[GRASS-SVN] r65640 - grass/trunk/gui/wxpython/tplot
svn_grass at osgeo.org
Sun Jul 19 10:05:11 PDT 2015
Author: lucadelu
Date: 2015-07-19 10:05:11 -0700 (Sun, 19 Jul 2015)
New Revision: 65640
grass/trunk/gui/wxpython/tplot/frame.py
grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
update tplot; starting implementation of stvds thanks to matej krejci for the initial patch
Modified: grass/trunk/gui/wxpython/tplot/frame.py
--- grass/trunk/gui/wxpython/tplot/frame.py 2015-07-19 16:53:47 UTC (rev 65639)
+++ grass/trunk/gui/wxpython/tplot/frame.py 2015-07-19 17:05:11 UTC (rev 65640)
@@ -1,3 +1,5 @@
+#!/usr/bin/env python
@package frame
@@ -14,12 +16,21 @@
(>=v2). Read the file COPYING that comes with GRASS for details.
@author Luca Delucchi
+ at author add stvds support-Matej Krejci
from itertools import cycle
import numpy as np
import wx
+from grass.pygrass.modules import Module
+import re
+import wx.lib.flatnotebook as FN
+from mapdisp.main import DMonGrassInterface
+from core.giface import StandaloneGrassInterface
+import grass.script as grass
+from core.utils import _
try:
import matplotlib
# The recommended way to use wx with mpl is with the WXAgg
@@ -39,11 +50,24 @@
import grass.temporal as tgis
from core.gcmd import GMessage, GError, GException, RunCommand
+from gui_core.widgets import CoordinatesValidator
from gui_core import gselect
from core import globalvar
from grass.pygrass.vector.geometry import Point
from grass.pygrass.raster import RasterRow
from collections import OrderedDict
+from subprocess import PIPE
+import os
+import multiprocessing as multi
+try:
+ import wx.lib.agw.flatnotebook as FN
+except ImportError:
+ import wx.lib.flatnotebook as FN
+from core import globalvar
+from gui_core.widgets import GNotebook
+import ipdb
ALPHA = 0.5
COLORS = ['b', 'g', 'r', 'c', 'm', 'y', 'k']
@@ -63,23 +87,44 @@
return True
+def findBetween(s, first, last):
+ try:
+ start = s.rindex(first) + len(first)
+ end = s.rindex(last, start)
+ return s[start:end]
+ except ValueError:
+ return ""
class TplotFrame(wx.Frame):
"""The main frame of the application"""
- def __init__(self, parent):
+ def __init__(self, parent, giface):
wx.Frame.__init__(self, parent, id=wx.ID_ANY,
title=_("GRASS GIS Temporal Plot Tool"))
tgis.init(True)
- self.datasets = []
- self.output = None
- self.timeData = {}
+ self._giface = giface
+ self.datasetsV = None
+ self.datasetsR = None
+ # self.vectorDraw=False
+ # self.rasterDraw=False
+ self.init()
self._layout()
- self.temporalType = None
- self.unit = None
# We create a database interface here to speedup the GUI
self.dbif = tgis.SQLDatabaseInterfaceConnection()
self.dbif.connect()
+ def init(self):
+ self.timeDataR = {}
+ self.timeDataV = {}
+ self.temporalType = None
+ self.unit = None
+ self.listWhereConditions = []
+ self.plotNameListR = []
+ self.plotNameListV = []
def __del__(self):
"""Close the database interface and stop the messenger and C-interface
subprocesses.
@@ -94,14 +139,14 @@
* mpl navigation toolbar
* Control panel for interaction
- self.panel = wx.Panel(self)
+ self.mainPanel = wx.Panel(self)
