[GRASS-SVN] r65605 - grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface
Sat Jul 18 06:02:23 PDT 2015
Author: martinl
Date: 2015-07-18 06:02:23 -0700 (Sat, 18 Jul 2015)
New Revision: 65605
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
   grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/read.py
Add suppress_required attribute to the Flag object
pygrass: Add a new method to check the correctness of the provide parameter, a new special parameter: check_ is added to skip the check
         (merge r65596, r65598 from trunk)
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py	2015-07-18 13:00:42 UTC (rev 65604)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/flag.py	2015-07-18 13:02:23 UTC (rev 65605)
@@ -33,6 +33,7 @@
         self.description = diz.get('description', None)
         self.default = diz.get('default', None)
         self.guisection = diz.get('guisection', None)
+        self.suppress_required = True if 'suppress_required' in diz else False
     def get_bash(self):
         """Return the BASH representation of a flag.
@@ -88,11 +89,18 @@
         """Return a string with the python representation of the instance."""
         return "Flag <%s> (%s)" % (self.name, self.description)
+    def __bool__(self):
+        """Return a boolean value"""
+        return self.value
+    def __nonzero__(self):
+        return self.__bool__()
     @docstring_property(__doc__)
     def __doc__(self):
         """Return a documentation string, something like:
-        {name}: {default}
+        {name}: {default}, suppress required {supress}
             {description}
         >>>  flag = Flag(diz=dict(name='a', description='Flag description',
@@ -109,4 +117,7 @@
         return read.DOC['flag'].format(name=self.name,
                                        default=repr(self.default),
-                                       description=self.description)
+                                       description=self.description,
+                                       supress=('suppress required'
+                                                if self.suppress_required
+                                                else ''))
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py	2015-07-18 13:00:42 UTC (rev 65604)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/module.py	2015-07-18 13:02:23 UTC (rev 65605)
@@ -504,6 +504,7 @@
         self.run_ = True
         self.finish_ = True
+        self.check_ = True
         self.env_ = None
         self.stdin_ = None
         self.stdin = None
@@ -543,7 +544,7 @@
             del(kargs['flags'])
         # set attributs
-        for key in ('run_', 'env_', 'finish_', 'stdout_', 'stderr_'):
+        for key in ('run_', 'env_', 'finish_', 'stdout_', 'stderr_', 'check_'):
             if key in kargs:
                 setattr(self, key, kargs.pop(key))
@@ -553,7 +554,7 @@
                 self.inputs[key[:-1]].value = kargs.pop(key)
-        # check args
+        # set/update args
         for param, arg in zip(self.params_list, args):
             param.value = arg
@@ -576,11 +577,8 @@
             # check reqire parameters
-            for k in self.required:
-                if ((k in self.inputs and self.inputs[k].value is None) or
-                        (k in self.outputs and self.outputs[k].value is None)):
-                    msg = "Required parameter <%s> not set."
-                    raise ParameterError(msg % k)
+            if self.check_:
+                self.check()
             return self.run()
         return self
@@ -634,6 +632,19 @@
         flags = self.flags.__doc__
         return '\n'.join([head, params, DOC['flag_head'], flags, DOC['foot']])
+    def check(self):
+        """Check the correctness of the provide parameters"""
+        required = True
+        for flg in self.flags.values():
+            if flg and flg.suppress_required:
+                required = False
+        if required:
+            for k in self.required:
+                if ((k in self.inputs and self.inputs[k].value is None) or
+                        (k in self.outputs and self.outputs[k].value is None)):
+                    msg = "Required parameter <%s> not set."
+                    raise ParameterError(msg % k)
     def get_dict(self):
         """Return a dictionary that includes the name, all valid
         inputs, outputs and flags
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/read.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/read.py	2015-07-18 13:00:42 UTC (rev 65604)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/modules/interface/read.py	2015-07-18 13:02:23 UTC (rev 65605)
@@ -91,7 +91,7 @@
     # flag
-    'flag': """{name}: {default}
+    'flag': """{name}: {default}, {supress}
     {description}""",
     # foot
