[GRASS-SVN] r65591 - grass/trunk/raster/r.mapcalc
svn_grass at osgeo.org
Tue Jul 14 20:18:21 PDT 2015
Author: glynn
Date: 2015-07-14 20:18:21 -0700 (Tue, 14 Jul 2015)
New Revision: 65591
grass/trunk/raster/r.mapcalc/map.c
Prevent concurrent raster reads when a mask is present
Modified: grass/trunk/raster/r.mapcalc/map.c
--- grass/trunk/raster/r.mapcalc/map.c 2015-07-14 19:09:54 UTC (rev 65590)
+++ grass/trunk/raster/r.mapcalc/map.c 2015-07-15 03:18:21 UTC (rev 65591)
@@ -71,6 +71,7 @@
static struct map *maps;
static int num_maps;
static int max_maps;
+static int masking;
static int min_row = INT_MAX;
static int max_row = -INT_MAX;
@@ -81,10 +82,24 @@
#ifdef HAVE_PTHREAD_H
static pthread_mutex_t cats_mutex;
+static pthread_mutex_t mask_mutex;
#endif
+static void read_row(int fd, void *buf, int row, int res_type)
+#ifdef HAVE_PTHREAD_H
+ if (masking)
+ pthread_mutex_lock(&mask_mutex);
+#endif
+ Rast_get_row(fd, buf, row, res_type);
+ if (masking)
+ pthread_mutex_unlock(&mask_mutex);
+#endif
static void cache_sub_init(struct row_cache *cache, int data_type)
struct sub_cache *sub = G_malloc(sizeof(struct sub_cache));
@@ -145,7 +160,7 @@
if (i >= 0 && i < cache->nrows) {
if (!sub->valid[i]) {
- Rast_get_row(cache->fd, sub->buf[i], row + i, data_type);
+ read_row(cache->fd, sub->buf[i], row + i, data_type);
sub->valid[i] = 1;
return sub->buf[i];
@@ -154,7 +169,7 @@
if (i <= -cache->nrows || i >= cache->nrows * 2 - 1) {
memset(sub->valid, 0, cache->nrows);
sub->row = i;
- Rast_get_row(cache->fd, sub->buf[0], row, data_type);
+ read_row(cache->fd, sub->buf[0], row, data_type);
sub->valid[0] = 1;
return sub->buf[0];
@@ -182,7 +197,7 @@
G_freea(tmp);
G_freea(vtmp);
- Rast_get_row(cache->fd, sub->buf[i], row, data_type);
+ read_row(cache->fd, sub->buf[i], row, data_type);
sub->valid[i] = 1;
return sub->buf[i];
@@ -365,11 +380,6 @@
#endif
-static void read_row(int fd, void *buf, int row, int res_type)
- Rast_get_row(fd, buf, row, res_type);
static void setup_map(struct map *m)
int nrows = m->max_row - m->min_row + 1;
@@ -576,6 +586,8 @@
pthread_mutex_init(&cats_mutex, NULL);
+ pthread_mutex_init(&mask_mutex, NULL);
+ masking = Rast_maskfd() >= 0;
#endif
for (i = 0; i < num_maps; i++)
@@ -635,6 +647,7 @@
pthread_mutex_destroy(&cats_mutex);
+ pthread_mutex_destroy(&mask_mutex);
#endif