# Create the mpl Figure and FigCanvas objects.
# 5x4 inches, 100 dots-per-inch
# color = wx.SystemSettings.GetColour(wx.SYS_COLOUR_BACKGROUND)
+ # ------------CANVAS AND TOOLBAR------------
self.fig = Figure((5.0, 4.0), facecolor=(1, 1, 1))
- self.canvas = FigCanvas(self.panel, wx.ID_ANY, self.fig)
+ self.canvas = FigCanvas(self.mainPanel, wx.ID_ANY, self.fig)
# axes are initialized later
self.axes2d = None
self.axes3d = None
@@ -113,52 +158,126 @@
# Layout
+ # ------------MAIN VERTICAL SIZER------------
self.vbox = wx.BoxSizer(wx.VERTICAL)
self.vbox.Add(self.canvas, 1, wx.LEFT | wx.TOP | wx.EXPAND)
self.vbox.Add(self.toolbar, 0, wx.EXPAND)
- self.vbox.AddSpacer(10)
+ # self.vbox.AddSpacer(10)
- gridSizer = wx.GridBagSizer(hgap=5, vgap=5)
+ # ------------ADD NOTEBOOK------------
+ self.ntb = GNotebook(parent=self.mainPanel, style=FN.FNB_FANCY_TABS)
- self.datasetSelect = gselect.Select(parent=self.panel, id=wx.ID_ANY,
- size=globalvar.DIALOG_GSELECT_SIZE,
- type='strds', multiple=True)
- self.drawButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Draw"))
- self.drawButton.Bind(wx.EVT_BUTTON, self.OnRedraw)
- self.helpButton = wx.Button(self.panel, id=wx.ID_ANY, label=_("Help"))
- self.helpButton.Bind(wx.EVT_BUTTON, self.OnHelp)
+ # ------------ITEMS IN NOTEBOOK PAGE (RASTER)------------------------
- self.coor = wx.StaticText(parent=self.panel, id=wx.ID_ANY,
- label=_('X and Y coordinates separated by comma:'))
+ self.controlPanelRaster = wx.Panel(parent=self.ntb, id=wx.ID_ANY)
+ self.datasetSelectLabelR = wx.StaticText(parent=self.controlPanelRaster,
+ id=wx.ID_ANY,
+ label=_('Raster temporal '
+ 'dataset (strds)'))
- self.coorval = wx.TextCtrl(parent=self.panel, id=wx.ID_ANY)
- self.coorval.SetToolTipString(_("Coordinates can be obtained for example "
- "by right-clicking on Map Display."))
+ self.datasetSelectR = gselect.Select(parent=self.controlPanelRaster,
+ id=wx.ID_ANY,
+ size=globalvar.DIALOG_GSELECT_SIZE,
+ type='strds', multiple=True)
+ self.coor = wx.StaticText(parent=self.controlPanelRaster, id=wx.ID_ANY,
+ label=_('X and Y coordinates separated by '
+ 'comma:'))
+ try:
+ self._giface.GetMapWindow()
+ self.coorval = gselect.CoordinatesSelect(parent=self.controlPanelRaster,
+ giface=self._giface)
+ except:
+ self.coorval = wx.TextCtrl(parent=self.controlPanelRaster,
+ id=wx.ID_ANY,
+ size=globalvar.DIALOG_TEXTCTRL_SIZE,
+ validator=CoordinatesValidator())
- gridSizer.Add(wx.StaticText(self.panel, id=wx.ID_ANY,
- label=_("Select space time raster dataset(s):")),
- pos=(0, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
- gridSizer.Add(self.datasetSelect, pos=(1, 0), flag=wx.EXPAND)
+ self.coorval.SetToolTipString(_("Coordinates can be obtained for example"
+ " by right-clicking on Map Display."))
