[GRASS-SVN] r65583 - grass-addons/grass7/raster/r.fidimo
svn_grass at osgeo.org
Mon Jul 13 05:36:57 PDT 2015
Author: jradinger
Date: 2015-07-13 05:36:56 -0700 (Mon, 13 Jul 2015)
New Revision: 65583
grass-addons/grass7/raster/r.fidimo/r.fidimo.py
Update removal list
Modified: grass-addons/grass7/raster/r.fidimo/r.fidimo.py
--- grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2015-07-13 11:00:28 UTC (rev 65582)
+++ grass-addons/grass7/raster/r.fidimo/r.fidimo.py 2015-07-13 12:36:56 UTC (rev 65583)
@@ -237,7 +237,7 @@
global tmp_map_rast
global tmp_map_vect
- tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_','distance_raster_buffered_tmp_', 'distance_raster_grow_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'drainage_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'realised_density_final_','rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'river_raster_combine_tmp_', 'river_raster_buffer_tmp_', 'river_raster_grow_start_tmp_', 'river_raster_nearest_tmp_', 'shreve_tmp_', 'source_populations_scalar_tmp_','source_populations_scalar_corrected_tmp_', 'strahler_tmp_', 'stream_rwatershed_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
+ tmp_map_rast = ['density_final_','density_final_corrected_','density_from_point_tmp_', 'density_from_point_unmasked_tmp_', 'distance_from_point_tmp_', 'distance_raster_tmp_', 'distance_raster_buffered_tmp_', "distance_raster_buffered_div_tmp_", 'distance_raster_grow_tmp_', 'division_overlay_tmp_', 'downstream_drain_tmp_', 'drainage_tmp_', 'flow_direction_tmp_', 'lower_distance_tmp_', 'realised_density_final_','rel_upstream_shreve_tmp_', 'river_raster_cat_tmp_', 'river_raster_tmp_', 'river_raster_combine_tmp_', 'river_raster_buffer_tmp_', 'river_raster_grow_start_tmp_', 'river_raster_nearest_tmp_', 'shreve_tmp_', 'source_populations_scalar_tmp_','source_populations_scalar_corrected_tmp_', 'strahler_tmp_', 'stream_rwatershed_tmp_', 'upper_distance_tmp_', 'upstream_part_tmp_', 'upstream_shreve_tmp_']
tmp_map_vect = ['river_points_tmp_', 'river_vector_tmp_', 'river_vector_nocat_tmp_','source_points_']
