[GRASS-SVN] r65658 - grass/branches/releasebranch_7_0/lib/python/script
svn_grass at osgeo.org
Sun Jul 19 12:15:57 PDT 2015
Author: wenzeslaus
Date: 2015-07-19 12:15:57 -0700 (Sun, 19 Jul 2015)
New Revision: 65658
grass/branches/releasebranch_7_0/lib/python/script/core.py
backport r65523 (improve python doc)
Modified: grass/branches/releasebranch_7_0/lib/python/script/core.py
--- grass/branches/releasebranch_7_0/lib/python/script/core.py 2015-07-19 19:15:14 UTC (rev 65657)
+++ grass/branches/releasebranch_7_0/lib/python/script/core.py 2015-07-19 19:15:57 UTC (rev 65658)
@@ -362,14 +362,28 @@
def run_command(*args, **kwargs):
- """Passes all arguments to start_command(), then waits for the process to
- complete, returning its exit code. Similar to subprocess.check_call(), but
- with the make_command() interface.
+ """Execute a module synchronously
- :param list args: list of unnamed arguments (see start_command() for details)
- :param list kwargs: list of named arguments (see start_command() for details)
+ This function passes all arguments to ``start_command()``,
+ then waits for the process to complete. It is similar to
+ ``subprocess.check_call()``, but with the ``make_command()``
+ interface.
- :return: exit code (0 for success)
+ For backward compatibility, the function returns exit code
+ by default but only if it is equal to zero. An exception is raised
+ in case of an non-zero return code.
+ >>> run_command('g.region', raster='elevation')
+ 0
+ See ``start_command()`` for details about parameters and usage.
+ :param *args: unnamed arguments passed to ``start_command()``
+ :param **kwargs: named arguments passed to ``start_command()``
+ :returns: 0 with default parameters for backward compatibility only
+ :raises: ``CalledModuleError`` when module returns non-zero return code
ps = start_command(*args, **kwargs)
returncode = ps.wait()
@@ -470,14 +484,27 @@
def write_command(*args, **kwargs):
- """Passes all arguments to feed_command, with the string specified
- by the 'stdin' argument fed to the process' stdin.
+ """Execute a module with standard input given by *stdin* parameter.
+ Passes all arguments to ``feed_command()``, with the string specified
+ by the *stdin* argument fed to the process' standard input.
- :return: return code
+ >>> gscript.write_command(
+ ... 'v.in.ascii', input='-',
+ ... stdin='%s|%s' % (635818.8, 221342.4),
+ ... output='view_point')
+ 0
+ # TODO: should we delete it from kwargs?
stdin = kwargs['stdin']
process = feed_command(*args, **kwargs)
process.communicate(stdin)
@@ -523,6 +550,7 @@
:param str debug: debug level (0-5)
if debug_level() >= debug:
+ # TODO: quite a random hack here, do we need it somewhere else too?
if sys.platform == "win32":
msg = msg.replace('&', '^&')