+ self.controlPanelSizerRaster = wx.BoxSizer(wx.VERTICAL)
+ # self.controlPanelSizer.Add(wx.StaticText(self.panel, id=wx.ID_ANY,
+ # label=_("Select space time raster dataset(s):")),
+ # pos=(0, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ self.controlPanelSizerRaster.Add(self.datasetSelectLabelR,
+ flag=wx.EXPAND)
+ self.controlPanelSizerRaster.Add(self.datasetSelectR, flag=wx.EXPAND)
- gridSizer.Add(self.coor, pos=(2, 0), flag=wx.EXPAND)
+ self.controlPanelSizerRaster.Add(self.coor, flag=wx.EXPAND)
+ self.controlPanelSizerRaster.Add(self.coorval, flag=wx.EXPAND)
- gridSizer.Add(self.coorval, pos=(3, 0), flag=wx.EXPAND)
- gridSizer.Add(self.drawButton, pos=(3, 1), flag=wx.EXPAND)
- gridSizer.Add(self.helpButton, pos=(3, 2), flag=wx.EXPAND)
+ self.controlPanelRaster.SetSizer(self.controlPanelSizerRaster)
+ self.controlPanelSizerRaster.Fit(self)
+ self.ntb.AddPage(page=self.controlPanelRaster, text=_('STRDS'),
+ name='STRDS')
- self.vbox.Add(gridSizer, proportion=0, flag=wx.EXPAND | wx.ALL,
- border=10)
+ # ------------ITEMS IN NOTEBOOK PAGE (VECTOR)------------------------
+ self.controlPanelVector = wx.Panel(parent=self.ntb, id=wx.ID_ANY)
+ self.datasetSelectLabelV = wx.StaticText(parent=self.controlPanelVector,
+ id=wx.ID_ANY,
+ label=_('Vector temporal '
+ self.datasetSelectV = gselect.Select(parent=self.controlPanelVector,
+ id=wx.ID_ANY,
+ type='stvds', multiple=True)
+ self.datasetSelectV.Bind(wx.EVT_COMBOBOX_CLOSEUP,
+ self.OnVectorSelected)
+ self.attribute = gselect.ColumnSelect(parent=self.controlPanelVector)
+ self.attributeLabel = wx.StaticText(parent=self.controlPanelVector,
+ id=wx.ID_ANY,
+ label=_('Select attribute '))
+ # TODO fix the select
+ #self.cats = gselect.VectorCategorySelect(parent=self.controlPanelVector,
+ # giface=self._giface)
+ self.catsLabel = wx.StaticText(parent=self.controlPanelVector,
+ id=wx.ID_ANY,
+ label=_('Select category of vector(s)'))
- self.panel.SetSizer(self.vbox)
+ self.controlPanelSizerVector = wx.BoxSizer(wx.VERTICAL)
+ #self.controlPanelSizer.Add(wx.StaticText(self.panel, id=wx.ID_ANY,
+ #label=_("Select space time raster dataset(s):")),
+ #pos=(0, 0), flag=wx.EXPAND | wx.ALIGN_CENTER_VERTICAL)
+ self.controlPanelSizerVector.Add(self.datasetSelectLabelV,
+ flag=wx.EXPAND)
+ self.controlPanelSizerVector.Add(self.datasetSelectV, flag=wx.EXPAND)
+ self.controlPanelSizerVector.Add(self.attributeLabel, flag=wx.EXPAND)
