[GRASS-SVN] r65587 - grass/trunk/vector/v.proj
svn_grass at osgeo.org
Tue Jul 14 08:49:12 PDT 2015
Author: martinl
Date: 2015-07-14 08:49:11 -0700 (Tue, 14 Jul 2015)
New Revision: 65587
grass/trunk/vector/v.proj/main.c
v.proj: reorder options to avoid user confusion
Modified: grass/trunk/vector/v.proj/main.c
--- grass/trunk/vector/v.proj/main.c 2015-07-14 13:11:58 UTC (rev 65586)
+++ grass/trunk/vector/v.proj/main.c 2015-07-14 15:49:11 UTC (rev 65587)
@@ -71,12 +71,6 @@
/* set up the options and flags for the command line parser */
- mapopt = G_define_standard_option(G_OPT_V_INPUT);
- mapopt->required = NO;
- mapopt->label = _("Name of input vector map to re-project");
- mapopt->description = NULL;
- mapopt->guisection = _("Source");
ilocopt = G_define_standard_option(G_OPT_M_LOCATION);
ilocopt->required = YES;
ilocopt->label = _("Location containing input vector map");
@@ -87,10 +81,15 @@
isetopt->description = _("Default: name of current mapset");
isetopt->guisection = _("Source");
+ mapopt = G_define_standard_option(G_OPT_V_INPUT);
+ mapopt->required = NO;
+ mapopt->label = _("Name of input vector map to re-project");
+ mapopt->description = NULL;
+ mapopt->guisection = _("Source");
ibaseopt = G_define_standard_option(G_OPT_M_DBASE);
ibaseopt->label = _("Path to GRASS database of input location");
- ibaseopt->guisection = _("Source");
smax = G_define_option();
smax->key = "smax";
smax->type = TYPE_DOUBLE;
