[GRASS-SVN] r65651 - in grass/branches/releasebranch_7_0/lib/python: docs/src pygrass/tests
svn_grass at osgeo.org
Sun Jul 19 12:00:58 PDT 2015
Author: wenzeslaus
Date: 2015-07-19 12:00:58 -0700 (Sun, 19 Jul 2015)
New Revision: 65651
grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_modules.rst
grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst
grass/branches/releasebranch_7_0/lib/python/pygrass/tests/benchmark.py
backport r65526 (pygrass to grass.pygrass)
Modified: grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_modules.rst
--- grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_modules.rst 2015-07-19 18:47:27 UTC (rev 65650)
+++ grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_modules.rst 2015-07-19 19:00:58 UTC (rev 65651)
@@ -5,7 +5,7 @@
are generated based on the XML module description that is used also for
the generation of the graphical user interface (GUI). ::
- >>> from pygrass.modules import Module
+ >>> from grass.pygrass.modules import Module
>>> slope_aspect = Module("r.slope.aspect", elevation='elevation',
... slope='slp', aspect='asp',
... format='percent', overwrite=True)
Modified: grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst
--- grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst 2015-07-19 18:47:27 UTC (rev 65650)
+++ grass/branches/releasebranch_7_0/lib/python/docs/src/pygrass_vector.rst 2015-07-19 19:00:58 UTC (rev 65651)
@@ -309,7 +309,7 @@
Of course is still possible work only with a specific area, with: ::
- >>> from pygrass.vector.geometry import Area
+ >>> from grass.pygrass.vector.geometry import Area
>>> area = Area(v_id=1859, c_mapinfo=municip.c_mapinfo)
>>> area.area()
39486.05401495844
Modified: grass/branches/releasebranch_7_0/lib/python/pygrass/tests/benchmark.py
--- grass/branches/releasebranch_7_0/lib/python/pygrass/tests/benchmark.py 2015-07-19 18:47:27 UTC (rev 65650)
+++ grass/branches/releasebranch_7_0/lib/python/pygrass/tests/benchmark.py 2015-07-19 19:00:58 UTC (rev 65651)
@@ -21,7 +21,7 @@
import grass.lib.gis as libgis
import grass.lib.raster as libraster
import grass.script as core
-import pygrass
+import grass.pygrass
import ctypes