+ self.controlPanelSizerVector.Add(self.attribute, flag=wx.EXPAND)
+ self.controlPanelSizerVector.Add(self.catsLabel, flag=wx.EXPAND)
+ #self.controlPanelSizerVector.Add(self.cats, flag=wx.EXPAND)
+ self.controlPanelVector.SetSizer(self.controlPanelSizerVector)
+ self.controlPanelSizerVector.Fit(self)
+ self.ntb.AddPage(page=self.controlPanelVector, text=_('STVDS'),
+ name='STVDS')
+ # ------------Buttons on the bottom(draw,help)------------
+ self.vButtPanel = wx.Panel(self.mainPanel, id=wx.ID_ANY)
+ self.vButtSizer = wx.BoxSizer(wx.HORIZONTAL)
+ self.drawButton = wx.Button(self.vButtPanel, id=wx.ID_ANY,
+ label=_("Draw"))
+ self.drawButton.Bind(wx.EVT_BUTTON, self.OnRedraw)
+ self.helpButton = wx.Button(self.vButtPanel, id=wx.ID_ANY,
+ label=_("Help"))
+ self.helpButton.Bind(wx.EVT_BUTTON, self.OnHelp)
+ self.vButtSizer.Add(self.drawButton)
+ self.vButtSizer.Add(self.helpButton)
+ self.vButtPanel.SetSizer(self.vButtSizer)
+ self.mainPanel.SetSizer(self.vbox)
+ self.vbox.Add(self.ntb, flag=wx.EXPAND)
+ self.vbox.Add(self.vButtPanel, flag=wx.EXPAND)
self.vbox.Fit(self)
- def _getData(self, timeseries):
+ def _getSTRDdata(self, timeseries):
"""Load data and read properties
:param list timeseries: a list of timeseries
- self.timeData = OrderedDict()
+ self.timeDataR = OrderedDict()
mode = None
unit = None
columns = ','.join(['name', 'start_time', 'end_time'])
@@ -169,18 +288,20 @@
sp = tgis.dataset_factory(etype, fullname)
sp.select(dbif=self.dbif)
- self.timeData[name] = OrderedDict()
+ self.plotNameListR.append(series)
+ self.timeDataR[name] = OrderedDict()
if not sp.is_in_db(dbif=self.dbif):
GError(self, message=_("Dataset <%s> not found in temporal "
"database") % (fullname))
return
- self.timeData[name]['temporalDataType'] = etype
- self.timeData[name]['temporalType'] = sp.get_temporal_type()
- self.timeData[name]['granularity'] = sp.get_granularity()
+ self.timeDataR[name]['temporalDataType'] = etype
+ self.timeDataR[name]['temporalType'] = sp.get_temporal_type()
+ self.timeDataR[name]['granularity'] = sp.get_granularity()
if mode is None:
- mode = self.timeData[name]['temporalType']
- elif self.timeData[name]['temporalType'] != mode:
+ mode = self.timeDataR[name]['temporalType']
+ elif self.timeDataR[name]['temporalType'] != mode:
GError(parent=self, message=_("Datasets have different temporal"
" type (absolute x relative), "
"which is not allowed."))
