[GRASS-SVN] r65654 - grass/branches/releasebranch_7_0/vector/v.extract
svn_grass at osgeo.org
Sun Jul 19 12:06:13 PDT 2015
Author: wenzeslaus
Date: 2015-07-19 12:06:13 -0700 (Sun, 19 Jul 2015)
New Revision: 65654
grass/branches/releasebranch_7_0/vector/v.extract/extract.c
backport r65475 (add main debug message to the extract_line function)
Modified: grass/branches/releasebranch_7_0/vector/v.extract/extract.c
--- grass/branches/releasebranch_7_0/vector/v.extract/extract.c 2015-07-19 19:04:15 UTC (rev 65653)
+++ grass/branches/releasebranch_7_0/vector/v.extract/extract.c 2015-07-19 19:06:13 UTC (rev 65654)
@@ -194,6 +194,9 @@
struct Map_info *Out, int new, int select_type, int dissolve,
int field, int type_only, int reverse)
+ G_debug(2, "extract_line(num_index=%d, new=%d, select_type=%d,"
+ " dissolve=%d, field=%d, type_only=%d, reverse=%d)",
+ num_index, new, select_type, dissolve, field, type_only, reverse);
int line, nlines, native;
struct line_pnts *Points;
struct line_cats *Line_Cats_Old, *CCats;
