[GRASS-SVN] r65677 - grass/trunk/lib/vector/Vlib
svn_grass at osgeo.org
Mon Jul 20 01:34:53 PDT 2015
Author: martinl
Date: 2015-07-20 01:34:53 -0700 (Mon, 20 Jul 2015)
New Revision: 65677
grass/trunk/lib/vector/Vlib/close.c
grass/trunk/lib/vector/Vlib/close_nat.c
grass/trunk/lib/vector/Vlib/local_proto.h
grass/trunk/lib/vector/Vlib/open.c
vlib: fix GRASS_VECTOR_TEMPORARY when creating temporary maps using Vect_open_new_tmp()
Modified: grass/trunk/lib/vector/Vlib/close.c
--- grass/trunk/lib/vector/Vlib/close.c 2015-07-20 08:02:19 UTC (rev 65676)
+++ grass/trunk/lib/vector/Vlib/close.c 2015-07-20 08:34:53 UTC (rev 65677)
@@ -5,7 +5,7 @@
Higher level functions for reading/writing/manipulating vectors.
- (C) 2001-2009, 2011-2012 by the GRASS Development Team
+ (C) 2001-2015 by the GRASS Development Team
This program is free software under the GNU General Public License
(>=v2). Read the file COPYING that comes with GRASS for details.
Modified: grass/trunk/lib/vector/Vlib/close_nat.c
--- grass/trunk/lib/vector/Vlib/close_nat.c 2015-07-20 08:02:19 UTC (rev 65676)
+++ grass/trunk/lib/vector/Vlib/close_nat.c 2015-07-20 08:34:53 UTC (rev 65677)
@@ -59,7 +59,7 @@
char *env = getenv("GRASS_VECTOR_TEMPORARY");
delete = TRUE;
- if (env) {
+ if (Map->temporary == TEMPORARY_MAP_ENV && env) {
if (G_strcasecmp(env, "move") == 0) {
/* copy temporary vector map to the current mapset */
char path_tmp[GPATH_MAX], path_map[GPATH_MAX];
@@ -82,6 +82,7 @@
#ifdef TEMPORARY_MAP_DB
int i, ndblinks;
+ int tmp;
struct field_info *fi;
dbConnection connection;
@@ -109,9 +110,10 @@
G_free(Map->dblnk);
Map->dblnk = dblinks;
- Map->temporary = FALSE;
+ tmp = Map->temporary;
+ Map->temporary = TEMPORARY_MAP_DISABLED;
Vect_write_dblinks(Map);
- Map->temporary = TRUE;
+ Map->temporary = tmp;
#endif
else if (G_strcasecmp(env, "delete") == 0) {
@@ -125,7 +127,11 @@
delete = FALSE;
+ else if (Map->temporary == TEMPORARY_MAP) {
+ G_debug(1, "V1_close_nat(): temporary map <%s> TO BE DELETED", Map->name);
+ delete = TRUE;
if (delete) {
char path_tmp[GPATH_MAX];
Modified: grass/trunk/lib/vector/Vlib/local_proto.h
--- grass/trunk/lib/vector/Vlib/local_proto.h 2015-07-20 08:02:19 UTC (rev 65676)
+++ grass/trunk/lib/vector/Vlib/local_proto.h 2015-07-20 08:34:53 UTC (rev 65677)
@@ -10,6 +10,11 @@
/*! Attributes of temporary maps */
/* #define TEMPORARY_MAP_DB */
+/*! Temporary mode */
+#define TEMPORARY_MAP_DISABLED 0
+#define TEMPORARY_MAP_ENV 1
+#define TEMPORARY_MAP 2
/* Internal vector library subroutines which are not part of public
API*/
Modified: grass/trunk/lib/vector/Vlib/open.c
--- grass/trunk/lib/vector/Vlib/open.c 2015-07-20 08:02:19 UTC (rev 65676)
+++ grass/trunk/lib/vector/Vlib/open.c 2015-07-20 08:34:53 UTC (rev 65677)
@@ -6,7 +6,7 @@
- (C) 2001-2009, 2012-2013 by the GRASS Development Team
@@ -154,7 +154,7 @@
\param update non-zero to open for update otherwise read-only mode
\param head_only read only header info from 'head', 'dbln', 'topo',
'cidx' is not opened. The header may be opened on level 2 only.
- \param is_tmp TRUE for temporary maps
+ \param is_tmp non-zero code for temporary maps
\return level of openness (1, 2)
\return -1 in error
@@ -175,7 +175,7 @@
is_tmp);
if (update && !is_tmp) {
- is_tmp = getenv("GRASS_VECTOR_TEMPORARY") ? TRUE : FALSE;
+ is_tmp = getenv("GRASS_VECTOR_TEMPORARY") ? TEMPORARY_MAP_ENV : TEMPORARY_MAP_DISABLED;
G_debug(1, "Vect__open_old(): is_tmp = %d (check GRASS_VECTOR_TEMPORARY)", is_tmp);
@@ -912,7 +912,7 @@
int is_tmp;
G_debug(1, "Vect_open_new(): is_tmp = %d", is_tmp);
return open_new(Map, name, with_z, is_tmp);
@@ -950,7 +950,7 @@
G_debug(1, "Vect_open_tmp_new(): name = '%s' with_z = %d", name, with_z);
- return open_new(Map, tmp_name, with_z, TRUE); /* temporary map */
+ return open_new(Map, tmp_name, with_z, TEMPORARY_MAP); /* temporary map */
@@ -1300,7 +1300,7 @@
* in the native format and when closing the map
* transferred to output OGR layer */
format = GV_FORMAT_NATIVE;
+ Map->temporary = TEMPORARY_MAP;
fp = G_fopen_old("", "OGR", G_mapset());
if (!fp) {
@@ -1417,7 +1417,7 @@
* transferred to output PostGIS layer */
