[GRASS-SVN] r65667 - grass-addons/grass7/raster/r.import
svn_grass at osgeo.org
Sun Jul 19 12:37:12 PDT 2015
Author: martinl
Date: 2015-07-19 12:37:12 -0700 (Sun, 19 Jul 2015)
New Revision: 65667
grass-addons/grass7/raster/r.import/r.import.py
r.import: clean up, replace input_file/directory by input
Modified: grass-addons/grass7/raster/r.import/r.import.py
--- grass-addons/grass7/raster/r.import/r.import.py 2015-07-19 19:28:02 UTC (rev 65666)
+++ grass-addons/grass7/raster/r.import/r.import.py 2015-07-19 19:37:12 UTC (rev 65667)
@@ -17,25 +17,17 @@
#%module
-#% description: Import raster data using GDAL library and reproject on the fly.
+#% description: Imports raster data into a GRASS raster map using GDAL library and reproject on the fly.
#% keyword: raster
#% keyword: import
#% keyword: projection
#%end
-#%option G_OPT_F_BIN_INPUT
-#% key: input_file
-#% required: no
-#% multiple: no
-#% description: Name of GDAL dataset (file) to be imported
-#% guisection: Input
+#%option
+#% key: input
+#% type: string
+#% required: yes
+#% description: Name of GDAL dataset to be imported
#%end
-#%option G_OPT_M_DIR
-#% key: input_directory
-#% required: no
-#% multiple: no
-#% description: Name of GDAL dataset (directory) to be imported
-#%end
#%option
#% key: band
#% type: integer
@@ -55,9 +47,6 @@
#% answer: 300
#%end
#%option G_OPT_R_OUTPUT
-#% required: yes
-#% multiple: no
-#% key_desc: name
#% description: Name for output raster map
#% guisection: Output
#%end
@@ -76,7 +65,7 @@
#% type: string
#% required: yes
#% multiple: no
-#% options: region,input
+#% options: input,region
#% description: Ouput raster map extents
#% descriptions: region;extents of current region;input;extents of input map
@@ -113,41 +102,27 @@
def cleanup():
# remove temp location
if tmploc:
- path = os.path.join(gisdbase, tmploc)
- grass.try_rmdir(path)
+ grass.try_rmdir(os.path.join(gisdbase, tmploc))
if srcgisrc:
grass.try_remove(srcgisrc)
def main():
global tmploc, srcgisrc, gisdbase
+ GDALdatasource = options['input']
output = options['output']
method = options['resample']
memory = options['memory']
do_import = flags['i']
- bands = None
- if options['band']:
- bands = options['band']
- tgtres = None
- if options['resolution']:
- tgtres = options['resolution']
+ bands = options['band']
+ tgtres = options['resolution']
# initialize global vars
tmploc = None
srcgisrc = None
gisdbase = None
- GDALdatasource = None
- if options['input_file']:
- GDALdatasource = options['input_file']
- if not GDALdatasource:
- GDALdatasource = options['input_directory']
- grass.fatal(_("Either option 'input_file' or option 'input_directory' must be given"))
grassenv = grass.gisenv()
tgtloc = grassenv['LOCATION_NAME']
tgtmapset = grassenv['MAPSET']
@@ -158,7 +133,6 @@
tmploc = 'temp_import_location_' + str(os.getpid())
f = open(srcgisrc, 'w')
- f.write('DEBUG: 0\n')
f.write('MAPSET: PERMANENT\n')
f.write('GISDBASE: %s\n' % gisdbase)
f.write('LOCATION_NAME: %s\n' % tmploc);
@@ -169,17 +143,15 @@
# create temp location from input without import
grass.message(_("Creating temporary location for <%s>...") % GDALdatasource)
- ps = grass.start_command('r.in.gdal', input = GDALdatasource,
- band = bands, output = output,
- memory = memory, flags = 'c',
- location = tmploc, quiet = True)