@@ -188,14 +309,14 @@
# check topology
maps = sp.get_registered_maps_as_objects(dbif=self.dbif)
- self.timeData[name]['validTopology'] = sp.check_temporal_topology(maps=maps, dbif=self.dbif)
+ self.timeDataR[name]['validTopology'] = sp.check_temporal_topology(maps=maps, dbif=self.dbif)
- self.timeData[name]['unit'] = None # only with relative
- if self.timeData[name]['temporalType'] == 'relative':
- start, end, self.timeData[name]['unit'] = sp.get_relative_time()
+ self.timeDataR[name]['unit'] = None # only with relative
+ if self.timeDataR[name]['temporalType'] == 'relative':
+ start, end, self.timeDataR[name]['unit'] = sp.get_relative_time()
if unit is None:
- unit = self.timeData[name]['unit']
- elif self.timeData[name]['unit'] != unit:
+ unit = self.timeDataR[name]['unit']
+ elif self.timeDataR[name]['unit'] != unit:
GError(self, _("Datasets have different time unit which "
"is not allowed."))
return
@@ -203,18 +324,145 @@
rows = sp.get_registered_maps(columns=columns, where=None,
order='start_time', dbif=self.dbif)
for row in rows:
- self.timeData[name][row[0]] = {}
- self.timeData[name][row[0]]['start_datetime'] = row[1]
- self.timeData[name][row[0]]['end_datetime'] = row[2]
+ self.timeDataR[name][row[0]] = {}
+ self.timeDataR[name][row[0]]['start_datetime'] = row[1]
+ self.timeDataR[name][row[0]]['end_datetime'] = row[2]
r = RasterRow(row[0])
r.open()
val = r.get_value(self.poi)
r.close()
- self.timeData[name][row[0]]['value'] = val
+ self.timeDataR[name][row[0]]['value'] = val
self.unit = unit
self.temporalType = mode
return
+ def parseVDbConn(self, map, layerInp):
+ '''find attribute key according to layer of input map'''
+ vdb = Module('v.db.connect', map=map, flags='g', stdout_=PIPE)
+ vdb = vdb.outputs.stdout
+ for line in vdb.splitlines():
+ lsplit = line.split('|')
+ layer = lsplit[0].split('/')[0]
+ if layer == layerInp:
+ return lsplit[2]
+ return None
+ def _getSTVDData(self, timeseries):
+ """Load data and read properties
+ :param list timeseries: a list of timeseries
+ try:
+ len(self.timeDataV)
+ except:
+ self.timeDataV = OrderedDict()
+ # TODO parse categories to where condition
+ # cats = self.cats.GetValue()
+ cats = [str(i) for i in range(1,137)]
+ cats = ','.join(cats)
+ # idKye = 'linkid' #TODO
+ mode = None
+ unit = None
+ attributes = self.attribute.GetValue()
+ columns = ','.join(['name', 'start_time', 'end_time', 'id', 'layer'])
+ for series in timeseries:
+ name = series[0]
+ fullname = name + '@' + series[1]
+ etype = series[2]
+ sp = tgis.dataset_factory(etype, fullname)
+ sp.select(dbif=self.dbif)
+ rows = sp.get_registered_maps(dbif=self.dbif, order="start_time",
+ columns=columns, where=None)
+ for attr in attributes.split(','):
+ for x, cat in enumerate(cats.split(',')):
+ # TODO chck
+ idKye = self.parseVDbConn(rows[x]['name'],
+ rows[x]['layer'])
+ conditionWhere = idKye + '=' + cat
+ self.listWhereConditions.append(conditionWhere)
+ name = str(series) + str(conditionWhere)
+ self.plotNameListV.append(name)
+ self.timeDataV[name] = OrderedDict()
+ if not sp.is_in_db(dbif=self.dbif):
+ GError(self, message=_("Dataset <%s> not found in "
+ "temporal database") % (fullname))
+ return
+ self.timeDataV[name]['temporalDataType'] = etype
+ self.timeDataV[name]['temporalType'] = sp.get_temporal_type()
+ self.timeDataV[name]['granularity'] = sp.get_granularity()
+ if mode is None:
+ mode = self.timeDataV[name]['temporalType']
+ elif self.timeDataV[name]['temporalType'] != mode:
+ GError(parent=self, message=_("Datasets have different temporal"
+ " type (absolute x relative), "
+ "which is not allowed."))
+ return
+ # check topology
+ maps = sp.get_registered_maps_as_objects(dbif=self.dbif)
+ self.timeDataV[name]['validTopology'] = sp.check_temporal_topology(maps=maps, dbif=self.dbif)
+ self.timeDataV[name]['unit'] = None # only with relative
+ if self.timeDataV[name]['temporalType'] == 'relative':
+ start, end, self.timeDataV[name]['unit'] = sp.get_relative_time()
+ if unit is None:
+ unit = self.timeDataV[name]['unit']
+ elif self.timeDataV[name]['unit'] != unit:
+ GError(self, _("Datasets have different time unit"
+ " which is not allowed."))
+ return
+ workers = multi.cpu_count()
+ # Check if workers are already being used
+ # run all bands in parallel
