[GRASS-SVN] r65567 - grass/trunk/display/d.vect
Fri Jul 10 14:05:41 PDT 2015
Author: martinl
Date: 2015-07-10 14:05:41 -0700 (Fri, 10 Jul 2015)
New Revision: 65567
   grass/trunk/display/d.vect/main.c
d.vect: remove boundary from default options (boundaries are render
when area type is given)
     It can speed up rendering maps with larger number of areas
This line, and those below, will beignored--
M    display/d.vect/main.c
Modified: grass/trunk/display/d.vect/main.c
--- grass/trunk/display/d.vect/main.c	2015-07-10 20:37:13 UTC (rev 65566)
+++ grass/trunk/display/d.vect/main.c	2015-07-10 21:05:41 UTC (rev 65567)
@@ -100,7 +100,7 @@
     /* Query */
     type_opt = G_define_standard_option(G_OPT_V_TYPE);
-    type_opt->answer = "point,line,boundary,area,face";
+    type_opt->answer = "point,line,area,face";
     type_opt->options = "point,line,boundary,centroid,area,face";
     type_opt->guisection = _("Selection");