- returncode = ps.wait()
+ returncode = grass.run_command('r.in.gdal', input = GDALdatasource,
+ band = bands, output = output,
+ memory = memory, flags = 'c',
+ location = tmploc, quiet = True)
# if it fails, return
if returncode != 0:
grass.fatal(_("Unable to read GDAL dataset <%s>") % GDALdatasource)
- sys.exit(1)
# switch to temp location
os.environ['GISRC'] = str(srcgisrc)
@@ -192,37 +164,32 @@
if insrs == tgtsrs:
# try r.in.gdal directly
grass.message(_("Importing <%s>...") % GDALdatasource)
- memory = memory, flags = 'k')
+ memory = memory, flags = 'k')
if returncode == 0:
grass.message(_("Input <%s> successfully imported without reprojection") % GDALdatasource)
- sys.exit(0)
+ return 0
else:
grass.fatal(_("Unable to import GDAL dataset <%s>") % GDALdatasource)
- sys.exit(1)
# make sure target is not xy
if grass.parse_command('g.proj', flags = 'g')['name'] == 'xy_location_unprojected':
grass.fatal(_("Coordinate reference system not available for current location <%s>") % tgtloc)
- sys.exit(1)
# make sure input is not xy
grass.fatal(_("Coordinate reference system not available for input <%s>") % GDALdatasource)
- sys.exit(1)
# import into temp location
grass.message(_("Importing <%s> to temporary location...") % GDALdatasource)
if returncode != 0:
@@ -238,8 +205,7 @@
path = os.path.join(gisdbase, tmploc, 'group', output, 'POINTS')
if os.path.exists(path):
grass.fatal(_("Input contains GCPs, rectification is required"))
- sys.exit(1)
# switch to target location
os.environ['GISRC'] = str(tgtgisrc)
@@ -275,7 +241,6 @@
memory = memory, quiet = True)
except:
grass.fatal(_("Unable to get reprojected map extents"))
- sys.exit(1)
srcregion = grass.parse_key_val(tgtextents, val_type = float, vsep = ' ')
n = srcregion['n']
@@ -294,9 +259,9 @@
# reproject to src
- ps = grass.start_command('v.proj', input = vreg, output = vreg,
- location = tgtloc, mapset = tgtmapset, quiet = True)
+ returncode = grass.run_command('v.proj', input = vreg, output = vreg,
+ location = tgtloc, mapset = tgtmapset, quiet = True)
if returncode != 0:
grass.fatal(_("Unable to reproject to source location"))
sys.exit(1)
@@ -320,7 +285,6 @@
grass.message(_("Specified target resolution: %g") % outres)
if do_import:
if options['extents'] == 'input':
grass.use_temp_region()
grass.run_command('g.region', n = n, s = s, e = e, w = w)
@@ -328,18 +292,15 @@
# r.proj
grass.message(_("Reprojecting <%s>...") % outfile)
- ps = grass.start_command('r.proj', location = tmploc,
- mapset = 'PERMANENT', input = outfile,
- method = method, resolution = tgtres,
- memory = memory, flags = rflags, quiet = True)
+ returncode = grass.run_command('r.proj', location = tmploc,
+ mapset = 'PERMANENT', input = outfile,
+ method = method, resolution = tgtres,
+ memory = memory, flags = rflags, quiet = True)
if returncode != 0:
grass.fatal(_("Unable to to reproject raster <%s>") % outfile)
- sys.exit(1)
if grass.raster_info(outfile)['min'] is None:
grass.fatal(_("The reprojected raster <%s> is empty") % outfile)
- sys.exit(1)
grass.del_temp_region()
@@ -350,8 +311,9 @@
else:
grass.message(_("The input <%s> can be imported and reprojected with the -i flag") % GDALdatasource)
+ return 0
if __name__ == "__main__":
options, flags = grass.parser()
atexit.register(cleanup)
- main()
+ sys.exit(main())