+ if "WORKERS" in os.environ:
+ workers = int(os.environ["WORKERS"])
+ else:
+ workers = len(rows)
+ # Initialize process dictionary
+ proc = {}
+ pout = {}
+ for j, row in enumerate(rows):
+ self.timeDataV[name][row[3]] = {}
+ self.timeDataV[name][row[3]]['start_datetime'] = row[1]
+ self.timeDataV[name][row[3]]['end_datetime'] = row[2]
+ if self.timeDataV[name][row[3]]['end_datetime'] is None:
+ self.timeDataV[name][row[3]]['end_datetime'] = row[1]
+ proc[j] = grass.pipe_command('v.db.select',
+ map=row['name'],
+ layer=row['layer'],
+ where=conditionWhere,
+ columns=attr,
+ flags='c')
+ if j % workers is 0:
+ # wait for the ones launched so far to finish
+ for jj in range(j):
+ if not proc[jj].stdout.closed:
+ pout[jj] = proc[jj].communicate()[0]
+ proc[jj].wait()
+ for row in range(len(proc)):
+ if not proc[row].stdout.closed:
+ pout[row] = proc[row].communicate()[0]
+ proc[row].wait()
+ for i, row in enumerate(rows):
+ self.timeDataV[name][row[3]]['value'] = pout[i]
+ ipdb.set_trace()
+ self.unit = unit
+ self.temporalType = mode
+ return
def _drawFigure(self):
"""Draws or print 2D plot (temporal extents)"""
self.axes2d.clear()
@@ -228,72 +476,141 @@
self.convert = lambda x: x
self.invconvert = self.convert
- colors = cycle(COLORS)
+ self.colors = cycle(COLORS)
- yticksNames = []
- yticksPos = []
- plots = []
- lookUp = LookUp(self.timeData, self.invconvert)
- for i, name in enumerate(self.datasets):
+ self.yticksNames = []
+ self.yticksPos = []
+ self.plots = []
+ if self.datasetsR:
+ self.lookUp = LookUp(self.timeDataR, self.invconvert)
+ else:
+ self.lookUp = LookUp(self.timeDataV, self.invconvert)
+ self.drawR()
+ if self.datasetsV:
+ self.drawV()
+ self.canvas.draw()
+ DataCursor(self.plots, self.lookUp, InfoFormat, self.convert)
+ def drawR(self):
+ for i, name in enumerate(self.datasetsR):
name = name[0]
- yticksNames.append(name) # just name; with mapset it would be long
- yticksPos.append(i)
+ # just name; with mapset it would be long
+ self.yticksNames.append(name)
+ self.yticksPos.append(1) # TODO
xdata = []
ydata = []
- for keys, values in self.timeData[name].iteritems():
+ for keys, values in self.timeDataR[name].iteritems():
if keys in ['temporalType', 'granularity', 'validTopology',
'unit', 'temporalDataType']:
continue
xdata.append(self.convert(values['start_datetime']))
ydata.append(values['value'])
- lookUp.AddDataset(yranges=ydata, xranges=xdata, datasetName=name)
- color = colors.next()
- plots.append(self.axes2d.plot(xdata, ydata, marker='o',
- color=color, label=name)[0])
+ self.lookUp.AddDataset(yranges=ydata, xranges=xdata,
+ datasetName=name)
+ color = self.colors.next()
+ self.plots.append(self.axes2d.plot(xdata, ydata, marker='o',
+ color=color,
+ label=self.plotNameListR[i])[0])
if self.temporalType == 'absolute':
- self.axes2d.set_xlabel(_("Temporal resolution: %s" % self.timeData[name]['granularity']))
+ self.axes2d.set_xlabel(_("Temporal resolution: %s" % self.timeDataR[name]['granularity']))
else:
self.axes2d.set_xlabel(_("Time [%s]") % self.unit)
- self.axes2d.set_ylabel(', '.join(yticksNames))
+ self.axes2d.set_ylabel(', '.join(self.yticksNames))
- #legend
+ # legend
handles, labels = self.axes2d.get_legend_handles_labels()
self.axes2d.legend(loc=0)
- if self.output:
- self.canvas.print_figure(filename=self.output, dpi=self.dpi)
+ def drawV(self):
+ for i, name in enumerate(self.plotNameListV):
+ self.yticksNames.append(self.attribute.GetValue())
+ self.yticksPos.append(0) # TODO
+ xdata = []
+ ydata = []
+ for keys, values in self.timeDataV[name].iteritems():
+ if keys in ['temporalType', 'granularity', 'validTopology',
+ 'unit', 'temporalDataType']:
+ continue
+ xdata.append(self.convert(values['start_datetime']))
+ ydata.append(values['value'])
+ datasetName=name)
+ #print xdata
+ #print ydata
+ color=color, label=name)[0])
+ if self.temporalType == 'absolute':
+ self.axes2d.set_xlabel(_("Temporal resolution: %s" % self.timeDataV[name]['granularity']))
else:
- self.canvas.draw()
- DataCursor(plots, lookUp, InfoFormat, self.convert)
+ self.axes2d.set_xlabel(_("Time [%s]") % self.unit)
- def OnRedraw(self, event):
+ # legend
+ handles, labels = self.axes2d.get_legend_handles_labels()
+ self.axes2d.legend(loc=0)
+ def OnRedraw(self, event=None):
"""Required redrawing."""
