[GRASS-SVN] r65674 - grass/trunk/scripts/i.tasscap
Mon Jul 20 00:57:13 PDT 2015
Author: lucadelu
Date: 2015-07-20 00:57:13 -0700 (Mon, 20 Jul 2015)
New Revision: 65674
   grass/trunk/scripts/i.tasscap/i.tasscap.py
update PEP8, thanks Nikos Alexandris r2690
Modified: grass/trunk/scripts/i.tasscap/i.tasscap.py
--- grass/trunk/scripts/i.tasscap/i.tasscap.py	2015-07-20 07:56:21 UTC (rev 65673)
+++ grass/trunk/scripts/i.tasscap/i.tasscap.py	2015-07-20 07:57:13 UTC (rev 65674)
@@ -1,5 +1,5 @@
 #!/usr/bin/env python
 # MODULE:	i.tasscap
@@ -24,7 +24,7 @@
 # LANDSAT-7:
 #  TASSCAP factors cited from:
 #   DERIVATION OF A TASSELED CAP TRANSFORMATION BASED ON LANDSAT 7 AT-SATELLITE REFLECTANCE
-#   Chengquan Huang, Bruce Wylie, Limin Yang, Collin Homer and Gregory Zylstra Raytheon ITSS,
+#   Chengquan Huang, Bruce Wylie, Limin Yang, Collin Homer and Gregory Zylstra Raytheon ITSS,
 #   USGS EROS Data Center Sioux Falls, SD 57198, USA
 #   http://landcover.usgs.gov/pdf/tasseled.pdf
@@ -33,17 +33,17 @@
 #  http://adis.cesnet.cz/cgi-bin/lwgate/IMAGRS-L/archives/imagrs-l.log0211/date/article-14.html
 #  Landsat8: Baig, M.H.A., Zhang, L., Shuai, T., Tong, Q., 2014. Derivation of a tasselled cap transformation
-#              based on Landsat 8 at-satellite reflectance. Remote Sensing Letters 5, 423-431.
+#              based on Landsat 8 at-satellite reflectance. Remote Sensing Letters 5, 423-431.
 #              doi:10.1080/2150704X.2014.915434
 #  MODIS Tasselled Cap coefficients
 #  https://gis.stackexchange.com/questions/116107/tasseled-cap-transformation-on-modis-in-grass/116110
-#  Ref: Lobser & Cohen (2007). MODIS tasselled cap: land cover characteristics
+#  Ref: Lobser & Cohen (2007). MODIS tasselled cap: land cover characteristics
 #                              expressed through transformed MODIS data.
 #       International Journal of Remote Sensing, Volume 28(22), Table 3
 #%Module
 #% description: Performs Tasseled Cap (Kauth Thomas) transformation.
 #% keyword: imagery
@@ -52,12 +52,15 @@
 #% keyword: MODIS
 #% keyword: Tasseled Cap transformation
 #%end
 #%option G_OPT_R_INPUTS
 #% description: For Landsat4-7: bands 1, 2, 3, 4, 5, 7; for Landsat8: bands 2, 3, 4, 5, 6, 7; for MODIS: bands 1, 2, 3, 4, 5, 6, 7
 #%end
 #%option G_OPT_R_BASENAME_OUTPUT
 #% label: Name for output basename raster map(s)
 #%end
 #%option
 #% key: sensor
 #% type: string
@@ -72,52 +75,78 @@
 # weights for 6 Landsat bands: TM4, TM5, TM7, OLI
 # MODIS: Red, NIR1, Blue, Green, NIR2, SWIR1, SWIR2
-parms = [[( 0.3037, 0.2793, 0.4743, 0.5585, 0.5082, 0.1863), # Landsat TM4
-	  (-0.2848,-0.2435,-0.5435, 0.7243, 0.0840,-0.1800),
-	  ( 0.1509, 0.1973, 0.3279, 0.3406,-0.7112,-0.4572)],
-	 [( 0.2909, 0.2493, 0.4806, 0.5568, 0.4438, 0.1706, 10.3695), # Landsat TM5
-	  (-0.2728,-0.2174,-0.5508, 0.7221, 0.0733,-0.1648, -0.7310),
-	  ( 0.1446, 0.1761, 0.3322, 0.3396,-0.6210,-0.4186, -3.3828),
-	  ( 0.8461,-0.0731,-0.4640,-0.0032,-0.0492,-0.0119,  0.7879)],
