return self.tag_stack[-1][0]
     def pop(self):
-	self.excluded = self.excluded_stack.pop()
-	data = self.data
-	self.data = self.data_stack.pop()
-	(tag, attrs) = self.tag_stack.pop()
-	self.append((tag, attrs, data))
-	return tag
+        self.excluded = self.excluded_stack.pop()
+        data = self.data
+        self.data = self.data_stack.pop()
+        (tag, attrs) = self.tag_stack.pop()
+        self.append((tag, attrs, data))
+        return tag
     def push(self, tag, attrs):
-	self.tag_stack.append((tag, attrs))
-	self.excluded_stack.append(self.excluded)
-	if tag in excluded:
-	    self.excluded = self.excluded.union(excluded[tag])
-	self.data_stack.append(self.data)
-	self.data = []
+        self.tag_stack.append((tag, attrs))
+        self.excluded_stack.append(self.excluded)
+        if tag in excluded:
+            self.excluded = self.excluded.union(excluded[tag])
+        self.data_stack.append(self.data)
+        self.data = []
     def append(self, item):
-	self.data.append(item)
+        self.data.append(item)
     def is_allowed(self, tag):
-	return tag not in self.excluded and tag in allowed[self.top()]
+        return tag not in self.excluded and tag in allowed[self.top()]
     def handle_starttag(self, tag, attrs):
-	if self.tag_stack != []:
-	    while not self.is_allowed(tag):
-		self.pop()
-	if tag not in single:
-	    self.push(tag, attrs)
-	else:
-	    self.append((tag, attrs, None))
+        if self.tag_stack != []:
+            while not self.is_allowed(tag):
+                self.pop()
+        if tag not in single:
+            self.push(tag, attrs)
+        else:
+            self.append((tag, attrs, None))
     def handle_entityref(self, name):
-	if name in self.entities:
-	    self.handle_data(self.entities[name])
-	elif name in htmlentitydefs.entitydefs:
-	    self.handle_data(htmlentitydefs.entitydefs[name])
-	else:
-	    sys.stderr.write("unrecognized entity: %s\n" % name)
+        if name in self.entities:
+            self.handle_data(self.entities[name])
+        elif name in htmlentitydefs.entitydefs:
+            self.handle_data(htmlentitydefs.entitydefs[name])
+        else:
+            sys.stderr.write("unrecognized entity: %s\n" % name)
     def handle_charref(self, name):
-	sys.stderr.write('unsupported character reference <%s>' % name);
+        sys.stderr.write('unsupported character reference <%s>' % name)
     def handle_data(self, data):
-	self.append(data)
+        self.append(data)
     def handle_endtag(self, tag):
-	while True:
-	    if self.pop() == tag:
-		break
+        while True:
+            if self.pop() == tag:
+                break
     def handle_decl(self, decl):
         self.decls.append(decl)
Modified: grass/trunk/tools/g.html2man/rest.py
--- grass/trunk/tools/g.html2man/rest.py	2015-07-06 20:30:45 UTC (rev 65543)
+++ grass/trunk/tools/g.html2man/rest.py	2015-07-08 04:13:49 UTC (rev 65544)
@@ -1,5 +1,6 @@
 import sys
 def match(node, tag, attr=None, val=None):
     if not isinstance(node, tuple):
         return False
@@ -13,6 +14,7 @@
             return False
     return True
 def find(node, tag, attr=None, val=None):
     if isinstance(node, tuple):
         node = node[2]
@@ -23,22 +25,26 @@
             return child
     raise ValueError('child not found')
 def children(node):
     return node[2]
 def text(node):
     return children(node)[0]
 def _(s):
     return s        # TODO
-def rest(root, f = sys.stdout):
+def rest(root, f=sys.stdout):
     def write(text):
         f.write(text)
     def show(item, italic=False, bold=False):
         if isinstance(item, str):
-            spc = '' # if item[-1] == '\n' else ' '
+            spc = ''  # if item[-1] == '\n' else ' '
             fmt = '**' if bold else ('*' if italic else '')
             write('%s%s%s%s' % (fmt, item, fmt, spc))
         elif match(item, 'b'):