- datasets = self.datasetSelect.GetValue().strip()
- if not datasets:
+ self.init()
+ datasetsR = self.datasetSelectR.GetValue().strip()
+ datasetsV = self.datasetSelectV.GetValue().strip()
+ if not datasetsR and not datasetsV:
return
- datasets = datasets.split(',')
- try:
- datasets = self._checkDatasets(datasets)
- if not datasets:
+ # check raster dataset
+ if datasetsR:
+ datasetsR = datasetsR.split(',')
+ try:
+ datasetsR = self._checkDatasets(datasetsR)
+ if not datasetsR:
+ return
+ except GException:
+ GError(parent=self, message=_("Invalid input raster dataset"))
return
- except GException:
- GError(parent=self, message=_("Invalid input data"))
- return
- self.datasets = datasets
- try:
- coordx, coordy = self.coorval.GetValue().split(',')
- coordx, coordy = float(coordx), float(coordy)
- except ValueError:
- GMessage(_("Incorrect format of coordinates, should be: x,y"))
- coors = [coordx, coordy]
- if coors:
try:
- self.poi = Point(float(coors[0]), float(coors[1]))
+ coordx, coordy = self.coorval.coordsField.GetValue().split(',')
+ coordx, coordy = float(coordx), float(coordy)
+ try:
+ coordx, coordy = self.coorval.GetValue().split(',')
+ GMessage(_("Incorrect format of coordinates, should be: x,y"))
+ coors = [coordx, coordy]
+ if coors:
+ try:
+ self.poi = Point(float(coors[0]), float(coors[1]))
+ GError(parent=self, message=_("Invalid input coordinates"))
+ return
+ self.datasetsR = datasetsR
+ # check vector dataset
+ if datasetsV:
+ datasetsV = datasetsV.split(',')
+ try:
+ datasetsV = self._checkDatasets(datasetsV)
+ if not datasetsV:
+ return
except GException:
- GError(parent=self, message=_("Invalid input coordinates"))
+ GError(parent=self, message=_("Invalid input vector dataset"))
return
+ self.datasetsV = datasetsV
self._redraw()
def _redraw(self):
@@ -301,7 +618,12 @@
Decides if to draw also 3D and adjusts layout if needed.
- self._getData(self.datasets)
+ self._getSTRDdata(self.datasetsR)
+ self._getSTVDData(self.datasetsV)
# axes3d are physically removed
if not self.axes2d:
self.axes2d = self.fig.add_subplot(1, 1, 1)
@@ -367,19 +689,23 @@
"""Function to show help"""
RunCommand('g.manual', quiet=True, entry='g.gui.tplot')
- def SetDatasets(self, datasets, coors, output, dpi):
+ def SetDatasets(self, rasters, vectors, coors, cats, attr):
"""Set the data
- :param list datasets: a list of temporal dataset's name
+ #TODO
+ :param list rasters: a list of temporal raster dataset's name
+ :param list vectors: a list of temporal vector dataset's name
:param list coors: a list with x/y coordinates
- :param str output: the name of output png file
- :param int dpi: the dpi value for png file
+ :param list cats: a list with incld. categories of vector
+ :param str attr: name of atribute of vectror data
- if not datasets or not coors:
+ if not (rasters or vectors) or not coors:
return
try:
- if not datasets:
+ if rasters:
+ self.datasetsR = self._checkDatasets(rasters)
+ if vectors:
+ self.datasetsV = self._checkDatasets(vectors)
+ if not (self.datasetsR or self.datasetsV):
return
except GException:
GError(parent=self, message=_("Invalid input temporal dataset"))
@@ -389,17 +715,32 @@
except GException:
return
- self.output = output
- self.dpi = dpi
- self.datasetSelect.SetValue(','.join(map(lambda x: x[0] + '@' + x[1],
- datasets)))
- self.coorval.SetValue(','.join(coors))
+ self.datasetSelectV.SetValue(','.join(map(lambda x: x[0] + '@' + x[1],
+ self.datasetsV)))
+ self.attribute.SetValue(attr)
+ self.datasetSelectR.SetValue(','.join(map(lambda x: x[0] + '@' + x[1],
+ self.datasetsR)))
+ try:
+ self.coorval.coordsField.SetValue(','.join(coors))
+ except:
+ self.coorval.SetValue(','.join(coors))
self._redraw()
+ def OnVectorSelected(self, event):
+ """Update the controlbox related to stvds"""
+ dataset = self.datasetSelectV.GetValue().strip()
+ vect_list = grass.read_command('t.vect.list', flags='s', input=dataset,
+ col='name')
+ vect_list = list(set(sorted(vect_list.split())))
+ for vec in vect_list:
+ self.attribute.InsertColumns(vec, 1)
class LookUp:
"""Helper class for searching info by coordinates"""
def __init__(self, timeData, convert):
self.data = {}
self.timeData = timeData
@@ -437,7 +778,8 @@
elif etype == 'str3ds':
text.append(_("Space time 3D raster dataset: %s") % key)
- text.append(_("Value for {date} is {val}".format(date=val[0], val=val[1])))
+ text.append(_("Value for {date} is {val}".format(date=val[0],
+ val=val[1])))
text.append('\n')
text.append(_("Press Del to dismiss."))