-	 [( 0.3561, 0.3972, 0.3904, 0.6966, 0.2286, 0.1596), # Landsat TM7
-	  (-0.3344,-0.3544,-0.4556, 0.6966,-0.0242,-0.2630),
-	  ( 0.2626, 0.2141, 0.0926, 0.0656,-0.7629,-0.5388),
-	  ( 0.0805,-0.0498, 0.1950,-0.1327, 0.5752,-0.7775)],
-	 [( 0.3029, 0.2786, 0.4733, 0.5599, 0.5080, 0.1872), # Landsat TM8
-	  (-0.2941,-0.2430,-0.5424, 0.7276, 0.0713,-0.1608),
-	  ( 0.1511, 0.1973, 0.3283, 0.3407,-0.7117,-0.4559),
-	  (-0.8239, 0.0849, 0.4396, -0.058, 0.2013,-0.2773)],
-	 [( 0.4395, 0.5945, 0.2460, 0.3918, 0.3506, 0.2136, 0.2678), # MODIS
-	  (-0.4064, 0.5129,-0.2744,-0.2893, 0.4882,-0.0036,-0.4169),
-	  ( 0.1147, 0.2489, 0.2408, 0.3132,-0.3122,-0.6416,-0.5087)]]
-#satellite information
-satellites = ["landsat4_tm", 'landsat5_tm', 'landsat7_etm', 'landsat8_oli', 'modis']
-used_bands = [6,6,6,6,7]
-#components information
+parms = [[(0.3037,  0.2793,  0.4743,  0.5585,  0.5082,  0.1863),  # Landsat TM4
+         (-0.2848, -0.2435, -0.5435,  0.7243,  0.0840, -0.1800),
+          (0.1509,  0.1973,  0.3279,  0.3406, -0.7112, -0.4572)],
+         [(0.2909,  0.2493,  0.4806,  0.5568,  0.4438,  0.1706, 10.3695),  # Landsat TM5
+         (-0.2728, -0.2174, -0.5508,  0.7221,  0.0733, -0.1648, -0.7310),
+          (0.1446,  0.1761,  0.3322,  0.3396, -0.6210, -0.4186, -3.3828),
+          (0.8461, -0.0731, -0.4640, -0.0032, -0.0492, -0.0119,  0.7879)],
+         [(0.3561,  0.3972,  0.3904,  0.6966,  0.2286,  0.1596),  # Landsat TM7
+         (-0.3344, -0.3544, -0.4556,  0.6966, -0.0242, -0.2630),
+          (0.2626,  0.2141,  0.0926,  0.0656, -0.7629, -0.5388),
+          (0.0805, -0.0498,  0.1950, -0.1327,  0.5752, -0.7775)],
+         [(0.3029,  0.2786,  0.4733,  0.5599,  0.5080,  0.1872),  # Landsat OLI
+         (-0.2941, -0.2430, -0.5424,  0.7276,  0.0713, -0.1608),
+          (0.1511,  0.1973,  0.3283,  0.3407, -0.7117, -0.4559),
+         (-0.8239,  0.0849,  0.4396, -0.0580,  0.2013, -0.2773)],
+         [(0.4395,  0.5945,  0.2460,  0.3918,  0.3506,  0.2136,  0.2678),  # MODIS
+         (-0.4064,  0.5129, -0.2744, -0.2893,  0.4882, -0.0036, -0.4169),
+          (0.1147,  0.2489,  0.2408,  0.3132, -0.3122, -0.6416, -0.5087)]]
+# satellite information
+satellites = ['landsat4_tm', 'landsat5_tm', 'landsat7_etm', 'landsat8_oli',
+              'modis']
+used_bands = [6, 6, 6, 6, 7]
+# components information
 ordinals = ["first", "second", "third", "fourth"]
 names = ["Brightness", "Greenness", "Wetness", "Haze"]
-def calc1bands6(out, bands, k1, k2, k3, k4, k5, k6, k0 = 0):
-    grass.mapcalc("$out = $k1 * $in1band + $k2 * $in2band + $k3 * $in3band + $k4 * $in4band + $k5 * $in5band + $k6 * $in6band + $k0",
-    out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k6 = k6, k0 = k0, **bands)
+def calc1bands6(out, bands, k1, k2, k3, k4, k5, k6, k0=0):
+    Tasseled cap transformation equation for Landsat bands
+    equation = ('$out = $k1 * $in1band + $k2 * $in2band + $k3 * $in3band + '
+                '$k4 * $in4band + $k5 * $in5band + $k6 * $in6band + $k0')
