[GRASS-SVN] r65681 - grass/branches/releasebranch_7_0/raster/r.flow
svn_grass at osgeo.org
Mon Jul 20 02:10:05 PDT 2015
Author: martinl
Date: 2015-07-20 02:10:05 -0700 (Mon, 20 Jul 2015)
New Revision: 65681
Added:
grass/branches/releasebranch_7_0/raster/r.flow/r_flow_accumulation.png
grass/branches/releasebranch_7_0/raster/r.flow/r_flow_length.png
grass/branches/releasebranch_7_0/raster/r.flow/r_flow_line.png
grass/branches/releasebranch_7_0/raster/r.flow/r.flow.html
r.flow: examples added (thanks to Ludmila Furtkevicova)
(merge 65680 from trunk)
Modified: grass/branches/releasebranch_7_0/raster/r.flow/r.flow.html
--- grass/branches/releasebranch_7_0/raster/r.flow/r.flow.html 2015-07-20 09:04:52 UTC (rev 65680)
+++ grass/branches/releasebranch_7_0/raster/r.flow/r.flow.html 2015-07-20 09:10:05 UTC (rev 65681)
@@ -156,6 +156,29 @@
great that quantization error is larger than one of the
dimensions. Resample the map and try again.
+<h2>EXAMPLES</h2>
+User can compute flow line vector map, flow path length raster map and flow accumulation raster map from an elevation raster map:
+<div class="code"><pre>
+g.region raster=elevation
+r.flow elevation=elevation skip=3 flowline=flowline flowlength=flowlength flowaccumulation=flowaccumulation
+</pre></div>
+<center>
+<img src="r_flow_line.png" alt="flow line">
+<img src="r_flow_length.png" alt="flow path length">
+<img src="r_flow_accumulation.png" alt="flow accumulation map">
+<p>
+Figure: Flow lines underlaid with an elevation map, flow lines underlaid with flow path lengths and flow accumulation map (North Carolina dataset)
+</center>
+d.vect map=flowline
+d.rast map=flowlength
+d.rastmap=flowaccumulation
<h2>REFERENCES</h2>
<ul>
Copied: grass/branches/releasebranch_7_0/raster/r.flow/r_flow_accumulation.png (from rev 65680, grass/trunk/raster/r.flow/r_flow_accumulation.png)
(Binary files differ)
Copied: grass/branches/releasebranch_7_0/raster/r.flow/r_flow_length.png (from rev 65680, grass/trunk/raster/r.flow/r_flow_length.png)
Copied: grass/branches/releasebranch_7_0/raster/r.flow/r_flow_line.png (from rev 65680, grass/trunk/raster/r.flow/r_flow_line.png)