@@ -452,6 +794,7 @@
Source: http://stackoverflow.com/questions/4652439/
is-there-a-matplotlib-equivalent-of-matlabs-datacursormode/4674445
def __init__(self, artists, lookUp, formatFunction, convert,
tolerance=5, offsets=(-30, 20), display_all=False):
"""Create the data cursor and connect it to the relevant figure.
@@ -538,14 +881,3 @@
annotation.set_text(text)
annotation.set_visible(True)
event.canvas.draw()
-def run(parent=None, datasets=None):
- frame = TplotFrame(parent)
- if datasets:
- frame.SetDatasets(datasets)
- frame.Show()
-if __name__ == '__main__':
- run()
Modified: grass/trunk/gui/wxpython/tplot/g.gui.tplot.py
--- grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-07-19 16:53:47 UTC (rev 65639)
+++ grass/trunk/gui/wxpython/tplot/g.gui.tplot.py 2015-07-19 17:05:11 UTC (rev 65640)
@@ -21,31 +21,58 @@
#%module
-#% description: Allows the user to see in a plot the values of one or more temporal datasets for a queried point defined by a coordinate pair.
-#% keyword: general
-#% keyword: GUI
-#% keyword: temporal
+#% description: Allows the user to see in a plot the values of one or more temporal raser datasets for a queried point defined by a coordinate pair. Also allows to plot data of vector dataset for a defined categories and attribut.
+#% keywords: general
+#% keywords: GUI
+#% keywords: temporal
#%end
-#%option G_OPT_STDS_INPUTS
+#%option G_OPT_STVDS_INPUTS
+#% key: stvds
#% required: no
#%end
+#%option G_OPT_STRDS_INPUTS
+#% key: strds
+#% required: no
+#%end
#%option G_OPT_M_COORDS
#% required: no
#%end
+#TODO use option G_OPT_V_CATS
+#%option
+#% key: cats
+#% label: Categories of vectores features
+#% description: To use only with stvds
+#% required: no
+#%end
+#%option
+#% key: attr
+#% label: Name of attribute
+#% description: Name of attribute which represent data for plotting
+#% required: no
+#%end
#%option G_OPT_F_OUTPUT
#% required: no
#% label: Name for output file
#% description: Add extension to specify format (.png, .pdf, .svg)
#%end
#%option
-#% key: dpi
-#% type: integer
-#% label: The DPI for output image
-#% description: To use only with output parameter
+#% key: size
+#% type: string
+#% label: The size for output image
+#% description: It works only with output parameter
#% required: no
#%end
import grass.script as gscript
def main():
@@ -57,26 +84,38 @@
from tplot.frame import TplotFrame
except ImportError as e:
gscript.fatal(e.message)
- datasets = options['inputs'].strip().split(',')
- datasets = [data for data in datasets if data]
+ rasters = None
+ if options['strds']:
+ rasters = options['strds'].strip().split(',')
+ vectors = None
+ attr = None
+ if options['stvds']:
+ vectors = options['stvds'].strip().split(',')
+ if not options['attr']:
+ gscript.fatal(_("With stvds you have to use also 'attr' option"))
+ else:
+ attr = options['attr']
coords = options['coordinates'].strip().split(',')
output = options['output']
- dpi = options['dpi']
- dpi = int(dpi) if dpi else None
- if dpi and not output:
- gscript.warning(
- _("No output filename set, so DPI option will not used"))
app = wx.App()
- frame = TplotFrame(None)
- frame.SetDatasets(datasets, coords, output, dpi)
+ frame = TplotFrame(parent=None, giface=StandaloneGrassInterface())
+ frame.SetDatasets(rasters, vectors, coords, None, attr)
if output:
- return
+ frame.OnRedraw()
+ if options['size']:
+ sizes = options['size'].strip().split(',')
+ sizes = [int(s) for s in sizes]
+ frame.canvas.SetSize(sizes)
+ if output.split('.')[-1].lower() == 'png':
+ frame.canvas.print_png(output)
+ if output.split('.')[-1].lower() in ['jpg', 'jpeg']:
+ frame.canvas.print_jpg(output)
+ if output.split('.')[-1].lower() in ['tif', 'tiff']:
+ frame.canvas.print_tif(output)
+ else:
+ frame.Show()
+ app.MainLoop()
- frame.Show()
- app.MainLoop()
main()