+    grass.mapcalc(equation, out=out, k1=k1, k2=k2, k3=k3, k4=k4, k5=k5,
+                  k6=k6, k0=k0, **bands)
 def calc1bands7(out, bands, k1, k2, k3, k4, k5, k6, k7):
-    grass.mapcalc("$out = $k1 * $in1band + $k2 * $in2band + $k3 * $in3band + $k4 * $in4band + $k5 * $in5band + $k6 * $in6band + $k7 * $in7band",
-    out = out, k1 = k1, k2 = k2, k3 = k3, k4 = k4, k5 = k5, k6 = k6, k7 = k7, **bands)
+    Tasseled cap transformation equation for MODIS bands
+                '$k4 * $in4band + $k5 * $in5band + $k6 * $in6band + $k7 * '
+                '$in7band')
+    grass.mapcalc(equation, out=out, k1=k1, k2=k2, k3=k3, k4=k4, k5=k5, k6=k6,
+                  k7=k7, **bands)
 def calcN(outpre, bands, satel):
-    i=satellites.index(satel)
-    grass.message(_("Satellite %s...") % satel)
+    Calculating Tasseled Cap components
+    i = satellites.index(satel)
+    grass.message(_("Satellite %s...") % satel)
     for j, p in enumerate(parms[i]):
         out = "%s.%d" % (outpre, j + 1)
         ord = ordinals[j]
-        name = " (%s)" % names[j]
-        grass.message(_("Calculating %s TC component %s%s ...") % (ord, out, name))
-        bands_num=used_bands[i]
-        eval("calc1bands%d(out, bands, *p)" % bands_num) #use combination function suitable for used number of bands
-        grass.run_command('r.colors', map = out, color = 'grey', quiet=True)
+        name = " (%s)" % names[j]
+        message = "Calculating {ordinal} TC component {outprefix}{outname} ..."
+        message = message.format(ordinal=ord, outprefix=out, outname=name)
+        grass.message(_(message))
+        bands_num = used_bands[i]
+        # use combination function suitable for used number of bands
+        eval("calc1bands%d(out, bands, *p)" % bands_num)
+        grass.run_command('r.colors', map=out, color='grey', quiet=True)
 def main():
     options, flags = grass.parser()
     satellite = options['sensor']
@@ -128,16 +157,18 @@
         grass.fatal(_("The number of input raster maps (bands) should be %s") % num_of_bands)
     bands = {}
-    for i, band in enumerate(inputs):
-        band_num = i + 1
+    for i, band in enumerate(inputs):
+        band_num = i + 1
         bands['in' + str(band_num) + 'band'] = band
     grass.debug(1, bands)
-    calcN(output_basename, bands, satellite) #core tasseled cap components computation
+    # core tasseled cap components computation
+    calcN(output_basename, bands, satellite)
-    #assign "Data Description" field in all four component maps
+    # assign "Data Description" field in all four component maps
     for i, comp in enumerate(names):
-        grass.run_command('r.support', map = "%s.%d" % (output_basename, i+1), description = "Tasseled Cap %d: %s" % (i+1, comp))
+        grass.run_command('r.support', map="%s.%d" % (output_basename, i+1),
+                          description="Tasseled Cap %d: %s" % (i+1, comp))
     grass.message(_("Tasseled Cap components calculated"))
